Incompatible ADC readings with the RES and Voltage Ref
I am using the PortentaH7 ADC to sample a signal however the results I get are way too different from what I should get with the RES and Ref Voltage that I use (for exemple the value I should get for 0V should be around 0000 0000 0000 0000 on a 16 bit RES yet I get values around 0000 0001 1111 0100). I wonder why I do get these values beacause aside from not giving me coherent values the signal form is perfectly fine... . Here a pic for a 12 bit Res with a 1V offset on the signal and 1V amplitude for 2.5V ref:
issue RES square
I wonder if anyone has faced this issue up till now and if not could someone test my code on his own portentaH7 to check wether the issue comes from my code or my board. The code :
//////////////////////////////////////CORE_CM7////////////////////////////////////
#ifdef CORE_CM7
#define HSEM_ID_INIT 0
#define HSEM_PROCESS_INIT 0
#define HSEM_ID_DATA 1
#define HSEM_PROCESS_DATA 1
#define HSEM_ID_RDY 2
#define HSEM_PROCESS_RDY 2
#define HSEM_ID_RST 3
#define HSEM_PROCESS_RST 3
#define HSEM_ID_FRQ 4
#define HSEM_PROCESS_FRQ 4
#define HSEM_ID_RDYM 5
#define HSEM_PROCESS_RDYM 5
/*************************Variable*************************/
int readyP = 0;
int initt = 0;
int freq = 0;
int readyM4 = 0;
String chaineF;
/**************************Shared struct********************/
struct shared_data
  uint8_t datReady1;
  uint8_t datInit;
  uint32_t datFreq;
  uint8_t datReset;
  uint8_t datReady;
  //uint32_t val;//status : 1=transfer complete 0=waiting
  uint32_t data_M4toM7[3];
  uint8_t sts_transfer;//status : 1=transfer complete 0=waiting
  uint8_t sts_buff1_or2; // status : 1=M7toM4_1, 0=M7toM4_2
  uint8_t sts_4to7; // status: 0 = no fluo, 1 = fluo, 2 = waiting for fluo
  //uint8_t sts_7to4; // status: 0 = empty, 1 = has data, 2 = locked (CM7-CM4)
  uint16_t M7toM4_1[10]; // bytes from CM7 to CM4 DMA1
  uint16_t M7toM4_2[10]; // bytes from CM7 to CM4 DMA2
volatile struct shared_data * const buff = (struct shared_data *)0x38001000;
/*************************function headers*********************/
void setupLabviewM7();
/**************************setup*******************************/
  LL_RCC_ForceCM4Boot();
  setupLabviewM7();
/****************************loop******************************/
  /*******************Poll for Reset order*******************/
  if (Serial.available() > 0) {
    char incomingByte = Serial.read();
    if (incomingByte == 'z') {
      while (HAL_HSEM_Take(HSEM_ID_RST, HSEM_PROCESS_RST) != HAL_OK) {};
      SCB_CleanInvalidateDCache_by_Addr(buff, sizeof(*buff));
      buff->datReset = 1;
      SCB_CleanDCache_by_Addr(buff, sizeof(*buff));
      HAL_HSEM_Release(HSEM_ID_RST, HSEM_PROCESS_RST);
      Serial.println("reseting");
      setupLabviewM7();
  /*****************Serial print values************************/
  while (HAL_HSEM_Take(HSEM_ID_DATA, HSEM_PROCESS_DATA) != HAL_OK) {};
  chaineF = (String)buff->data_M4toM7[0] + "|" + (String)buff->data_M4toM7[1] + "|" + (String)buff->data_M4toM7[2];
  HAL_HSEM_Release(HSEM_ID_DATA, HSEM_PROCESS_DATA);
  Serial.println(chaineF);
/*****************SETUP FUNCTION CM7***********************/
void setupLabviewM7(void) {
  readyM4 = 0;
  readyP = 0;
  initt = 0;
  freq = 0;
  /***************LABVIEW COM**************/
  while (initt != 1) { //Check message from Labview before starting!
      if (incomingByte == 'i') {
        initt = 1;
        while (HAL_HSEM_Take(HSEM_ID_INIT, HSEM_PROCESS_INIT) != HAL_OK) {};
        buff->datInit = 1;
        HAL_HSEM_Release(HSEM_ID_INIT, HSEM_PROCESS_INIT);
  while (freq != 1) {
    while (HAL_HSEM_Take(HSEM_ID_FRQ, HSEM_PROCESS_FRQ) != HAL_OK) {};
      switch (incomingByte) {
        case 'a':
          buff->datFreq = 100;
        case 'b':
          buff->datFreq = 200;
        case 'c':
          buff->datFreq = 300;
        case 'd':
          buff->datFreq = 400;
        case 'e':
          buff->datFreq = 500;
        case 'f':
          buff->datFreq = 600;
        case 'g':
          buff->datFreq = 700;
        case 'h':
          buff->datFreq = 800;
        case 'i':
          buff->datFreq = 900;
      } SCB_CleanDCache_by_Addr(buff, sizeof(*buff));
      HAL_HSEM_Release(HSEM_ID_FRQ, HSEM_PROCESS_FRQ);
      freq = 1;
  /***********SETUP******************/
  //No setup on M7
  /***********SETUP DONE*************/
  while (readyM4 != 1) {
    while (HAL_HSEM_Take(HSEM_ID_RDYM, HSEM_PROCESS_RDYM) != HAL_OK) {};
    if (buff->datReady1 == 1) {
      readyM4 = 1;
    HAL_HSEM_Release(HSEM_ID_RDYM, HSEM_PROCESS_RDYM);
  while (readyP != 1) {
    Serial.println("ready");
      if (incomingByte == 'r') {
        readyP = 1;
        while (HAL_HSEM_Take(HSEM_ID_RDY, HSEM_PROCESS_RDY) != HAL_OK) {};
        buff->datReady = 1;
        HAL_HSEM_Release(HSEM_ID_RDY, HSEM_PROCESS_RDY);
  buff->datInit = 0;
  buff->datReset = 0;
  buff->datReady = 0;
  buff->datReady1 = 0;
#endif
//////////////////////////////////////END CORE_CM7////////////////////////////////////
///////////////////////////////////////CORE_CM4////////////////////////////////////
#ifdef CORE_CM4
/*****************************function headers**********************/
void setupLabviewM4();
//void setupTresholdManual();
void ADC_Init();
void ADC_Stop();
void DMA_Stop();
void DMA_Start();
void ADC_Start();
void DMA_Config();
void VREFBUF_Init();
void AC_TIMER1_Init();
void AC_TIMER1_Stop();
void AC_TIMER1_ChangeFreq(int);
void TrigDAC(uint16_t,int);
void DAC_Config();
void GPIOH_Init();
void GPIOH_Port15_Toggle();
/***************************variables*******************************/
bool SetupComplete = false;
int myValEch = 200;
int readyP = 0;
int initt = 0;
int freq = 0;
int myLED;
int updateEV = 0;
int DMABuffered = 0;
int DMABufferedi = 0;
int Eosmp = 0;
int Eocie = 0;
int Eos = 0;
int DMAError = 0;
int valADC = 0;
bool TCpair = true;
int Mat1 =1;
/**************************shared struct*****************************/
struct shared_data
  uint8_t datReady1;
  uint8_t datInit;
  uint32_t datFreq;
  uint8_t datReset;
  uint8_t datReady;
/******************************setup*********************************/
  setupLabviewM4();
/******************************loop**********************************/
  /*********************Poll for Reset**********************/
  if (buff->datReset == 1) {
    setupLabviewM4();
  /*********************Algorithms**************************/
  //TEST ALGO
  while(!(DMABuffered>DMABufferedi)){
      digitalWrite(LEDB,LOW);
  digitalWrite(LEDB,HIGH);
  if(Mat1==1){
    buff->data_M4toM7[0] = myValEch;
    buff->data_M4toM7[1] = buff->M7toM4_1[4];
    buff->data_M4toM7[2] = buff->M7toM4_1[9];
    DMABufferedi=DMABuffered;
  }else if(Mat1==0){
    buff->data_M4toM7[1] = buff->M7toM4_2[4];
    buff->data_M4toM7[2] = buff->M7toM4_2[9];
/************************Setup functions********************/
void setupLabviewM4(void) {
  readyP = 0;
  initt = 0;
  freq = 0;
    if (buff->datInit == 1) {
      initt = 1;
    } HAL_HSEM_Release(HSEM_ID_INIT, HSEM_PROCESS_INIT);
  while (freq != 1) {
    myValEch = buff->datFreq;
    freq = 1;
  if (SetupComplete) {
    digitalWrite(LEDG,LOW);
    ADC_Stop();
    AC_TIMER1_Stop();
    DMA_Stop();
    DMABufferedi= 0;
    DMABuffered= 0;
    DMA_Start();
    AC_TIMER1_ChangeFreq(myValEch);
    GPIOH_Init();
    //analogReference();
    VREFBUF_Init();
    DAC_Config();
    DMA_Config();
    AC_TIMER1_Init();
    ADC_Init();
    SetupComplete = true;
  //ALGO TEST
  //randomSeed(analogRead(0));//To replace with M4 Init code
  buff->datReady1 = 1;
    if (buff->datReady == 1) {
      readyP = 1;
    } HAL_HSEM_Release(HSEM_ID_RDY, HSEM_PROCESS_RDY);
  ADC_Start();
/***********************Peripherals functions********************/
void VREFBUF_Init(void) {
  SET_BIT(RCC_C2->APB4ENR, RCC_APB4ENR_VREFEN_Msk);
  SET_BIT(VREFBUF->CSR, VREFBUF_CSR_ENVR_Msk);
  CLEAR_BIT(VREFBUF->CSR, VREFBUF_CSR_HIZ_Msk);
  while (VREFBUF_CSR_VRR & VREFBUF_CSR_VRR_Msk != 1) {}
void DMA_Config(void) {
  /************DMA CLock Enable******************/
  SET_BIT(RCC_C2->AHB1ENR, RCC_AHB1ENR_DMA1EN_Msk);
  /***************P2M****************************/
  CLEAR_BIT(DMA1_Stream1->CR, DMA_SxCR_DIR_0 | DMA_SxCR_DIR_1);
  /******************Disable FIFO*************************/
  //LL_DMA_DisableFifoMode(DMA1, LL_DMA_STREAM_1);
  //LL_DMA_SetMemoryBurstxfer(DMA1, LL_DMA_STREAM_1, LL_DMA_MBURST_SINGLE);
  /******************Memory size**************************/
  SET_BIT(DMA1_Stream1->CR, DMA_SxCR_MSIZE_0);
  CLEAR_BIT(DMA1_Stream1->CR, DMA_SxCR_MSIZE_1);
  /******************MEM Increment**********************/
  SET_BIT(DMA1_Stream1->CR, DMA_SxCR_MINC_Msk);
  /******************MEM Address to buffer**************/
  DMA1_Stream1->M0AR = (uint32_t)&buff->M7toM4_1; //0x30000000;
  DMA1_Stream1->M1AR = (uint32_t)&buff->M7toM4_2; //0x30000000;
  /*******************Number of data transfer***********/
  SET_BIT(DMA1_Stream1->NDTR, DMA_SxNDT_3 | DMA_SxNDT_1);
  /***********************DMA Mode**********************/
  SET_BIT(DMA1_Stream1->CR, DMA_SxCR_CIRC_Msk);//circular
  SET_BIT(DMA1_Stream1->CR, DMA_SxCR_DBM_Msk);//Double Buffer Mode
  /*******************Flow controller*******************/
  //SET_BIT(DMA1_Stream1->CR, DMA_SxCR_PFCTRL_Msk);//ADC in control
  /******************Periph size************************/
  SET_BIT(DMA1_Stream1->CR, DMA_SxCR_PSIZE_0);
  CLEAR_BIT(DMA1_Stream1->CR, DMA_SxCR_PSIZE_1);
  /******************Peripheral no Increment*************/
  CLEAR_BIT(DMA1_Stream1->CR, DMA_SxCR_PINCOS_Msk);
  /******************Periph request**********************/
  SET_BIT(DMAMUX1_Channel1->CCR, DMAMUX_CxCR_DMAREQ_ID_1 | DMAMUX_CxCR_DMAREQ_ID_3);//adc2_dma
  //  SET_BIT(DMAMUX1_Channel1->CCR, DMAMUX_CxCR_SYNC_ID_0 | DMAMUX_CxCR_SYNC_ID_1 | DMAMUX_CxCR_SYNC_ID_2);//TIM12_TRGO
  //  SET_BIT(DMAMUX1_Channel1->CCR, DMAMUX_CxCR_SPOL_0);//rising edge
  //  DMAMUX1_Channel1->CCR = 0; //Number of requests after synchro (add 1 to the reg value)
  //  SET_BIT(DMAMUX1_Channel1->CCR, DMAMUX_CxCR_EGE_Msk);//Event Generation end of synchro req
  //  SET_BIT(DMAMUX1_Channel1->CCR, DMAMUX_CxCR_SE_Msk);//Synchro Enable
  /******************Periph address***********************/
  DMA1_Stream1->PAR = (uint32_t)&ADC2->DR;
  /******************TC IT********************************/
  SET_BIT(DMA1_Stream1->CR, DMA_SxCR_TCIE_Msk | DMA_SxCR_TEIE_Msk); //TC IT
  DMA1->LIFCR = DMA_LIFCR_CTCIF1;//Clear IT in LISR Register
  NVIC_SetVector(DMA1_Stream1_IRQn, (uint32_t)&DMA1_Stream1_IRQHandler);
  NVIC_EnableIRQ(DMA1_Stream1_IRQn);
  /*******************Enable DMA****************************/
  SET_BIT(DMA1_Stream1->CR, DMA_SxCR_EN_Msk);
void DMA1_Stream1_IRQHandler(void) {
  if (DMA1->LISR & DMA_LISR_TCIF1 ) {
    //TCpair = !TCpair;
    //buff->sts_buff1_or2 = DMABuffered % 2;
    //valADC=BufferADC[0];
    DMABuffered = DMABuffered + 1;
    Mat1=(Mat1+1)%2;
    //buff->sts_transfer = 1;
  if (DMA1->LISR & DMA_LISR_TEIF1 ) {
    DMAError = DMAError + 1;
    DMA1->LIFCR = DMA_LIFCR_CTEIF1;
void ADC_Init(void) {
  /*******************Horloges**************************/
  SET_BIT(RCC_C2->APB4ENR, RCC_APB4ENR_SYSCFGEN_Msk); //SYSCFG clock
  SET_BIT(RCC_C2->APB4ENR, RCC_APB4ENR_RTCAPBEN_Msk); //RTCAPB clock
  SET_BIT(RCC_C2->AHB1ENR, RCC_AHB1ENR_ADC12EN_Msk); //ADC12 clocks
  //SET_BIT(RCC_C2->AHB4ENR, RCC_AHB4ENR_GPIOAEN_Msk); //GPIOA clock
  //delay(1000);
  SET_BIT(RCC_C2->AHB4ENR, RCC_AHB4ENR_GPIOCEN_Msk); //GPIOA clock
  /********************Port config************************/
//  SET_BIT(GPIOA->MODER, GPIO_MODER_MODE1_0);
//  SET_BIT(GPIOA->MODER, GPIO_MODER_MODE1_1);
//  CLEAR_BIT(GPIOA->PUPDR, GPIO_PUPDR_PUPD1_0);
//  CLEAR_BIT(GPIOA->PUPDR, GPIO_PUPDR_PUPD1_1);
  SET_BIT(GPIOC->MODER, GPIO_MODER_MODE4_0);
  SET_BIT(GPIOC->MODER, GPIO_MODER_MODE4_1);
  CLEAR_BIT(GPIOC->PUPDR, GPIO_PUPDR_PUPD4_0);
  CLEAR_BIT(GPIOC->PUPDR, GPIO_PUPDR_PUPD4_1);
  //SET_BIT(SYSCFG->PMCR, SYSCFG_PMCR_PA0SO_Msk);
  delay(1000);//PA0_C in analog mode
  /********************ADC voltage regulator***************/
  CLEAR_BIT(ADC2->CR, ADC_CR_DEEPPWD_Msk); //END DEEPPWD
  SET_BIT(ADC2->CR, ADC_CR_ADVREGEN_Msk); //ENABLE ADC VOLTAGE REG
  delay(1000);//WAIT VOLTAGE REG
  /********************ADC calibration*********************/
  CLEAR_BIT(ADC2->CR, ADC_CR_ADCALDIF_Msk);
  SET_BIT(ADC2->CR, ADC_CR_ADCALLIN_Msk);
  SET_BIT(ADC2->CR, ADC_CR_ADCAL_Msk);
  while (ADC_CR_ADCAL & ADC_CR_ADCAL_Msk != 0) {}
  /******************ADC clock*****************************/
  SET_BIT(ADC12_COMMON->CCR, ADC_CCR_CKMODE_0 | ADC_CCR_CKMODE_1);
  /*******************ADC Prescaler************************/
  SET_BIT(ADC12_COMMON->CCR, ADC_CCR_PRESC_0 | ADC_CCR_PRESC_1 );
  /*******************Input Mode***************************/
  CLEAR_BIT(ADC2->DIFSEL, ADC_DIFSEL_DIFSEL_0); //Single Ended
  /*******************ADC Enable***************************/
  SET_BIT(ADC2->ISR, ADC_ISR_ADRDY_Msk);
  SET_BIT(ADC2->CR, ADC_CR_ADEN_Msk);
  while (ADC_ISR_ADRDY & ADC_ISR_ADRDY_Msk != 1) {}
  /********************ADC RES*****************************/
  //SET_BIT(ADC2->CFGR, ADC_CFGR_RES_2 | ADC_CFGR_RES_1);
  CLEAR_BIT(ADC2->CFGR, ADC_CFGR_RES_0 | ADC_CFGR_RES_1 | ADC_CFGR_RES_2);
  /********************ADC Data Management*****************/
  SET_BIT(ADC2->CFGR, ADC_CFGR_DMNGT_0 | ADC_CFGR_DMNGT_1);//DMA Circular mode
  /********************OVRMODE*****************************/
  SET_BIT(ADC2->CFGR, ADC_CFGR_OVRMOD_Msk); //Erase old data
  /********************CONT/Single/Discont*****************/
  SET_BIT(ADC2->CFGR, ADC_CFGR_DISCEN_Msk); // discontinuous mode
  CLEAR_BIT(ADC2->CFGR, ADC_CFGR_CONT_Msk); // | ADC_CFGR_DISCEN_Msk
  /********************Trigger Detection*******************/
  SET_BIT(ADC2->CFGR, ADC_CFGR_EXTEN_0 | ADC_CFGR_EXTSEL_1 | ADC_CFGR_EXTSEL_3);//Trig rising edge TRGO2
  CLEAR_BIT(ADC2->CFGR, ADC_CFGR_EXTEN_1 | ADC_CFGR_EXTSEL_0 | ADC_CFGR_EXTSEL_2 | ADC_CFGR_EXTSEL_4);
  /********************INput Preselection******************/
  SET_BIT(ADC2->PCSEL, ADC_PCSEL_PCSEL_0);//Chan 0
  /********************Sample Time reg*********************/
  SET_BIT(ADC2->SMPR1, ADC_SMPR1_SMP0_0); //2.5 CLCK Cycles
  /********************ADC IT******************************/
  SET_BIT(ADC2->IER, ADC_IER_EOCIE_Msk | ADC_IER_EOSMPIE_Msk  );//| ADC_IER_EOSIE_Msk | ADC_IER_OVRIE_Msk
  NVIC_EnableIRQ(ADC_IRQn);
  NVIC_SetVector(ADC_IRQn, (uint32_t)&ADC_IRQHandler);
void ADC_IRQHandler(void) {
  if (ADC2->ISR & 0x02) {
    Eosmp += 1;
    SET_BIT(ADC2->ISR, ADC_IER_EOSMPIE_Msk);
  if (ADC2->ISR & 0x04) {
    Eocie += 1;
    SET_BIT(ADC2->ISR, ADC_IER_EOCIE_Msk);
  //  if (ADC2->ISR & 0x08) {
  //    Eos += 1;
  //    SET_BIT(ADC2->ISR, ADC_IER_EOSIE_Msk);
void ADC_Start(void) {
  SET_BIT(ADC2->CR, ADC_CR_ADSTART_Msk); //Start
void AC_TIMER1_Init(void) {
  //------------------------------Horloge Timer1----------------------------------------//
  SET_BIT(RCC_C2->APB2ENR, RCC_APB2ENR_TIM1EN_Msk);
  //------------------------------Select TRGO source-----------------------------------//
  TIM1->PSC = 19; //PSC=1
  //----------------------------------------------------------TIM2 autoreload register--------------------------------------------//
  TIM1->ARR = 47;//200kHz
  //---------selectupdatevent-----------------//
  SET_BIT(TIM1->CR2, TIM_CR2_MMS2_1);
  //-----------IT-----------------------//
  //  SET_BIT(TIM1->DIER,TIM_DIER_UIE_Msk);
  //  NVIC_SetPriority(TIM1_UP_IRQn,0);
  //  NVIC_SetVector(TIM1_UP_IRQn, (uint32_t)&TIM1_UP_IRQHandler);
  //  NVIC_EnableIRQ(TIM1_UP_IRQn);
  SET_BIT(TIM1->CR1, TIM_CR1_CEN_Msk);//CEN=1
void GPIOH_Init(void) {
  SET_BIT(RCC_C2->AHB4ENR, RCC_AHB4ENR_GPIOHEN_Msk);
  SET_BIT(GPIOH->MODER, GPIO_MODER_MODE15_0);
  CLEAR_BIT(GPIOH->MODER, GPIO_MODER_MODE15_1);
  CLEAR_BIT(GPIOH->OTYPER, GPIO_OTYPER_OT15);
void GPIOH_Port15_Toggle(void) {
  SET_BIT(GPIOH->BSRR, GPIO_BSRR_BS15);
  CLEAR_BIT(GPIOH->BSRR, GPIO_BSRR_BS15);
  SET_BIT(GPIOH->BSRR, GPIO_BSRR_BR15);
  CLEAR_BIT(GPIOH->BSRR, GPIO_BSRR_BR15);
void AC_TIMER1_ChangeFreq(int myValEch) {
  TIM1->ARR = myValEch;//Change this value to get correct frequency
  SET_BIT(TIM1->CR1, TIM_CR1_CEN_Msk);//RESTART
void ADC_Stop(void) {
  //STOP ADC CONV
  SET_BIT(ADC2->CR, ADC_CR_ADSTP_Msk);
  //Poll ADC STOPPED
  while (!(ADC2->CR & ADC_CR_ADSTART)) {}
void AC_TIMER1_Stop(void) {
  CLEAR_BIT(TIM1->CR1, TIM_CR1_CEN_Msk);//STOP
void DMA_Stop(void) {
  CLEAR_BIT(DMA1_Stream1->CR, DMA_SxCR_EN_Msk);
void DMA_Start(void) {
void DAC_Config(void) {
  /**************************Configure GPIO pins************/
  SET_BIT(RCC->AHB4ENR, RCC_AHB4ENR_GPIOAEN_Msk); //GPIOA clock
  SET_BIT(GPIOA->MODER, GPIO_MODER_MODE4_0);
  SET_BIT(GPIOA->MODER, GPIO_MODER_MODE4_1);
  CLEAR_BIT(GPIOA->PUPDR, GPIO_PUPDR_PUPD4_0);
  CLEAR_BIT(GPIOA->PUPDR, GPIO_PUPDR_PUPD4_1);
  /*******************EN_DAC_CLCK*************************/
  SET_BIT(RCC->APB1LENR,RCC_APB1LENR_DAC12EN_Msk);
  /*******************DAC_MODE*****************************/
  SET_BIT(DAC1->MCR, DAC_MCR_MODE2_1); //disable buffer DAC chan 2
  //Chan 1 000 buffer enabled
  /********************CR**********************************/
void TrigDAC(uint16_t value,int timepulse) {
  //int timTrig=100000;
  DAC1->DHR12R1=value;
  SET_BIT(DAC1->CR, DAC_CR_EN1_Msk ); //Enable DAC
//  while (timTrig > 1) {
//    timTrig--;
  delay(timepulse);
  CLEAR_BIT(DAC1->CR, DAC_CR_EN1_Msk ); //Enable DAC
#endif
/////////////////////////////////END CORE_CM4//////////////////////////////////////
This code is supposed to work with a Labview interface but you can just go in your serial monitor and write:
'i'
when it says ready write :
'r'
You will get :
'data1|data2|data3'
The data corresponding to the ADC is data2 and data3.
For the montage since I use VrefBuf from the board (with a 2.5 V value) you must do the following circuit on Vref pin:
With of course all the grounds linked (source, portenta,...).
are able to simplify your sketch? i will try with Uno and Mega.
Unfortunately this sketch can not be tried on Mega or Uno since I programmed the Portenta registers directly and they are different from the Uno's and Mega's.
Well I have tested a few things and the readings are worse than what I expect (to the point where I wonder if the card is okay). Here is a reading of a DC signal with my board :
(1000 samples 16 bit res 1V offset)
The datasheet from STM specifies a 10 LSB error for my ADC parameters. Can this really be linked to the voltage reference at this point... Easy test does anyone get these kind of readings with his/her portenta using the analogread function as is . Code :
/* DEFINE */
#define SAMPLES (500) // Number of samples to acquire (== size of the array)
/*INIT*/
const int analogInPin = A1; // Analog input pin that the photomultiplier is attached to
int sensorVal [SAMPLES]; // Array where the analog values are stored in
long timeElapsed = 0; // Initial time [μs]
long timeStart = 0; // Elapsed time [μs]
/* SETUP */
Serial.begin(115200); // Open serial port at 115200 bps
analogReadResolution(16); // Sets the size of the value returned by photomultiplier [bits]
pinMode(analogInPin,INPUT); // Set the analog pin as INPUT
/* MAIN LOOP */
//timeStart = micros();
for(int i=0; i<SAMPLES ; i++){
sensorVal[i] = analogRead(analogInPin); // Read and store the analog value
//Serial.print("Value : ");
Serial.println(sensorVal[i]);
//timeElapsed = micros()-timeStart; // Calculate elapsed time [μs]
//Serial.println(timeElapsed);
//Serial.print ("Sampling frequency: ");
//Serial.print ((float)SAMPLES/timeElapsed*1000); // Print sampling rate
//Serial.println(" kHz");
//delay(2000);
My disgusting readings with analog read (same signal as above 1V offset) :
You say it is difficult to put it down to the VREF but.....
The power supply scheme is....... well, here's VREF:
I tried your code in post #4 and here's a 1khz square wave 1V amplitude and 0V offset. Here's 200 lines of data. It uh.... It's sort of there in spirit I guess? When I take a larger dataset, it becomes unusable. The onboard vREF has a 30% margin of error. 30% error is a reference meaning basically nothing. It may as well be a digital hi/lo.
Sorry, I cannot upload multiple images.
A simple plot of the 201 data points. Yes, that is a square wave feeding in.
ETA: seems to peak about 7500-8500 on the data. Crunching the math for 8500*(3.1V/65565) = ~.4V.
With the ST guidance in mind, specifically:
"Furthermore, it is recommended to re-run the offset calibration whenever the VREF voltage changes by more than 10%."
as per AN5354 the Portenta H7 would need to be recalibrated every few microseconds.
Thanks a lot for the feedback, I am currently waiting for the delivery of a 2.5V Vref component with +/-1mV error.
I hope his voltage ref saves the day :slight_smile: !
you and me both! I'm developing for automotive (motorcycle) and need to monitor hall voltages from throttle inputs. What VRef are you looking at? I have been eyeing the Onsemi NCV51460 and the TI REF2033-Q1.
I took this one and managed to do not notice it is a µcomponent...shame on me!!
I will manange to test it anyway.
ADR421ARMZ-REEL7
Just checking in to see if the vref calmed down your readings before I pull the trigger on my PCB design. Did it offer any workable improvements? The deeper I get into portenta, the more it feels like a half-executed product.
Could not try the Ref with my poor welding material and I am currently waiting for my PCB, for now I managed to get better results by increasing the clock cycles before the ADC sampling phase (software solution).
And yeah I also share your opinion and I feel like I should have gone for an Stm product like the Nucleo...
Edit : It must work since someone got 1LSB with 2.048 ref lemme find the topic link
