Input float from serial monitor
sorry for this dumb question, im new to arduino. i want to calculate how much user shld drink based on their weight. currently the weight is in string. is it possible for me to convert to float/ integer.
String weight;
float goal;
delay(2000);
Serial.println("What is your weight?");
if(Serial.available()){
weight = Serial.readStringUntil('\n');
    Serial.println("your weight is " + weight + "!");
String.toFloat()
set that
You could change that to:
float weight = Serial.parseFloat();
Try the following codes placing in your sketch with Newline option in the Line ending tab of SM.
  if (Serial.available())
    byte m = Serial.readBytesUntil('\n', weight, 10);
    weight[m] = '\0'; //insert null-charcater
    goal = atof(weight);   //converting string/ASCII to float
    Serial.print("your weight is: ");
    Serial.println(goal, 2);
Output:
your weight is: 69.75
