Hi?? Samebody have the JDY-10 BLE BLUETOOTH 4.0 Datasheet and PINMAP? I Need localize the PIN RESET here to modify firmware
I hope this helps. I have yet to work with them if you find any good example codes send them my way lol
This is the best I can get, I believe that the JDY-10 is very similar to the HM-10 cc2541.
I was going to upload a picture but it;s saying it's too big.
on mine the reset is pin #1.
for example if the bottom edge with all the pins is towards your body start from the top and go in a anti-clockwise motion for pin 1, 2, etc. I wish the picture had loaded.
Hi Raptor, I'm currently working with this module, did you find out the purpose of pins 1-16? I'm interested to share information on the jdy-10, I'm only able to to use it as a slave.
Has anyone got this module to submit data, aka "passthrough" mode? There's no AT+MODE command and no mode pin to pull low/high!
Regards,
Andrew
Here is my JDY-10 pinout.
Can anyone help me out with the configuartion of the GPIO and generation of the PWM on JDY10 V1.8 ?
Suche jemand der mir erklärt wie ich eine Verbindung zum JDY-10-V2.4 aufbauen kann.
Wie man in den AT Befehl Modus kommt.
Good day!
Please somebody help me. My JDY-10 displayed in HM10 Bluetooth Serial Lite and successfully connected, but in iPhone Bluetooth settings only displayed when connected (device name JDY-10-v2.4). When connection closed JDY-10 don't displayed in iPhone settings.
I found this if it helps anyone. It was in chinese i had to have google translate it.
User-Manual-3511895.pdf (246 KB)
