Keyboard shortcut for find in all files?
Following on How to "find in all files" in IDE 2.0? ...
How do I open "find in all files" from a keyboard shortcut? ctrl+shift+F opens a web browser.
Most other editors (Sublime text, VSCode, IntelliJ, etc) use ctrl+shift+F for advanced find.
Your topic was moved to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Thank you
Well now that the conversation is derailed, can you be specific about which way I could use it better? I'd rather not make assumptions when you could tell me.
Hi @aggrav8d. You can use the "Search: Find in Files" command.
A keyboard shortcut is not configured for this command by default, but you can configure one according to your preferences. I'll provide instructions:
  1. Select File > Advanced > Keyboard Shortcuts (or Arduino IDE > Advanced > Keyboard Shortcuts for macOS users) from the Arduino IDE menus.
    The "Keyboard Shortcuts" tab will open in the Arduino IDE window.
  2. Type Search: Find in Files in the "Search keybindings" field of the "Keyboard Shortcuts" tab.
  3. Hover the mouse pointer over the "** Search: Find in Files**" row in the search results.
    A pencil icon ("Edit Keybinding") will appear at the left side of the row.
  4. Click the pencil icon.
    The "Edit Keybinding for ___" dialog will open.
  5. The input field in the dialog contains a text representation of the keyboard shortcut. Adjust this according to your preferences.
    ā“˜ Notes about the syntax:
    • For most keys you can simply use the name of the key (i.e., a, 3, /, f2).
    • Special key names:
      • cmd - Command key (⌘) on macOS.
      • ctrlcmd - Ctrl key on Linux/Windows, Command key (⌘) on macOS.
    • Use the + separator for key combinations (e.g., ctrl+s).
    • Use a space separator for key sequences (AKA "chords") (e.g., ctrl+k ctrl+i).
  6. Click the "OK" button in the dialog.
  7. Click the X icon on the "Keyboard Shortcuts" tab.
Great!
How do i clear the "find in reference" that is now conflicting? It won't let me set the value to nothing.
Unfortunately there isn't a way to disable keyboard shortcuts via the convenient keyboard shortcuts configuration GUI, but it can be done by manually adding a "removal entry" to the data file where Arduino IDE stores your custom keyboard shortcuts settings.
You can do that by following these instructions:
  2. Click the { } icon at the right side of the tab bar.
    A "keymaps.json" tab will open in a split editor panel.
  3. Add the following text to the "keymaps.json" tab:
        "command": "-arduino-find-in-reference",
        "keybinding": "CtrlCmd+Shift+F"
    :exclamation: If there is existing content in the "keymaps.json" tab, you must merge the above entry into the content.
  4. Click the X icon on the "keymaps.json" tab.
  5. If you get a save confirmation dialog, click the "SAVE" button.
  6. Click the X icon on the "Keyboard Shortcuts" tab.
Please let me know if you have any questions or problems while following those instructions.
You originally posted this in 'Programming', but it's not a question about programming - it's a question specifically about the v2.x IDE.
