I need help about the different between Arduino UNO and Leonardo in Serial Port.
I'm doing a dc motor control project. I found a pretty good video about this subject.It uses the PID to control the speed of motor base on set speed.Here the links:
I change the code a little bit to fit my project. Here the code:
String mySt = "";
char myChar;
boolean stringComplete = false;  // whether the string is complete
boolean motor_start = false;
const byte pin_a = 2;   //for encoder pulse A
const byte pin_b = 3;   //for encoder pulse B
const byte pin_fwd = 4; //for H-bridge: run motor forward
const byte pin_bwd = 5; //for H-bridge: run motor backward
const byte pin_pwm = 6; //for H-bridge: motor speed
int encoder = 0;
int m_direction = 0;
int sv_speed = 100;     //this value is 0~255
double pv_speed = 0;
double set_speed = 0;
double e_speed = 0; //error of speed = set_speed - pv_speed
double e_speed_pre = 0;  //last error of speed
double e_speed_sum = 0;  //sum error of speed
double pwm_pulse = 0;     //this value is 0~255
double kp = 0;         //0.06
double ki = 0;        //0.055
double kd = 0;         //0.04
int timer1_counter; //for timer
int i=0;
  pinMode(pin_a,INPUT_PULLUP);
  pinMode(pin_b,INPUT_PULLUP);
  pinMode(pin_fwd,OUTPUT);
  pinMode(pin_bwd,OUTPUT);
  pinMode(pin_pwm,OUTPUT);
  attachInterrupt(digitalPinToInterrupt(pin_a), detect_a, RISING);
  // start serial port at 9600 bps:
  //--------------------------timer setup
  noInterrupts();           // disable all interrupts
  TCCR1A = 0;
  TCCR1B = 0;
  timer1_counter = 59286;   // preload timer 65536-16MHz/256/2Hz (34286 for 0.5sec) (59286 for 0.1sec)
  TCNT1 = timer1_counter;   // preload timer
  TCCR1B |= (1 << CS12);    // 256 prescaler
  TIMSK1 |= (1 << TOIE1);   // enable timer overflow interrupt
  interrupts();             // enable all interrupts
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  analogWrite(pin_pwm,0);   //stop motor
  digitalWrite(pin_fwd,0);  //stop motor
  digitalWrite(pin_bwd,0);  //stop motor
  if (stringComplete) {
    // clear the string when COM receiving is completed
    mySt = "";  //note: in code below, mySt will not become blank, mySt is blank until '\n' is received
  //receive command from Visual Studio
  if (mySt.substring(0,7) == "forward"){
    digitalWrite(pin_fwd,1);      //run motor run forward
    motor_start = true;
   if (mySt.substring(0,8) == "backward"){
    digitalWrite(pin_fwd,0);      //run motor run bacward
    digitalWrite(pin_bwd,1);
    motor_start = true;
  if (mySt.substring(0,4) == "stop"){
    //get string after set_speed
  if (mySt.substring(0,5) == "vs_kp"){
    kp = mySt.substring(5,mySt.length()).toFloat(); //get string after vs_kp
  if (mySt.substring(0,5) == "vs_ki"){
    ki = mySt.substring(5,mySt.length()).toFloat(); //get string after vs_ki
  if (mySt.substring(0,5) == "vs_kd"){
    kd = mySt.substring(5,mySt.length()).toFloat(); //get string after vs_kd
  if (mySt.substring(0,12) == "vs_set_speed"){
    set_speed = mySt.substring(12,mySt.length()).toFloat();  //get string after set_speed
void detect_a() {
  encoder+=1; //increasing encoder at new pulse
  m_direction = digitalRead(pin_b); //read direction of motor
ISR(TIMER1_OVF_vect)        // interrupt service routine - tick every 0.1sec
  TCNT1 = timer1_counter;   // set timer
  pv_speed = 60.0*(encoder/330.0)/0.1;  //calculate motor speed, unit is rpm
  encoder=0;
  //print out speed
  if (Serial.available() <= 0) {
    Serial.println(pv_speed);         //Print speed (rpm) value to Visual Studio
  //PID program
  if (motor_start){
    e_speed = set_speed - pv_speed;
    pwm_pulse = e_speed*kp + e_speed_sum*ki + (e_speed - e_speed_pre)*kd;
    e_speed_pre = e_speed;  //save last (previous) error
    e_speed_sum += e_speed; //sum of error
    if (e_speed_sum >4000) e_speed_sum = 4000;
    if (e_speed_sum <-4000) e_speed_sum = -4000;
  else{
    e_speed = 0;
    e_speed_pre = 0;
    e_speed_sum = 0;
    pwm_pulse = 0;
  //update new speed
  if (pwm_pulse <255 & pwm_pulse >0){
    analogWrite(pin_pwm,pwm_pulse);  //set motor speed
  else{
    if (pwm_pulse>255){
      analogWrite(pin_pwm,255);
    else{
void serialEvent() {
  while (Serial.available()) {
    // get the new byte:
    char inChar = (char)Serial.read();
    // add it to the inputString:
    if (inChar != '\n') {
      mySt += inChar;
    // if the incoming character is a newline, set a flag
    // so the main loop can do something about it:
    if (inChar == '\n') {
      stringComplete = true;
So basically , the code receive Set speed, kp,ki,kd,direction,start and stop command, from the serial port and do some math to caculate the pwm and sends it to the pwm pin,then print the speed (rpm) to serial port every 0.1s.
For example,i start the code and it start sending speed (0.00) to the serial Port, i type in 'vs_set_speed200' -> 'vs_kp0.5' -> 'vs_ki0.05' -> 'vs_kd0.04' -> 'forward', the motor will slowly spinning forward to reach the 200 rpm speed.
I try it on the UNO and it work perfect. But when i try it on the Leonardo, when i upload the code, it still sending speed (0.00) like the UNO, but when i type in anything to the Serial Monitor, it stop sending speed to the Serial Monitor immediately,and no matter what i type in next it won't work.
Is there any different between the UNO and the Leonardo that causes this problem? Please help me.
Thanks for reading.
Google "I need help" or edit Your post telling what the issue is. That will make more of knowing helpers to read and reply to Your post.
Yes, there are differences between the Uno and the Leonardo serial communication. After the call to Serial.begin(), you need an additional line to wait for the serial connection to activate.
 while (!Serial); //wait for connection to become live
Start with a very simple sketch and get communications working between the Leonardo and the serial monitor, before doing anything else.
Avoid using Strings. They cause memory problems and unexpected program crashes on AVR based Arduinos.
On an Uno when you use Serial.print() the data goes through the USB cable via the Rx and Tx pins (0 and 1) and it is a good idea not to use pins 0 and 1 for other purposes in your program.
On a Leonardo Serial.print() sends data through the USB port but does not use pins 0 and 1. Instead, pins 0 and 1 are used by Serial1.print() and data sent with Serial1.print() does not go through the USB cable. This means that the Leonardo has an extra HardwareSerial port compared to the Uno.
Plus what is in Reply #2
...R
To add to this, when using the Leonardo to send serial over the USB you will find that the baud rate you specify has no effect on the transfer speed as it all happens as fast as the USB can manage it.
