Hi...yet another noob :)...so I have 2 arduinos connected using 2 wire. and this is what the master is doing:
sendCommand(4, '1', '9', '1');
boolean sendCommand(int device, byte method, byte parameter, byte value)
Wire.beginTransmission(device);
Wire.write('<');
Wire.write(method);
Wire.write(':');
Wire.write(parameter);
Wire.write(':');
Wire.write(value);
Wire.write('>');
Wire.endTransmission();
Serial.println("(M:1) TRANSMIT SUCCESS");
the slave reads it as follows:
Wire.begin(4); //
Wire.onReceive(receiveEvent);
delay(100);
void receiveEvent(int howMany)
while (1 < Wire.available())
char c = Wire.read();
Serial.print(c);
int x = Wire.read();
Serial.println(x);
However the output on the slave over serial is "<1:9:162" everything else is correct except the last character which is represented by "62" instead of ">" im not sure if its how serial is interpreting it or if its how its being sent over the i2c protocol...PLEASE HELP ![]()
