Hi all. After hours of going nowhere trying to get my pedal and sequential shifter working, here i am begging for assistance or insight. I am looking to confirm a few things...
for the hx711 dt and sck should go on pins 3 and 2 of the pro micro right?
Ive Attempted to put my hx711 in 80hz fast mode. ive lifted pin 15 and shorted it to pin 16 to get 5v. correct?
i had the load cell working on an uno so that portion should be fine.
am i missing something? i ran the hx711 calibration code and it uploaded successfully. just shows 0lbs on monitor and doesnt respond to pressure applied to the load cell.
i plan on also using two, two terminal momentary switches for my sequential shifter.
info on coding buttons and digital signals for a game controller seems super scarce, so any info or tips would be amazing.
The HX711 chip (you didn't provide a link to the used breakout board so I have to assume you're using the chip directly) doesn't have pins with these labels. But you should connect DOUT to D2 and PD_SCK to D3. Don't forget to connect AGND to GND!
If that means you connected pin 15 of the HX711 to 5V (which is also connected to pin 16 of the chip), this is correct.
Simply not enough information. I guess you're asking about a circuit. If that's correct, I'm missing the wiring diagram (or schematics if you have).
pylon:
just using a breadboard to test the chip, no breakout board. vcc is going to 5v and gnd to gnd
thats what i did.
i was just mentioning the whole project to give everyone an idea what im trying to accomplish. im assuming once i get the load cell functioning the buttons will be somewhat easy.
thanks for taking the time to help.
this is the code i uploaded
Example using the SparkFun HX711 breakout board with a scale
By: Nathan Seidle
SparkFun Electronics
Date: November 19th, 2014
License: This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license).
This is the calibration sketch. Use it to determine the calibration_factor that the main example uses. It also
outputs the zero_factor useful for projects that have a permanent mass on the scale in between power cycles.
Setup your scale and start the sketch WITHOUT a weight on the scale
Once readings are displayed place the weight on the scale
Press +/- or a/z to adjust the calibration_factor until the output readings match the known weight
Use this calibration_factor on the example sketch
This example assumes pounds (lbs). If you prefer kilograms, change the Serial.print(" lbs"); line to kg. The
calibration factor will be significantly different but it will be linearly related to lbs (1 lbs = 0.453592 kg).
Your calibration factor may be very positive or very negative. It all depends on the setup of your scale system
and the direction the sensors deflect from zero state
This example code uses bogde's excellent library: https://github.com/bogde/HX711
bogde's library is released under a GNU GENERAL PUBLIC LICENSE
Arduino pin 2 -> HX711 CLK
3 -> DOUT
5V -> VCC
GND -> GND
Most any pin on the Arduino Uno will be compatible with DOUT/CLK.
The HX711 board can be powered from 2.7V to 5V so the Arduino 5V power should be fine.
#include "HX711.h"
#define DOUT 2
#define CLK 3
HX711 scale(DOUT, CLK);
float calibration_factor = -11050; //-7050 worked for my 440lb max scale setup
Serial.println("HX711 calibration sketch");
Serial.println("Remove all weight from scale");
Serial.println("After readings begin, place known weight on scale");
Serial.println("Press + or a to increase calibration factor");
Serial.println("Press - or z to decrease calibration factor");
scale.set_scale();
scale.tare(); //Reset the scale to 0
long zero_factor = scale.read_average(); //Get a baseline reading
Serial.print("Zero factor: "); //This can be used to remove the need to tare the scale. Useful in permanent scale projects.
Serial.println(zero_factor);
scale.set_scale(calibration_factor); //Adjust to this calibration factor
Serial.print("Reading: ");
Serial.print(scale.get_units(), 1);
Serial.print(" lbs"); //Change this to kg and re-adjust the calibration factor if you follow SI units like a sane person
Serial.print(" calibration_factor: ");
Serial.print(calibration_factor);
if (Serial.available())
char temp = Serial.read();
if (temp == '+' || temp == 'a')
calibration_factor += 10;
else if (temp == '-' || temp == 'z')
calibration_factor -= 10;
here is the wiring
ignore the 10k resistor. its not connected to anything.
