PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.1.1
Starting backend process. PID: 16512
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/bbarlow/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-07-13T13:28:18.771Z root INFO Backend Object.initialize: 5.1 ms [Finished 2.708 s after backend start]
2023-07-13T13:28:18.772Z root INFO Backend Object.configure: 4.3 ms [Finished 2.708 s after backend start]
2023-07-13T13:28:18.773Z root INFO Backend MessagingContribution.onStart: 1.6 ms [Finished 2.708 s after backend start]
2023-07-13T13:28:18.774Z root INFO Backend OSBackendApplicationContribution.configure: 0.5 ms [Finished 2.771 s after backend start]
2023-07-13T13:28:18.775Z root INFO Backend DefaultWorkspaceServer.onStart: 0.4 ms [Finished 2.771 s after backend start]
2023-07-13T13:28:18.776Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.2 ms [Finished 2.771 s after backend start]
2023-07-13T13:28:18.777Z root WARN Backend PluginLocalizationBackendContribution.initialize took longer than the expected maximum 50 milliseconds: 62.6 ms [Finished 2.771 s after backend start]
2023-07-13T13:28:18.778Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.4 ms [Finished 2.771 s after backend start]
2023-07-13T13:28:18.779Z root INFO Backend ElectronTokenBackendContribution.configure: 2.8 ms [Finished 2.774 s after backend start]
2023-07-13T13:28:18.779Z config INFO >>> Initializing CLI configuration...
2023-07-13T13:28:18.780Z root INFO Backend PluginDeployerContribution.initialize: 0.6 ms [Finished 2.775 s after backend start]
2023-07-13T13:28:18.780Z root INFO Backend ConfigServiceImpl.onStart: 1.1 ms [Finished 2.775 s after backend start]
2023-07-13T13:28:18.782Z config INFO Loading CLI configuration from c:\Users\bbarlow\.arduinoIDE\arduino-cli.yaml...
2023-07-13T13:28:18.782Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.5 ms [Finished 2.777 s after backend start]
2023-07-13T13:28:18.783Z root INFO Backend ArduinoDaemonImpl.onStart: 1.4 ms [Finished 2.778 s after backend start]
2023-07-13T13:28:18.783Z root INFO Backend NodeFileUploadService.configure: 2.6 ms [Finished 2.778 s after backend start]
2023-07-13T13:28:18.783Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-07-13T13:28:18.783Z discovery-log INFO start
2023-07-13T13:28:18.783Z discovery-log INFO start new deferred
2023-07-13T13:28:18.784Z root INFO Backend HostedPluginLocalizationService.initialize: 0.5 ms [Finished 2.779 s after backend start]
2023-07-13T13:28:18.784Z root INFO Backend BoardDiscovery.onStart: 1.3 ms [Finished 2.780 s after backend start]
2023-07-13T13:28:18.784Z root INFO Backend FileDownloadEndpoint.configure: 1.2 ms [Finished 2.781 s after backend start]
2023-07-13T13:28:18.784Z root INFO Backend AuthenticationServiceImpl.onStart: 0.5 ms [Finished 2.783 s after backend start]
2023-07-13T13:28:18.785Z root INFO Backend PluginApiContribution.configure: 0.6 ms [Finished 2.783 s after backend start]
2023-07-13T13:28:18.786Z root INFO Backend HostedPluginReader.configure: 0.8 ms [Finished 2.784 s after backend start]
2023-07-13T13:28:18.787Z root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 2.785 s after backend start]
2023-07-13T13:28:18.787Z root INFO Backend PlotterBackendContribution.configure: 1.8 ms [Finished 2.787 s after backend start]
2023-07-13T13:28:18.793Z root INFO Theia app listening on http://localhost:52119.
2023-07-13T13:28:18.793Z root INFO Finished starting backend application: 9.8 ms [Finished 2.793 s after backend start]
2023-07-13T13:28:18.795Z root WARN The local plugin referenced by local-dir:/c%3A/Users/bbarlow/.arduinoIDE/plugins does not exist.
2023-07-13T13:28:18.796Z root WARN The local plugin referenced by local-dir:/c%3A/Users/bbarlow/.arduinoIDE/extensions does not exist.
2023-07-13T13:28:18.810Z root WARN The local plugin referenced by local-dir:C:\Users\bbarlow\.arduinoIDE\plugins does not exist.
2023-07-13T13:28:18.858Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.858Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-07-13T13:28:18.861Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.867Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.8" with engines:
2023-07-13T13:28:18.868Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.869Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-07-13T13:28:18.871Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.871Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-07-13T13:28:18.872Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.872Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-07-13T13:28:18.873Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.874Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-07-13T13:28:18.874Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.875Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-07-13T13:28:18.875Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.876Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-07-13T13:28:18.876Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.883Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-07-13T13:28:18.884Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.884Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-07-13T13:28:18.886Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.887Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-07-13T13:28:18.889Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.890Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-07-13T13:28:18.895Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.909Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-07-13T13:28:18.913Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.920Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-07-13T13:28:18.932Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.941Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-07-13T13:28:18.942Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.952Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-07-13T13:28:18.952Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.959Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-07-13T13:28:18.960Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.961Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-07-13T13:28:18.964Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.965Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-07-13T13:28:18.966Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.966Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-07-13T13:28:18.967Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-13T13:28:18.968Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-07-13T13:28:18.982Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\bbarlow\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\bbarlow\\AppData\\Local\\Arduino15\\staging","user":"\\\\cscfsv02\\bbarlow$\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-07-13T13:28:18.982Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-07-13T13:28:18.983Z config INFO Loaded the CLI configuration.
2023-07-13T13:28:19.014Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/bbarlow/AppData/Local/Arduino15","sketchDirUri":"file://cscfsv02/bbarlow%24/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2023-07-13T13:28:19.015Z config INFO Validating the CLI configuration...
2023-07-13T13:28:19.024Z root INFO Resolve plugins list: 242.5 ms [Finished 3.023 s after backend start]
2023-07-13T13:28:19.040Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 13.8 ms [Finished 3.038 s after backend start]
2023-07-13T13:28:19.047Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.8" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 8.3 ms [Finished 3.047 s after backend start]
2023-07-13T13:28:19.066Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 18.9 ms [Finished 3.066 s after backend start]
2023-07-13T13:28:19.067Z config INFO The CLI config is valid.
2023-07-13T13:28:19.069Z config INFO <<< Initialized the CLI configuration.
2023-07-13T13:28:19.075Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 8.8 ms [Finished 3.075 s after backend start]
2023-07-13T13:28:19.076Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 1.1 ms [Finished 3.076 s after backend start]
2023-07-13T13:28:19.260Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 183.7 ms [Finished 3.260 s after backend start]
2023-07-13T13:28:19.436Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 176.6 ms [Finished 3.437 s after backend start]
2023-07-13T13:28:19.465Z daemon INFO INFO[0000] Using config file: c:\Users\bbarlow\.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.32.3
INFO[0000] Executing `arduino-cli daemon`
Daemon is now listening on 127.0.0.1:52120
{"IP":"127.0.0.1","Port":"52120"}
2023-07-13T13:28:19.466Z daemon INFO Daemon is running.
2023-07-13T13:28:19.819Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 372.1 ms [Finished 3.809 s after backend start]
2023-07-13T13:28:20.092Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 282.1 ms [Finished 4.092 s after backend start]
2023-07-13T13:28:20.094Z daemon INFO INFO[0000] Loading hardware from: C:\Users\bbarlow\AppData\Local\Arduino15\packages
INFO[0000] Loading package arduino from: C:\Users\bbarlow\AppData\Local\Arduino15\packages\arduino\hardware
INFO[0000] Checking signature error="opening signature file: open C:\\Users\\bbarlow\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\bbarlow\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json" signatureFile="C:\\Users\\bbarlow\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig"
INFO[0000] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0000] Loaded platform platform="arduino:avr@1.8.6"
INFO[0000] Checking existence of 'tools' path: C:\Users\bbarlow\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loading tools from dir: C:\Users\bbarlow\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loaded tool tool="arduino:arduinoOTA@1.3.0"
INFO[0000] Loaded tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0000] Loaded tool tool="arduino:avrdude@6.3.0-arduino17"
INFO[0000] Loading package builtin from: C:\Users\bbarlow\AppData\Local\Arduino15\packages\builtin
INFO[0000] Checking existence of 'tools' path: C:\Users\bbarlow\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loading tools from dir: C:\Users\bbarlow\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loaded tool tool="builtin:ctags@5.8-arduino11"
INFO[0000] Loaded tool tool="builtin:dfu-discovery@0.1.2"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.5"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.6"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.8"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.9"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.3.2"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.3.5"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.4.0"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.10.0"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.12.0"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.13.0"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.9.1"
INFO[0000] Checking signature index="C:\\Users\\bbarlow\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\bbarlow\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
INFO[0000] Adding libraries dir dir="C:\\Users\\bbarlow\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
INFO[0000] Loading libraries index file index="C:\\Users\\bbarlow\\AppData\\Local\\Arduino15\\library_index.json"
2023-07-13T13:28:20.255Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 162.9 ms [Finished 4.255 s after backend start]
2023-07-13T13:28:20.349Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 94.0 ms [Finished 4.349 s after backend start]
2023-07-13T13:28:20.351Z daemon INFO INFO[0000] Adding libraries dir dir="C:\\Users\\bbarlow\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0000] Adding libraries dir dir="\\\\cscfsv02\\bbarlow$\\Arduino\\libraries" location=user
2023-07-13T13:28:20.485Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 135.4 ms [Finished 4.485 s after backend start]
2023-07-13T13:28:20.617Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 131.9 ms [Finished 4.617 s after backend start]
2023-07-13T13:28:20.776Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 158.8 ms [Finished 4.776 s after backend start]
2023-07-13T13:28:20.830Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 54.5 ms [Finished 4.830 s after backend start]
2023-07-13T13:28:20.964Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 134.0 ms [Finished 4.964 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
2023-07-13T13:28:21.222Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 257.2 ms [Finished 5.222 s after backend start]
Opening channel for service path '/services/ide-updater'.
2023-07-13T13:28:21.395Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 173.7 ms [Finished 5.395 s after backend start]
2023-07-13T13:28:21.441Z daemon INFO WARN[0002] Error loading library error="rpc error: code = Internal desc = loading library from \\\\cscfsv02\\bbarlow$\\Arduino\\libraries\\package-3111619977: invalid library: no header files found"
WARN[0002] Error loading library error="rpc error: code = Internal desc = loading library from \\\\cscfsv02\\bbarlow$\\Arduino\\libraries\\package-895582910: invalid library: no header files found"
2023-07-13T13:28:21.456Z discovery-log INFO start request start watch
2023-07-13T13:28:21.457Z discovery-log INFO start requested start watch
2023-07-13T13:28:21.457Z discovery-log INFO start resolved watching
2023-07-13T13:28:21.657Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 262.0 ms [Finished 5.658 s after backend start]
2023-07-13T13:28:21.658Z daemon INFO INFO[0002] starting discovery builtin:mdns-discovery process
INFO[0002] starting discovery builtin:serial-discovery process
INFO[0002] started discovery builtin:serial-discovery process
INFO[0002] sending command HELLO 1 "arduino-cli 0.32.3" to discovery builtin:serial-discovery
INFO[0002] started discovery builtin:mdns-discovery process
INFO[0002] sending command HELLO 1 "arduino-cli 0.32.3" to discovery builtin:mdns-discovery
INFO[0002] from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1
INFO[0002] sending command START_SYNC to discovery builtin:serial-discovery
INFO[0002] from discovery builtin:serial-discovery received message type: start_sync, message: OK
INFO[0002] from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
INFO[0002] sending command START_SYNC to discovery builtin:mdns-discovery
INFO[0002] from discovery builtin:mdns-discovery received message type: start_sync, message: OK
INFO[0002] from discovery builtin:serial-discovery received message type: add, port: COM1
2023-07-13T13:28:21.662Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-07-13T13:28:21.834Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 176.6 ms [Finished 5.834 s after backend start]
2023-07-13T13:28:22.087Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 252.6 ms [Finished 6.087 s after backend start]
2023-07-13T13:28:22.088Z root INFO Deploy plugins list: 242.5 ms [Finished 6.088 s after backend start]
2023-07-13T13:28:22.101Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 593.2 ms [Finished 2.966 s after frontend start]
2023-07-13T13:28:22.147Z root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 255.5 ms [Finished 3.248 s after frontend start]
2023-07-13T13:28:22.329Z root WARN Frontend c.onStart took longer than the expected maximum 100 milliseconds: 135.7 ms [Finished 3.436 s after frontend start]
2023-07-13T13:28:22.372Z root INFO Start frontend contributions: 1194.1 ms [Finished 3.453 s after frontend start]
2023-07-13T13:28:22.373Z root INFO Changed application state from 'init' to 'started_contributions'.
2023-07-13T13:28:22.408Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2023-07-13T13:28:22.409Z root INFO >>> Restoring the layout state...
2023-07-13T13:28:22.412Z root INFO ------- SERIALIZED LAYOUT DATA -------
2023-07-13T13:28:22.418Z root INFO {"version":5,"mainPanel":{"main":null},"mainPanelPinned":[],"bottomPanel":{"config":{"main":null},"pinned":[],"expanded":false},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}]},"rightPanel":{"type":"sidepanel","items":[]}}
2023-07-13T13:28:22.419Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2023-07-13T13:28:22.442Z root INFO <<< The layout has been successfully restored.
2023-07-13T13:28:22.455Z root INFO Initialize the workbench layout: 50.0 ms [Finished 3.557 s after frontend start]
2023-07-13T13:28:22.475Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2023-07-13T13:28:22.531Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b] Waiting for backend deployment: 196.1 ms [Finished 3.642 s after frontend start]
2023-07-13T13:28:23.289Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652) starting instance
2023-07-13T13:28:23.701Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b] Sync of 21 plugins: 1139.4 ms [Finished 4.782 s after frontend start]
2023-07-13T13:28:23.707Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][marus25.cortex-debug]: Loaded contributions.
2023-07-13T13:28:23.709Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][arduino.vscode-arduino-tools]: Loaded contributions.
2023-07-13T13:28:23.709Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][vscode.cpp]: Loaded contributions.
2023-07-13T13:28:23.710Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][vscode.json]: Loaded contributions.
2023-07-13T13:28:23.711Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][vscode.json-language-features]: Loaded contributions.
2023-07-13T13:28:23.711Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-bg]: Loaded contributions.
2023-07-13T13:28:23.712Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
2023-07-13T13:28:23.713Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
2023-07-13T13:28:23.713Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
2023-07-13T13:28:23.717Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
2023-07-13T13:28:23.717Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-hu]: Loaded contributions.
2023-07-13T13:28:23.719Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
2023-07-13T13:28:23.720Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
2023-07-13T13:28:23.722Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-ko]: Loaded contributions.
2023-07-13T13:28:23.722Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
2023-07-13T13:28:23.723Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-pl]: Loaded contributions.
2023-07-13T13:28:23.724Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
2023-07-13T13:28:23.725Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
2023-07-13T13:28:23.725Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
2023-07-13T13:28:23.726Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-uk]: Loaded contributions.
2023-07-13T13:28:23.727Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
2023-07-13T13:28:23.731Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b] Load contributions of 21 plugins: 32.0 ms [Finished 4.814 s after frontend start]
2023-07-13T13:28:24.215Z root INFO Frontend application start: 2370.0 ms [Finished 8.213 s after backend start]
2023-07-13T13:28:24.223Z root INFO Replace loading indicator with ready workbench UI (animation): 1288.6 ms [Finished 4.858 s after frontend start]
2023-07-13T13:28:24.223Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2023-07-13T13:28:24.224Z root WARN Linked preference "workbench.colorCustomizations" not found. Source: "editor.bracketPairColorization.enabled"
2023-07-13T13:28:24.236Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2023-07-13T13:28:24.237Z root WARN a registered grammar configuration for 'cpp' language is overridden
Checking for update
Update for version 2.1.1 is not available (latest version: 2.1.1, downgrade is allowed).
2023-07-13T13:28:24.543Z daemon INFO INFO[0005] Updating libraries index
2023-07-13T13:28:24.560Z root INFO core-client-provider [library-index]
2023-07-13T13:28:24.561Z root INFO core-client-provider [platform-index]
2023-07-13T13:28:24.568Z daemon INFO INFO[0005] Starting download url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
INFO[0005] Updating index url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
INFO[0005] Starting download url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-07-13T13:28:25.034Z root ERROR ---- !!!SLOW!!! DURATION: search took 601.025 ms. Args: [{"type":"Updatable"}] ----
2023-07-13T13:28:25.303Z sketches-service WARN Mismatching sketch file <fade2.ino> and sketch folder name <LEDFader1>. Skipping
2023-07-13T13:28:25.563Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): PluginManagerExtImpl/init()
2023-07-13T13:28:25.565Z sketches-service WARN Mismatching sketch file <fade2.ino> and sketch folder name <LEDFader1>. Skipping
2023-07-13T13:28:25.566Z sketches-service WARN Mismatching sketch file <fade2.ino> and sketch folder name <LEDFader1>. Skipping
2023-07-13T13:28:25.567Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(cortex-debug@1.5.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.579Z root INFO [hosted-plugin: 7652] Debugger contribution has been registered: cortex-debug
2023-07-13T13:28:25.582Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(vscode-arduino-tools@0.0.2-beta.8 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.583Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(cpp@1.52.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.585Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(json@1.46.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.586Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(json-language-features@1.46.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.588Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(vscode-language-pack-bg@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.589Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(vscode-language-pack-cs@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.592Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(vscode-language-pack-de@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.594Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(vscode-language-pack-es@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.595Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(vscode-language-pack-fr@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.596Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(vscode-language-pack-hu@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.598Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(vscode-language-pack-it@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.600Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(vscode-language-pack-ja@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.601Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(vscode-language-pack-ko@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.602Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(vscode-language-pack-nl@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.604Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(vscode-language-pack-pl@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.605Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(vscode-language-pack-pt-BR@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.607Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(vscode-language-pack-ru@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.611Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(vscode-language-pack-tr@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.612Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(vscode-language-pack-uk@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.613Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): initializing(vscode-language-pack-zh-hans@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:25.622Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2023-07-13T13:28:25.672Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][marus25.cortex-debug]: Started plugin.
2023-07-13T13:28:25.676Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][arduino.vscode-arduino-tools]: Started plugin.
2023-07-13T13:28:25.676Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][vscode.cpp]: Started plugin.
2023-07-13T13:28:25.677Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][vscode.json]: Started plugin.
2023-07-13T13:28:25.678Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][vscode.json-language-features]: Started plugin.
2023-07-13T13:28:25.678Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-bg]: Started plugin.
2023-07-13T13:28:25.679Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-cs]: Started plugin.
2023-07-13T13:28:25.679Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-de]: Started plugin.
2023-07-13T13:28:25.680Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-es]: Started plugin.
2023-07-13T13:28:25.680Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-fr]: Started plugin.
2023-07-13T13:28:25.681Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-hu]: Started plugin.
2023-07-13T13:28:25.681Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-it]: Started plugin.
2023-07-13T13:28:25.682Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-ja]: Started plugin.
2023-07-13T13:28:25.682Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-ko]: Started plugin.
2023-07-13T13:28:25.682Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-nl]: Started plugin.
2023-07-13T13:28:25.683Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-pl]: Started plugin.
2023-07-13T13:28:25.683Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-pt-br]: Started plugin.
2023-07-13T13:28:25.684Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-ru]: Started plugin.
2023-07-13T13:28:25.684Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-tr]: Started plugin.
2023-07-13T13:28:25.685Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-uk]: Started plugin.
2023-07-13T13:28:25.685Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b][ms-ceintl.vscode-language-pack-zh-hans]: Started plugin.
2023-07-13T13:28:25.728Z root INFO [hosted-plugin: 7652] PLUGIN_HOST(7652): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2023-07-13T13:28:25.774Z root INFO [hosted-plugin: 7652] Debug configuration provider has been registered: cortex-debug, trigger: 1
2023-07-13T13:28:25.779Z root INFO [hosted-plugin: 7652] GDB server console created
2023-07-13T13:28:25.789Z root INFO [06135b83-a061-4384-85a0-9430089a4e7b] Start of 21 plugins: 2077.7 ms [Finished 6.903 s after frontend start]
2023-07-13T13:28:27.118Z daemon INFO INFO[0007] Loading hardware from: C:\Users\bbarlow\AppData\Local\Arduino15\packages
2023-07-13T13:28:27.121Z daemon INFO INFO[0007] Loading package arduino from: C:\Users\bbarlow\AppData\Local\Arduino15\packages\arduino\hardware
2023-07-13T13:28:27.131Z daemon INFO INFO[0007] Checking signature error="opening signature file: open C:\\Users\\bbarlow\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\bbarlow\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json" signatureFile="C:\\Users\\bbarlow\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig"
2023-07-13T13:28:27.133Z daemon INFO INFO[0007] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0007] Loaded platform platform="arduino:avr@1.8.6"
2023-07-13T13:28:27.133Z daemon INFO INFO[0007] Checking existence of 'tools' path: C:\Users\bbarlow\AppData\Local\Arduino15\packages\arduino\tools
INFO[0007] Loading tools from dir: C:\Users\bbarlow\AppData\Local\Arduino15\packages\arduino\tools
2023-07-13T13:28:27.135Z daemon INFO INFO[0007] Loaded tool tool="arduino:arduinoOTA@1.3.0"
2023-07-13T13:28:27.135Z daemon INFO INFO[0007] Loaded tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2023-07-13T13:28:27.136Z daemon INFO INFO[0007] Loaded tool tool="arduino:avrdude@6.3.0-arduino17"
2023-07-13T13:28:27.138Z daemon INFO INFO[0007] Loading package builtin from: C:\Users\bbarlow\AppData\Local\Arduino15\packages\builtin
2023-07-13T13:28:27.139Z daemon INFO INFO[0007] Checking existence of 'tools' path: C:\Users\bbarlow\AppData\Local\Arduino15\packages\builtin\tools
INFO[0007] Loading tools from dir: C:\Users\bbarlow\AppData\Local\Arduino15\packages\builtin\tools
2023-07-13T13:28:27.140Z daemon INFO INFO[0007] Loaded tool tool="builtin:ctags@5.8-arduino11"
2023-07-13T13:28:27.145Z daemon INFO INFO[0007] Loaded tool tool="builtin:dfu-discovery@0.1.2"
INFO[0007] Loaded tool tool="builtin:mdns-discovery@1.0.5"
INFO[0007] Loaded tool tool="builtin:mdns-discovery@1.0.6"
INFO[0007] Loaded tool tool="builtin:mdns-discovery@1.0.8"
INFO[0007] Loaded tool tool="builtin:mdns-discovery@1.0.9"
INFO[0007] Loaded tool tool="builtin:serial-discovery@1.3.2"
INFO[0007] Loaded tool tool="builtin:serial-discovery@1.3.5"
INFO[0007] Loaded tool tool="builtin:serial-discovery@1.4.0"
INFO[0007] Loaded tool tool="builtin:serial-monitor@0.10.0"
INFO[0007] Loaded tool tool="builtin:serial-monitor@0.12.0"
INFO[0007] Loaded tool tool="builtin:serial-monitor@0.13.0"
INFO[0007] Loaded tool tool="builtin:serial-monitor@0.9.1"
2023-07-13T13:28:27.156Z daemon INFO INFO[0007] Checking signature index="C:\\Users\\bbarlow\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\bbarlow\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2023-07-13T13:28:27.161Z discovery-log INFO {"eventType":"remove","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-07-13T13:28:27.164Z daemon INFO INFO[0007] sending command QUIT to discovery builtin:serial-discovery
INFO[0007] from discovery builtin:serial-discovery received message type: quit, message: OK
INFO[0007] killing discovery builtin:serial-discovery process
INFO[0007] Discovery event channel closed builtin:serial-discovery. Exiting goroutine.
2023-07-13T13:28:27.167Z root INFO Attached boards and available ports changed:
2023-07-13T13:28:27.168Z root INFO - Port is no longer available on COM1 Serial Port
2023-07-13T13:28:27.168Z root INFO ------------------------------------------
2023-07-13T13:28:27.187Z daemon INFO INFO[0007] Closed and removed discovery builtin:serial-discovery
INFO[0007] sending command QUIT to discovery builtin:mdns-discovery
2023-07-13T13:28:27.188Z daemon INFO INFO[0007] from discovery builtin:mdns-discovery received message type: quit, message: OK
INFO[0007] killing discovery builtin:mdns-discovery process
INFO[0007] Discovery event channel closed builtin:mdns-discovery. Exiting goroutine.
2023-07-13T13:28:27.202Z daemon INFO INFO[0007] Closed and removed discovery builtin:mdns-discovery
2023-07-13T13:28:27.204Z daemon INFO INFO[0007] starting discovery builtin:serial-discovery process
2023-07-13T13:28:27.207Z daemon INFO INFO[0007] started discovery builtin:serial-discovery process
INFO[0007] sending command HELLO 1 "arduino-cli 0.32.3" to discovery builtin:serial-discovery
2023-07-13T13:28:27.235Z daemon INFO INFO[0007] from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1
INFO[0007] sending command START_SYNC to discovery builtin:serial-discovery
2023-07-13T13:28:27.236Z daemon INFO INFO[0007] from discovery builtin:serial-discovery received message type: start_sync, message: OK
2023-07-13T13:28:27.238Z daemon INFO INFO[0007] starting discovery builtin:mdns-discovery process
2023-07-13T13:28:27.242Z daemon INFO INFO[0007] started discovery builtin:mdns-discovery process
INFO[0007] sending command HELLO 1 "arduino-cli 0.32.3" to discovery builtin:mdns-discovery
2023-07-13T13:28:27.250Z daemon INFO INFO[0007] from discovery builtin:serial-discovery received message type: add, port: COM1
2023-07-13T13:28:27.252Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-07-13T13:28:27.282Z daemon INFO INFO[0007] from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
2023-07-13T13:28:27.284Z daemon INFO INFO[0007] sending command START_SYNC to discovery builtin:mdns-discovery
2023-07-13T13:28:27.293Z daemon INFO INFO[0007] from discovery builtin:mdns-discovery received message type: start_sync, message: OK
2023-07-13T13:28:27.294Z root INFO Attached boards and available ports changed:
2023-07-13T13:28:27.294Z root INFO - New port is available on COM1 Serial Port
2023-07-13T13:28:27.295Z root INFO ------------------------------------------
2023-07-13T13:28:27.323Z daemon INFO INFO[0007] Adding libraries dir dir="C:\\Users\\bbarlow\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
2023-07-13T13:28:27.324Z daemon INFO INFO[0007] Loading libraries index file index="C:\\Users\\bbarlow\\AppData\\Local\\Arduino15\\library_index.json"
2023-07-13T13:28:27.532Z daemon INFO INFO[0008] Adding libraries dir dir="C:\\Users\\bbarlow\\AppData\\Local\\Arduino15\\libraries" location=ide
2023-07-13T13:28:27.537Z daemon INFO INFO[0008] Adding libraries dir dir="\\\\cscfsv02\\bbarlow$\\Arduino\\libraries" location=user
2023-07-13T13:28:27.848Z daemon INFO WARN[0008] Error loading library error="rpc error: code = Internal desc = loading library from \\\\cscfsv02\\bbarlow$\\Arduino\\libraries\\package-3111619977: invalid library: no header files found"
WARN[0008] Error loading library error="rpc error: code = Internal desc = loading library from \\\\cscfsv02\\bbarlow$\\Arduino\\libraries\\package-895582910: invalid library: no header files found"
Closing channel on service path '/services/electron-window-ext'.
Closing channel on service path '/services/electron-window'.
Closing channel on service path '/services/ide-updater'.
2023-07-13T13:28:37.929Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 105.7 ms [Finished 1.045 s after frontend start]
2023-07-13T13:28:38.296Z root INFO Start frontend contributions: 326.6 ms [Finished 1.206 s after frontend start]
2023-07-13T13:28:38.297Z root INFO Changed application state from 'init' to 'started_contributions'.
2023-07-13T13:28:38.300Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2023-07-13T13:28:38.303Z root INFO >>> Restoring the layout state...
2023-07-13T13:28:38.303Z root INFO <<< Nothing to restore.
2023-07-13T13:28:38.304Z root INFO Initialize the workbench layout: 15.9 ms [Finished 1.239 s after frontend start]
2023-07-13T13:28:38.305Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2023-07-13T13:28:38.327Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0] Waiting for backend deployment: 262.6 ms [Finished 1.466 s after frontend start]
2023-07-13T13:28:39.088Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960) starting instance
2023-07-13T13:28:39.342Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0] Sync of 21 plugins: 985.4 ms [Finished 2.451 s after frontend start]
2023-07-13T13:28:39.346Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][marus25.cortex-debug]: Loaded contributions.
2023-07-13T13:28:39.348Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][arduino.vscode-arduino-tools]: Loaded contributions.
2023-07-13T13:28:39.348Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][vscode.cpp]: Loaded contributions.
2023-07-13T13:28:39.349Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][vscode.json]: Loaded contributions.
2023-07-13T13:28:39.350Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][vscode.json-language-features]: Loaded contributions.
2023-07-13T13:28:39.351Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-bg]: Loaded contributions.
2023-07-13T13:28:39.352Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
2023-07-13T13:28:39.353Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
2023-07-13T13:28:39.353Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
2023-07-13T13:28:39.354Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
2023-07-13T13:28:39.355Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-hu]: Loaded contributions.
2023-07-13T13:28:39.355Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
2023-07-13T13:28:39.356Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
2023-07-13T13:28:39.356Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-ko]: Loaded contributions.
2023-07-13T13:28:39.357Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
2023-07-13T13:28:39.357Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-pl]: Loaded contributions.
2023-07-13T13:28:39.358Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
2023-07-13T13:28:39.363Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
2023-07-13T13:28:39.367Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
2023-07-13T13:28:39.367Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-uk]: Loaded contributions.
2023-07-13T13:28:39.368Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
2023-07-13T13:28:39.369Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0] Load contributions of 21 plugins: 30.6 ms [Finished 2.482 s after frontend start]
2023-07-13T13:28:40.054Z root INFO Frontend application start: 2158.6 ms [Finished 24.054 s after backend start]
2023-07-13T13:28:40.057Z root INFO Replace loading indicator with ready workbench UI (animation): 1564.2 ms [Finished 2.808 s after frontend start]
2023-07-13T13:28:40.070Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2023-07-13T13:28:40.073Z root WARN Linked preference "workbench.colorCustomizations" not found. Source: "editor.bracketPairColorization.enabled"
2023-07-13T13:28:40.074Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2023-07-13T13:28:40.075Z root WARN a registered grammar configuration for 'cpp' language is overridden
2023-07-13T13:28:40.247Z root INFO Executing startup tasks:
2023-07-13T13:28:40.248Z root INFO - 'arduino-use-inherited-boards-config' , args: [{}]
2023-07-13T13:28:40.352Z sketches-service WARN Mismatching sketch file <fade2.ino> and sketch folder name <LEDFader1>. Skipping
2023-07-13T13:28:40.617Z sketches-service WARN Mismatching sketch file <fade2.ino> and sketch folder name <LEDFader1>. Skipping
2023-07-13T13:28:40.620Z sketches-service WARN Mismatching sketch file <fade2.ino> and sketch folder name <LEDFader1>. Skipping
2023-07-13T13:28:40.959Z root ERROR ---- !!!SLOW!!! DURATION: search took 337.525 ms. Args: [{"type":"Updatable"}] ----
2023-07-13T13:28:41.146Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): PluginManagerExtImpl/init()
2023-07-13T13:28:41.156Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): initializing(cortex-debug@1.5.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:41.166Z root INFO [hosted-plugin: 1960] Debugger contribution has been registered: cortex-debug
2023-07-13T13:28:41.169Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): initializing(vscode-arduino-tools@0.0.2-beta.8 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:41.170Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): initializing(cpp@1.52.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:41.173Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): initializing(json@1.46.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:41.173Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): initializing(json-language-features@1.46.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:41.174Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): initializing(vscode-language-pack-bg@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:41.176Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): initializing(vscode-language-pack-cs@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:41.177Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): initializing(vscode-language-pack-de@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:41.181Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): initializing(vscode-language-pack-es@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(1960): initializing(vscode-language-pack-fr@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:41.182Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): initializing(vscode-language-pack-hu@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:41.183Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): initializing(vscode-language-pack-it@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:41.185Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): initializing(vscode-language-pack-ja@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:41.186Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): initializing(vscode-language-pack-ko@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:41.187Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): initializing(vscode-language-pack-nl@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:41.187Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): initializing(vscode-language-pack-pl@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:41.188Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): initializing(vscode-language-pack-pt-BR@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:41.189Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): initializing(vscode-language-pack-ru@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:41.190Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): initializing(vscode-language-pack-tr@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:41.191Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): initializing(vscode-language-pack-uk@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:41.192Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): initializing(vscode-language-pack-zh-hans@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-13T13:28:41.210Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2023-07-13T13:28:41.264Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][marus25.cortex-debug]: Started plugin.
2023-07-13T13:28:41.267Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][arduino.vscode-arduino-tools]: Started plugin.
2023-07-13T13:28:41.268Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][vscode.cpp]: Started plugin.
2023-07-13T13:28:41.269Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][vscode.json]: Started plugin.
2023-07-13T13:28:41.269Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][vscode.json-language-features]: Started plugin.
2023-07-13T13:28:41.270Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-bg]: Started plugin.
2023-07-13T13:28:41.270Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-cs]: Started plugin.
2023-07-13T13:28:41.271Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-de]: Started plugin.
2023-07-13T13:28:41.272Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-es]: Started plugin.
2023-07-13T13:28:41.272Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-fr]: Started plugin.
2023-07-13T13:28:41.273Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-hu]: Started plugin.
2023-07-13T13:28:41.273Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-it]: Started plugin.
2023-07-13T13:28:41.274Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-ja]: Started plugin.
2023-07-13T13:28:41.274Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-ko]: Started plugin.
2023-07-13T13:28:41.275Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-nl]: Started plugin.
2023-07-13T13:28:41.275Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-pl]: Started plugin.
2023-07-13T13:28:41.276Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-pt-br]: Started plugin.
2023-07-13T13:28:41.276Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-ru]: Started plugin.
2023-07-13T13:28:41.277Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-tr]: Started plugin.
2023-07-13T13:28:41.277Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-uk]: Started plugin.
2023-07-13T13:28:41.278Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0][ms-ceintl.vscode-language-pack-zh-hans]: Started plugin.
2023-07-13T13:28:41.308Z root INFO [hosted-plugin: 1960] PLUGIN_HOST(1960): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2023-07-13T13:28:41.355Z root INFO [hosted-plugin: 1960] Debug configuration provider has been registered: cortex-debug, trigger: 1
2023-07-13T13:28:41.363Z root INFO [hosted-plugin: 1960] GDB server console created
2023-07-13T13:28:41.372Z root INFO [72cc8e76-bd48-4bd4-a205-49aa070e3da0] Start of 21 plugins: 2010.5 ms [Finished 4.513 s after frontend start]
