I would like to implement the TF02-Pro with the ESP32. I know that it works with Arduino so I've assumed that it will work with ESP as well.
The TF02-Pro has 4 wires defined as: red +5V, black GND, green TX, white RX.
I have connected them as follows:
Sensor 5V to ESP 5V;
Sensor GND to ESP GND;
Sensor TX to ESP RX;
Sensor RX to ESP TX;
Also, the TF02-PRO adopts the serial port data communication protocol.
Communication interface: UART
Communication level: LVTTL(3.3V)
Default baud rate: 115200
Data bit: 8
Stop bit: 1
Parity check: None
I have followed this guide: https://www.roscomponents.com/en/index.php?controller=attachment&id_attachment=309
This is the code resulting:
#include <Arduino.h>
#define RXD2 16
#define TXD2 17
int dist; // LiDAR actually measured distance value
int strength; // LiDAR signal strength
int check; // check numerical value storage
int i;
int uart[9]; // store data measured by LiDAR
const int HEADER = 0x59; // data package frame header
Serial.println("Started.");
Serial2.begin(115200, SERIAL_8N1, RXD2, TXD2);
if (Serial2.available()) //check whether the serial port has data input
if (Serial2.read() == HEADER) // determine data package frame header 0x59
uart[0] = HEADER;
if (Serial2.read() == HEADER) //determine data package frame header 0x59
uart[1] = HEADER;
for (i = 2; i < 9; i++) // store data to array
uart[i] = Serial2.read();
check = uart[0] + uart[1] + uart[2] + uart[3] + uart[4] + uart[5] + uart[6] + uart[7];
if (uart[8] == (check & 0xff)) // check the received data as per protocols
dist = uart[2] + uart[3] * 256; // calculate distance value
strength = uart[4] + uart[5] * 256; // calculate signal strength value
Serial.print("dist = ");
Serial.print(dist); // output LiDAR tests distance value
Serial.print('\t');
Serial.print("strength = ");
Serial.print(strength); // output signal strength value
Serial.print('\n');
The issue is that I have no output except Serial.println("Started.");.
I have also tried changing the pins:
#define RXD2 22
#define TXD2 23
And I still have no output. (other than Serial.println("Started.");.)
I have opened the sensor's case and I have measured the voltage input and it's around 4.6V. The Product Manual of TF02-Pro says that the supply voltage should be 5V~12V.
I have also tried the code from here: TF02 Lidar For Arduino And Pixhawk | How To Use but I still got no output.
If this works on an Arduino, shouldn't it work on an ESP32 ?
Thank you.
