I can't upload Fastled.h to arduino nano.
Hello. Thanks to all for reading. I've been trying to upload this to my arduino nano, but i had no luck. I am trying to made a homemade ambilight.
this is the error that i have.
Arduino:1.8.6 (Windows 10), Tarjeta:"Arduino Nano, ATmega328P"
In file included from C:\Users\IVÃ?N\Documents\Arduino\adalight_ws2812-master\Adalight_WS2812\Adalight_WS2812.ino:1:0:
C:\Users\IVÁN\Documents\Arduino\libraries\FastLED/FastLED.h:17:21: note: #pragma message: FastLED version 3.002.000
pragma message "FastLED version 3.002.000"
El Sketch usa 4514 bytes (14%) del espacio de almacenamiento de programa. El máximo es 30720 bytes.
Las variables Globales usan 460 bytes (22%) de la memoria dinámica, dejando 1588 bytes para las variables locales. El máximo es 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xfb
Problema subiendo a la placa. Visita http://www.arduino.cc/en/Guide/Troubleshooting#upload para sugerencias.
Este reporte podría tener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
I've beent triying various ports but i have no luck. Also i've soldered to pins to gnd and pin6 of the nano, i don't know if maybe thats a problem. Anyone knows why this could happen? Thanks.
You can't upload a .h header file to an Arduino.
Have you selected the correct board?
(deleted)
Hello, thank you for taking your time to reply.
Yes, i've selected arduino nano in tools > board.
Well, im not trying to upload a .h file, just this
#include "FastLED.h"
#define NUM_LEDS 60
#define DATA_PIN 6
#define serialRate 500000
static const uint8_t prefix[] = {'A', 'd', 'a'};
// Define the array of leds
CRGB leds[NUM_LEDS];
FastLED.addLeds<WS2811, DATA_PIN, RGB>(leds, NUM_LEDS);
Serial.begin(serialRate);
Serial.print("Ada\n");
for(int i = 0; i < sizeof(prefix); ++i){
while (!Serial.available());
if(prefix != Serial.read())
  • return;*
  • while(Serial.available() < 3);*
  • int highByte = Serial.read();*
  • int lowByte = Serial.read();*
  • int checksum = Serial.read();*
  • if (checksum != (highByte ^ lowByte ^ 0x55)){*
  • return;}*
  • uint16_t ledCount = ((highByte & 0x00FF) << 8 | (lowByte & 0x00FF) ) + 1;*
  • if (ledCount > NUM_LEDS){*
  • ledCount = NUM_LEDS;}*
  • for (int i = 0; i < ledCount; i++){*
    _ leds*.r = Serial.read();_
    _ leds.g = Serial.read();
    leds.b = Serial.read();}
    FastLED.show();
    }[/quote]*
    but i've tried with 2 computers, changing ports and i can't seem to be able.
    Thank your repliying spycatcher2k. I'll try._
Hello, thanks Spycatcher, that worked! :slight_smile:
