IDE hangs on startup: "dial tcp: lookup downloads.arduino.cc: no such host"
Continuing the discussion from Arduino 2.0.3 stuck on loading screen:
PS C:\Users\Ikponmwosa\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Users\Ikponmwosa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\Ikponmwosa\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 17564
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/Ikponmwosa/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-03-20T18:28:10.472Z root INFO Backend Object.initialize: 10.0 ms [Finished 1.162 s after backend start]
2024-03-20T18:28:10.473Z root INFO Backend Object.configure: 8.6 ms [Finished 1.162 s after backend start]
2024-03-20T18:28:10.473Z root INFO Backend s.onStart: 4.9 ms [Finished 1.162 s after backend start]
2024-03-20T18:28:10.474Z root INFO Backend s.configure: 0.5 ms [Finished 1.205 s after backend start]
2024-03-20T18:28:10.476Z root INFO Backend d.onStart: 0.4 ms [Finished 1.206 s after backend start]
2024-03-20T18:28:10.477Z root INFO Backend d.configure: 0.2 ms [Finished 1.206 s after backend start]
2024-03-20T18:28:10.479Z root INFO Backend d.initialize: 43.6 ms [Finished 1.206 s after backend start]
2024-03-20T18:28:10.479Z root INFO Backend c.onStart: 0.4 ms [Finished 1.206 s after backend start]
2024-03-20T18:28:10.480Z root INFO Backend a.configure: 2.0 ms [Finished 1.208 s after backend start]
2024-03-20T18:28:10.483Z config INFO >>> Initializing CLI configuration...
2024-03-20T18:28:10.483Z root INFO Backend c.initialize: 1.1 ms [Finished 1.209 s after backend start]
2024-03-20T18:28:10.483Z root INFO Backend R.onStart: 1.7 ms [Finished 1.210 s after backend start]
2024-03-20T18:28:10.485Z config INFO Loading CLI configuration from c:\Users\Ikponmwosa\.arduinoIDE\arduino-cli.yaml...
2024-03-20T18:28:10.486Z daemon INFO Starting daemon from C:\Users\Ikponmwosa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-20T18:28:10.486Z root INFO Backend a.initialize: 0.7 ms [Finished 1.212 s after backend start]
2024-03-20T18:28:10.486Z root INFO Backend w.onStart: 2.1 ms [Finished 1.213 s after backend start]
2024-03-20T18:28:10.486Z root INFO Backend r.configure: 3.4 ms [Finished 1.214 s after backend start]
2024-03-20T18:28:10.487Z discovery-log INFO start
2024-03-20T18:28:10.487Z discovery-log INFO start new deferred
2024-03-20T18:28:10.487Z root INFO Backend d.initialize: 0.8 ms [Finished 1.215 s after backend start]
2024-03-20T18:28:10.487Z root INFO Backend y.onStart: 3.7 ms [Finished 1.218 s after backend start]
2024-03-20T18:28:10.487Z root INFO Backend r.configure: 3.3 ms [Finished 1.218 s after backend start]
2024-03-20T18:28:10.487Z root INFO Backend a.onStart: 0.9 ms [Finished 1.221 s after backend start]
2024-03-20T18:28:10.487Z root INFO Backend h.configure: 0.8 ms [Finished 1.221 s after backend start]
2024-03-20T18:28:10.487Z root INFO Backend s.configure: 0.4 ms [Finished 1.221 s after backend start]
2024-03-20T18:28:10.487Z root INFO Backend l.configure: 0.1 ms [Finished 1.222 s after backend start]
2024-03-20T18:28:10.493Z root INFO Theia app listening on http://127.0.0.1:58204.
2024-03-20T18:28:10.493Z root INFO Finished starting backend application: 6.8 ms [Finished 1.228 s after backend start]
2024-03-20T18:28:10.516Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Ikponmwosa/.arduinoIDE/plugins does not exist.
2024-03-20T18:28:10.516Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Ikponmwosa/.arduinoIDE/extensions does not exist.
2024-03-20T18:28:10.516Z root WARN The local plugin referenced by local-dir:C:\Users\Ikponmwosa\.arduinoIDE\plugins does not exist.
2024-03-20T18:28:10.554Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\Ikponmwosa\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\Ikponmwosa\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\Ikponmwosa\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-03-20T18:28:10.554Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-03-20T18:28:10.554Z config INFO Loaded the CLI configuration.
2024-03-20T18:28:10.565Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Ikponmwosa/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/Ikponmwosa/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-03-20T18:28:10.565Z config INFO Validating the CLI configuration...
2024-03-20T18:28:10.567Z config INFO The CLI config is valid.
2024-03-20T18:28:10.567Z config INFO <<< Initialized the CLI configuration.
2024-03-20T18:28:10.626Z root INFO Resolve plugins list: 140.5 ms [Finished 1.359 s after backend start]
2024-03-20T18:28:11.121Z daemon INFO time="2024-03-20T18:28:11Z" level=info msg="Using config file: c:\\Users\\Ikponmwosa\\.arduinoIDE\\arduino-cli.yaml"
time="2024-03-20T18:28:11Z" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-03-20T18:28:11Z" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:58207
{"IP":"127.0.0.1","Port":"58207"}
2024-03-20T18:28:11.122Z daemon INFO Daemon is running.
2024-03-20T18:28:11.299Z daemon INFO time="2024-03-20T18:28:11Z" level=info msg="Checking signature" index="C:\\Users\\Ikponmwosa\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\Ikponmwosa\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2024-03-20T18:28:11Z" level=info msg="Loading hardware from: C:\\Users\\Ikponmwosa\\AppData\\Local\\Arduino15\\packages"
time="2024-03-20T18:28:11Z" level=info msg="Loading package builtin from: C:\\Users\\Ikponmwosa\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2024-03-20T18:28:11Z" level=info msg="Checking existence of 'tools' path: C:\\Users\\Ikponmwosa\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-03-20T18:28:11Z" level=info msg="Loading tools from dir: C:\\Users\\Ikponmwosa\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-03-20T18:28:11Z" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-03-20T18:28:11Z" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.0_Windows_64bit.zip"
time="2024-03-20T18:28:11Z" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.9_Windows_64bit.zip"
time="2024-03-20T18:28:11Z" level=info msg="Starting download" url="https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.14.1_Windows_64bit.zip"
time="2024-03-20T18:28:11Z" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/dfu-discovery/dfu-discovery_v0.1.2_Windows_64bit.zip"
time="2024-03-20T18:28:11Z" level=info msg="Loading libraries index file" index="C:\\Users\\Ikponmwosa\\AppData\\Local\\Arduino15\\library_index.json"
2024-03-20T18:28:11.313Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:serial-discovery@1.4.0 tool: Get "https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.0_Windows_64bit.zip": dial tcp: lookup downloads.arduino.cc: no such host
2024-03-20T18:28:11.315Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:mdns-discovery@1.0.9 tool: Get "https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.9_Windows_64bit.zip": dial tcp: lookup downloads.arduino.cc: no such host
2024-03-20T18:28:11.321Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:serial-monitor@0.14.1 tool: Get "https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.14.1_Windows_64bit.zip": dial tcp: lookup downloads.arduino.cc: no such host
2024-03-20T18:28:11.329Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:dfu-discovery@0.1.2 tool: Get "https://downloads.arduino.cc/discovery/dfu-discovery/dfu-discovery_v0.1.2_Windows_64bit.zip": dial tcp: lookup downloads.arduino.cc: no such host
2024-03-20T18:28:11.331Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not installed
2024-03-20T18:28:11.334Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not installed
2024-03-20T18:28:11.867Z daemon INFO time="2024-03-20T18:28:11Z" level=info msg="Adding libraries dir" dir="C:\\Users\\Ikponmwosa\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-03-20T18:28:11Z" level=info msg="Adding libraries dir" dir="C:\\Users\\Ikponmwosa\\Documents\\Arduino\\libraries" location=user
2024-03-20T18:28:11.876Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not installed
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not installed
2024-03-20T18:28:11.883Z daemon INFO time="2024-03-20T18:28:11Z" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-03-20T18:28:11.899Z daemon INFO time="2024-03-20T18:28:11Z" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-03-20T18:28:11.902Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-03-20T18:28:11.910Z root ERROR Failed to update platform indexes. Error: 13 INTERNAL: Some indexes could not be updated.
    at t.callErrorFromStatus (C:\Users\Ikponmwosa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:763461)
    at Object.onReceiveStatus (C:\Users\Ikponmwosa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:791078)
    at Object.onReceiveStatus (C:\Users\Ikponmwosa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:784102)
    at C:\Users\Ikponmwosa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:870224
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
    at s.makeServerStreamRequest (C:\Users\Ikponmwosa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:790845)
    at s.updateIndex (C:\Users\Ikponmwosa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:855121)
    at C:\Users\Ikponmwosa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:623733
    at C:\Users\Ikponmwosa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:624081
    at new Promise (<anonymous>)
    at E.doUpdateIndex (C:\Users\Ikponmwosa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:624060)
    at E.updatePlatformIndex (C:\Users\Ikponmwosa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:623705)
    at E.updateIndex (C:\Users\Ikponmwosa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:623073)
    at E.initInstanceWithFallback (C:\Users\Ikponmwosa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:621317)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2024-03-20T18:28:12.031Z daemon INFO time="2024-03-20T18:28:11Z" level=info msg="Checking signature" index="C:\\Users\\Ikponmwosa\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\Ikponmwosa\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-03-20T18:28:12.033Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:serial-discovery@1.4.0 tool: Get "https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.0_Windows_64bit.zip": dial tcp: lookup downloads.arduino.cc: no such host
2024-03-20T18:28:12.034Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:mdns-discovery@1.0.9 tool: Get "https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.9_Windows_64bit.zip": dial tcp: lookup downloads.arduino.cc: no such host
2024-03-20T18:28:12.034Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:serial-monitor@0.14.1 tool: Get "https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.14.1_Windows_64bit.zip": dial tcp: lookup downloads.arduino.cc: no such host
2024-03-20T18:28:12.036Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:dfu-discovery@0.1.2 tool: Get "https://downloads.arduino.cc/discovery/dfu-discovery/dfu-discovery_v0.1.2_Windows_64bit.zip": dial tcp: lookup downloads.arduino.cc: no such host
2024-03-20T18:28:12.036Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not installed
2024-03-20T18:28:12.036Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not installed
2024-03-20T18:28:12.428Z daemon INFO time="2024-03-20T18:28:12Z" level=info msg="Adding libraries dir" dir="C:\\Users\\Ikponmwosa\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-03-20T18:28:12Z" level=info msg="Adding libraries dir" dir="C:\\Users\\Ikponmwosa\\Documents\\Arduino\\libraries" location=user
2024-03-20T18:28:12.431Z root ERROR Uncaught Exception:  Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-03-20T18:28:12.431Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
    at C:\Users\Ikponmwosa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:622877
    at E.evaluateErrorStatus (C:\Users\Ikponmwosa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:622893)
    at async a.<anonymous> (C:\Users\Ikponmwosa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:622563)
2024-03-20T18:28:13.072Z root INFO Deploy plugins list: 140.5 ms [Finished 3.807 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-03-20T18:28:14.680Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 313.0 ms [Finished 3.911 s after frontend start]
2024-03-20T18:28:14.680Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-03-20T18:28:14.794Z root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 117.4 ms [Finished 4.084 s after frontend start]
[14256:0320/182814.914:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
Hi @35ikponmwosa.
On the first run after a fresh installation, Arduino IDE downloads some additional essential components from the Internet and installs them. If it can't install those components then the startup fails. So the computer must have access to the Internet on the first startup.
The errors indicate Arduino IDE is not able to access the Internet. If it is not already, please connect your computer to the Internet, close the Arduino IDE window, then start Arduino IDE again. This time it should start up successfully.
After that first run, an Internet connection is not required. However, there are some supplemental features such as "Library Manager" that have an inherent dependency on the Internet. Those features will not be usable while your computer is offline. But the essential functionality of editing, compiling, and uploading sketches will be available even without an Internet connection.
