Hi there!
As title suggests, installing Arduino IDE on a XPS laptop results in application getting stuck on pulsing logo screen. Full details below:
PS C:\Program Files\arduino-ide> & ".\Arduino IDE"
Arduino IDE 2.3.3
Checking for frontend application configuration customizations. Module path: C:\Program Files\arduino-ide\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\arduino-ide\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.3" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.0.4" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-09-25T09:41:18.242Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.3","cliVersion":"1.0.4","buildDate":"2024-09-25T09:41:18.242Z"}
Starting backend process. PID: 21728
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/msavvides/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-09-30T08:49:50.945Z root INFO Backend Object.initialize: 6.2 ms [Finished 0.703 s after backend start]
2024-09-30T08:49:50.977Z root INFO Backend Object.configure: 5.0 ms [Finished 0.703 s after backend start]
2024-09-30T08:49:50.977Z root INFO Backend a.onStart: 1.8 ms [Finished 0.703 s after backend start]
2024-09-30T08:49:50.978Z root INFO Backend a.configure: 0.4 ms [Finished 0.729 s after backend start]
2024-09-30T08:49:50.979Z root INFO Backend d.onStart: 0.3 ms [Finished 0.729 s after backend start]
2024-09-30T08:49:50.981Z root INFO Backend d.configure: 0.1 ms [Finished 0.729 s after backend start]
2024-09-30T08:49:50.983Z root INFO Backend d.initialize: 25.6 ms [Finished 0.729 s after backend start]
2024-09-30T08:49:50.983Z root INFO Backend c.onStart: 0.3 ms [Finished 0.729 s after backend start]
2024-09-30T08:49:50.984Z root INFO Backend s.configure: 32.1 ms [Finished 0.761 s after backend start]
2024-09-30T08:49:50.987Z config INFO >>> Initializing CLI configuration...
2024-09-30T08:49:50.988Z root INFO Backend c.initialize: 1.1 ms [Finished 0.762 s after backend start]
2024-09-30T08:49:50.988Z root INFO Backend x.onStart: 1.5 ms [Finished 0.763 s after backend start]
2024-09-30T08:49:50.990Z config INFO Loading CLI configuration from c:\Users\msavvides\.arduinoIDE\arduino-cli.yaml...
2024-09-30T08:49:50.991Z daemon INFO Starting daemon from C:\Program Files\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-30T08:49:50.991Z root INFO Backend s.initialize: 0.7 ms [Finished 0.765 s after backend start]
2024-09-30T08:49:50.991Z root INFO Backend w.onStart: 2.5 ms [Finished 0.767 s after backend start]
2024-09-30T08:49:50.991Z root INFO Backend r.configure: 4.0 ms [Finished 0.767 s after backend start]
2024-09-30T08:49:50.991Z discovery-log INFO start
2024-09-30T08:49:50.991Z discovery-log INFO start new deferred
2024-09-30T08:49:50.991Z root INFO Backend d.initialize: 1.2 ms [Finished 0.768 s after backend start]
2024-09-30T08:49:50.991Z root INFO Backend y.onStart: 4.1 ms [Finished 0.771 s after backend start]
2024-09-30T08:49:50.991Z root INFO Backend r.configure: 3.2 ms [Finished 0.772 s after backend start]
2024-09-30T08:49:50.991Z root INFO Backend s.onStart: 0.9 ms [Finished 0.774 s after backend start]
2024-09-30T08:49:50.991Z root INFO Backend h.configure: 0.8 ms [Finished 0.774 s after backend start]
2024-09-30T08:49:50.991Z root INFO Backend a.configure: 0.3 ms [Finished 0.775 s after backend start]
2024-09-30T08:49:50.991Z root INFO Backend l.configure: 0.1 ms [Finished 0.775 s after backend start]
2024-09-30T08:49:50.996Z root INFO Theia app listening on http://127.0.0.1:57597.
2024-09-30T08:49:50.996Z root INFO Finished starting backend application: 5.4 ms [Finished 0.780 s after backend start]
2024-09-30T08:49:51.023Z root WARN The local plugin referenced by local-dir:/c%3A/Users/msavvides/.arduinoIDE/plugins does not exist.
2024-09-30T08:49:51.024Z root WARN The local plugin referenced by local-dir:/c%3A/Users/msavvides/.arduinoIDE/extensions does not exist.
2024-09-30T08:49:51.024Z root WARN The local plugin referenced by local-dir:C:\Users\msavvides\.arduinoIDE\plugins does not exist.
2024-09-30T08:49:51.075Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]}}
2024-09-30T08:49:51.075Z config INFO Loading fallback CLI configuration to get 'directories.data' and 'directories.user'
2024-09-30T08:49:51.170Z root INFO Resolve plugins list: 180.8 ms [Finished 0.953 s after backend start]
2024-09-30T08:49:52.673Z daemon INFO time="2024-09-30T09:49:52+01:00" level=info msg="arduino-cli version 1.0.4"
time="2024-09-30T09:49:52+01:00" level=info msg="Using config file: c:\\Users\\msavvides\\.arduinoIDE\\arduino-cli.yaml"
time="2024-09-30T09:49:52+01:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:57601
{"IP":"127.0.0.1","Port":"57601"}
2024-09-30T08:49:52.673Z daemon INFO Daemon is running.
2024-09-30T08:49:52.674Z config INFO Loaded fallback CLI configuration: {"directories":{"user":"C:\\Users\\msavvides\\OneDrive - Haberdashers' Elstree Schools\\Documents\\Arduino","data":"C:\\Users\\msavvides\\AppData\\Local\\Arduino15"}}
2024-09-30T08:49:52.674Z config INFO Merged CLI configuration with the fallback: {"directories":{"user":"C:\\Users\\msavvides\\OneDrive - Haberdashers' Elstree Schools\\Documents\\Arduino","data":"C:\\Users\\msavvides\\AppData\\Local\\Arduino15"},"board_manager":{"additional_urls":[]}}
2024-09-30T08:49:52.674Z config INFO Loaded the CLI configuration.
2024-09-30T08:49:52.681Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/msavvides/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/msavvides/OneDrive%20-%20Haberdashers%27%20Elstree%20Schools/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-09-30T08:49:52.681Z config INFO Validating the CLI configuration...
2024-09-30T08:49:52.683Z config INFO The CLI config is valid.
2024-09-30T08:49:52.683Z config INFO <<< Initialized the CLI configuration.
2024-09-30T08:49:52.692Z root ERROR Uncaught Exception: Error: 13 INTERNAL: Received RST_STREAM with code 0
2024-09-30T08:49:52.692Z root ERROR Error: 13 INTERNAL: Received RST_STREAM with code 0
at t.callErrorFromStatus (C:\Program Files\arduino-ide\resources\app\lib\backend\main.js:2:912720)
at Object.onReceiveStatus (C:\Program Files\arduino-ide\resources\app\lib\backend\main.js:2:938041)
at Object.onReceiveStatus (C:\Program Files\arduino-ide\resources\app\lib\backend\main.js:2:933919)
at Object.onReceiveStatus (C:\Program Files\arduino-ide\resources\app\lib\backend\main.js:2:933364)
at C:\Program Files\arduino-ide\resources\app\lib\backend\main.js:2:1019505
at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
at a.makeUnaryRequest (C:\Program Files\arduino-ide\resources\app\lib\backend\main.js:2:937582)
at a.create (C:\Program Files\arduino-ide\resources\app\lib\backend\main.js:2:1004397)
at instance (C:\Program Files\arduino-ide\resources\app\lib\backend\main.js:2:769581)
at new Promise (<anonymous>)
at v.createClient (C:\Program Files\arduino-ide\resources\app\lib\backend\main.js:2:769558)
at v.create (C:\Program Files\arduino-ide\resources\app\lib\backend\main.js:2:768466)
at C:\Program Files\arduino-ide\resources\app\lib\backend\main.js:2:767362
at C:\Program Files\arduino-ide\resources\app\lib\backend\main.js:2:1212097
at i.invoke (C:\Program Files\arduino-ide\resources\app\lib\backend\main.js:2:1212187)
at a.fire (C:\Program Files\arduino-ide\resources\app\lib\backend\main.js:2:1213990)
2024-09-30T08:49:52.931Z root INFO Deploy plugins list: 180.8 ms [Finished 2.714 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-09-30T08:49:53.543Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 194.1 ms [Finished 2.370 s after frontend start]
2024-09-30T08:49:53.543Z root WARN A command editor.action.toggleStickyScroll is already registered.
Any help would be appreciated, I've tried uninstalling / reinstalling, deleting Arduino15 and related folders and tried to use to Arduino CLI to update Arduino with no success.
