Introducing the World's First Power Supply with Super Capacitance Battery System!
Hello Everyone!
We're thrilled to introduce SourcePure Super Capacitance, the world's first portable power supply featuring a revolutionary super capacitance battery system! Designed for makers, engineers, and hobbyists, this innovative device brings unprecedented power efficiency and convenience to your projects.
Why SourcePure Super Capacitance is a Game-Changer:
  • Super Fast Charging: Fully charges in under 1 minute!
  • Extended Power: Delivers over an hour of continuous power at 1A.
  • Multiple Outputs: Offers 5V, 3.3V, and 1.8V channels, perfect for all your projects.
  • Ultra-Low Noise: Ensures clean, stable power for sensitive electronics and precision work.
  • Durable and Compact: Encased in a robust aluminum shell, ideal for both desk and field use.
Be among the first to explore this groundbreaking technology! We're launching on CrowdSupply, and by subscribing to our prelaunch page, Be the first to know when our campaign launches and get exclusive early bird offers!
Curious to see it in action? Watch Our Introduction Video to learn more about the innovative features and benefits of SourcePure Super Capacitance.
Subscribe Now on CrowdSupply
Don't miss out on the opportunity to revolutionize your power solutions with SourcePure Super Capacitance. Join us in bringing reliable, clean power to every project, from prototyping to final builds!
Feel free to ask any questions or share your thoughts!
Best regards,
RFOXiA Team
What is the capacity in mAh
@sonofcy Thanks for your question.
SourcePure comes with 2 different sources you can use:
1- Using the internal Super capacitors which requires less than 1 minute (nearly 43 seconds) of charging and can be used for 1 hour at continuous 1A. Charging the super capacitors is done by connecting SourcePure directly to main source (110V/220V) through an attachable power cable.
2- SourcePure also comes with a rechargeable 9V 3000mAH battery that can support you for 3 hours at 1A.
SourcePure Super Capacitance will be launched as a crowdfunding campaign on Crowdsupply pretty soon, you can simply subscribe now by your email so you will get an email notification once the campaign is Live
So 1AH.
Can we see a picture of your charger? From the picture of the unit, looks like it uses banana plugs, which would be a NO-NO from a safety point of view.
This is an advertisement for crowd supply funding, this device does not exist.
Directly to 110V/220V? Is there a build-in charger that converts the AC to DC? The device has an input labeled 8V-28V, that would require an average of nearly 15A at 28V for the 43 second charge, a substantial size power supply.
Just 1 Ampere hour? A typical 18650 cell has capacity 2.5 - 3.5 Ah and is a tiny fraction of the size.
200w (1)
This charger is embedded inside the device (its circuit is on the bottom side of the PCB, in the image the top side is shown) and it uses a power cable to charge the super capacitors directly from the wall (110v/220v)
SourePure embeds 400F super capacitors which can be charged at 50A 10V using an embedded fast Switch Mode Power Supply that is powered directly from the main source (110v-220v) through an attachable power cable, the charging needs less than 1 minutes (nearly 43 seconds), after charging the energy stored in the super capacitors is converted into stable 5V DC output using switching mode BUCK-BOOST converter, which is further stepped using ultra low noise LDOs to 3.3V and 1.8V
It doesn't look like plug A fits in socket B.
(Where "plug A" is 100-220AC and "socket B" says "IN 8V-28V")
And from "0.41Wh 2.7V 400F" the 0.41Wh @ 2.7V gives 0.14 hours. How do you get 5V*1A*1hr= 5Wh out of a 0.41Wh cap?
SourcePure SC as an new innovative hardware product will be launched as a crowdfunding campaign on crowdsupply, currently it's in the prelaunch phase where you can subscribe on the product showing your interest and intention to back it once the campaign is live, according to the rules in Crowdsupply we need to have a minimum number of backers so the campaign can go live, we are already got 8 times of this subscribers number and we are finalizing the campaign page design including the campaign main video, it will be live pretty soon.
Yes exactly SourcePure super capacitance has a built-it AC-DC converter which converter 110VAC/220VAC to 10V 50A that charges the super capacitors.
You can power SourcePure SC using 3 different sources:
1- Charge the internal Super capacitor in less than a minute directly from any available main source and use SourcePure SC for an hour at continuous 1A
2- Use the rechargeable 9V 3000mAH battery that can gives you 3 hours at continuous 1A.
This table compare the first two methods
Power Source Charge Source Charge Time Work time Case
Super Capacitors Directly from Main Source (110v/220v) using attachable power cable < 1 Minute 1 hours @1A Suitable when there is main source available
3000mAH rechargeable battery Using USB type C 1.5 hours 3 hours @1A Suitable for long testing outdoor
3- You can use SourcePure to turn any common power supply noisy output into an ultra-noise filtered DC output which is needed for noise sensitive circuits and RF circuits, that is the input port labeled 8V-28V like this photo
Yes the internal Super capacitor is nearly equivalent to +1AH. in additional to you can use a rechargeable 9V 3AH battery to power the device, here you can see the difference between the two ways:
A typical 18650 3.7V cell needs in average 2 hours of charging with a special charger, The internal Super capacitors system in SourcePure Super Capacitance needs less than 1 minute to be fully charged from any available main source whether 110V like in the US or 220V like in Europe and most Asian countries
some popcorn to me please :smiling_face:
The port for the power cable is completely another independent port from the one labeled "In (8V-28V)" and they are used for entirely different purposes:
1- The port where the power cable is connected is used to feed the embedded charger for the super capacitors system from AC source
2- The input port that is labeled "In (8V-28V)" is a feature that leverages the ultra-low noise output of the device where you can feed the device from any noisy external power supply and get a pure & clean & stable DC output which is very useful for engineers who work with RF circuits and noise sensitive analogue circuit, like this photo
Sorry, I made this edit above:
Exposing the embedded converter's 5V 50A output might be a useful feature.
Good question! Sounds like the claim is extremely misleading.
The actual claim is this:
Assuming 100% efficiency, 0.41 Wh = 1A @ 0.41V for one hour.
I looked at the website, and it does not seem to make the claim of "1A for one hour" at any voltage.
But it does show how one actually charges the capacitor, using the Arduino Forum's all-time favorite source of energy!
