I2C Display PCB Connector Help
Hello all!
I am trying to make a OLED module for Arduino (as explained in this thread: I2C Display PCB Footprint Help).
Now, I can't seem to find a suitable connector to put on the PCB for this display though!
Here is the data sheet:
And screenshot of the measurements:
I think it is a FPC connector?
Thanks in advance!
Edit:
I am trying to get it from LCSC (Connectors - Electronic Components Distributor - LCSC).
How about his one?
I know it is not your preferred supplier but it will give you something to search on.
Correct. 25 pin. Mouser?
Thanks @Grumpy_Mike and @buckfast_beekeeper !
The pin spacing is 0.5mm? :thinking: I thought the drawing said that they are spaced 0.65mm apart.
If 0.5 is correct, would this work?
Or this?
Thanks!
Well it works as a through hole device mounted vertically. I would have thought you wanted a horizontal surface mount connector so it will be flush with the PCB.
Can't make that one out the connector to the PCB looks odd.
Where does it say that? I get the 0.5mm from the drawing showing the distance between two adjacent connectors centred on the holes.
