LCD flickers and doesn't update right
HI,
I try to make a darts scoreboard with arduino.
My LCD keeps flickering and doesn't always update right.
Anyone knows how to prevent it?
Thanks!
this is the code:
#include <Wire.h>
#include <Keypad.h>
#include <TM1637Display.h>
#include <IRremote.h>
const int lcdColumns = 16; // number of columns on the LCD display
const int lcdRows = 2;     // number of rows on the LCD display
const int irReceiverPin = 8;  // pin for the IR receiver
IRrecv irReceiver(irReceiverPin);  // create an instance of the IRrecv class
decode_results results;  // create an instance of the decode_results class
LiquidCrystal_I2C lcd(0x27, lcdColumns, lcdRows); // initialize the LCD
TM1637Display display1(13, 12); // initialize the first four-digit display
TM1637Display display2(10, 9);  // initialize the second four-digit display
const byte ROWS = 4; // number of rows on the keypad
const byte COLS = 4; // number of columns on the keypad
char keys[ROWS][COLS] = {
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins[ROWS] = {7, 6, 5, 4}; // connect keypad rows to these Arduino pins
byte colPins[COLS] = {3, 2, 1, 0}; // connect keypad columns to these Arduino pins
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
int score1 = 501; // starting score for player 1
int score2 = 501; // starting score for player 2
int turns1 = 0;   // number of turns taken by player 1
int turns2 = 0;   // number of turns taken by player 2
int totalscore1 = 0;
int totalscore2 = 0;
bool player1Turn = true; // flag to track whose turn it is
  lcd.init(); // initialize the LCD
  lcd.backlight(); // turn on the backlight
  lcd.clear(); // clear the LCD
  lcd.setCursor(0, 0); // move cursor to (0, 0)
  lcd.print("Player 1: 501"); // print starting score for player 1
  lcd.setCursor(0, 1); // move cursor to (0, 1)
  lcd.print("Player 2: 501"); // print starting score for player 2
  display1.setBrightness(0x0f); // set brightness of the first four-digit display
  display1.showNumberDec(501, false, 4, 0); // show starting score for player 1 on the first four-digit display
  display2.setBrightness(0x0f); // set brightness of the second four-digit display
  display2.showNumberDec(501, false, 4, 0); // show starting score for player 2 on the second four-digit display
  irReceiver.enableIRIn();  // start the IR receiver
  char key = keypad.getKey(); // get the key that was pressed
  if (key) { // if a key was pressed
    if (key == '#') { // if the key is the '#' key
      // toggle the turn flag
      if (player1Turn) {
        totalscore1 = 501 - score1;
        turns1++;
        totalscore2 = 501 - score2;
        turns2++;
      player1Turn = !player1Turn;
    } else if (key == 'A') { // if the key is the 'A' key
      // subtract 50 points from the current player's score
      if (player1Turn) {
        score1 -= 50;
        score2 -= 50;
    } else if (key == 'B') { // if the key is the 'B' key
      // subtract 25 points from the current player's score
      if (player1Turn) {
        score1 -= 25;
        score2 -= 25;
    } else if (key == 'C') { // if the key is the 'C' key
      // subtract 20 points from the current player's score
      if (player1Turn) {
        score1 -= 20;
        score2 -= 20;
    } else if (key == 'D') { // if the key is the 'D' key
      // subtract 10 points from the current player's score
      if (player1Turn) {
        score1 -= 10;
        score2 -= 10;
    } else { // if the key is a number key
      // subtract the value of the key from the current player's score
      int value = key - '0';
      if (player1Turn) {
        score1 -= value;
        score2 -= value;
  if (irReceiver.decode(&results)) {  // if the receiver has received a signal
    switch (results.value) {
      case 0xFF6897:  // code for button "1"
        if (player1Turn) {
          score1 -= 1;
          score2 -= 1;
      case 0xFF9867:  // code for button "2"
        if (player1Turn) {
          score1 -= 2;
          score2 -= 2;
      case 0xFFB04F:  // code for button "3"
        if (player1Turn) {
          score1 -= 3;
          score2 -= 3;
      case 0xFF30CF:  // code for button "4"
        if (player1Turn) {
          score1 -= 4;
          score2 -= 4;
      case 0xFF18E7:  // code for button "5"
        if (player1Turn) {
          score1 -= 5;
          score2 -= 5;
      case 0xFF7A85:  // code for button "6"
        if (player1Turn) {
          score1 -= 6;
          score2 -= 6;
      case 0xFF10EF:  // code for button "7"
        if (player1Turn) {
          score1 -= 7;
          score2 -= 7;
      case 0xFF38C7:  // code for button "8"
        if (player1Turn) {
          score1 -= 8;
          score2 -= 8;
      case 0xFF5AA5:  // code for button "9"
        if (player1Turn) {
          score1 -= 9;
          score2 -= 9;
      case 0xFF52AD:  // code for button "#"
        if (player1Turn) {
          turns1++;
          turns2++;
      case 0xFF629D:  // code for button "UP"
        if (player1Turn) {
          score1 -= 10;
          score2 -= 10;
      case 0xFFC23D:  // code for button "RIGHT"
        if (player1Turn) {
          score1 -= 20;
          score2 -= 20;
      case 0xFFA857:  // code for button "DOWN"
        if (player1Turn) {
          score1 -= 25;
          score2 -= 25;
      case 0xFF22DD:  // code for button "LEFT"
        if (player1Turn) {
          score1 -= 50;
          score2 -= 50;
      default:
    irReceiver.resume();  // resume receiver
  // update the displays with the new scores and average scores
  lcd.clear(); // clear the LCD display
  lcd.print("P1: "); // print label for player 1
  lcd.print(score1); // print player 1's updated score
  lcd.print(" "); // print space
  // print average score for player 1
  if (turns1 > 0) {
    lcd.print("Avg: ");
    lcd.print(totalscore1 / turns1);
    lcd.print("Avg: N/A");
  lcd.print("P2: "); // print label for player 2
  lcd.print(score2); // print player 2's updated score
  // print average score for player 2
  if (turns2 > 0) {
    lcd.print("Avg: ");
    lcd.print(totalscore2 / turns2);
  display1.showNumberDec(score1, false, 4, 0); // update the first four-digit display
  display2.showNumberDec(score2, false, 4, 0); // update the second four-digit display
  if (player1Turn) {
    digitalWrite(11, HIGH);
  else {
    digitalWrite(11, LOW);
don't do a clear and rewrite every loop cycle.
Only write to the LCD if something has changed.
Thanks it worked!
