Lcd flickering while conected to power outlet
Hello i am new here i have LCD display 1.9" 170x320 color TFT SPI ST7789 and when i connect my arduino to my PC usb port it works perfectly fine , but when i connect to a wall outlet it suddenly starts flickering
I dont know how to do chematic but i have it conected :
LCD ARDUINO
GND -> GND
VCC ->5v
SCL->D13
SDA->D11
RES->D8
DC->D9
CS->D10
BLK->3.3V
Lcd chematic i found :
Other information that would be useful:
  • State which Arduino you have
  • Provide details of the power supply you are using
  • Post your code in code tags
  • Post photos of your project, make sure they are clear and show the problem
I have Arduino UNo R4 wifi
power suply : Input: 100–240 V ~ 50–60 Hz, 0.3 A
Output:5 V βŽ“ 1.55 A
code:
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_ST7789.h>
// Define pins connected to the TFT display
#define TFT_CS   10   // Chip Select
#define TFT_DC   9    // Data/Command
#define TFT_RST  8    // Reset
// Create an instance of the ST7789 display
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
  // Initialize SPI communication
  SPI.begin();
  // Initialize the ST7789 display (1.9" screen, usually 170x320 pixels)
  tft.init(170, 320);
  // Set screen rotation (0–3, each rotates 90 degrees)
  tft.setRotation(0);
  // Fill the screen with black color
  tft.fillScreen(ST77XX_BLACK);
  // Set text color and size
  tft.setTextColor(ST77XX_WHITE);  // White text
  tft.setTextSize(2);              // Text scale factor
  // Set the cursor position and print text
  tft.setCursor(10, 20);
  tft.println("Test 12");
  // Draw a green rectangle around the screen edges
  tft.drawRect(0, 0, 170, 320, ST77XX_GREEN);
  // Nothing happens in loop; the display is static
The USB port on the PC can supply a stable 5V with limited current, while many wall adapters, especially cheap ones, may not provide "clean" voltage / current.
Can you try with another power adapter ?
do you have longer wires :innocent: :grimacing:
i tried with another one and it still doesnt work
What about something simple like genuine "Samsung" phone charger?
Those cheap "65W" 5-port superhyper chargers are often really bad quality in my opinion.
Ps. what is that surface you have your devices on?
Schematics are the basic language of electronics!
It is not hard, try this link: How to Read a Schematic - SparkFun Learn By using schematics you make it much easier to follow your circuit then your convoluted word salad. You can load a very good schematic capture program that will go from a blank sheet to the Gerber files needed to make a PCB. It is not a weekend learn but when downloading they may ask for a non required donation.
Okay i resolved the issue by plugging it in via the huawei laptop charger it works perfectly fine now .
