2024-06-15 22:24:19 Arduino IDE 2.3.2
2024-06-15 22:24:19 Checking for frontend application configuration customizations. Module path: C:\Users\Σπύρος\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\Σπύρος\AppData\Local\Programs\Arduino IDE\resources\app\package.json
2024-06-15 22:24:19 Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
2024-06-15 22:24:19 Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
2024-06-15 22:24:19 Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
2024-06-15 22:24:19 Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
2024-06-15 22:24:19 Starting backend process. PID: 1556
2024-06-15 22:24:20 Using browser-only version of superagent in non-browser environment
2024-06-15 22:24:20 Configuration directory URI: 'file:///c%3A/Users/%CE%A3%CF%80%CF%8D%CF%81%CE%BF%CF%82/.arduinoIDE'
2024-06-15 22:24:20 Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-06-15 22:24:20 2024-06-15T19:24:20.869Z root INFO Backend Object.initialize: 6.6 ms [Finished 0.940 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.870Z root INFO Backend Object.configure: 5.5 ms [Finished 0.940 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.870Z root INFO Backend s.onStart: 2.8 ms [Finished 0.940 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.871Z root INFO Backend s.configure: 0.5 ms [Finished 0.983 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.873Z root INFO Backend d.onStart: 0.4 ms [Finished 0.983 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.874Z root INFO Backend d.configure: 0.2 ms [Finished 0.984 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.875Z root INFO Backend d.initialize: 43.3 ms [Finished 0.984 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.875Z root INFO Backend c.onStart: 0.5 ms [Finished 0.984 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.876Z root INFO Backend a.configure: 1.9 ms [Finished 0.986 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.878Z config INFO >>> Initializing CLI configuration...
2024-06-15 22:24:20 2024-06-15T19:24:20.879Z root INFO Backend c.initialize: 0.9 ms [Finished 0.987 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.879Z root INFO Backend R.onStart: 1.4 ms [Finished 0.988 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.880Z config INFO Loading CLI configuration from c:\Users\Σπύρος\.arduinoIDE\arduino-cli.yaml...
2024-06-15 22:24:20 2024-06-15T19:24:20.881Z daemon INFO Starting daemon from C:\Users\Σπύρος\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-06-15 22:24:20 2024-06-15T19:24:20.881Z root INFO Backend a.initialize: 0.6 ms [Finished 0.989 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.881Z root INFO Backend w.onStart: 1.8 ms [Finished 0.991 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.881Z root INFO Backend r.configure: 3.0 ms [Finished 0.991 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.881Z discovery-log INFO start
2024-06-15 22:24:20 2024-06-15T19:24:20.882Z discovery-log INFO start new deferred
2024-06-15 22:24:20 2024-06-15T19:24:20.882Z root INFO Backend d.initialize: 0.8 ms [Finished 0.992 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.882Z root INFO Backend y.onStart: 2.9 ms [Finished 0.994 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.882Z root INFO Backend r.configure: 2.3 ms [Finished 0.994 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.882Z root INFO Backend a.onStart: 0.9 ms [Finished 0.997 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.882Z root INFO Backend h.configure: 0.8 ms [Finished 0.997 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.882Z root INFO Backend s.configure: 0.3 ms [Finished 0.997 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.882Z root INFO Backend l.configure: 0.2 ms [Finished 0.997 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.887Z root INFO Theia app listening on http://127.0.0.1:56251.
2024-06-15 22:24:20 2024-06-15T19:24:20.887Z root INFO Finished starting backend application: 5.5 ms [Finished 1.002 s after backend start]
2024-06-15 22:24:20 2024-06-15T19:24:20.908Z root WARN The local plugin referenced by local-dir:/c%3A/Users/%CE%A3%CF%80%CF%8D%CF%81%CE%BF%CF%82/.arduinoIDE/plugins does not exist.
2024-06-15 22:24:20 2024-06-15T19:24:20.909Z root WARN The local plugin referenced by local-dir:/c%3A/Users/%CE%A3%CF%80%CF%8D%CF%81%CE%BF%CF%82/.arduinoIDE/extensions does not exist.
2024-06-15 22:24:20 2024-06-15T19:24:20.909Z root WARN The local plugin referenced by local-dir:C:\Users\Σπύρος\.arduinoIDE\plugins does not exist.
2024-06-15 22:24:21 2024-06-15T19:24:20.962Z root INFO Resolve plugins list: 82.2 ms [Finished 1.077 s after backend start]
2024-06-15 22:24:21 2024-06-15T19:24:21.271Z daemon INFO time="2024-06-15T22:24:21+03:00" level=info msg="Config file not found, using default values"
time="2024-06-15T22:24:21+03:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-06-15T22:24:21+03:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:56252
{"IP":"127.0.0.1","Port":"56252"}
2024-06-15 22:24:21 2024-06-15T19:24:21.271Z daemon INFO Daemon is running.
2024-06-15 22:24:21 2024-06-15T19:24:21.279Z root INFO Error: Error executing C:\Users\Σπύρος\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe config init --dest-dir c:\Users\Σπύρος\.arduinoIDE: Error: invalid path creating config dir: C:\Users\???????????,\AppData\Local\Arduino15 error: mkdir C:\Users\???????????,: The filename, directory name, or volume label syntax is incorrect.
at ChildProcess.<anonymous> (C:\Users\Σπύρος\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:639804)
at ChildProcess.emit (node:events:514:28)
at Process.onexit (node:internal/child_process:291:12)
2024-06-15 22:24:21 2024-06-15T19:24:21.286Z config ERROR Failed to initialize the CLI configuration. Error: Error executing C:\Users\Σπύρος\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe config init --dest-dir c:\Users\Σπύρος\.arduinoIDE: Error: invalid path creating config dir: C:\Users\???????????,\AppData\Local\Arduino15 error: mkdir C:\Users\???????????,: The filename, directory name, or volume label syntax is incorrect.
2024-06-15 22:24:21 2024-06-15T19:24:21.540Z daemon INFO time="2024-06-15T22:24:21+03:00" level=info msg="Checking signature" index="C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2024-06-15T22:24:21+03:00" level=info msg="Loading hardware from: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages"
time="2024-06-15T22:24:21+03:00" level=info msg="Loading package MegaCore from: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\MegaCore\\hardware"
time="2024-06-15T22:24:21+03:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded platform" platform="MegaCore:avr@3.0.1"
time="2024-06-15T22:24:21+03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\MegaCore\\tools"
time="2024-06-15T22:24:21+03:00" level=info msg="Loading tools from dir: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\MegaCore\\tools"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="MegaCore:avrdude@7.2-arduino.1"
time="2024-06-15T22:24:21+03:00" level=info msg="Loading package MightyCore from: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded platform" platform="MightyCore:avr@3.0.1"
time="2024-06-15T22:24:21+03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\MightyCore\\tools"
time="2024-06-15T22:24:21+03:00" level=info msg="Loading tools from dir: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\MightyCore\\tools"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="MightyCore:avrdude@7.2-arduino.1"
time="2024-06-15T22:24:21+03:00" level=info msg="Loading package arduino from: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
time="2024-06-15T22:24:21+03:00" level=info msg="Missing signature file" index="C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2024-06-15T22:24:21+03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-06-15T22:24:21+03:00" level=info msg="Loading tools from dir: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2024-06-15T22:24:21+03:00" level=info msg="Loading package builtin from: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2024-06-15T22:24:21+03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-06-15T22:24:21+03:00" level=info msg="Loading tools from dir: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2024-06-15T22:24:21+03:00" level=info msg="Loading package esp32 from: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
2024-06-15 22:24:21 2024-06-15T19:24:21.781Z daemon INFO time="2024-06-15T22:24:21+03:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded platform" platform="esp32:esp32@2.0.16"
time="2024-06-15T22:24:21+03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-06-15T22:24:21+03:00" level=info msg="Loading tools from dir: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.5.1"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.12.0-esp32-20230921"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-06-15 22:24:21 2024-06-15T19:24:21.782Z daemon INFO time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-06-15 22:24:21 2024-06-15T19:24:21.800Z daemon INFO time="2024-06-15T22:24:21+03:00" level=info msg="Loading package esp8266 from: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware"
2024-06-15 22:24:22 2024-06-15T19:24:22.016Z daemon INFO time="2024-06-15T22:24:21+03:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded platform" platform="esp8266:esp8266@3.1.2"
time="2024-06-15T22:24:21+03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2024-06-15T22:24:21+03:00" level=info msg="Loading tools from dir: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="esp8266:python3@3.7.2-post1"
time="2024-06-15T22:24:21+03:00" level=info msg="Loaded tool" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
time="2024-06-15T22:24:21+03:00" level=info msg="Loading package rp2040 from: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware"
2024-06-15 22:24:22 2024-06-15T19:24:22.115Z daemon INFO time="2024-06-15T22:24:22+03:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-06-15T22:24:22+03:00" level=info msg="Loaded platform" platform="rp2040:rp2040@3.8.0"
time="2024-06-15T22:24:22+03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools"
time="2024-06-15T22:24:22+03:00" level=info msg="Loading tools from dir: C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools"
time="2024-06-15T22:24:22+03:00" level=info msg="Loaded tool" tool="rp2040:pqt-elf2uf2@2.2.0-d04e724"
time="2024-06-15T22:24:22+03:00" level=info msg="Loaded tool" tool="rp2040:pqt-gcc@2.2.0-d04e724"
time="2024-06-15T22:24:22+03:00" level=info msg="Loaded tool" tool="rp2040:pqt-mklittlefs@2.2.0-d04e724"
time="2024-06-15T22:24:22+03:00" level=info msg="Loaded tool" tool="rp2040:pqt-openocd@2.2.0-d04e724"
time="2024-06-15T22:24:22+03:00" level=info msg="Loaded tool" tool="rp2040:pqt-picotool@2.2.0-d04e724"
time="2024-06-15T22:24:22+03:00" level=info msg="Loaded tool" tool="rp2040:pqt-pioasm@2.2.0-d04e724"
time="2024-06-15T22:24:22+03:00" level=info msg="Loaded tool" tool="rp2040:pqt-python3@1.0.1-base-3a57aed"
time="2024-06-15T22:24:22+03:00" level=info msg="Searching tools required for platform rp2040:rp2040@3.8.0"
time="2024-06-15T22:24:22+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\MegaCore\\hardware\\avr\\3.0.1\\libraries" location=platform
time="2024-06-15T22:24:22+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\3.0.1\\libraries" location=platform
2024-06-15 22:24:22 2024-06-15T19:24:22.141Z daemon INFO time="2024-06-15T22:24:22+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries" location=platform
time="2024-06-15T22:24:22+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
2024-06-15 22:24:22 2024-06-15T19:24:22.153Z daemon INFO time="2024-06-15T22:24:22+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.16\\libraries" location=platform
2024-06-15 22:24:22 2024-06-15T19:24:22.235Z daemon INFO time="2024-06-15T22:24:22+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.8.0\\libraries" location=platform
time="2024-06-15T22:24:22+03:00" level=info msg="Loading libraries index file" index="C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\library_index.json"
2024-06-15 22:24:22 2024-06-15T19:24:22.861Z daemon INFO time="2024-06-15T22:24:22+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Σπύρος\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-06-15T22:24:22+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Σπύρος\\Documents\\Arduino\\libraries" location=user
2024-06-15 22:24:23 2024-06-15T19:24:23.229Z root INFO Deploy plugins list: 82.2 ms [Finished 3.344 s after backend start]
2024-06-15 22:24:24 Opening channel for service path '/services/electron-window'.
2024-06-15 22:24:24 Opening channel for service path '/services/ide-updater'.
2024-06-15 22:24:24 2024-06-15T19:24:24.669Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 344.0 ms [Finished 3.382 s after frontend start]
2024-06-15 22:24:24 2024-06-15T19:24:24.669Z root WARN A command editor.action.toggleStickyScroll is already registered.
I suspect that the IDE does not like your username as it contains non-ascii characters. It's a known issue.
Can you create an other user on the PC with e.g. the name that you use on the forum? And see if you can install and start the IDE under that user?
Thank you.
You're right
