IbusBM problem with showing two values
Hi everyone, I have this question I'm trying to do telemetry. I am using ia6b and Flysky i6. I am using the ibus library. I control the body IBusServo.addSensor (IBUS_MEAS_TYPE_GPS_STATUS);
takes 4 bytes as two values.
However, I cannot introduce two values; (
I enter two numbers:
IBusServo.setSensorMeasurement (1, (77,22));
And I get:
Can anyone help me how to enter it so that it correctly displays 2 numerical variables?
My code:
  IBusServo.begin(Serial1);
  // adding 2 sensors
  IBusServo.addSensor(IBUS_MEAS_TYPE_GPS_STATUS);
  IBusServo.addSensor(IBUS_MEAS_TYPE_S85);
  IBusServo.addSensor(IBUS_MEAS_TYPE_FLIGHT_MODE);
  ibusServo();
void ibusServo()
  IBusServo.setSensorMeasurement(1, (77,22));
  IBusServo.setSensorMeasurement(2,23);
  IBusServo.setSensorMeasurement(3,1); // 5 Return, 6 RTL, 2 low V, 3 wait, 1 HOME, 4 Manual, 7 circle, 8 Error, 0 Save, 9 to point
  delay(2000);
IbusBM.cpp
 * Interface to the RC IBus protocol
 * Based on original work from: https://gitlab.com/timwilkinson/FlySkyIBus
 * Extended to also handle sensors/telemetry data to be sent back to the transmitter,
 * interrupts driven and other features.
 * This lib requires a hardware UART for communication
 * Another version using software serial is here https://github.com/Hrastovc/iBUStelemetry
 * Explaination of sensor/ telemetry prtocol here:
 * https://github.com/betaflight/betaflight/wiki/Single-wire-FlySky-(IBus)-telemetry
 * This library is free software; you can redistribute it and/or
 * modify it under the terms of the GNU Lesser General Public
 * License as published by the Free Software Foundation; either
 * version 2.1 of the License, or (at your option) any later version.
 * Created 12 March 2019 Bart Mellink
 * Updated 4 April 2019 to support ESP32
 * updated 13 jun 2019 to support STM32 (pauluzs)
 * Updated 21 Jul 2020 to support MBED (David Peverley)
#include <Arduino.h>
#include "IBusBM.h"
// pointer to the first class instance to be used to call the loop() method from timer interrupt
// will be initiated by class constructor, then daisy channed to other class instances if we have more than one
IBusBM* IBusBMfirst = NULL;
// Interrupt on timer0 - called every 1 ms
// we call the IBusSensor.loop() here, so we are certain we respond to sensor requests in a timely matter
#ifdef ARDUINO_ARCH_AVR
SIGNAL(TIMER0_COMPA_vect) {
  if (IBusBMfirst) IBusBMfirst->loop();  // gets new servo values if available and process any sensor data
#else
void  onTimer() {
#endif
#if defined(ARDUINO_ARCH_MBED)
extern "C" {
  void TIMER4_IRQHandler_v() {
    if (NRF_TIMER4->EVENTS_COMPARE[0] == 1) {
        onTimer();
        NRF_TIMER4->EVENTS_COMPARE[0] = 0;
#endif
 *  supports max 14 channels in this lib (with messagelength of 0x20 there is room for 14 channels)
  Example set of bytes coming over the iBUS line for setting servos:
    20 40 DB 5 DC 5 54 5 DC 5 E8 3 D0 7 D2 5 E8 3 DC 5 DC 5 DC 5 DC 5 DC 5 DC 5 DA F3
  Explanation
    Protocol length: 20
    Command code: 40
    Channel 0: DB 5  -> value 0x5DB
    Channel 1: DC 5  -> value 0x5Dc
    Channel 2: 54 5  -> value 0x554
    Channel 3: DC 5  -> value 0x5DC
    Channel 4: E8 3  -> value 0x3E8
    Channel 5: D0 7  -> value 0x7D0
    Channel 6: D2 5  -> value 0x5D2
    Channel 7: E8 3  -> value 0x3E8
    Channel 8: DC 5  -> value 0x5DC
    Channel 9: DC 5  -> value 0x5DC
    Channel 10: DC 5 -> value 0x5DC
    Channel 11: DC 5 -> value 0x5DC
    Channel 12: DC 5 -> value 0x5DC
    Channel 13: DC 5 -> value 0x5DC
    Checksum: DA F3 -> calculated by adding up all previous bytes, total must be FFFF
#if defined(_VARIANT_ARDUINO_STM32_)
void IBusBM::begin(HardwareSerial &serial, TIM_TypeDef * timerid, int8_t rxPin, int8_t txPin) {
#else
void IBusBM::begin(HardwareSerial &serial, int8_t timerid, int8_t rxPin, int8_t txPin) {
#endif
  #ifdef ARDUINO_ARCH_ESP32
    serial.begin(115200, SERIAL_8N1, rxPin, txPin);
  #else
    serial.begin(115200, SERIAL_8N1);
  #endif
  this->stream = &serial;
  this->state = DISCARD;
  this->last = millis();
  this->ptr = 0;
  this->len = 0;
  this->chksum = 0;
  this->lchksum = 0;
  // we need to process the iBUS sensor protocol handler frequently enough (at least once each ms) to ensure the response data
  // from the sensor is sent on time to the receiver
  // if timerid==IBUSBM_NOTIMER the user is responsible for calling the loop function
  this->IBusBMnext = IBusBMfirst;
  if (!IBusBMfirst && timerid != IBUSBM_NOTIMER) {
      // on AVR architectures Timer0 is already used for millis() - we'll just interrupt somewhere in the middle and call the TIMER0_COMPA_vect interrupt
      OCR0A = 0xAF;
      TIMSK0 |= _BV(OCIE0A);
    #else
      // on other architectures we need to use a time
      #if defined(ARDUINO_ARCH_ESP32)
        hw_timer_t * timer = NULL;
        timer = timerBegin(timerid, F_CPU / 1000000L, true); // defaults to timer_id = 0; divider=80 (1 ms); countUp = true;
        timerAttachInterrupt(timer, &onTimer, true); // edge = true
        timerAlarmWrite(timer, 1000, true);  //1 ms
        timerAlarmEnable(timer);
      #elif defined(_VARIANT_ARDUINO_STM32_)
        // see https://github.com/stm32duino/wiki/wiki/HardwareTimer-library
        HardwareTimer *stimer_t = new HardwareTimer(timerid);
        stimer_t->setOverflow(1000, HERTZ_FORMAT); // 1000 Hz
        stimer_t->attachInterrupt(onTimer);
        stimer_t->resume();
      #elif defined(ARDUINO_ARCH_MBED)
        NRF_TIMER4->TASKS_STOP = 1; // Stop timer
        NRF_TIMER4->MODE = TIMER_MODE_MODE_Timer;  // Set the timer in Counter Mode
        NRF_TIMER4->BITMODE = TIMER_BITMODE_BITMODE_16Bit << TIMER_BITMODE_BITMODE_Pos;
        NRF_TIMER2->TASKS_CLEAR = 1;               // clear the task first to be usable for later
        // Set prescaler & compare register.
        // Prescaler = 0 gives 16MHz timer.
        // Prescaler = 4 (2^4) gives 1MHz timer.
        NRF_TIMER4->PRESCALER = 4 << TIMER_PRESCALER_PRESCALER_Pos;
        NRF_TIMER4->CC[0] = 1000;
        // Enable interrupt on Timer 4 for CC[0] compare match events
        NRF_TIMER4->INTENSET = TIMER_INTENSET_COMPARE0_Enabled << TIMER_INTENSET_COMPARE0_Pos;
        NRF_TIMER4->SHORTS = TIMER_SHORTS_COMPARE0_CLEAR_Enabled << TIMER_SHORTS_COMPARE0_CLEAR_Pos;
        NVIC_EnableIRQ(TIMER4_IRQn);
        NRF_TIMER4->TASKS_START = 1;      // Start TIMER2
      #else
        // It should not be too difficult to support additional architectures as most have timer functions, but I only tested AVR and ESP32
        #warning "Timing only supportted for AVR, ESP32 and STM32 architectures. Use timerid IBUSBM_NOTIMER"
      #endif
    #endif
  IBusBMfirst = this;
// called from timer interrupt or mannually by user (if IBUSBM_NOTIMER set in begin())
void IBusBM::loop(void) {
  // if we have multiple instances of IBusBM, we (recursively) call the other instances loop() function
  if (IBusBMnext) IBusBMnext->loop();
  // only process data already in our UART receive buffer
  while (stream->available() > 0) {
    // only consider a new data package if we have not heard anything for >3ms
    uint32_t now = millis();
    if (now - last >= PROTOCOL_TIMEGAP){
      state = GET_LENGTH;
    last = now;
    uint8_t v = stream->read();
    switch (state) {
      case GET_LENGTH:
        if (v <= PROTOCOL_LENGTH && v > PROTOCOL_OVERHEAD) {
          ptr = 0;
          len = v - PROTOCOL_OVERHEAD;
          chksum = 0xFFFF - v;
          state = GET_DATA;
          state = DISCARD;
      case GET_DATA:
        buffer[ptr++] = v;
        chksum -= v;
        if (ptr == len) {
          state = GET_CHKSUML;
      case GET_CHKSUML:
        lchksum = v;
        state = GET_CHKSUMH;
      case GET_CHKSUMH:
        // Validate checksum
        if (chksum == (v << 8) + lchksum) {
          // Checksum is all fine Execute command -
          uint8_t adr = buffer[0] & 0x0f;
          if (buffer[0]==PROTOCOL_COMMAND40) {
            // Valid servo command received - extract channel data
            for (uint8_t i = 1; i < PROTOCOL_CHANNELS * 2 + 1; i += 2) {
              channel[i / 2] = buffer[i] | (buffer[i + 1] << 8);
            cnt_rec++;
          } else if (adr<=NumberSensors && adr>0 && len==1) {
            // all sensor data commands go here
            // we only process the len==1 commands (=message length is 4 bytes incl overhead) to prevent the case the
            // return messages from the UART TX port loop back to the RX port and are processed again. This is extra
            // precaution as it will also be prevented by the PROTOCOL_TIMEGAP required
           sensorinfo *s = &sensors[adr-1];
           delayMicroseconds(100);
            switch (buffer[0] & 0x0f0) {
              case PROTOCOL_COMMAND_DISCOVER: // 0x80, discover sensor
                cnt_poll++;
                // echo discover command: 0x04, 0x81, 0x7A, 0xFF
                stream->write(0x04);
                stream->write(PROTOCOL_COMMAND_DISCOVER + adr);
                chksum = 0xFFFF - (0x04 + PROTOCOL_COMMAND_DISCOVER + adr);
              case PROTOCOL_COMMAND_TYPE: // 0x90, send sensor type
                // echo sensortype command: 0x06 0x91 0x00 0x02 0x66 0xFF
                stream->write(0x06);
                stream->write(PROTOCOL_COMMAND_TYPE + adr);
                stream->write(s->sensorType);
                stream->write(s->sensorLength);
                chksum = 0xFFFF - (0x06 + PROTOCOL_COMMAND_TYPE + adr + s->sensorType + s->sensorLength);
              case PROTOCOL_COMMAND_VALUE: // 0xA0, send sensor data
                cnt_sensor++;
                uint8_t t;
                // echo sensor value command: 0x06 0x91 0x00 0x02 0x66 0xFF
                stream->write(t = 0x04 + s->sensorLength);
                chksum = 0xFFFF - t;
                stream->write(t = PROTOCOL_COMMAND_VALUE + adr);
                chksum -= t;
                stream->write(t = s->sensorValue & 0x0ff);
                chksum -= t;
                stream->write(t = (s->sensorValue >> 8) & 0x0ff);
                chksum -= t;
                if (s->sensorLength==4) {
                  stream->write(t = (s->sensorValue >> 16) & 0x0ff);
                  chksum -= t;
                  stream->write(t = (s->sensorValue >> 24) & 0x0ff);
                  chksum -= t;
              default:
                adr=0; // unknown command, prevent sending chksum
            if (adr>0) {
              stream->write(chksum & 0x0ff);
              stream->write(chksum >> 8);
        state = DISCARD;
      case DISCARD:
      default:
uint16_t IBusBM::readChannel(uint8_t channelNr) {
  if (channelNr < PROTOCOL_CHANNELS) {
    return channel[channelNr];
    return 0;
uint8_t IBusBM::addSensor(uint8_t type, uint8_t len) {
  // add a sensor, return sensor number
  if (len!=2 && len!=4) len = 2;
  if (NumberSensors < SENSORMAX) {
    sensorinfo *s = &sensors[NumberSensors];
    s->sensorType = type;
    s->sensorLength = len;
    s->sensorValue = 0;
    NumberSensors++;
  return NumberSensors;
void IBusBM::setSensorMeasurement(uint8_t adr, int32_t value) {
   if (adr<=NumberSensors && adr>0)
     sensors[adr-1].sensorValue = value;
IbusBM.h
#ifndef IBusBM_h
#define IBusBM_h
#include <inttypes.h>
#include "mbed.h"
#include "HardwareSerial.h"
#endif
// if you have an opentx transciever you can add additional sensor types here.
// see https://github.com/cleanflight/cleanflight/blob/7cd417959b3cb605aa574fc8c0f16759943527ef/src/main/telemetry/ibus_shared.h
// below the values supported by the Turnigy FS-MT6 transceiver
#define IBUSS_INTV 0x00 // Internal voltage (in 0.01)
#define IBUS_MEAS_TYPE_TEM            0x01 // Temperature (in 0.1 degrees, where 0=-40'C)
#define IBUSS_RPM                     0x02 // RPM
#define IBUS_MEAS_TYPE_EXTV           0x03 // External voltage (in 0.01)
#define IBUS_MEAS_TYPE_CELL           0x04 // Avg cell voltage
#define IBUS_MEAS_TYPE_BAT_CURR       0x05 // Battery current
#define IBUS_MEAS_TYPE_FUEL           0x06 // Remaining battery percentage
#define IBUS_MEAS_TYPE_RPM            0x07 // Throttle value / battery capacity
#define IBUS_MEAS_TYPE_CMP_HEAD       0x08 // Heading
#define IBUS_MEAS_TYPE_CLIMB_RATE     0x09 // Climb rate
#define IBUS_MEAS_TYPE_COG            0x0a // Course over ground
#define IBUS_MEAS_TYPE_GPS_STATUS     0x0b // GPS status (2 values)
#define IBUS_MEAS_TYPE_ACC_X          0x0c // Acc X
#define IBUS_MEAS_TYPE_ACC_Y          0x0d // Acc Y
#define IBUS_MEAS_TYPE_ACC_Z          0x0e // Acc Z
#define IBUS_MEAS_TYPE_ROLL           0x0f // Roll
#define IBUS_MEAS_TYPE_PITCH          0x10 // Pitch
#define IBUS_MEAS_TYPE_YAW            0x11 // Yaw
#define IBUS_MEAS_TYPE_VERTICAL_SPEED 0x12 // Vertical speed
#define IBUS_MEAS_TYPE_GROUND_SPEED   0x13 // Speed m/s
#define IBUS_MEAS_TYPE_GPS_DIST       0x14 // Distance from home
#define IBUS_MEAS_TYPE_ARMED          0x15 // Armed / unarmed
#define IBUS_MEAS_TYPE_FLIGHT_MODE    0x16 // Flight mode
#define IBUS_MEAS_TYPE_PRES           0x41 // Pressure (in Pa)
#define IBUS_MEAS_TYPE_SPE            0x7e // Speed km/h
#define IBUS_SERVO                    0xfd // Servo value
// 4 byte sensors
#define IBUS_MEAS_TYPE_GPS_LAT 0x80 // WGS84 in degrees * 1E7
#define IBUS_MEAS_TYPE_GPS_LON 0x81 // WGS84 in degrees * 1E7
#define IBUS_MEAS_TYPE_GPS_ALT 0x82 // GPS altitude
#define IBUS_MEAS_TYPE_ALT     0x83 // Altitude
#define IBUS_MEAS_TYPE_ALT_MAX 0x84 // Max altitude
#define IBUS_MEAS_TYPE_S85     0x85
#define IBUS_MEAS_TYPE_S86     0x86
#define IBUS_MEAS_TYPE_S87     0x87
#define IBUS_MEAS_TYPE_S88     0x88
#define IBUS_MEAS_TYPE_S89     0x89
#define IBUS_MEAS_TYPE_S8a     0x8a
#define HardwareSerial arduino::HardwareSerial
#else
  #if !defined(ARDUINO_ARCH_MEGAAVR)
class HardwareSerial;
  #endif
#endif
class Stream;
class IBusBM {
public:
  #if !defined(STM32_CORE_VERSION) || (STM32_CORE_VERSION  < 0x01090000)
    #error "Due to API change, this sketch is compatible with STM32_CORE_VERSION  >= 0x01090000"
  #endif
  #define IBUSBM_NOTIMER NULL // no timer interrupt used
  void begin(HardwareSerial &serial, TIM_TypeDef * timerid=TIM1, int8_t rxPin=-1, int8_t txPin=-1);
#else
  #define IBUSBM_NOTIMER -1 // no timer interrupt used
  void begin(HardwareSerial &serial, int8_t timerid=0, int8_t rxPin=-1, int8_t txPin=-1);
#endif
  uint16_t readChannel(uint8_t channelNr); // read servo channel 0..9
  uint8_t addSensor(uint8_t type, uint8_t len=2); // add sensor type and data length (2 or 4), returns address
  void setSensorMeasurement(uint8_t adr, int32_t value);
  void loop(void); // used internally for interrupt handline, but needs to be defined as public
  volatile uint8_t cnt_poll; // count received number of sensor poll messages
  volatile uint8_t cnt_sensor; // count times a sensor value has been sent back
  volatile uint8_t cnt_rec; // count received number of servo messages
private:
  enum State {GET_LENGTH, GET_DATA, GET_CHKSUML, GET_CHKSUMH, DISCARD};
  static const uint8_t PROTOCOL_LENGTH = 0x20;
  static const uint8_t PROTOCOL_OVERHEAD = 3; // packet is <len><cmd><data....><chkl><chkh>, overhead=cmd+chk bytes
  static const uint8_t PROTOCOL_TIMEGAP = 3; // Packets are received very ~7ms so use ~half that for the gap
  static const uint8_t PROTOCOL_CHANNELS = 14;
  static const uint8_t PROTOCOL_COMMAND40 = 0x40;        // Command to set servo or motor speed is always 0x40
  static const uint8_t PROTOCOL_COMMAND_DISCOVER = 0x80; // Command discover sensor (lowest 4 bits are sensor)
  static const uint8_t PROTOCOL_COMMAND_TYPE = 0x90;     // Command discover sensor (lowest 4 bits are sensor)
  static const uint8_t PROTOCOL_COMMAND_VALUE = 0xA0;    // Command send sensor data (lowest 4 bits are sensor)
  static const uint8_t SENSORMAX = 10; // Max number of sensors
  uint8_t state;                    // state machine state for iBUS protocol
  HardwareSerial *stream;           // serial port
  uint32_t last;                    // milis() of prior message
  uint8_t buffer[PROTOCOL_LENGTH];  // message buffer
  uint8_t ptr;                      // pointer in buffer
  uint8_t len;                      // message length
  uint16_t channel[PROTOCOL_CHANNELS]; // servo data received
  uint16_t chksum;                  // checksum calculation
  uint8_t lchksum;                  // checksum lower byte received
  typedef struct {
    uint8_t sensorType;             // sensor type (0,1,2,3, etc)
    uint8_t sensorLength;           // data length for defined sensor (can be 2 or 4)
    int32_t sensorValue;            // sensor data for defined sensors (16 or 32 bits)
  } sensorinfo;
  sensorinfo sensors[SENSORMAX];
  uint8_t NumberSensors = 0;        // number of sensors
  IBusBM* IBusBMnext = NULL;        // pointer to the next class instance to be used to call the loop() method from timer interrupt
#endif
I don't know the library nor what you are really using, but in C++ the coma operator won't do what you think (you are not sending 2 parameters)
calling
is exactly the same as calling
IBusServo.setSensorMeasurement (1, 22);
the 77 is not taken into account
the code shows this as well, only 2 parameters are expected: the address and the value:
why do you think you can give 2 values to a given sensor? what are you trying to achieve?
re reading your text
if you mean you want to combine 77 and 22 in a 4 byte representation then you need to know what is the correct representation. Is that a 16 bit representation for each value and which one goes in the Most significant two bytes and which one goes to the lower part?
it could be for example written as ((77ul << 16) | (22ul) )
that would put 77 in the top 16 bits and 22 in the bottom 16 bits
Thx @J-M-L
I declared two values as you wrote and it went without a problem;)
uint16_t twoValues(uint8_t firstVal, uint8_t secondVal);
great ! glad it helped (although it seems you are generating a uint16_t and not a uint32_t)
@atmanu
what does this have to do with this thread?? do yourself a favour and please read How to get the best out of this forum
