I am in the process of mounting my first project in a project box, and could really use some inspiration as to how this can be done.
The project consists of:
Some buttons and leds
A handful of breakout boards (SD, GPS, Accelerometer, OBD)
LiPO charger and battery
The plan was to include a solder breadboard with the buttons, leds and the small breakout boards. While the larger breakout boards are fixed to the box and connected to the main board with cables.
But I could really use some recommendations as to how breakout boards are normally handled/fixed in a project box, and perhaps some pictures of how others have done it.
You can even buy project boxes with soldered PCBs already made for them:
Sometimes parts are affixed to the board so that when things like potentiometers and jacks are screwed into the case, they are all at the proper height and all LEDs and displays are in the proper place and height. In that case, the parts are the board mount. It can be a bit tricky to get that correct.
Something similar can be done using short wires between the things mounted in the front panel and the board. Not nearly as critical, and you are simply relying on the very short wires to make up for any inaccuracies but be short and stiff enough to hold the board.
Obviously, not good for anything heavy on the board, like a large heat sink.
Sometimes, boards are held in by parts being mounted on a heatsink, and the heatsink is bolted down. Again, nothing heavy on the board like large electrolytic capacitors or large toroids, or you should also be using standoffs and mounting the board properly.
Having the board hanging by stiff wires or component leads isn't good if this is something exposed to a lot of vibration. In cases like that, for instance automotive use, use only stranded flexible wire and mount the board on standoffs, possibly even using rubber standoffs.
I have found that it is a good idea to use a bit of ribbon cable between LCD displays and the main board. Otherwise, normal knocking around can flex the LCD board from the weight and torque of the main board pulling on its connector, and there is only a conductive silicone ribbon between the LCD glass itself and the LCD driver board. Flexing that can make it unreliable.
I am not too keen on have bolts/screws through the case to hold the boards within, so I am contemplating either just gluing the bolts to the inside of the case, or use some kind of strong double sided tape.
What I always do is build the entire project on a "sub plate", then when it's finished I attach the subplate to the bottom of the project box.
Round-headed bolts look pretty awful, but if you use countersink bits and compatible screws, you can put the mounts on one side (like the bottom) and it's really unobtrusive.
If you have access to a place that has a large inventory of fasteners (check for a Fastenal in your town -- there's one here in Anchorage, AK, if you can believe that...), go there and see what they have. I picked up a few boxes of small (#6, plus or minus a few sizes) machine screws and compatible lock-nuts, in black, with countersink Allen heads. I think they look sharp.
As it is now, I need to mount breakout boards/breadboards to both the bottom and the lid of the box. If I have bolts/screws popping out all over that would look quite messy. Also I risk scratching whatever I put the box on (my car for example ).
SirNickity:
I had not considered countersunk screws, that was an excellent idea! Thanks.
SirNickity:
I live in Denmark, so the nearest Fastenal may be a bit far away. But we have comparable shops, so I will go hunting tomorrow
Krupski:
That would make for a very clean installation, much cleaner than what I am planning. Hmmm, I would need a "two story" sub plate to fit all the stuff, but that might actually be doable.
