IDE hangs on startup: "dial tcp: lookup downloads.arduino.cc: no such host"
the Arduino IDE just shows the logo
2024-11-26 10:57:25 Arduino IDE 2.3.3
2024-11-26 10:57:25 Checking for frontend application configuration customizations. Module path: C:\Data\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Data\Arduino IDE\resources\app\package.json
2024-11-26 10:57:25 Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.3" (type of string)
2024-11-26 10:57:25 Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.0.4" (type of string)
2024-11-26 10:57:25 Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-09-25T09:41:18.242Z" (type of string)
2024-11-26 10:57:25 Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.3","cliVersion":"1.0.4","buildDate":"2024-09-25T09:41:18.242Z"}
2024-11-26 10:57:31 Starting backend process. PID: 10728
2024-11-26 10:57:32 Using browser-only version of superagent in non-browser environment
2024-11-26 10:57:32 Configuration directory URI: 'file:///c%3A/Users/zhouyu30/.arduinoIDE'
2024-11-26 10:57:32 Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-11-26 10:57:32 2024-11-26T02:57:32.474Z root INFO Backend Object.initialize: 5.6 ms [Finished 1.091 s after backend start]
2024-11-26 10:57:32 2024-11-26T02:57:32.477Z root INFO Backend Object.configure: 4.3 ms [Finished 1.091 s after backend start]
2024-11-26 10:57:32 2024-11-26T02:57:32.477Z root INFO Backend a.onStart: 2.3 ms [Finished 1.091 s after backend start]
2024-11-26 10:57:32 2024-11-26T02:57:32.478Z root INFO Backend a.configure: 0.4 ms [Finished 1.129 s after backend start]
2024-11-26 10:57:32 2024-11-26T02:57:32.479Z root INFO Backend d.onStart: 0.2 ms [Finished 1.129 s after backend start]
2024-11-26 10:57:32 2024-11-26T02:57:32.480Z root INFO Backend d.configure: 0.1 ms [Finished 1.130 s after backend start]
2024-11-26 10:57:32 2024-11-26T02:57:32.481Z root INFO Backend d.initialize: 38.4 ms [Finished 1.130 s after backend start]
2024-11-26 10:57:32 2024-11-26T02:57:32.481Z root INFO Backend c.onStart: 0.3 ms [Finished 1.130 s after backend start]
2024-11-26 10:57:32 2024-11-26T02:57:32.482Z root INFO Backend s.configure: 4.0 ms [Finished 1.134 s after backend start]
2024-11-26 10:57:32 2024-11-26T02:57:32.484Z config INFO >>> Initializing CLI configuration...
2024-11-26 10:57:32 2024-11-26T02:57:32.484Z root INFO Backend c.initialize: 0.7 ms [Finished 1.134 s after backend start]
2024-11-26 10:57:32 2024-11-26T02:57:32.484Z root INFO Backend x.onStart: 1.0 ms [Finished 1.135 s after backend start]
2024-11-26 10:57:32 2024-11-26T02:57:32.485Z config INFO Loading CLI configuration from c:\Users\zhouyu30\.arduinoIDE\arduino-cli.yaml...
2024-11-26 10:57:32 2024-11-26T02:57:32.486Z daemon INFO Starting daemon from C:\Data\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-11-26 10:57:32 2024-11-26T02:57:32.486Z root INFO Backend s.initialize: 0.5 ms [Finished 1.136 s after backend start]
2024-11-26 10:57:32 2024-11-26T02:57:32.486Z root INFO Backend w.onStart: 1.5 ms [Finished 1.137 s after backend start]
2024-11-26 10:57:32 2024-11-26T02:57:32.486Z root INFO Backend r.configure: 2.3 ms [Finished 1.137 s after backend start]
2024-11-26 10:57:32 2024-11-26T02:57:32.486Z discovery-log INFO start
2024-11-26 10:57:32 2024-11-26T02:57:32.486Z discovery-log INFO start new deferred
2024-11-26 10:57:32 2024-11-26T02:57:32.486Z root INFO Backend d.initialize: 0.6 ms [Finished 1.138 s after backend start]
2024-11-26 10:57:32 2024-11-26T02:57:32.486Z root INFO Backend y.onStart: 2.6 ms [Finished 1.140 s after backend start]
2024-11-26 10:57:32 2024-11-26T02:57:32.486Z root INFO Backend r.configure: 2.1 ms [Finished 1.140 s after backend start]
2024-11-26 10:57:32 2024-11-26T02:57:32.486Z root INFO Backend s.onStart: 0.6 ms [Finished 1.142 s after backend start]
2024-11-26 10:57:32 2024-11-26T02:57:32.486Z root INFO Backend h.configure: 0.5 ms [Finished 1.142 s after backend start]
2024-11-26 10:57:32 2024-11-26T02:57:32.486Z root INFO Backend a.configure: 0.2 ms [Finished 1.142 s after backend start]
2024-11-26 10:57:32 2024-11-26T02:57:32.486Z root INFO Backend l.configure: 0.1 ms [Finished 1.142 s after backend start]
2024-11-26 10:57:33 2024-11-26T02:57:33.683Z root INFO Theia app listening on http://127.0.0.1:59470.
2024-11-26 10:57:33 2024-11-26T02:57:33.683Z root INFO Finished starting backend application: 1197.6 ms [Finished 2.340 s after backend start]
2024-11-26 10:57:34 2024-11-26T02:57:34.382Z root WARN The local plugin referenced by local-dir:/c%3A/Users/zhouyu30/.arduinoIDE/plugins does not exist.
2024-11-26 10:57:34 2024-11-26T02:57:34.382Z root WARN The local plugin referenced by local-dir:/c%3A/Users/zhouyu30/.arduinoIDE/extensions does not exist.
2024-11-26 10:57:34 2024-11-26T02:57:34.382Z root WARN The local plugin referenced by local-dir:C:\Users\zhouyu30\.arduinoIDE\plugins does not exist.
2024-11-26 10:57:34 2024-11-26T02:57:34.431Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]}}
2024-11-26 10:57:34 2024-11-26T02:57:34.431Z config INFO Loading fallback CLI configuration to get 'directories.data' and 'directories.user'
2024-11-26 10:57:34 2024-11-26T02:57:34.465Z root INFO Resolve plugins list: 1980.4 ms [Finished 3.121 s after backend start]
2024-11-26 10:57:36 2024-11-26T02:57:36.028Z root INFO Deploy plugins list: 1980.4 ms [Finished 4.684 s after backend start]
2024-11-26 10:57:36 Opening channel for service path '/services/electron-window'.
2024-11-26 10:57:36 2024-11-26T02:57:36.516Z daemon INFO time="2024-11-26T10:57:36+08:00" level=info msg="arduino-cli version 1.0.4"
2024-11-26 10:57:36 2024-11-26T02:57:36.517Z daemon INFO time="2024-11-26T10:57:36+08:00" level=info msg="Using config file: c:\\Users\\zhouyu30\\.arduinoIDE\\arduino-cli.yaml"
2024-11-26 10:57:36 2024-11-26T02:57:36.517Z daemon INFO time="2024-11-26T10:57:36+08:00" level=info msg="Executing `arduino-cli daemon`"
2024-11-26 10:57:36 Opening channel for service path '/services/ide-updater'.
2024-11-26 10:57:36 2024-11-26T02:57:36.531Z daemon INFO Daemon is now listening on 127.0.0.1:59538
{"IP":"127.0.0.1","Port":"59538"}
2024-11-26 10:57:36 2024-11-26T02:57:36.531Z daemon INFO Daemon is running.
2024-11-26 10:57:36 2024-11-26T02:57:36.552Z config INFO Loaded fallback CLI configuration: {"directories":{"user":"C:\\Users\\zhouyu30\\OneDrive - Faurecia\\文档\\Arduino","data":"C:\\Users\\zhouyu30\\AppData\\Local\\Arduino15"}}
2024-11-26 10:57:36 2024-11-26T02:57:36.552Z config INFO Merged CLI configuration with the fallback: {"directories":{"user":"C:\\Users\\zhouyu30\\OneDrive - Faurecia\\文档\\Arduino","data":"C:\\Users\\zhouyu30\\AppData\\Local\\Arduino15"},"board_manager":{"additional_urls":[]}}
2024-11-26 10:57:36 2024-11-26T02:57:36.552Z config INFO Loaded the CLI configuration.
2024-11-26 10:57:36 2024-11-26T02:57:36.560Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/zhouyu30/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/zhouyu30/OneDrive%20-%20Faurecia/%E6%96%87%E6%A1%A3/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-11-26 10:57:36 2024-11-26T02:57:36.560Z config INFO Validating the CLI configuration...
2024-11-26 10:57:36 2024-11-26T02:57:36.560Z config INFO The CLI config is valid.
2024-11-26 10:57:36 2024-11-26T02:57:36.560Z config INFO <<< Initialized the CLI configuration.
2024-11-26 10:57:36 2024-11-26T02:57:36.562Z daemon INFO time="2024-11-26T10:57:36+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-11-26 10:57:36 2024-11-26T02:57:36.577Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc: no such host
2024-11-26 10:57:36 2024-11-26T02:57:36.578Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\zhouyu30\AppData\Local\Arduino15\package_index.json: open C:\Users\zhouyu30\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-11-26 10:57:36 2024-11-26T02:57:36.578Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-11-26 10:57:36 2024-11-26T02:57:36.579Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-11-26 10:57:36 2024-11-26T02:57:36.579Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\zhouyu30\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-11-26 10:57:36 2024-11-26T02:57:36.584Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Loading index file: loading json index file C:\Users\zhouyu30\AppData\Local\Arduino15\package_index.json: open C:\Users\zhouyu30\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
[library-index] - code: 9, message: Loading index file: reading library_index.json: open C:\Users\zhouyu30\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-11-26 10:57:36 2024-11-26T02:57:36.585Z daemon INFO time="2024-11-26T10:57:36+08:00" level=info msg="Loading hardware from: C:\\Users\\zhouyu30\\AppData\\Local\\Arduino15\\packages"
time="2024-11-26T10:57:36+08:00" level=info msg="Loading libraries index file" index="C:\\Users\\zhouyu30\\AppData\\Local\\Arduino15\\library_index.json"
time="2024-11-26T10:57:36+08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\zhouyu30\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
time="2024-11-26T10:57:36+08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\zhouyu30\\OneDrive - Faurecia\\文档\\Arduino\\libraries" isSingleLibrary=false location=user
time="2024-11-26T10:57:36+08:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-11-26 10:57:36 2024-11-26T02:57:36.588Z daemon INFO time="2024-11-26T10:57:36+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-11-26 10:57:36 2024-11-26T02:57:36.589Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-11-26 10:57:36 2024-11-26T02:57:36.591Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-11-26 10:57:36 2024-11-26T02:57:36.591Z daemon INFO time="2024-11-26T10:57:36+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-11-26 10:57:36 2024-11-26T02:57:36.594Z root ERROR Failed to update platform, library indexes. Error: 13 INTERNAL: Some indexes could not be updated.
    at t.callErrorFromStatus (C:\Data\Arduino IDE\resources\app\lib\backend\main.js:2:912720)
    at Object.onReceiveStatus (C:\Data\Arduino IDE\resources\app\lib\backend\main.js:2:940342)
    at Object.onReceiveStatus (C:\Data\Arduino IDE\resources\app\lib\backend\main.js:2:933364)
    at C:\Data\Arduino IDE\resources\app\lib\backend\main.js:2:1019505
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
    at a.makeServerStreamRequest (C:\Data\Arduino IDE\resources\app\lib\backend\main.js:2:940109)
    at a.updateIndex (C:\Data\Arduino IDE\resources\app\lib\backend\main.js:2:1004397)
    at C:\Data\Arduino IDE\resources\app\lib\backend\main.js:2:771327
    at C:\Data\Arduino IDE\resources\app\lib\backend\main.js:2:771675
    at new Promise (<anonymous>)
    at v.doUpdateIndex (C:\Data\Arduino IDE\resources\app\lib\backend\main.js:2:771654)
    at v.updatePlatformIndex (C:\Data\Arduino IDE\resources\app\lib\backend\main.js:2:771299)
    at v.updateIndex (C:\Data\Arduino IDE\resources\app\lib\backend\main.js:2:770667)
    at v.initInstanceWithFallback (C:\Data\Arduino IDE\resources\app\lib\backend\main.js:2:768960)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2024-11-26 10:57:36 2024-11-26T02:57:36.599Z daemon INFO time="2024-11-26T10:57:36+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-11-26 10:57:36 2024-11-26T02:57:36.600Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc: no such host
2024-11-26 10:57:36 2024-11-26T02:57:36.600Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\zhouyu30\AppData\Local\Arduino15\package_index.json: open C:\Users\zhouyu30\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-11-26 10:57:36 2024-11-26T02:57:36.601Z daemon INFO time="2024-11-26T10:57:36+08:00" level=info msg="Loading hardware from: C:\\Users\\zhouyu30\\AppData\\Local\\Arduino15\\packages"
2024-11-26 10:57:36 2024-11-26T02:57:36.601Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-11-26 10:57:36 2024-11-26T02:57:36.601Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-11-26 10:57:36 2024-11-26T02:57:36.601Z daemon INFO time="2024-11-26T10:57:36+08:00" level=info msg="Loading libraries index file" index="C:\\Users\\zhouyu30\\AppData\\Local\\Arduino15\\library_index.json"
2024-11-26 10:57:36 2024-11-26T02:57:36.602Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\zhouyu30\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-11-26 10:57:36 2024-11-26T02:57:36.603Z root ERROR Uncaught Exception:  Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-11-26 10:57:36 2024-11-26T02:57:36.603Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
    at C:\Data\Arduino IDE\resources\app\lib\backend\main.js:2:770471
    at v.evaluateErrorStatus (C:\Data\Arduino IDE\resources\app\lib\backend\main.js:2:770487)
    at async s.<anonymous> (C:\Data\Arduino IDE\resources\app\lib\backend\main.js:2:770157)
2024-11-26 10:57:37 2024-11-26T02:57:37.037Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 410.4 ms [Finished 3.120 s after frontend start]
2024-11-26 10:57:37 2024-11-26T02:57:37.037Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-11-26 10:58:51 Closing channel on service path '/services/electron-window'.
2024-11-26 10:58:51 Closing channel on service path '/services/ide-updater'.
2024-11-26 10:58:51 Stored workspaces roots:
2024-11-26 10:58:51 No sketches were scheduled for deletion.
2024-11-26 10:59:56 Arduino IDE 2.3.3
2024-11-26 10:59:56 Checking for frontend application configuration customizations. Module path: C:\Data\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Data\Arduino IDE\resources\app\package.json
2024-11-26 10:59:56 Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.3" (type of string)
2024-11-26 10:59:56 Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.0.4" (type of string)
2024-11-26 10:59:56 Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-09-25T09:41:18.242Z" (type of string)
2024-11-26 10:59:56 Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.3","cliVersion":"1.0.4","buildDate":"2024-09-25T09:41:18.242Z"}
2024-11-26 11:00:01 Starting backend process. PID: 19012
2024-11-26 11:00:02 Using browser-only version of superagent in non-browser environment
2024-11-26 11:00:02 Configuration directory URI: 'file:///c%3A/Users/zhouyu30/.arduinoIDE'
2024-11-26 11:00:02 Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-11-26 11:00:02 2024-11-26T03:00:02.865Z root INFO Backend Object.initialize: 7.2 ms [Finished 1.124 s after backend start]
2024-11-26 11:00:02 2024-11-26T03:00:02.870Z root INFO Backend Object.configure: 5.4 ms [Finished 1.124 s after backend start]
2024-11-26 11:00:02 2024-11-26T03:00:02.870Z root INFO Backend a.onStart: 3.1 ms [Finished 1.124 s after backend start]
2024-11-26 11:00:02 2024-11-26T03:00:02.871Z root INFO Backend a.configure: 0.6 ms [Finished 1.162 s after backend start]
2024-11-26 11:00:02 2024-11-26T03:00:02.872Z root INFO Backend d.onStart: 0.4 ms [Finished 1.162 s after backend start]
2024-11-26 11:00:02 2024-11-26T03:00:02.873Z root INFO Backend d.configure: 0.2 ms [Finished 1.163 s after backend start]
2024-11-26 11:00:02 2024-11-26T03:00:02.874Z root INFO Backend d.initialize: 37.9 ms [Finished 1.163 s after backend start]
2024-11-26 11:00:02 2024-11-26T03:00:02.874Z root INFO Backend c.onStart: 0.4 ms [Finished 1.163 s after backend start]
2024-11-26 11:00:02 2024-11-26T03:00:02.876Z root INFO Backend s.configure: 5.2 ms [Finished 1.168 s after backend start]
2024-11-26 11:00:02 2024-11-26T03:00:02.878Z config INFO >>> Initializing CLI configuration...
2024-11-26 11:00:02 2024-11-26T03:00:02.878Z root INFO Backend c.initialize: 0.9 ms [Finished 1.169 s after backend start]
2024-11-26 11:00:02 2024-11-26T03:00:02.878Z root INFO Backend x.onStart: 1.2 ms [Finished 1.170 s after backend start]
2024-11-26 11:00:02 2024-11-26T03:00:02.879Z config INFO Loading CLI configuration from c:\Users\zhouyu30\.arduinoIDE\arduino-cli.yaml...
2024-11-26 11:00:02 2024-11-26T03:00:02.880Z daemon INFO Starting daemon from C:\Data\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-11-26 11:00:02 2024-11-26T03:00:02.880Z root INFO Backend s.initialize: 0.7 ms [Finished 1.171 s after backend start]
2024-11-26 11:00:02 2024-11-26T03:00:02.880Z root INFO Backend w.onStart: 1.9 ms [Finished 1.172 s after backend start]
2024-11-26 11:00:02 2024-11-26T03:00:02.880Z root INFO Backend r.configure: 3.1 ms [Finished 1.173 s after backend start]
2024-11-26 11:00:02 2024-11-26T03:00:02.881Z discovery-log INFO start
2024-11-26 11:00:02 2024-11-26T03:00:02.881Z discovery-log INFO start new deferred
2024-11-26 11:00:02 2024-11-26T03:00:02.881Z root INFO Backend d.initialize: 0.9 ms [Finished 1.174 s after backend start]
2024-11-26 11:00:02 2024-11-26T03:00:02.881Z root INFO Backend y.onStart: 3.2 ms [Finished 1.176 s after backend start]
2024-11-26 11:00:02 2024-11-26T03:00:02.881Z root INFO Backend r.configure: 2.6 ms [Finished 1.176 s after backend start]
2024-11-26 11:00:02 2024-11-26T03:00:02.881Z root INFO Backend s.onStart: 0.8 ms [Finished 1.178 s after backend start]
2024-11-26 11:00:02 2024-11-26T03:00:02.881Z root INFO Backend h.configure: 0.7 ms [Finished 1.179 s after backend start]
2024-11-26 11:00:02 2024-11-26T03:00:02.881Z root INFO Backend a.configure: 0.3 ms [Finished 1.179 s after backend start]
2024-11-26 11:00:02 2024-11-26T03:00:02.881Z root INFO Backend l.configure: 0.1 ms [Finished 1.179 s after backend start]
2024-11-26 11:00:04 2024-11-26T03:00:04.327Z root INFO Theia app listening on http://127.0.0.1:60475.
2024-11-26 11:00:04 2024-11-26T03:00:04.328Z root INFO Finished starting backend application: 1447.0 ms [Finished 2.626 s after backend start]
2024-11-26 11:00:05 2024-11-26T03:00:05.020Z root WARN The local plugin referenced by local-dir:/c%3A/Users/zhouyu30/.arduinoIDE/plugins does not exist.
2024-11-26 11:00:05 2024-11-26T03:00:05.020Z root WARN The local plugin referenced by local-dir:/c%3A/Users/zhouyu30/.arduinoIDE/extensions does not exist.
2024-11-26 11:00:05 2024-11-26T03:00:05.021Z root WARN The local plugin referenced by local-dir:C:\Users\zhouyu30\.arduinoIDE\plugins does not exist.
2024-11-26 11:00:05 2024-11-26T03:00:05.071Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]}}
2024-11-26 11:00:05 2024-11-26T03:00:05.072Z config INFO Loading fallback CLI configuration to get 'directories.data' and 'directories.user'
2024-11-26 11:00:05 2024-11-26T03:00:05.122Z root INFO Resolve plugins list: 2237.1 ms [Finished 3.414 s after backend start]
2024-11-26 11:00:07 Opening channel for service path '/services/electron-window'.
2024-11-26 11:00:07 2024-11-26T03:00:07.427Z root INFO Deploy plugins list: 2237.1 ms [Finished 5.725 s after backend start]
2024-11-26 11:00:07 Opening channel for service path '/services/ide-updater'.
2024-11-26 11:00:07 2024-11-26T03:00:07.824Z config INFO Loaded fallback CLI configuration: {"directories":{"user":"C:\\Users\\zhouyu30\\OneDrive - Faurecia\\文档\\Arduino","data":"C:\\Users\\zhouyu30\\AppData\\Local\\Arduino15"}}
2024-11-26 11:00:07 2024-11-26T03:00:07.824Z config INFO Merged CLI configuration with the fallback: {"directories":{"user":"C:\\Users\\zhouyu30\\OneDrive - Faurecia\\文档\\Arduino","data":"C:\\Users\\zhouyu30\\AppData\\Local\\Arduino15"},"board_manager":{"additional_urls":[]}}
2024-11-26 11:00:07 2024-11-26T03:00:07.824Z config INFO Loaded the CLI configuration.
2024-11-26 11:00:07 2024-11-26T03:00:07.824Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/zhouyu30/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/zhouyu30/OneDrive%20-%20Faurecia/%E6%96%87%E6%A1%A3/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-11-26 11:00:07 2024-11-26T03:00:07.825Z config INFO Validating the CLI configuration...
2024-11-26 11:00:07 2024-11-26T03:00:07.825Z config INFO The CLI config is valid.
2024-11-26 11:00:07 2024-11-26T03:00:07.825Z config INFO <<< Initialized the CLI configuration.
2024-11-26 11:00:07 2024-11-26T03:00:07.836Z daemon INFO time="2024-11-26T11:00:07+08:00" level=info msg="arduino-cli version 1.0.4"
2024-11-26 11:00:07 2024-11-26T03:00:07.836Z daemon INFO time="2024-11-26T11:00:07+08:00" level=info msg="Using config file: c:\\Users\\zhouyu30\\.arduinoIDE\\arduino-cli.yaml"
2024-11-26 11:00:07 2024-11-26T03:00:07.837Z daemon INFO time="2024-11-26T11:00:07+08:00" level=info msg="Executing `arduino-cli daemon`"
2024-11-26 11:00:07 2024-11-26T03:00:07.846Z daemon INFO Daemon is now listening on 127.0.0.1:60549
{"IP":"127.0.0.1","Port":"60549"}
2024-11-26 11:00:07 2024-11-26T03:00:07.846Z daemon INFO Daemon is running.
2024-11-26 11:00:07 2024-11-26T03:00:07.867Z daemon INFO time="2024-11-26T11:00:07+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-11-26 11:00:07 2024-11-26T03:00:07.881Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc: no such host
2024-11-26 11:00:07 2024-11-26T03:00:07.881Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\zhouyu30\AppData\Local\Arduino15\package_index.json: open C:\Users\zhouyu30\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-11-26 11:00:07 2024-11-26T03:00:07.882Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-11-26 11:00:07 2024-11-26T03:00:07.882Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-11-26 11:00:07 2024-11-26T03:00:07.882Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\zhouyu30\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-11-26 11:00:07 2024-11-26T03:00:07.887Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-11-26 11:00:07 2024-11-26T03:00:07.888Z daemon INFO time="2024-11-26T11:00:07+08:00" level=info msg="Loading hardware from: C:\\Users\\zhouyu30\\AppData\\Local\\Arduino15\\packages"
time="2024-11-26T11:00:07+08:00" level=info msg="Loading libraries index file" index="C:\\Users\\zhouyu30\\AppData\\Local\\Arduino15\\library_index.json"
time="2024-11-26T11:00:07+08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\zhouyu30\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
time="2024-11-26T11:00:07+08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\zhouyu30\\OneDrive - Faurecia\\文档\\Arduino\\libraries" isSingleLibrary=false location=user
2024-11-26 11:00:07 2024-11-26T03:00:07.925Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-11-26 11:00:07 2024-11-26T03:00:07.926Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-11-26 11:00:07 2024-11-26T03:00:07.929Z root ERROR Failed to update platform, library indexes. Error: 13 INTERNAL: Some indexes could not be updated.
for call at
2024-11-26 11:00:07 2024-11-26T03:00:07.930Z daemon INFO time="2024-11-26T11:00:07+08:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
time="2024-11-26T11:00:07+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-11-26 11:00:07 2024-11-26T03:00:07.934Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc: no such host
2024-11-26 11:00:07 2024-11-26T03:00:07.934Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\zhouyu30\AppData\Local\Arduino15\package_index.json: open C:\Users\zhouyu30\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-11-26 11:00:07 2024-11-26T03:00:07.935Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-11-26 11:00:07 2024-11-26T03:00:07.935Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-11-26 11:00:07 2024-11-26T03:00:07.935Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\zhouyu30\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-11-26 11:00:07 2024-11-26T03:00:07.935Z daemon INFO time="2024-11-26T11:00:07+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-11-26 11:00:07 2024-11-26T03:00:07.937Z root ERROR Uncaught Exception:  Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-11-26 11:00:07 2024-11-26T03:00:07.938Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-11-26 11:00:08 2024-11-26T03:00:08.006Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 449.3 ms [Finished 3.545 s after frontend start]
2024-11-26 11:00:08 2024-11-26T03:00:08.016Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-11-26 11:07:57 Closing channel on service path '/services/electron-window'.
2024-11-26 11:07:57 Closing channel on service path '/services/ide-updater'.
2024-11-26 11:07:57 Stored workspaces roots:
2024-11-26 11:07:57 No sketches were scheduled for deletion.
2024-11-26 13:07:10 Arduino IDE 2.3.3
2024-11-26 13:07:10 Checking for frontend application configuration customizations. Module path: C:\Data\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Data\Arduino IDE\resources\app\package.json
2024-11-26 13:07:10 Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.3" (type of string)
2024-11-26 13:07:10 Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.0.4" (type of string)
2024-11-26 13:07:10 Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-09-25T09:41:18.242Z" (type of string)
2024-11-26 13:07:10 Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.3","cliVersion":"1.0.4","buildDate":"2024-09-25T09:41:18.242Z"}
2024-11-26 13:07:11 Starting backend process. PID: 18112
2024-11-26 13:07:11 Using browser-only version of superagent in non-browser environment
2024-11-26 13:07:11 Configuration directory URI: 'file:///c%3A/Users/zhouyu30/.arduinoIDE'
2024-11-26 13:07:11 Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-11-26 13:07:11 2024-11-26T05:07:11.974Z root INFO Backend Object.initialize: 4.3 ms [Finished 0.719 s after backend start]
2024-11-26 13:07:11 2024-11-26T05:07:11.979Z root INFO Backend Object.configure: 3.5 ms [Finished 0.719 s after backend start]
2024-11-26 13:07:11 2024-11-26T05:07:11.979Z root INFO Backend a.onStart: 1.9 ms [Finished 0.719 s after backend start]
2024-11-26 13:07:11 2024-11-26T05:07:11.980Z root INFO Backend a.configure: 0.3 ms [Finished 0.749 s after backend start]
2024-11-26 13:07:11 2024-11-26T05:07:11.980Z root INFO Backend d.onStart: 0.2 ms [Finished 0.749 s after backend start]
2024-11-26 13:07:11 2024-11-26T05:07:11.982Z root INFO Backend d.configure: 0.1 ms [Finished 0.749 s after backend start]
2024-11-26 13:07:11 2024-11-26T05:07:11.983Z root INFO Backend d.initialize: 30.0 ms [Finished 0.750 s after backend start]
2024-11-26 13:07:11 2024-11-26T05:07:11.983Z root INFO Backend c.onStart: 0.3 ms [Finished 0.750 s after backend start]
2024-11-26 13:07:11 2024-11-26T05:07:11.983Z root INFO Backend s.configure: 4.9 ms [Finished 0.755 s after backend start]
2024-11-26 13:07:11 2024-11-26T05:07:11.985Z config INFO >>> Initializing CLI configuration...
2024-11-26 13:07:11 2024-11-26T05:07:11.985Z root INFO Backend c.initialize: 0.8 ms [Finished 0.755 s after backend start]
2024-11-26 13:07:11 2024-11-26T05:07:11.985Z root INFO Backend x.onStart: 1.0 ms [Finished 0.756 s after backend start]
2024-11-26 13:07:11 2024-11-26T05:07:11.986Z config INFO Loading CLI configuration from c:\Users\zhouyu30\.arduinoIDE\arduino-cli.yaml...
2024-11-26 13:07:11 2024-11-26T05:07:11.987Z daemon INFO Starting daemon from C:\Data\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-11-26 13:07:11 2024-11-26T05:07:11.987Z root INFO Backend s.initialize: 0.6 ms [Finished 0.757 s after backend start]
2024-11-26 13:07:11 2024-11-26T05:07:11.987Z root INFO Backend w.onStart: 1.6 ms [Finished 0.758 s after backend start]
2024-11-26 13:07:11 2024-11-26T05:07:11.987Z root INFO Backend r.configure: 2.4 ms [Finished 0.758 s after backend start]
2024-11-26 13:07:11 2024-11-26T05:07:11.987Z discovery-log INFO start
2024-11-26 13:07:11 2024-11-26T05:07:11.987Z discovery-log INFO start new deferred
2024-11-26 13:07:11 2024-11-26T05:07:11.987Z root INFO Backend d.initialize: 0.5 ms [Finished 0.759 s after backend start]
2024-11-26 13:07:11 2024-11-26T05:07:11.987Z root INFO Backend y.onStart: 2.0 ms [Finished 0.760 s after backend start]
2024-11-26 13:07:11 2024-11-26T05:07:11.987Z root INFO Backend r.configure: 1.7 ms [Finished 0.761 s after backend start]
2024-11-26 13:07:11 2024-11-26T05:07:11.987Z root INFO Backend s.onStart: 0.6 ms [Finished 0.762 s after backend start]
2024-11-26 13:07:11 2024-11-26T05:07:11.987Z root INFO Backend h.configure: 0.6 ms [Finished 0.762 s after backend start]
2024-11-26 13:07:11 2024-11-26T05:07:11.987Z root INFO Backend a.configure: 0.2 ms [Finished 0.762 s after backend start]
2024-11-26 13:07:11 2024-11-26T05:07:11.987Z root INFO Backend l.configure: 0.1 ms [Finished 0.762 s after backend start]
2024-11-26 13:07:13 2024-11-26T05:07:13.134Z root INFO Theia app listening on http://127.0.0.1:62288.
2024-11-26 13:07:13 2024-11-26T05:07:13.135Z root INFO Finished starting backend application: 1147.7 ms [Finished 1.910 s after backend start]
2024-11-26 13:07:13 2024-11-26T05:07:13.148Z root WARN The local plugin referenced by local-dir:/c%3A/Users/zhouyu30/.arduinoIDE/plugins does not exist.
2024-11-26 13:07:13 2024-11-26T05:07:13.148Z root WARN The local plugin referenced by local-dir:/c%3A/Users/zhouyu30/.arduinoIDE/extensions does not exist.
2024-11-26 13:07:13 2024-11-26T05:07:13.149Z root WARN The local plugin referenced by local-dir:C:\Users\zhouyu30\.arduinoIDE\plugins does not exist.
2024-11-26 13:07:13 2024-11-26T05:07:13.200Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]}}
2024-11-26 13:07:13 2024-11-26T05:07:13.200Z config INFO Loading fallback CLI configuration to get 'directories.data' and 'directories.user'
2024-11-26 13:07:13 2024-11-26T05:07:13.242Z root INFO Resolve plugins list: 1256.5 ms [Finished 2.017 s after backend start]
2024-11-26 13:07:14 2024-11-26T05:07:14.335Z daemon INFO time="2024-11-26T13:07:14+08:00" level=info msg="arduino-cli version 1.0.4"
2024-11-26 13:07:14 2024-11-26T05:07:14.337Z daemon INFO time="2024-11-26T13:07:14+08:00" level=info msg="Using config file: c:\\Users\\zhouyu30\\.arduinoIDE\\arduino-cli.yaml"
time="2024-11-26T13:07:14+08:00" level=info msg="Executing `arduino-cli daemon`"
2024-11-26 13:07:14 2024-11-26T05:07:14.355Z daemon INFO Daemon is now listening on 127.0.0.1:62293
{"IP":"127.0.0.1","Port":"62293"}
2024-11-26 13:07:14 2024-11-26T05:07:14.355Z daemon INFO Daemon is running.
2024-11-26 13:07:14 2024-11-26T05:07:14.454Z daemon INFO time="2024-11-26T13:07:14+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-11-26 13:07:14 2024-11-26T05:07:14.794Z root INFO Deploy plugins list: 1256.5 ms [Finished 3.570 s after backend start]
2024-11-26 13:07:15 2024-11-26T05:07:15.253Z config INFO Loaded fallback CLI configuration: {"directories":{"user":"C:\\Users\\zhouyu30\\OneDrive - Faurecia\\文档\\Arduino","data":"C:\\Users\\zhouyu30\\AppData\\Local\\Arduino15"}}
2024-11-26 13:07:15 2024-11-26T05:07:15.253Z config INFO Merged CLI configuration with the fallback: {"directories":{"user":"C:\\Users\\zhouyu30\\OneDrive - Faurecia\\文档\\Arduino","data":"C:\\Users\\zhouyu30\\AppData\\Local\\Arduino15"},"board_manager":{"additional_urls":[]}}
2024-11-26 13:07:15 2024-11-26T05:07:15.253Z config INFO Loaded the CLI configuration.
2024-11-26 13:07:15 2024-11-26T05:07:15.253Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/zhouyu30/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/zhouyu30/OneDrive%20-%20Faurecia/%E6%96%87%E6%A1%A3/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-11-26 13:07:15 2024-11-26T05:07:15.253Z config INFO Validating the CLI configuration...
2024-11-26 13:07:15 2024-11-26T05:07:15.254Z config INFO The CLI config is valid.
2024-11-26 13:07:15 2024-11-26T05:07:15.254Z config INFO <<< Initialized the CLI configuration.
2024-11-26 13:07:15 2024-11-26T05:07:15.325Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc: getaddrinfow: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server.
2024-11-26 13:07:15 2024-11-26T05:07:15.326Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\zhouyu30\AppData\Local\Arduino15\package_index.json: open C:\Users\zhouyu30\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-11-26 13:07:15 2024-11-26T05:07:15.326Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-11-26 13:07:15 2024-11-26T05:07:15.326Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-11-26 13:07:15 2024-11-26T05:07:15.327Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\zhouyu30\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-11-26 13:07:15 2024-11-26T05:07:15.332Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-11-26 13:07:15 2024-11-26T05:07:15.333Z daemon INFO time="2024-11-26T13:07:15+08:00" level=info msg="Loading hardware from: C:\\Users\\zhouyu30\\AppData\\Local\\Arduino15\\packages"
time="2024-11-26T13:07:15+08:00" level=info msg="Loading libraries index file" index="C:\\Users\\zhouyu30\\AppData\\Local\\Arduino15\\library_index.json"
time="2024-11-26T13:07:15+08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\zhouyu30\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
time="2024-11-26T13:07:15+08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\zhouyu30\\OneDrive - Faurecia\\文档\\Arduino\\libraries" isSingleLibrary=false location=user
time="2024-11-26T13:07:15+08:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-11-26 13:07:15 2024-11-26T05:07:15.335Z daemon INFO time="2024-11-26T13:07:15+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
time="2024-11-26T13:07:15+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-11-26 13:07:15 2024-11-26T05:07:15.336Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-11-26 13:07:15 2024-11-26T05:07:15.337Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-11-26 13:07:15 Opening channel for service path '/services/electron-window'.
2024-11-26 13:07:15 2024-11-26T05:07:15.339Z root ERROR Failed to update platform, library indexes. Error: 13 INTERNAL: Some indexes could not be updated.
for call at
2024-11-26 13:07:15 2024-11-26T05:07:15.342Z daemon INFO time="2024-11-26T13:07:15+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-11-26 13:07:15 2024-11-26T05:07:15.343Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc: getaddrinfow: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server.
2024-11-26 13:07:15 2024-11-26T05:07:15.343Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\zhouyu30\AppData\Local\Arduino15\package_index.json: open C:\Users\zhouyu30\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-11-26 13:07:15 2024-11-26T05:07:15.344Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-11-26 13:07:15 2024-11-26T05:07:15.344Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-11-26 13:07:15 2024-11-26T05:07:15.344Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\zhouyu30\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-11-26 13:07:15 2024-11-26T05:07:15.344Z daemon INFO time="2024-11-26T13:07:15+08:00" level=info msg="Loading hardware from: C:\\Users\\zhouyu30\\AppData\\Local\\Arduino15\\packages"
2024-11-26 13:07:15 2024-11-26T05:07:15.345Z root ERROR Uncaught Exception:  Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-11-26 13:07:15 2024-11-26T05:07:15.345Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-11-26 13:07:15 Opening channel for service path '/services/ide-updater'.
2024-11-26 13:07:15 2024-11-26T05:07:15.980Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 505.6 ms [Finished 2.675 s after frontend start]
2024-11-26 13:07:15 2024-11-26T05:07:15.988Z root WARN A command editor.action.toggleStickyScroll is already registered.
type or paste code here
Hi @zhouyr. On the first run after a fresh installation, Arduino IDE downloads some additional essential components from the Internet and installs them. If it can't install those components then the startup fails. So the computer must have access to the Internet on the first startup.
The errors indicate Arduino IDE is not able to access the Internet. If it is not already, please connect your computer to the Internet, close the Arduino IDE window, then start Arduino IDE again. This time it should start up successfully.
After that first run, an Internet connection is not required. However, there are some supplemental features such as "Library Manager" that have an inherent dependency on the Internet. Those features will not be usable while your computer is offline. But the essential functionality of editing, compiling, and uploading sketches will be available even without an Internet connection.
Hello, can I install the additional essential components manually? the Arduino IDE don't have access to the internet in my network.
Do you have access to another Windows computer that can provide Arduino IDE with Internet access? If so, you could run Arduino IDE on that computer, then copy the downloaded files over to the other computer that doesn't provide Internet access. That would be the most simple solution.
If this approach is feasible, let me know and I'll provide instructions you can follow to do it.
I don't have the computer can provide Arduino IDE with internet access now, but I can use the current computer to download files by browser
the problem is solved, I set a proxy for Arduino IDE, thanks for your support
I'm glad it is working now. Thanks for taking the time to post an update!
Regards, Per
