I came across an ISD1760 module and wanted to incorporate it into an alarm messaging project. I became despondent as I could not find an end to end description of how to control these sound chips.
Looking back at the forum posts on ISD17xx there is a bunch of posts all closed some 10 years ago but I could not find a solution to the previously posted queries.
Then I found this post https://www.open-electronics.org/a-voice-shield-for-arduino-give-voice-to-your-ideas/#comment-13245 which describes how to build an ISD17xx Arduino Uno shield.
The shield building is by the way but the post included links to download a <ISD1700.h> library and a demo sketch.
The sketch supports command line type control through the Arduio serial monitor via SPI.
Also at the link, there is a downloadable Windows app which is supposed to be able to copy prepared audio files onto the ISD17xx and crucially give you the exact start and end address so you can use the random access set_play option to play them back. I could not get this to install.
However the demo sketch has an 'm' command that allows you to set a base address (m0, m1, m2 etc) so that if you then use the 'r' command to do a set_rec, at least you know where the recording starts and you can easily guess the end address by trial and error until your playback is not chopped short.
I'm just posting this to try an save others time looking for such a solution.
