I want to have only one LED that serves as indicator for each connection the ESP makes.
I wanted to use this type of LED. I want to include it in the code wherein if the ESP is on, red light will turn on. If it is connected to wifi, green light will on, if it is connected to the database green light will blink for approximately 5 secs (or is there a way to make the LED turn yellow if the ESP connects to the database?). Lastly, if it is disconnected to wifi or database, led is off.
I am planning to use GPIO4, GPIO5 of the ESP for the pin of the LED.
Here is my code:
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
#include <ESP8266WiFi.h>
//Network credentials
const char* ssid = "wifi";
const char* pass = "password";
//Database credentials
IPAddress server_addr (192,167,2,100); // MySQL server IP
char user[] = "name";
char password[] = "pass";
char database[] = "table";
// Default values
uint32_t data_1 = 0;
uint32_t data_2 = 0;
WiFiClient client;
MySQL_Connection conn((Client *)&client);
//Create an instance of the cursor passing in the connection
MySQL_Cursor cur = MySQL_Cursor(&conn);
//Declaration of byte format
uint8_t header = 0xFF; // byte 0 as header
uint8_t address1 = 0xFA; // 1st layer address
uint8_t address2 = 0xFB; // 2nd layer address
uint8_t byte2 = 0x90;
uint8_t byte6 = 0x10;
//Wi-Fi connection set up
void setup_wifi() {
//Connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, pass);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial1.begin(9600, SERIAL_8N1);
setup_wifi();
// Connect to MySQL server
if (conn.connect(server_addr, 3306, user, password, database)) {
Serial.println("Connected to MySQL server"); }
else {
Serial.println("Connection to MySQL server failed");
return;
void loop () {
// Execute query to get a single row
char query[] = "SELECT SUM(data1), SUM(data2) FROM data ORDER BY time DESC LIMIT 1 ";
MySQL_Cursor* cursor = new MySQL_Cursor(&conn);
if (conn.connected())
cursor->execute(query);
// Fetch the columns and print them
column_names *cols = cursor->get_columns();
for (int f = 0; f < cols->num_fields; f++) {
Serial.print(cols->fields[f]->name);
if (f < cols->num_fields-1) {
Serial.print(',');
// Fetch the first row of data
row_values* row = NULL;
int data1 = 0;
int data2 = 0;
do {
row = cursor->get_next_row();
if (row != NULL) {
data1 = atoi(row->values[1]);
data2 = atoi(row->values[2]);
} while (row != NULL);
//Assign the converted values to data_1 - data_4
data_1 = data1;
data_2 = data2;
Serial.println(data_1);
Serial.println(data_2);
// Clean up cursor memory to avoid memory leak
delete cursor;
conn.close();
Serial.println("Connection...");
delay(200);
Serial.println("Successful reconnect!");
Serial.println("Cannot reconnect!");
// Process the values of data_1, data_2
for (int i = 1; i <= 2; i++) {
uint32_t data_i;
uint8_t address;
if (i == 1) {
data_i = data_1;
address = address1;
} else if (i == 2) {
data_i = data_2;
address = address2;
uint8_t byte5 = (data_i >> 16) & 0xFF;
uint8_t byte4 = (data_i >> 8) & 0xFF;
uint8_t byte3 = data_i & 0xFF;
uint8_t checksum = (address + byte2 + byte3 + byte4 + byte5 + byte6);
uint8_t data_packet[8] = {header, address, byte2, byte3, byte4, byte5, byte6, checksum};
Serial1.write(data_packet, sizeof(data_packet));
Serial1.flush();}
