Hie, I’m looking for ideas, I have a voice module an ISD1760 driven by arduino uno. My problem is that I would like to trigger a specific message (among 5 messages previously recorded manually on the ISD) via a specific event of the arduino
Ex: if x < 4
( play a specific message)
Someone can enlighten me because I am pretty weak in prog syntax to access and read messages that are somewhere !!! in the memory of the ISD1760 .
I have the datasheet and i have been going through it, you need to specify the set_record start and end address for you to be able to set_play from that address, but im very new to this im not sure how to go about that
There is code to play from current pointer on this forum but it doesn’t specify how to then play from a specific memory location
