Issues with attiny85 connection
I've spent this afternoon attempting to program an attiny85 I purchased a while ago with an arduino uno. It worked fine last night however I noticed the program didn't seem to be running completely smoothly the next morning so I tried to test the chip with the generic blink program, which is when problems began. I'm using the wiring diagram from:
And I have checked an endless amount of times the wiring is right. However after uploading the arduino ISP sketch to my uno, when I connect the attiny85 to the pins the yellow L light on the board goes off, and when I try to upload a sketch I get an invalid device signature error. Is this something I'm doing wrong or is the attiny bricked?
Please do this:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Attempt an upload
  • After the upload fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the forum toolbar).
Do you have the 10uf cap from the Uno reset to ground to disable the Uno reset?
It worked at one time and now does not ?
One way of achieving this is to select the wrong board type and choose the burn boot loader option which sets the fuses to expect a non existing crystal oscillator.
Incidentally, the diagram here http://highlowtech.org/?p=1706 is a good example of a bad Fritzing diagram where important detail (pin numbers etc. are obscured) and a simple connections table would have been far more useful.
Are you programming your tiny on a solderless breadboard? This has given me problems on more than one occasion. If so, try wiggling the connections around a bit, or move to a different breadboard.
It seems like the wide shape of the pins on a pdip chip can spread the pinchers inside the breadboard to the point that thin wires don't always make good contact.
