I can't burn bootloader
Good day. First post here and I am a complete beginner with Arduino although I have made some feeble attempts to learn some in the past. My boys were recently gifted a OSOYOO kit and now they are interested. It seems that somehow the bootloader is no longer on their board. We were able to get another one (we are currently in Ivory Coast) and I have been trying to burn the bootloader back using the new Uno as ISP. But I just get an error message. I will paste the error below. Hopefully someone can help and it isn't too complicated! Thanks!
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM6
         Using Programmer              : arduino
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0xffffff (probably .avr8x_mega) (retrying)
Error while burning bootloader.
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
Can you tell us how you have wired the 2 boards together please. But I suspect it's a faulty chip, rather than a lost bootloader.
That usually means that the wiring is bad or the target machine's system clock is not running. Double-check the programming wires (Pins 11, 12, and 13 straight across and Pin 10 on the UNO to Reset on the target). And power, and ground.
I say I think it is the bootloader because of the troubleshooting steps I followed. Somewhere I read that if a loopback test is successful then it was probably a problem with the bootloader. And the loopback test works fine.
Here is the schematic that I followed for reburning the bootloader.
https://images.app.goo.gl/DY6rzCd2LXjTeTL66
The loopback test is for the USB-to-Serial adapter part of the Arduino. It has nothing to do with using the ICSP header to burn a fresh bootloader.
Also, the old bootloader on the target machine has nothing to do with burning a fresh bootloader because you don't need a bootloader on the chip to install a bootloader. That's sort of the point.
In-Circuit Serial Programming through the ICSP header uses hardware to write directly into FLASH memory.
I would suggest you spend $8 to buy a USBasp with a 6-pin adapter. This is a much easier programmer to use than the Arduino as ISP.
https://www.amazon.com/Partstower-USBasp-Programmer-ATMEGA8-Downloader/dp/B07D81JYHV/ref=sr_1_9
Unfortunately, I can't get a USBasp or or anything similar. As I said, we are currently in Ivory Coast and that kind of thing isn't available here. Which is why I'm trying to figure this out with the two Arduino Uno boards that I have.
