Issue with ESP32cam - upload times out!
Issue with ESP32cam
Worked fine at first...
Sad... I may of hooked it up wrong a few days ago. Can it take 6V to the pin screen printed as 5V? I assume yes becasue I saw a VR on board. It is a AITHINKER model.
Pretty much the example sketch used.... times out...
I tried 3.3 to the VCC, then 5V to VCC from an esp32 (dummy shorted to reset), then moved that to 5V on cam, then trashed that 32 and used an 8266. I then tried switching Tx and Rx. Nothing. LED blinks when it is reset. Oh, GP0 is grounded.
Oh, actually now the LED is dimmly flashing brighter about 2hz 10% duty. Stil bright blink on reset. Serial mon is quiet.
Broke - know i had another module but forgot what i did with it!!
Sketch uses 2100647 bytes (66%) of program storage space. Maximum is 3145728 bytes.
Global variables use 53544 bytes (16%) of dynamic memory, leaving 274136 bytes for local variables. Maximum is 327680 bytes.
C:\Users\matt\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\2.6.1/esptool.exe --chip esp32 --port COM4 --baud 460800 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 C:\Users\matt\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/partitions/boot_app0.bin 0x1000 C:\Users\matt\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/bin/bootloader_qio_80m.bin 0x10000 C:\Users\matt\AppData\Local\Temp\arduino_build_172825/CameraWebServer.ino.bin 0x8000 C:\Users\matt\AppData\Local\Temp\arduino_build_172825/CameraWebServer.ino.partitions.bin
esptool.py v2.6
Serial port COM4
Connecting........_____....._____....._____....._____....._____....._____.....____An error occurred while uploading the sketch
_
A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
