i created 1 code i know that it work on 38khz and i dont understand how to use vs838 as proximity i saw lot of ppl use that with ne555 i also tried but i wanna do that with arduino uno can someone help me with the code here what i tried-
pinMode(4, OUTPUT);
pinMode(13, OUTPUT);
digitalWrite(4, HIGH);
delayMicroseconds(13);
digitalWrite(4, LOW);
delayMicroseconds (14);
AND
THIS ONE IS FROM INTERNET
i understand that it work on 38khz but i have to control on and off time alos of that pulse like 10us,that time defines distance i think please help me with this topic
/* Code to pulse pin 3 with a modulated signal
- Can be used to drive an IR LED to keep a TSOP IR reciever happy
- This allows you to use a modulated reciever and a continious beam detector
- By Mike Cook Nov 2011 - Released under the Open Source licence
volatile byte pulse = 0;
ISR(TIMER2_COMPB_vect){ // Interrupt service routine to pulse the modulated pin 3
pulse++;
if(pulse >= 8) { // change number for number of modulation cycles in a pulse
pulse =0;
TCCR2A ^= _BV(COM2B1); // toggle pin 3 enable, turning the pin on and off
void setIrModOutput(){ // sets pin 3 going at the IR modulation rate
pinMode(3, OUTPUT);
TCCR2A = _BV(COM2B1) | _BV(WGM21) | _BV(WGM20); // Just enable output on Pin 3 and disable it on Pin 11
TCCR2B = _BV(WGM22) | _BV(CS22);
OCR2A = 51; // defines the frequency 51 = 38.4 KHz, 54 = 36.2 KHz, 58 = 34 KHz, 62 = 32 KHz
OCR2B = 26; // deines the duty cycle - Half the OCR2A value for 50%
TCCR2B = TCCR2B & 0b00111000 | 0x2; // select a prescale value of 8:1 of the system clock
void setup(){
setIrModOutput();
TIMSK2 = _BV(OCIE2B); // Output Compare Match B Interrupt Enable
void loop(){
// do something here
