I'm trying to use an L239D H-Bridge motor driver but I'm only able to control one motor at a time.
The motors and the controllers aren't defective.
If I unplug one motor the other one spins.
The motors are those common 3-12V dc motors.
My power source is a 9V Battery.
The motors seem to be running at only 3V.
The motors draw around 200mA @ 3V
The L239D Is from an Arduino Starter Kit (From arduino.cc)
Circuit + code: https://mechatrofice.com/arduino/l293d-motor-driver (I didn't write the code)
A common problem when people use smoke alarm batteries to power motors. Use AA cells in series to get 12 volts or so and try that.
Paul
Still seem to have the same problem.
I'm powering it with my lab bench power supply.
At least they run at 9V now.
I fixed it by powering it from my power supply at 6 volts.
The dropout of the arduino Vin regulator caused some problems when powering it with 5 volts
Can you please post a circuit diagram of your project please?
Include power supply and pin names/labels.
Thanks.. Tom..
The circuit diagram and code is in this link: (scroll down a bit) https://mechatrofice.com/arduino/l293d-motor-driver
The power supply is a Lab Bench Power Supply @ 5V
I have to re-upload the code every couple times of starting it up.
The Arduino's L led just blinks and the motor's start up is very inconsistent
It works better when you supply it with 7v
@LinuxNinja99 reference circuit;
Now can I suggest you draw your circuit, reverse engineer your project.
I hope you have the USB connected while doing these tests or at least a 5V supply between gnd and 5V pin of the Uno?
Can you please post a picture of your project so we can see your component layout?
Thanks.. Tom..
