We are building an alarm clock for a school project that turns off when a laser pointer is shot at it. We are using a servo arm to turn off the alarm button when the laser pointer is shot at a photo diode. The problem is, we don't know what type of hardware to use for the laser pointer to be shot at. We have code that works using a potentiometer to move the servo arm and we now need to change that code to make it work for the laser pointer. Any help would be appreciated.
A phototransitor. Try to find one that matches the wavelength of the laser.
You'll have to experiment with resistor values, etc. to get the sensitivity right. You'll need to block ambient light as much as possible. You may need to an optical filter because it will be sensitive to light at other wavelengths... It's just most sensitive at the specified wavelength. If you need it to be completely immune to false triggering, you'll need a laser that can transmit a "code" similar to the way a remote control works.
