ICSP module between UNO card and computer windows
Hello,
Who has already used this module (see photo) between an UNO Card and a computer with usb ?
and what software ?
Tks
Best regards
Looks interesting.
Search for USBasp. For example, https://m.youtube.com/watch?v=ToKerwRR-70
Does that module have a name and a datasheet? Example code is often found there.
I have one that looks identical. It uses a version of the USBasp software mentioned earlier. I set mine up years ago and I think there have been software upgrades since then.
Hello friends,
Thanks for messages and video;
It's USBasp USBisp
the driver LibUSB-win32 with ZADIC 2.5 .......years ago. Win7.
This module is old, But the description on Amazon says Windows 7. Several cards did not work.
Have any of you made it work under Windows 10 family ?
bt4too
I run Linux so have never tried it with Windows. The developer is here.
https://www.fischl.de/usbasp/
Several variants are available as shown on his web site. There are probably a dozen manufactures and it is sold by hundreds of vendors. One write up on Windows installation is here (I have no idea if works).
https://www.drivereasy.com/knowledge/usbasp-driver-issues-in-windows-10-8-7-solved/
@oldcurmudgeon
Thanks for your message and the like www drivereasy....... I've watched it.
I see the video from @mancera1979 mancera1979 too.
In this video, the power; 5 Volts enters in module USBasp from USB cable connected at computer.
And it's the current enters in UNO card through this module USBasp.
AFTER:
the soft
the driver soft is already in the processor memory, is this correct ?
Someone between you would have the schematis of this card USBasp ???
I would like to receive this schematic, TKS.
to be continued,
bt4too
It does not help the OP very much but using the USBASP device under Windows means the complexity of installing a special driver as has already been pointed out. My preferred approach would be to simply dedicate a Nano to the task of an ICSP programmer by loading it with the ArduinoISP sketch found in the IDE examples folder.
See post #6 (link 1) for the schematic of the USBASP
@6v6gt
Thank you for the schematic into post 6;
But if anyone of you has the PDF version, I would like to receive it.
For the soft : I just downloaded : ZADIC 2. 8 .exe
I hope it's good for my Windows 10 family ? ? ? because I see Win 7 in descriptions;
who used this module with windows 10 ?
There is no more Windows Seven in computer in 2023.
to be continued,
bt4too
