I would like to ask how to connect a touch sensor, a piezzo buzzer, an infrared sensor, and a couple of LEDs in Arduiono uno without them heating up
406670622_328278243463052_3713091767332026661_n
412371524_1008713240199529_7999221713551193441_n
Can you guys identify what I'm doing wrong? It just says that "an error occurred while uploading the sketch."
Please, I need this ASAP
I've done all of these before, but not all at the same time.
I don't think they should be heating up...maybe you are providing too much power? I also don't use breadboards so it might be some issue with that.
Please post a hand drawn wiring diagram, with pins and parts clearly labeled. Hand drawn is fine.
If anything is heating up, something is wrong (missing current limiting resistors, for example), and you should pull the plug, and not continue until the problem is identified and fixed.
Surely they are not ALL heating up. Please be specific.
Just the IR sensor
If you are really in a hurry: make better pictures. Add schematic, add vode, be more dpecific....
Which is what? Remember, we are not mind readers nor can we see over you shoulder.
