Initialising Error for esp 32 cam on serial monitor
I am new to esp 32 cam and I tried to upload my first program through examples, web server.
All libraries are installed, preferences are done.connections are also made as per diagram.I have used a Usb to UART converter for programming my esp 32 cam.
Code is successfully uploaded with no errors...than I open my serial monitor and I see this text going on and on infinite times...I don't know what to do...anybody please help...it's urgent :cry:
have a read of how-to-get-the-best-out-of-this-forum
  1. what Tools>Board have you selected - recommended is board "AI Thinker ESP32-CAM"
  2. have you any other devices connected to the ESP-CAM, e.g. sensors, relays, etc
  3. can you upload and run the very simple program File>Examples>Basics>BareMinimum?
avoid uploading images of screen shots - they are difficult to read and take of lot of storage
copy the text and then select < CODE/ > and paste the code or text where it says “type or paste code here”
rst:Ux3 (SW_RESET),boot:Uxl3 (SPI_FAST_FLASH_BOOT)configsip: 0, SPIWP: Oxee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1344 load: 0x40078000, len: 13964 load:0x40080400, len:3600 entry 0x400805f0
ets Jul 29 2019 12:21:46
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
This is the code
i have uploaded code successfully on my esp 32 cam via arduino IDE. but once i open my serial monitor this error shows up continously. can anyone help me
error:
code:
#include <esp_camera.h>
#include <esp_int_wdt.h>
#include <esp_task_wdt.h>
#include <WiFi.h>
#include <DNSServer.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include "src/parsebytes.h"
#include "time.h"
#include <ESPmDNS.h>
/* This sketch is a extension/expansion/reork of the 'official' ESP32 Camera example
 *  sketch from Expressif:
 *  https://github.com/espressif/arduino-esp32/tree/master/libraries/ESP32/examples/Camera/CameraWebServer
 *  It is modified to allow control of Illumination LED Lamps's (present on some modules),
 *  greater feedback via a status LED, and the HTML contents are present in plain text
 *  for easy modification.
 *  A camera name can now be configured, and wifi details can be stored in an optional
 *  header file to allow easier updated of the repo.
 *  The web UI has had changes to add the lamp control, rotation, a standalone viewer,
 *  more feeedback, new controls and other tweaks and changes,
 * note: Make sure that you have either selected ESP32 AI Thinker,
 *       or another board which has PSRAM enabled to use high resolution camera modes
 *  FOR NETWORK AND HARDWARE SETTINGS COPY OR RENAME 'myconfig.sample.h' TO 'myconfig.h' AND EDIT THAT.
 * By default this sketch will assume an AI-THINKER ESP-CAM and create
 * an accesspoint called "ESP32-CAM-CONNECT" (password: "InsecurePassword")
// Primary config, or defaults.
#if __has_include("myconfig.h")
    struct station { const char ssid[65]; const char password[65]; const bool dhcp;};  // do no edit
    #include "myconfig.h"
#else
    #warning "Using Defaults: Copy myconfig.sample.h to myconfig.h and edit that to use your own settings"
    #define WIFI_AP_ENABLE
    #define CAMERA_MODEL_AI_THINKER
    stationList[] = {{"ESP32-CAM-CONNECT","InsecurePassword", true}};
#endif
// Upstream version string
#include "src/version.h"
// Pin Mappings
#include "camera_pins.h"
// Camera config structure
camera_config_t config;
// Internal filesystem (SPIFFS)
// used for non-volatile camera settings
#include "storage.h"
// Sketch Info
int sketchSize;
int sketchSpace;
String sketchMD5;
// Start with accesspoint mode disabled, wifi setup will activate it if
// no known networks are found, and WIFI_AP_ENABLE has been defined
bool accesspoint = false;
// IP address, Netmask and Gateway, populated when connected
IPAddress ip;
IPAddress net;
IPAddress gw;
// Declare external function from app_httpd.cpp
extern void startCameraServer(int hPort, int sPort);
extern void serialDump();
// Names for the Camera. (set these in myconfig.h)
#if defined(CAM_NAME)
    char myName[] = CAM_NAME;
#else
    char myName[] = "ESP32 camera server";
#endif
#if defined(MDNS_NAME)
    char mdnsName[] = MDNS_NAME;
#else
    char mdnsName[] = "esp32-cam";
#endif
// Ports for http and stream (override in myconfig.h)
#if defined(HTTP_PORT)
    int httpPort = HTTP_PORT;
#else
    int httpPort = 80;
#endif
#if defined(STREAM_PORT)
    int streamPort = STREAM_PORT;
#else
    int streamPort = 81;
#endif
#if !defined(WIFI_WATCHDOG)
    #define WIFI_WATCHDOG 15000
#endif
// Number of known networks in stationList[]
int stationCount = sizeof(stationList)/sizeof(stationList[0]);
// If we have AP mode enabled, ignore first entry in the stationList[]
#if defined(WIFI_AP_ENABLE)
    int firstStation = 1;
#else
    int firstStation = 0;
#endif
// Select between full and simple index as the default.
#if defined(DEFAULT_INDEX_FULL)
    char default_index[] = "full";
#else
    char default_index[] = "simple";
#endif
// DNS server
const byte DNS_PORT = 53;
DNSServer dnsServer;
bool captivePortal = false;
char apName[64] = "Undefined";
// The app and stream URLs
char httpURL[64] = {"Undefined"};
char streamURL[64] = {"Undefined"};
// Counters for info screens and debug
int8_t streamCount = 0;          // Number of currently active streams
unsigned long streamsServed = 0; // Total completed streams
unsigned long imagesServed = 0;  // Total image requests
// This will be displayed to identify the firmware
char myVer[] PROGMEM = __DATE__ " @ " __TIME__;
// This will be set to the sensors PID (identifier) during initialisation
//camera_pid_t sensorPID;
int sensorPID;
// Camera module bus communications frequency.
// Originally: config.xclk_freq_mhz = 20000000, but this lead to visual artifacts on many modules.
// See https://github.com/espressif/esp32-camera/issues/150#issuecomment-726473652 et al.
#if !defined (XCLK_FREQ_MHZ)
    unsigned long xclk = 8;
#else
    unsigned long xclk = XCLK_FREQ_MHZ;
#endif
// initial rotation
// can be set in myconfig.h
#if !defined(CAM_ROTATION)
    #define CAM_ROTATION 0
#endif
int myRotation = CAM_ROTATION;
// minimal frame duration in ms, effectively 1/maxFPS
#if !defined(MIN_FRAME_TIME)
    #define MIN_FRAME_TIME 0
#endif
int minFrameTime = MIN_FRAME_TIME;
// Illumination LAMP and status LED
#if defined(LAMP_DISABLE)
    int lampVal = -1; // lamp is disabled in config
#elif defined(LAMP_PIN)
    #if defined(LAMP_DEFAULT)
        int lampVal = constrain(LAMP_DEFAULT,0,100); // initial lamp value, range 0-100
    #else
        int lampVal = 0; //default to off
    #endif
#else
    int lampVal = -1; // no lamp pin assigned
#endif
#if defined(LED_DISABLE)
    #undef LED_PIN    // undefining this disables the notification LED
#endif
bool autoLamp = false;         // Automatic lamp (auto on while camera running)
int lampChannel = 7;           // a free PWM channel (some channels used by camera)
const int pwmfreq = 50000;     // 50K pwm frequency
const int pwmresolution = 9;   // duty cycle bit range
const int pwmMax = pow(2,pwmresolution)-1;
#if defined(NO_FS)
    bool filesystem = false;
#else
    bool filesystem = true;
#endif
#if defined(NO_OTA)
    bool otaEnabled = false;
#else
    bool otaEnabled = true;
#endif
#if defined(OTA_PASSWORD)
    char otaPassword[] = OTA_PASSWORD;
#else
    char otaPassword[] = "";
#endif
#if defined(NTPSERVER)
    bool haveTime = true;
    const char* ntpServer = NTPSERVER;
    const long  gmtOffset_sec = NTP_GMT_OFFSET;
    const int   daylightOffset_sec = NTP_DST_OFFSET;
#else
    bool haveTime = false;
    const char* ntpServer = "";
    const long  gmtOffset_sec = 0;
    const int   daylightOffset_sec = 0;
#endif
// Critical error string; if set during init (camera hardware failure) it
// will be returned for all http requests
String critERR = "";
// Debug flag for stream and capture data
bool debugData;
void debugOn() {
    debugData = true;
    Serial.println("Camera debug data is enabled (send 'd' for status dump, or any other char to disable debug)");
void debugOff() {
    debugData = false;
    Serial.println("Camera debug data is disabled (send 'd' for status dump, or any other char to enable debug)");
// Serial input (debugging controls)
void handleSerial() {
    if (Serial.available()) {
        char cmd = Serial.read();
        if (cmd == 'd' ) {
            serialDump();
            if (debugData) debugOff();
            else debugOn();
    while (Serial.available()) Serial.read();  // chomp the buffer
// Notification LED
void flashLED(int flashtime) {
#if defined(LED_PIN)                // If we have it; flash it.
    digitalWrite(LED_PIN, LED_ON);  // On at full power.
    delay(flashtime);               // delay
    digitalWrite(LED_PIN, LED_OFF); // turn Off
#else
    return;                         // No notifcation LED, do nothing, no delay
#endif
// Lamp Control
void setLamp(int newVal) {
#if defined(LAMP_PIN)
    if (newVal != -1) {
        // Apply a logarithmic function to the scale.
        int brightness = round((pow(2,(1+(newVal*0.02)))-2)/6*pwmMax);
        ledcWrite(lampChannel, brightness);
        Serial.print("Lamp: ");
        Serial.print(newVal);
        Serial.print("%, pwm = ");
        Serial.println(brightness);
#endif
void printLocalTime(bool extraData=false) {
    struct tm timeinfo;
    if(!getLocalTime(&timeinfo)){
        Serial.println("Failed to obtain time");
        Serial.println(&timeinfo, "%H:%M:%S, %A, %B %d %Y");
    if (extraData) {
        Serial.printf("NTP Server: %s, GMT Offset: %li(s), DST Offset: %i(s)\r\n", ntpServer, gmtOffset_sec, daylightOffset_sec);
void calcURLs() {
    // Set the URL's
    #if defined(URL_HOSTNAME)
        if (httpPort != 80) {
            sprintf(httpURL, "http://%s:%d/", URL_HOSTNAME, httpPort);
            sprintf(httpURL, "http://%s/", URL_HOSTNAME);
        sprintf(streamURL, "http://%s:%d/", URL_HOSTNAME, streamPort);
    #else
        Serial.println("Setting httpURL");
            sprintf(httpURL, "http://%d.%d.%d.%d:%d/", ip[0], ip[1], ip[2], ip[3], httpPort);
            sprintf(httpURL, "http://%d.%d.%d.%d/", ip[0], ip[1], ip[2], ip[3]);
        sprintf(streamURL, "http://%d.%d.%d.%d:%d/", ip[0], ip[1], ip[2], ip[3], streamPort);
    #endif
void StartCamera() {
    // Populate camera config structure with hardware and other defaults
    config.ledc_channel = LEDC_CHANNEL_0;
    config.ledc_timer = LEDC_TIMER_0;
    config.pin_d0 = Y2_GPIO_NUM;
    config.pin_d1 = Y3_GPIO_NUM;
    config.pin_d2 = Y4_GPIO_NUM;
    config.pin_d3 = Y5_GPIO_NUM;
    config.pin_d4 = Y6_GPIO_NUM;
    config.pin_d5 = Y7_GPIO_NUM;
    config.pin_d6 = Y8_GPIO_NUM;
    config.pin_d7 = Y9_GPIO_NUM;
    config.pin_xclk = XCLK_GPIO_NUM;
    config.pin_pclk = PCLK_GPIO_NUM;
    config.pin_vsync = VSYNC_GPIO_NUM;
    config.pin_href = HREF_GPIO_NUM;
    config.pin_sscb_sda = SIOD_GPIO_NUM;
    config.pin_sscb_scl = SIOC_GPIO_NUM;
    config.pin_pwdn = PWDN_GPIO_NUM;
    config.pin_reset = RESET_GPIO_NUM;
    config.xclk_freq_hz = xclk * 1000000;
    config.pixel_format = PIXFORMAT_JPEG;
    // Low(ish) default framesize and quality
    config.frame_size = FRAMESIZE_SVGA;
    config.jpeg_quality = 12;
    config.fb_location = CAMERA_FB_IN_PSRAM;
    config.fb_count = 2;
    config.grab_mode = CAMERA_GRAB_LATEST;
    #if defined(CAMERA_MODEL_ESP_EYE)
        pinMode(13, INPUT_PULLUP);
        pinMode(14, INPUT_PULLUP);
    #endif
    // camera init
    esp_err_t err = esp_camera_init(&config);
    if (err != ESP_OK) {
        delay(100);  // need a delay here or the next serial o/p gets missed
        Serial.printf("\r\n\r\nCRITICAL FAILURE: Camera sensor failed to initialise.\r\n\r\n");
        Serial.printf("A full (hard, power off/on) reboot will probably be needed to recover from this.\r\n");
        Serial.printf("Meanwhile; this unit will reboot in 1 minute since these errors sometime clear automatically\r\n");
        // Reset the I2C bus.. may help when rebooting.
        periph_module_disable(PERIPH_I2C0_MODULE); // try to shut I2C down properly in case that is the problem
        periph_module_disable(PERIPH_I2C1_MODULE);
        periph_module_reset(PERIPH_I2C0_MODULE);
        periph_module_reset(PERIPH_I2C1_MODULE);
        // And set the error text for the UI
        critERR = "<h1>Error!</h1><hr><p>Camera module failed to initialise!</p><p>Please reset (power off/on) the camera.</p>";
        critERR += "<p>We will continue to reboot once per minute since this error sometimes clears automatically.</p>";
        // Start a 60 second watchdog timer
        esp_task_wdt_init(60,true);
        esp_task_wdt_add(NULL);
        Serial.println("Camera init succeeded");
        // Get a reference to the sensor
        sensor_t * s = esp_camera_sensor_get();
        // Dump camera module, warn for unsupported modules.
        sensorPID = s->id.PID;
        switch (sensorPID) {
            case OV9650_PID: Serial.println("WARNING: OV9650 camera module is not properly supported, will fallback to OV2640 operation"); break;
            case OV7725_PID: Serial.println("WARNING: OV7725 camera module is not properly supported, will fallback to OV2640 operation"); break;
            case OV2640_PID: Serial.println("OV2640 camera module detected"); break;
            case OV3660_PID: Serial.println("OV3660 camera module detected"); break;
            default: Serial.println("WARNING: Camera module is unknown and not properly supported, will fallback to OV2640 operation");
        // OV3660 initial sensors are flipped vertically and colors are a bit saturated
        if (sensorPID == OV3660_PID) {
            s->set_vflip(s, 1);  //flip it back
            s->set_brightness(s, 1);  //up the blightness just a bit
            s->set_saturation(s, -2);  //lower the saturation
        // M5 Stack Wide has special needs
        #if defined(CAMERA_MODEL_M5STACK_WIDE)
            s->set_vflip(s, 1);
            s->set_hmirror(s, 1);
        #endif
        // Config can override mirror and flip
        #if defined(H_MIRROR)
            s->set_hmirror(s, H_MIRROR);
        #endif
        #if defined(V_FLIP)
            s->set_vflip(s, V_FLIP);
        #endif
        // set initial frame rate
        #if defined(DEFAULT_RESOLUTION)
            s->set_framesize(s, DEFAULT_RESOLUTION);
        #endif
        * Add any other defaults you want to apply at startup here:
        * uncomment the line and set the value as desired (see the comments)
        * these are defined in the esp headers here:
        * https://github.com/espressif/esp32-camera/blob/master/driver/include/sensor.h#L149
        //s->set_framesize(s, FRAMESIZE_SVGA); // FRAMESIZE_[QQVGA|HQVGA|QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA|QXGA(ov3660)]);
        //s->set_quality(s, val);       // 10 to 63
        //s->set_brightness(s, 0);      // -2 to 2
        //s->set_contrast(s, 0);        // -2 to 2
        //s->set_saturation(s, 0);      // -2 to 2
        //s->set_special_effect(s, 0);  // 0 to 6 (0 - No Effect, 1 - Negative, 2 - Grayscale, 3 - Red Tint, 4 - Green Tint, 5 - Blue Tint, 6 - Sepia)
        //s->set_whitebal(s, 1);        // aka 'awb' in the UI; 0 = disable , 1 = enable
        //s->set_awb_gain(s, 1);        // 0 = disable , 1 = enable
        //s->set_wb_mode(s, 0);         // 0 to 4 - if awb_gain enabled (0 - Auto, 1 - Sunny, 2 - Cloudy, 3 - Office, 4 - Home)
        //s->set_exposure_ctrl(s, 1);   // 0 = disable , 1 = enable
        //s->set_aec2(s, 0);            // 0 = disable , 1 = enable
        //s->set_ae_level(s, 0);        // -2 to 2
        //s->set_aec_value(s, 300);     // 0 to 1200
        //s->set_gain_ctrl(s, 1);       // 0 = disable , 1 = enable
        //s->set_agc_gain(s, 0);        // 0 to 30
        //s->set_gainceiling(s, (gainceiling_t)0);  // 0 to 6
        //s->set_bpc(s, 0);             // 0 = disable , 1 = enable
        //s->set_wpc(s, 1);             // 0 = disable , 1 = enable
        //s->set_raw_gma(s, 1);         // 0 = disable , 1 = enable
        //s->set_lenc(s, 1);            // 0 = disable , 1 = enable
        //s->set_hmirror(s, 0);         // 0 = disable , 1 = enable
        //s->set_vflip(s, 0);           // 0 = disable , 1 = enable
        //s->set_dcw(s, 1);             // 0 = disable , 1 = enable
        //s->set_colorbar(s, 0);        // 0 = disable , 1 = enable
    // We now have camera with default init
void WifiSetup() {
    // Feedback that we are now attempting to connect
    flashLED(300);
    delay(100);
    flashLED(300);
    Serial.println("Starting WiFi");
    // Disable power saving on WiFi to improve responsiveness
    // (https://github.com/espressif/arduino-esp32/issues/1484)
    WiFi.setSleep(false);
    Serial.print("Known external SSIDs: ");
    if (stationCount > firstStation) {
        for (int i=firstStation; i < stationCount; i++) Serial.printf(" '%s'", stationList[i].ssid);
        Serial.print("None");
    byte mac[6] = {0,0,0,0,0,0};
    WiFi.macAddress(mac);
    Serial.printf("MAC address: %02X:%02X:%02X:%02X:%02X:%02X\r\n", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
    int bestStation = -1;
    long bestRSSI = -1024;
    char bestSSID[65] = "";
    uint8_t bestBSSID[6];
        // We have a list to scan
        Serial.printf("Scanning local Wifi Networks\r\n");
        int stationsFound = WiFi.scanNetworks();
        Serial.printf("%i networks found\r\n", stationsFound);
        if (stationsFound > 0) {
            for (int i = 0; i < stationsFound; ++i) {
                // Print SSID and RSSI for each network found
                String thisSSID = WiFi.SSID(i);
                int thisRSSI = WiFi.RSSI(i);
                String thisBSSID = WiFi.BSSIDstr(i);
                Serial.printf("%3i : [%s] %s (%i)", i + 1, thisBSSID.c_str(), thisSSID.c_str(), thisRSSI);
                // Scan our list of known external stations
                for (int sta = firstStation; sta < stationCount; sta++) {
                    if ((strcmp(stationList[sta].ssid, thisSSID.c_str()) == 0) ||
                    (strcmp(stationList[sta].ssid, thisBSSID.c_str()) == 0)) {
                        Serial.print("  -  Known!");
                        // Chose the strongest RSSI seen
                        if (thisRSSI > bestRSSI) {
                            bestStation = sta;
                            strncpy(bestSSID, thisSSID.c_str(), 64);
                            // Convert char bssid[] to a byte array
                            parseBytes(thisBSSID.c_str(), ':', bestBSSID, 6, 16);
                            bestRSSI = thisRSSI;
        // No list to scan, therefore we are an accesspoint
        accesspoint = true;
    if (bestStation == -1) {
        if (!accesspoint) {
                Serial.println("No known networks found, entering AccessPoint fallback mode");
                accesspoint = true;
            #else
                Serial.println("No known networks found");
            #endif
            Serial.println("AccessPoint mode selected in config");
        Serial.printf("Connecting to Wifi Network %d: [%02X:%02X:%02X:%02X:%02X:%02X] %s \r\n",
                       bestStation, bestBSSID[0], bestBSSID[1], bestBSSID[2], bestBSSID[3],
                       bestBSSID[4], bestBSSID[5], bestSSID);
        // Apply static settings if necesscary
        if (stationList[bestStation].dhcp == false) {
            #if defined(ST_IP)
                Serial.println("Applying static IP settings");
                #if !defined (ST_GATEWAY)  || !defined (ST_NETMASK)
                    #error "You must supply both Gateway and NetMask when specifying a static IP address"
                #endif
                IPAddress staticIP(ST_IP);
                IPAddress gateway(ST_GATEWAY);
                IPAddress subnet(ST_NETMASK);
                #if !defined(ST_DNS1)
                    WiFi.config(staticIP, gateway, subnet);
                #else
                    IPAddress dns1(ST_DNS1);
                #if !defined(ST_DNS2)
                    WiFi.config(staticIP, gateway, subnet, dns1);
                #else
                    IPAddress dns2(ST_DNS2);
                    WiFi.config(staticIP, gateway, subnet, dns1, dns2);
                #endif
                #endif
            #else
                Serial.println("Static IP settings requested but not defined in config, falling back to dhcp");
            #endif
        WiFi.setHostname(mdnsName);
        // Initiate network connection request (3rd argument, channel = 0 is 'auto')
        WiFi.begin(bestSSID, stationList[bestStation].password, 0, bestBSSID);
        // Wait to connect, or timeout
        unsigned long start = millis();
        while ((millis() - start <= WIFI_WATCHDOG) && (WiFi.status() != WL_CONNECTED)) {
            Serial.print('.');
        // If we have connected, inform user
        if (WiFi.status() == WL_CONNECTED) {
            Serial.println("Client connection succeeded");
            // Note IP details
            ip = WiFi.localIP();
            net = WiFi.subnetMask();
            gw = WiFi.gatewayIP();
            Serial.printf("IP address: %d.%d.%d.%d\r\n",ip[0],ip[1],ip[2],ip[3]);
            Serial.printf("Netmask   : %d.%d.%d.%d\r\n",net[0],net[1],net[2],net[3]);
            Serial.printf("Gateway   : %d.%d.%d.%d\r\n",gw[0],gw[1],gw[2],gw[3]);
            calcURLs();
            // Flash the LED to show we are connected
            for (int i = 0; i < 5; i++) {
                flashLED(50);
                delay(150);
            Serial.println("Client connection Failed");
            WiFi.disconnect();   // (resets the WiFi scan)
    if (accesspoint && (WiFi.status() != WL_CONNECTED)) {
        // The accesspoint has been enabled, and we have not connected to any existing networks
        #if defined(AP_CHAN)
            Serial.println("Setting up Fixed Channel AccessPoint");
            Serial.print("  SSID     : ");
            Serial.println(stationList[0].ssid);
            Serial.print("  Password : ");
            Serial.println(stationList[0].password);
            Serial.print("  Channel  : ");
            Serial.println(AP_CHAN);
            WiFi.softAP(stationList[0].ssid, stationList[0].password, AP_CHAN);
        # else
            Serial.println("Setting up AccessPoint");
            WiFi.softAP(stationList[0].ssid, stationList[0].password);
        #endif
        #if defined(AP_ADDRESS)
            // User has specified the AP details; apply them after a short delay
            // (https://github.com/espressif/arduino-esp32/issues/985#issuecomment-359157428)
            delay(100);
            IPAddress local_IP(AP_ADDRESS);
            IPAddress gateway(AP_ADDRESS);
            IPAddress subnet(255,255,255,0);
            WiFi.softAPConfig(local_IP, gateway, subnet);
        #endif
        // Note AP details
        ip = WiFi.softAPIP();
        strcpy(apName, stationList[0].ssid);
        calcURLs();
            flashLED(150);
            delay(50);
        // Start the DNS captive portal if requested
        if (stationList[0].dhcp == true) {
            Serial.println("Starting Captive Portal");
            dnsServer.start(DNS_PORT, "*", ip);
            captivePortal = true;
    Serial.setDebugOutput(true);
    Serial.println("====");
    Serial.print("esp32-cam-webserver: ");
    Serial.println(myName);
    Serial.print("Code Built: ");
    Serial.println(myVer);
    Serial.print("Base Release: ");
    Serial.println(baseVersion);
    // Warn if no PSRAM is detected (typically user error with board selection in the IDE)
    if(!psramFound()){
        Serial.println("\r\nFatal Error; Halting");
        while (true) {
            Serial.println("No PSRAM found; camera cannot be initialised: Please check the board config for your module.");
            delay(5000);
    if (stationCount == 0) {
        while (true) {
            Serial.println("No wifi details have been configured; we cannot connect to existing WiFi or start our own AccessPoint, there is no point in proceeding.");
            delay(5000);
    #if defined(LED_PIN)  // If we have a notification LED, set it to output
        pinMode(LED_PIN, OUTPUT);
    #endif
    // Start the SPIFFS filesystem before we initialise the camera
    if (filesystem) {
        filesystemStart();
        delay(200); // a short delay to let spi bus settle after SPIFFS init
    // Start (init) the camera
    StartCamera();
    // Now load and apply any saved preferences
    if (filesystem) {
        delay(200); // a short delay to let spi bus settle after camera init
        loadPrefs(SPIFFS);
        Serial.println("No Internal Filesystem, cannot load or save preferences");
    * Camera setup complete; initialise the rest of the hardware.
    // Start Wifi and loop until we are connected or have started an AccessPoint
    while ((WiFi.status() != WL_CONNECTED) && !accesspoint)  {
        WifiSetup();
    // Set up OTA
    if (otaEnabled) {
        // Start OTA once connected
        Serial.println("Setting up OTA");
        // Port defaults to 3232
        // ArduinoOTA.setPort(3232);
        // Hostname defaults to esp3232-[MAC]
        ArduinoOTA.setHostname(mdnsName);
        // No authentication by default
        if (strlen(otaPassword) != 0) {
            ArduinoOTA.setPassword(otaPassword);
            Serial.printf("OTA Password: %s\n\r", otaPassword);
            Serial.printf("\r\nNo OTA password has been set! (insecure)\r\n\r\n");
        ArduinoOTA
            .onStart([]() {
                String type;
                if (ArduinoOTA.getCommand() == U_FLASH)
                    type = "sketch";
                else // U_SPIFFS
                    // NOTE: if updating SPIFFS this would be the place to unmount SPIFFS using SPIFFS.end()
                    type = "filesystem";
                Serial.println("Start updating " + type);
                // Stop the camera since OTA will crash the module if it is running.
                // the unit will need rebooting to restart it, either by OTA on success, or manually by the user
                Serial.println("Stopping Camera");
                esp_err_t err = esp_camera_deinit();
                critERR = "<h1>OTA Has been started</h1><hr><p>Camera has Halted!</p>";
                critERR += "<p>Wait for OTA to finish and reboot, or <a href=\"control?var=reboot&val=0\" title=\"Reboot Now (may interrupt OTA)\">reboot manually</a> to recover</p>";
            .onEnd([]() {
                Serial.println("\r\nEnd");
            .onProgress([](unsigned int progress, unsigned int total) {
                Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
            .onError([](ota_error_t error) {
                Serial.printf("Error[%u]: ", error);
                if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
                else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
                else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
                else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
                else if (error == OTA_END_ERROR) Serial.println("End Failed");
        ArduinoOTA.begin();
        Serial.println("OTA is disabled");
        if (!MDNS.begin(mdnsName)) {
          Serial.println("Error setting up MDNS responder!");
        Serial.println("mDNS responder started");
    //MDNS Config -- note that if OTA is NOT enabled this needs prior steps!
    MDNS.addService("http", "tcp", 80);
    Serial.println("Added HTTP service to MDNS server");
    // Set time via NTP server when enabled
    if (haveTime) {
        Serial.print("Time: ");
        configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
        printLocalTime(true);
        Serial.println("Time functions disabled");
    // Gather static values used when dumping status; these are slow functions, so just do them once during startup
    sketchSize = ESP.getSketchSize();
    sketchSpace = ESP.getFreeSketchSpace();
    sketchMD5 = ESP.getSketchMD5();
    // Initialise and set the lamp
    if (lampVal != -1) {
            ledcSetup(lampChannel, pwmfreq, pwmresolution);  // configure LED PWM channel
            ledcAttachPin(LAMP_PIN, lampChannel);            // attach the GPIO pin to the channel
            if (autoLamp) setLamp(0);                        // set default value
            else setLamp(lampVal);
         #endif
        Serial.println("No lamp, or lamp disabled in config");
    // Start the camera server
    startCameraServer(httpPort, streamPort);
    if (critERR.length() == 0) {
        Serial.printf("\r\nCamera Ready!\r\nUse '%s' to connect\r\n", httpURL);
        Serial.printf("Stream viewer available at '%sview'\r\n", streamURL);
        Serial.printf("Raw stream URL is '%s'\r\n", streamURL);
        #if defined(DEBUG_DEFAULT_ON)
            debugOn();
        #else
            debugOff();
        #endif
        Serial.printf("\r\nCamera unavailable due to initialisation errors.\r\n\r\n");
    // Info line; use for Info messages; eg 'This is a Beta!' warnings, etc. as necesscary
    // Serial.print("\r\nThis is the 4.1 beta\r\n");
    // As a final init step chomp out the serial buffer in case we have recieved mis-keys or garbage during startup
     *  Just loop forever, reconnecting Wifi As necesscary in client mode
     * The stream and URI handler processes initiated by the startCameraServer() call at the
     * end of setup() will handle the camera and UI processing from now on.
    if (accesspoint) {
        // Accespoint is permanently up, so just loop, servicing the captive portal as needed
        // Rather than loop forever, follow the watchdog, in case we later add auto re-scan.
        while (millis() - start < WIFI_WATCHDOG ) {
            delay(100);
            if (otaEnabled) ArduinoOTA.handle();
            handleSerial();
            if (captivePortal) dnsServer.processNextRequest();
        // client mode can fail; so reconnect as appropriate
        static bool warned = false;
            // We are connected, wait a bit and re-check
            if (warned) {
                // Tell the user if we have just reconnected
                Serial.println("WiFi reconnected");
                warned = false;
            // loop here for WIFI_WATCHDOG, turning debugData true/false depending on serial input..
                delay(100);
                handleSerial();
            // disconnected; attempt to reconnect
            if (!warned) {
                // Tell the user if we just disconnected
                WiFi.disconnect();  // ensures disconnect is complete, wifi scan cleared
                Serial.println("WiFi disconnected, retrying");
                warned = true;
            WifiSetup();
please try this code on your code viewer
if you upload a simple code that just prints "hello world", does it work?
Such resets can result from an inadequate power supply.
