ohk so i confronted him about this, he basically told me some bullshit story about how he didnt understand which is hard to believe since he's "Made his own", I did look on youtube and found this girls code. I plugged it in and the green light seems to be flashing less frequently and im seeing less of the warning message, Which im guessing is good?
Heres her code. Also do you mind just sending any sketch or image or something that you know will work for my bread board. I really appreciated the help your doing for me. Thank you
// midi channels
const int CHANNEL1 = 0;
const int CHANNEL2 = 1;
// pitch bend
const int PITCHBEND_CMD = 224;
const int PB_LSB = 0;
int PB_VALUE = 64;
bool PBisOn = false;
// control change
const int CONTROLCHANGE1_CMD = 176;
const int CC_LSB = 1;
int CC_VALUE = 64;
bool CCisOn = false;
// notes
const int NOTE_ON_CMD = 144;
const int NOTE_OFF_CMD = 128;
const int NOTE_VELOCITY = 127;
// drums
int DRUM_VELOCITY = 0;
int DRUM_NOTE[] = {31,32,33,34,35,36};
const int DRUM_TOL = 19;
bool drumOn[] = {false,false,false,false,false,false};
// joystick analog pins
const int X_pin = 0;
const int Y_pin = 1;
// drum pins
const int drumPin[] = {2,3,4,5,6,7};
// keyboard matrix
const int NUM_ROWS = 8;
const int NUM_COLS = 7;
// Row input pins
const int row1Pin = 5;
const int row2Pin = 6;
const int row3Pin = 7;
const int row4Pin = 8;
const int row5Pin = 9;
const int row6Pin = 10;
const int row7Pin = 11;
const int row8Pin = 12;
// 74HC595 pins
const int dataPin = 4;
const int latchPin = 3;
const int clockPin = 2;
boolean keyPressed[NUM_ROWS][NUM_COLS];
uint8_t keyToMidiMap[NUM_ROWS][NUM_COLS];
// bitmasks for scanning columns
int bits[] =
B10000000,
B01000000,
B00100000,
B00010000,
B00001000,
B00000100,
B00000010,
B00000001
// MIDI baud rate
const int SERIAL_RATE = 31250; // needs to be 31250 when going through midi port, can be 9600 for hairless
int note = 28;
for(int colCtr = 0; colCtr < NUM_COLS; ++colCtr)
for(int rowCtr = 0; rowCtr < NUM_ROWS; ++rowCtr)
keyPressed[rowCtr][colCtr] = false;
keyToMidiMap[rowCtr][colCtr] = note;
note++;
// setup pins output/input mode
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(latchPin, OUTPUT);
pinMode(row1Pin, INPUT);
pinMode(row2Pin, INPUT);
pinMode(row3Pin, INPUT);
pinMode(row4Pin, INPUT);
pinMode(row5Pin, INPUT);
pinMode(row6Pin, INPUT);
pinMode(row7Pin, INPUT);
pinMode(row8Pin, INPUT);
Serial.begin(SERIAL_RATE);
// keyboard
for (int colCtr = 0; colCtr < NUM_COLS; ++colCtr)
//scan next column
scanColumn(colCtr);
//get row values at this column
int rowValue[NUM_ROWS];
rowValue[0] = digitalRead(row1Pin);
rowValue[1] = digitalRead(row2Pin);
rowValue[2] = digitalRead(row3Pin);
rowValue[3] = digitalRead(row4Pin);
rowValue[4] = digitalRead(row5Pin);
rowValue[5] = digitalRead(row6Pin);
rowValue[6] = digitalRead(row7Pin);
rowValue[7] = digitalRead(row8Pin);
// process keys pressed
for(int rowCtr=0; rowCtr<NUM_ROWS; ++rowCtr)
if(rowValue[rowCtr] != 0 && !keyPressed[rowCtr][colCtr])
keyPressed[rowCtr][colCtr] = true;
sendMidiMessage(NOTE_ON_CMD, CHANNEL1, keyToMidiMap[rowCtr][colCtr], NOTE_VELOCITY);
// process keys released
if(rowValue[rowCtr] == 0 && keyPressed[rowCtr][colCtr])
sendMidiMessage(NOTE_OFF_CMD, CHANNEL1, keyToMidiMap[rowCtr][colCtr], NOTE_VELOCITY);
// joystick X-axis - pitch bend
PB_VALUE = (analogRead(X_pin) / 1024.0) * 127;
if (PB_VALUE < 53 || PB_VALUE > 56) {
sendMidiMessage(PITCHBEND_CMD,CHANNEL1,PB_LSB,PB_VALUE);
PBisOn=true;
else if (PBisOn==true && PB_VALUE > 53 && PB_VALUE < 56) {
PBisOn=false;
// joystick Y-axis - control change
CC_VALUE = (analogRead(Y_pin) / 1024.0) * 127;
if (CC_VALUE < 53 || CC_VALUE > 56) {
sendMidiMessage(CONTROLCHANGE1_CMD,CHANNEL1,CC_LSB,CC_VALUE);
CCisOn=true;
else if ( CCisOn == true && CC_VALUE > 53 && CC_VALUE < 56) {
CCisOn=false;
// drums
for(int drumNo = 0; drumNo < 6; ++drumNo){
DRUM_VELOCITY = (analogRead(drumPin[drumNo]) / 1023.0) * 127;
if( drumOn[drumNo]==false && DRUM_VELOCITY > DRUM_TOL ){
sendMidiMessage(NOTE_ON_CMD,CHANNEL2,DRUM_NOTE[drumNo],DRUM_VELOCITY);
drumOn[drumNo]=true;
else if ( drumOn[drumNo]==true && DRUM_VELOCITY <= DRUM_TOL ) {
sendMidiMessage(NOTE_OFF_CMD,CHANNEL2,DRUM_NOTE[drumNo],DRUM_VELOCITY);
drumOn[drumNo]=false;
// functions
void sendMidiMessage(int cmd, int channel, int lsb, int msb) {
Serial.write(cmd + channel); // send command plus the channel number
Serial.write(lsb); // least significant bit
Serial.write(msb); // most significant bit
void scanColumn(int colNum)
digitalWrite(latchPin, LOW);
if(0 <= colNum && colNum <= 7)
shiftOut(dataPin, clockPin, MSBFIRST, B00000000); //right sr
shiftOut(dataPin, clockPin, MSBFIRST, bits[colNum]); //left sr
shiftOut(dataPin, clockPin, MSBFIRST, bits[colNum-8]); //right sr
shiftOut(dataPin, clockPin, MSBFIRST, B00000000); //left sr
digitalWrite(latchPin, HIGH);
`type or paste code here`
