IMU 9Dof with Arduino Micro
Somebody correct me if im wrong with my connection of my 9Dof IMU Sensor stick ( Sparkfun ) and my Arduino Micro board..
My connection:
IMU : Arduino
SCL : Digital Pin 3
SDA : Digital Pin 2
GND : GND
Vcc : 3V
with 2 4.7k Ohms pull-up resistor to each of the SDA SCL pin with 3v.
I need a confirmation here please.
Thank you in advance!
#include <Adafruit_Sensor.h>
#include <Wire.h>
#define ADXL345_ADDRESS (0XA6 >> 1)
#define ADXL345_REGISTER_XLSB (0x32)
#define ADXL_REGISTER_PWRCTL (0x2D)
#define ADXL_PWRCTL_MEASURE (1 << 3)
#define ITG3200_ADDRESS (0xD0 >> 1)
#define ITG3200_REGISTER_XMSB (0x1D)
#define ITG3200_REGISTER_DLPF_FS (0x16)
#define ITG3200_FULLSCALE (0x03 << 3)
#define ITG3200_42HZ (0x03)
#define HMC5843_ADDRESS (0x3C >> 1)
#define HMC5843_REGISTER_XMSB (0x03)
#define HMC5843_REGISTER_MEASMODE (0x02)
#define HMC5843_MEASMODE_CONT (0x00)
int accelerometer_data[3];
int gyro_data[3];
int magnetometer_data[3];
char c;
  Wire.begin();
  for(int i = 0; i < 3; ++i) {
    accelerometer_data[i] = magnetometer_data[i] = gyro_data[i] = 0;
  init_adxl345();
  init_hmc5843();
  init_itg3200();
   read_adxl345();
   Serial.print("ACCEL: ");
   Serial.print(accelerometer_data[0]);
   Serial.print("\t");
   Serial.print(accelerometer_data[1]);
   Serial.print("\t");
   Serial.print(accelerometer_data[2]);
   Serial.print("\t");
   read_hmc5843();
   Serial.print("MAG: ");
   Serial.print(magnetometer_data[0]);
   Serial.print(",");
   Serial.print(magnetometer_data[1]);
   Serial.print(",");
   Serial.print(magnetometer_data[2]);
   Serial.print("\t");
   read_itg3200();
   Serial.print("GYRO: ");
   Serial.print(gyro_data[0]);
   Serial.print("\t");
   Serial.print(gyro_data[1]);
   Serial.print("\t");
   Serial.print(gyro_data[2]);
   Serial.print("\n");
   delay(100);
void i2c_write(int address, byte reg, byte data) {
  Wire.beginTransmission(address);
  Wire.write(reg);
  Wire.write(data);
  Wire.endTransmission();
void i2c_read(int address, byte reg, int count, byte* data) {
 int i = 0;
 Wire.write(reg);
 Wire.requestFrom(address,count);
 while(Wire.available()){
   c = Wire.read();
   data[i] = c;
   i++;
void init_adxl345() {
  byte data = 0;
  i2c_write(ADXL345_ADDRESS, ADXL_REGISTER_PWRCTL, ADXL_PWRCTL_MEASURE);
  i2c_read(ADXL345_ADDRESS, ADXL_REGISTER_PWRCTL, 1, &data);
  Serial.println((unsigned int)data);
void read_adxl345() {
 byte bytes[6];
 memset(bytes,0,6);
 i2c_read(ADXL345_ADDRESS, ADXL345_REGISTER_XLSB, 6, bytes);
 for (int i=0;i<3;++i) {
 accelerometer_data[i] = (int)bytes[2*i] + (((int)bytes[2*i + 1]) << 8);
void init_itg3200() {
  byte data = 0;
  i2c_write(ITG3200_ADDRESS, ITG3200_REGISTER_DLPF_FS, ITG3200_FULLSCALE | ITG3200_42HZ);
  i2c_read(ITG3200_ADDRESS, ITG3200_REGISTER_DLPF_FS, 1, &data);
void read_itg3200() {
  byte bytes[6];
  memset(bytes,0,6);
  i2c_read(ITG3200_ADDRESS, ITG3200_REGISTER_XMSB, 6, bytes);
  gyro_data[i] = (int)bytes[2*i + 1] + (((int)bytes[2*i]) << 8);
void init_hmc5843() {
  byte data = 0;
  i2c_write(HMC5843_ADDRESS, HMC5843_REGISTER_MEASMODE, HMC5843_MEASMODE_CONT);
  i2c_read(HMC5843_ADDRESS, HMC5843_REGISTER_MEASMODE, 1, &data);
void read_hmc5843() {
 byte bytes[6];
 memset(bytes,0,6);
 i2c_read(HMC5843_ADDRESS, HMC5843_REGISTER_XMSB, 6, bytes);
 magnetometer_data[i] = (int)bytes[2*i + 1] + (((int)bytes[2*i]) << 8);
Correct..
Connect the SCL pin on the breakout to the SCL pin on your Arduino. On an UNO & '328 based Arduino, this is also known as A5, on a Mega it is also known as digital 21 and on a Leonardo/Micro, digital 3
Connect the SDA pin on the breakout to the SDA pin on your Arduino. On an UNO & '328 based Arduino, this is also known as A4, on a Mega it is also known as digital 20 and on a Leonardo/Micro, digital 2
Connect the VIN pin on the breakout to 3.3V or 5V on your Uno (5V is preferred but if you have a 3V logic Arduino 3V is best)
Connect the GND pin on the breakout to the GND pin on your Uno
That's it! With those four wires, you should be able to talk to any of the I2C chips on the board and run any of the example sketches.
[u]https://learn.adafruit.com/adafruit-9-dof-imu-breakout/connecting-it-up[/u]
