I'm trying to remotely turn on a Canon Powershot S5 camera. It has a power knob that you turn about 15 degrees and then it snaps back to center. Here's a picture:
Note that knob at the bottom right, with the "off" button inside of it. I'd like to simply turn that knob.
I was thinking a stepper motor glued to the top of the knob?
That's kind of a shot in the dark though, I have no experience with stepper motors. If I went that route, would I then use something like this to drive it?
I would use a rubber hose or a rubber foot (the kind with a hole in the middle for the screw) to "grab" the camera knob.
Interesting. Could you elaborate on this? I've been worried about damaging the knob through excessive force, and this sounds like a good solution.
As far as the camera being controllable via USB, this camera's predecessor, the S3, turns on when it receives 5v through the USB port. Alas, for whatever reason, the S5 doesn't do that, but I need to use the S5 because only it has a flash hotshoe.
I'd go one step further on Richard's thought; use a servo with a straight horn (and maybe something to extend it), at the end of which you put some kind of rubber tip. Position the servo so that it "thumbs" the little projection of the knob left and right. This "thumb" lever should have enough give so that it acts like a user's thumb and doesn't rotate the knob more than necessary. You could then set up a second servo to "thumb" the off button, too...
