I haven't used arduino before, but I'm working on a project and looking for advice. The project is a puzzle where various puzzle pieces are arranged in a grid and can be rotated in increments of 90 degrees, the puzzle is solved when the pieces are all rotated the right way. The puzzle is part of a larger project of connected puzzles.
I want to implement this by mounting all the pieces on dials that can rotate in increments of 90 degrees, and are arranged in a grid. Some sort of electronic sensor would be able to tell when all the dials are rotated the right way and send a signal that the puzzle is solved. I think everything would be connected to a single esp
Does this goal make sense at all? if so, what sorts of hardware would be useful for it? where could i find a dial that can rotate increments of 90 degrees only?
if not, what other approach makes sense?
Maybe my english is not so good, or the description is too vage.
Is not just a detection problem, but also a construction problem. What materials are you going to use? Is this just a 3d printed puzzle? It has different colors? Different shapes? Will it be durable or just cardboard?
I suggest doing some research about all the posibilities and then narrow the search to what is used on similar devices.
Multimeters use traces, this might be a possibility to detect possition. .
Other posibility could be color detection (if the puzzles can be designed with different colors on every piece) or light detection (is pieces have different shapes).
You could use a simple switch or something like this:
This is the best and cheapest solution, all the others, which would work, are way too expensive or complex, and not all would have the positive click that you need on this sort of project.
You can get switches from many suppliers, even eBay. Look for a four position switch. If necessary ask the eBay supplier what sort of switch this is.
You have to make sure that these switches will be able to make continuous rotation, and not just have four positions and then stop, meaning you have to wind it back when it reaches the end.
Depending on the constriction of the switch, it could be modified to continuous rotation by filling away an end stop. I have done this myself in many projects.
Are you intending to buy all the components? From what I read from your description your device could be made quite simply and use a conductive rotation piece and a contact point at the correct orientation. Then a battery and LED would tell when the entire board had all the pieces correctly positioned.
