Hi could someone please help me with the voltage dividers
I have 1.8k ohm and 3.3k ohm resistors
I’m running them from pins 19 & 20 from the microbit expansion card to the Arduino uno
Many thanks
Is this following the subject of L298N to Uno? Perhaps you should start another topic of "Micro:bit expansion board to Uno"?
Hi it’s part of the same project
I got a new L298N done away with the fusebox relay set and replaced it with a 12v 6 way fusebox I’ve now connected the 298 to Arduino and to the two motors
Following on now I need to connect the microbit to the Arduino
The world does not know this. You also marked this topic as "solved" so to the outside observer, the L298N problem is solved (and nothing else). You will attract more interest to Micro:bit expansion board if you start another topic. It's free.
[edit] In your next topic, show a wiring diagram with all your devices, and your program code if you have it ready. You read what you need in your topic for your best results when you signed up for your user account.
