I have my IR receiver wired as attached. When I have power running through the board, the receiver becomes very hot.
Most likely, the receiver is wired backwards and now destroyed. It may take the Arduino with it.
Post a link to the receiver module, after reading and following the directions in the "How to use this forum" post.
#include <IRremote.h>
const int RECV_PIN = 9;
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup(){
irrecv.enableIRIn();
irrecv.blink13(true);
void loop(){
if (irrecv.decode(&results)){
Serial.println(results.value, HEX);
irrecv.resume();
I see you did not bother to read the "How to use this forum" post, or post a link to the module.
That is an outstanding approach to getting help!
I have read the "How to use this forum". I don't know what the link to the module is.
(deleted)
Emmad24:
Perhaps start from the beginning. How did you acquire this module?
When you say module, do you mean the type of Arduino board? If so, I have an Arduino Uno and I got it from my professor for the class.
(deleted)
I had someone help and I got it working thank you though
Although I thought the picture would be enough because that is the type of receiver I have. Don't have a link to it.
The point is, you did not ever provide a picture of the IR receiver.
You did at one point, show a Fritzing diagram of something or other.
So someone helped you to put the connections round the right way.
