I've got an Arduino Yun and I'm working on a Sparkfun tutorial that is not completely working for me. In this tutorial you use the Yun to send information to a sparkfun datastream, this is mine. Specifically, you are supposed to set a variable called "name" using the console interface. Before I post my code I've got to mention that the code posted on the sparkfun site uses "serial" not "console" intending for the user to connect to the Yun via a USB cable and I am connecting via wifi. After scratching my head a little I found that all I needed to do to get it to work (or at least get to the point I'm at) was replace "Serial" with "Console" in the code... meaning if I saw "Serial.begin" it would be replaced with "Console.begin".
The attached screenshot shows the console interface, and specifically that when I've entered a name that the name is echoed back to me as expected by the "if (Console.available())" section, however that variable gets set to "" when curl sends "name" to the stream. Also worth noting is that the default name does get posted by curl if I do not override it at the console.
Thanks!!
Here is the code:
Phant_Yun.ino
Post data to SparkFun's data stream server system (phant) using
an Arduino Yun
Jim Lindblom @ SparkFun Electronics
Original Creation Date: July 3, 2014
This sketch uses an Arduino Yun to POST sensor readings to
SparkFun's data logging streams (http://data.sparkfun.com). A post
will be initiated whenever pin 3 is connected to ground.
Make sure you fill in your data stream's public, private, and data
keys before uploading! These are in the global variable section.
Hardware Hookup:
* These components are connected to the Arduino's I/O pins:
* D3 - Active-low momentary button (pulled high internally)
* A0 - Photoresistor (which is combined with a 10k resistor
to form a voltage divider output to the Arduino).
* D5 - SPST switch to select either 5V or 0V to this pin.
* Your Yun should also, somehow, be connected to the Internet.
You can use Ethernet, or the on-board WiFi module.
Development environment specifics:
IDE: Arduino 1.5.6-r2
Hardware Platform: Arduino Yun
This code is beerware; if you see me (or any other SparkFun
employee) at the local, and you've found our code helpful, please
buy us a round!
curl example from:
https://github.com/sparkfun/phant/blob/master/examples/sh/curl_post.sh
Distributed as-is; no warranty is given.
// Process.h gives us access to the Process class, which can be
// used to construct Shell commands and read the response.
#include <Process.h>
#include <Console.h>
// Phant Stuff //
// URL to phant server (only change if you're not using data.sparkfun
String phantURL = "http://data.sparkfun.com/input/";
// Public key (the one you see in the URL):
String publicKey = "ZG02gWXDGvcjxvjZ6JMj";
// Private key, which only someone posting to the stream knows
String privateKey = "NOTTHEPRIVATEKEY";
// How many data fields are in your stream?
const int NUM_FIELDS = 3;
// What are the names of your fields?
String fieldName[NUM_FIELDS] = {"light", "switch", "name"};
// We'll use this array later to store our field data
String fieldData[NUM_FIELDS];
// Pin Inputs //
const int triggerPin = 3;
const int lightPin = A0;
const int switchPin = 5;
String name = "anon"; //this is the default name
boolean newName = true;
// initialize serial communication:
Bridge.begin();
Console.begin();
// Setup Input Pins:
pinMode(triggerPin, INPUT_PULLUP);
pinMode(switchPin, INPUT_PULLUP);
pinMode(lightPin, INPUT_PULLUP);
while (!Console){
; // wait for Console port to connect.
Console.println("=========== Ready to Stream ===========");
Console.println("Press the button (D3) to send an update");
Console.println("Type your name, followed by '!' to update name");
// If the trigger pin (3) goes low, send the data.
if (!digitalRead(triggerPin))
// Gather Data
fieldData[0] = String(analogRead(lightPin));
fieldData[1] = String(digitalRead(switchPin));
fieldData[2] = name;
// Post Data
Console.println("Posting Data!");
postData(); // the postData() function does all the work,
// see below.
// Check for a new name input:
char c = Console.read();
if (c == '!')
newName = true;
Console.print("Your name is ");
Console.println(name);
else if (newName)
newName = false;
name = "";
name += c;
name += c;
void postData()
Process phant; // Used to send command to Shell, and view response
String curlCmd; // Where we'll put our curl command
String curlData[NUM_FIELDS]; // temp variables to store curl data
// Construct curl data fields
// Should look like: --data "fieldName=fieldData"
for (int i=0; i<NUM_FIELDS; i++)
curlData[i] = "--data \"" + fieldName[i] + "=" + fieldData[i] + "\" ";
// Construct the curl command:
curlCmd = "curl ";
curlCmd += "--header "; // Put our private key in the header.
curlCmd += "\"Phant-Private-Key: "; // Tells our server the key is coming
curlCmd += privateKey;
curlCmd += "\" "; // Enclose the entire header with quotes.
curlCmd += curlData[i]; // Add our data fields to the command
curlCmd += phantURL + publicKey; // Add the server URL, including public key
// Send the curl command:
Console.print("Sending command: ");
Console.println(curlCmd); // Print command for debug
phant.runShellCommand(curlCmd); // Send command through Shell
// Read out the response:
Console.print("Response: ");
// Use the phant process to read in any response from Linux:
while (phant.available())
char c = phant.read();
Console.write(c);
