Hello, for a project I am trying to create a ping pong game! I am using an LCD display and some push buttons however it doesnt seem like the display is receiving any input from the push buttons.
Code:
#include <LiquidCrystal.h>
#include <avr/interrupt.h>
//----------------------------------------MACROS------------------------------------------
// Assigning LCD PINS
#define RS 12
#define EN 11
#define D4 9
#define D5 8
#define D6 7
#define D7 6
// Buttons that move the paddle
#define Player_1_moveDownButton 10 // Player 1's Down Button is connected to digital pin 4
#define Player_1_moveUpButton 5 // Player 1's Down Button is connected to digital pin 4
#define Player_2_moveDownButton 2 // Player 2's Down Button is connected to digital pin 4
#define Player_2_moveUpButton 3 // Player 2's Down Button is connected to digital pin 4
// Assigning Player Numbers
#define Player_1 1
#define Player_2 2
// Delay for updating the ball
#define DiagonalballUpdateTime 21
#define HorizontalballUpdateTime 15
//Starting Position of the Ball
#define Start_X 35
#define Start_Y 7
#define Button_Pressed (p1_UpButState | p1_DownButState | p2_UpButState | p2_DownButState)
void(* resetFunc) (void) = 0; //declaring reset function at address 0
// Global Variables for Pin Change Interrupt Service Routine
volatile boolean x_Up = true;
volatile boolean x_Down = true;
LiquidCrystal lcd(RS, EN, D4, D5, D6, D7); // Creating Object of type Liquid Crystal
//------------------------------------PADDLE CLASS------------------------------------------
class Paddle
public:
// Storing Value of each row of the Character Column for the Player's Paddle
uint8_t PaddleColArray[16] = {0,0,0,0,0,4,4,4,0,0,0,0,0,0,0,0};
uint8_t PaddlePos = 6; // Recording Paddles's middle position as reference to move it
uint8_t Score = 0; // Score of each Player
// When the Player presses the "UP" Button
void MovePaddleUp()
// Make sure the paddle doesn't go off the board
if(PaddlePos != 1)
PaddlePos--;
PaddleColArray[PaddlePos+2]=0;
PaddleColArray[PaddlePos-1]=4;
// When the Player presses the "DOWN" Button
void MovePaddleDown()
if(PaddlePos != 14)
PaddlePos++;
PaddleColArray[PaddlePos-2]=0;
PaddleColArray[PaddlePos+1]=4;
// Printing Paddles using each Player's Number
void PrintPaddles(uint8_t Player_Num)
if(Player_Num == 2)
// Each character must have a unique character ID and array to print
lcd.createChar(0, PaddleColArray);
lcd.createChar(1, PaddleColArray+8);
// Move cursor to 15th character on the 1st row
lcd.setCursor(14, 0);
lcd.write(byte(0));
lcd.setCursor(14, 1);
lcd.write(byte(1));
//if(Player_Num == 1)
lcd.createChar(2, PaddleColArray);
lcd.createChar(3, PaddleColArray+8);
lcd.setCursor(1, 0);
lcd.write(byte(2));
lcd.setCursor(1, 1);
lcd.write(byte(3));
// Creating Objects of Class "Paddle"
Paddle p1, p2;
//------------------------------------PRINT_GAME CLASS------------------------------------------
class Print_Game
public:
// Printing texts when the game starts
void Start_Game()
lcd.print(F(" PING PONG GAME "));
//Set the Cursor at the starting of 2nd row
lcd.setCursor(0, 1);
lcd.print(F("PRESS ANY BUTTON"));
// Variables to record the state of Push-Buttons
uint8_t p1_UpButState = 0;
uint8_t p1_DownButState = 0;
uint8_t p2_UpButState = 0;
uint8_t p2_DownButState = 0;
// Waiting till any one of the button is pressed
while(!(Button_Pressed))
// Low Level Code for digitalread() function for each input pin
p1_UpButState = ((PIND & (1 << Player_1_moveUpButton)) );
p1_DownButState = ((PINB & (1 << (Player_1_moveDownButton-8))) );
p2_UpButState = ((PIND & (1 << Player_2_moveUpButton)) );
p2_DownButState = ((PIND & (1 << Player_2_moveDownButton)) );
lcd.clear(); //Clearing LCD to start the game
// Printing score each time a player scores
void Print_Score()
// Clearing the LCD to print scores
lcd.clear();
lcd.print(F("PLAYER1 PLAYER2"));
lcd.setCursor(3 ,1);
lcd.print(p1.Score);
lcd.setCursor(12 ,1);
lcd.print(p2.Score);
// Scores remain on the display for 2 seconds
delay(2000);
// Clearing the display to continue the game
lcd.clear();
// Printing the Winner on Display
void Print_Winner(int Player_Num)
lcd.setCursor(0 ,0);
lcd.print(F(" GAME OVER "));
lcd.print(F("PLAYER "));
lcd.print(Player_Num);
lcd.setCursor(11 ,1);
lcd.print(F("WINS"));
// Text remains on screen for 5 seconds
delay(5000);
// Resetting the Game
resetFunc();
// Creating an Object of Print_Game Class
Print_Game g;
//------------------------------------BALL CLASS------------------------------------------
class Ball
private:
// Flag to reset the ball and paddles when a point is scored
uint8_t Point_Scored = 0;
// X and Y Direction Components of the Ball
uint8_t ballYDir = 0; // Ball starts off going horizontal
uint8_t ballXDir = -1; // Call starts off going left
// Location of the Ball
uint8_t ballY = Start_Y;
uint8_t ballX = Start_X;
// Row values of Character of the LCD in which the Ball is present
uint8_t ballCharArray[8] = {0, 0, 0, 0, 0, 0, 0, 16};
public:
// Declaring member fucntions defined outside of class
void GenerateBallArray();
void PrintBall();
void UpdateBall(uint8_t , uint8_t);
void AwardAPoint();
//----------------------------Member Fuctions of Class BALL---------------------------------
// Generate the 8 values that make up the character to draw
void Ball :: GenerateBallArray()
for(uint8_t i=0; i<8; i++)
if(i == (ballY % 8))
ballCharArray[i] = 2 << (4 - (ballX % 5));
ballCharArray[i] = 0;
void Ball :: PrintBall()
// Calculate the column we will draw in
uint8_t LCDCol = ballX / 5;
// Either the top or bottom row
uint8_t LCDRow = (ballY <= 7) ? 0 : 1;
// Assign array to the charNum
lcd.createChar(4, ballCharArray);
// Move the cursor into position
lcd.setCursor(LCDCol,LCDRow);
// Draw the character
lcd.write(byte(4));
// Updating the Ball's Position
void Ball :: UpdateBall(uint8_t P1_PaddlePos, uint8_t P2_PaddlePos)
// Short wait before update
// Handling different delays so that
// ball has same speed when it's going diagonally
if(ballYDir) // When it's going Diagonally
delay(DiagonalballUpdateTime);
else // When it's going Horizontally
delay(HorizontalballUpdateTime);
//-------------CALCULATING BALL'S NEXT POSITION------------
//If the Ball goes off-board
if((ballX <= 6) || (ballX >= 73))
AwardAPoint();
//If Ball is at the Player 2 edge
else if(ballX == 72)
// IF THE BALL STRIKES THE MIDDLE POSITION OF THE PADDLE
if(ballY == P2_PaddlePos)
ballXDir = -1;
// IF THE BALL STRIKES THE BOTTOM POSITION OF THE PADDLE
else if(ballY == (P2_PaddlePos + 1))
ballXDir = -1;
if(ballY == 15) // If the ball strikes the paddle at the bottom corner of the display
ballYDir = -1;
ballYDir = 1;
// IF THE BALL STRIKES THE TOP POSITION OF THE PADDLE
else if(ballY == (P2_PaddlePos - 1)){
ballXDir = -1;
if(ballY == 0) // If the ball strikes the paddle at the upper corner of the display
ballYDir = 1;
ballYDir = -1;
//If Ball is at the Player 1 edge
else if(ballX == 7)
if(ballY == P1_PaddlePos)
ballXDir = 1;
else if(ballY == (P1_PaddlePos + 1)){
ballXDir = 1;
ballYDir = -1;
ballYDir = 1;
else if(ballY == (P1_PaddlePos - 1))
ballXDir = 1;
ballYDir = 1;
ballYDir = -1;
// If the Ball Hit top or bottom of display then change Y Direction
else if((ballY == 0) || (ballY == 15))
ballYDir *= -1;
//Resetting the Ball and Paddles IF a point is scored
if(Point_Scored == 1)
// Resetting the Ball
ballX = Start_X;
ballY = Start_Y;
ballXDir *= -1;
ballYDir = 0;
// Resetting the Paddles
p1.PaddlePos = 6;
p2.PaddlePos = 6;
for(uint8_t i=0; i<16; i++)
if((i==5) || (i==6) || (i==7))
p1.PaddleColArray[i] = 4;
p2.PaddleColArray[i] = 4;
p1.PaddleColArray[i] = 0;
p2.PaddleColArray[i] = 0;
Point_Scored = 0; //Resetting the Point_Scored Flag
// Delete Ball from it's Current Location
lcd.setCursor(LCDCol, LCDRow);
lcd.print(" ");
// Change ball's position based on direction set on X & Y
ballX += ballXDir;
ballY += ballYDir;
// Create the array for the ball character
// Printing ball after calculating the new location
PrintBall();
// Increase player's score each time one scores
void Ball :: AwardAPoint()
if(ballX <= 8) // When Player 2 Scores
p2.Score++;
else // When Player 2 Scores
p1.Score++;
// When one of the player reaches the winning score of 10
if(p1.Score == 10) // If Player 1 reaches 10 first
g.Print_Winner(Player_1); // Printing Player 1 as Winner
else if(p2.Score == 10) // If Player 2 reaches 10 first
g.Print_Winner(Player_2); // Printing Player 2 as Winner
// Printing the Score of both players
g.Print_Score();
Point_Scored = 1; // Setting the Flag to reset the locations of Paddles and Ball
// Creating an Object of class BALL
Ball b;
//---------------------------------------SETUP---------------------------------------------
// The display has 2 rows with 16 characters per row
lcd.begin(16, 2);
// Setup buttons so we can receive input
DDRD &= ~(1<<Player_1_moveUpButton);
// Low level version of the statement: pinMode( Player_1_moveUpButton, INPUT);
// Similarly, setting all other pins to input
DDRD &= ~(1<<Player_1_moveDownButton);
DDRD &= ~(1<<Player_2_moveUpButton);
DDRD &= ~(1<<Player_2_moveDownButton);
// Printing the first statement
g.Start_Game();
// Print paddles on LCD
p1.PrintPaddles(Player_1);
p2.PrintPaddles(Player_2);
// Print Ball on LCD
b.PrintBall();
// Enabling Pin Change Interrup for Player 1's "UP" Button
PCMSK2 |= (1 << PCINT21);
PCICR |= (1 << PCIE2);
// Enabling Pin Change Interrup for Player 1's "DOWN" Button
PCMSK0 |= (1 << PCINT2);
PCICR |= (1 << PCIE0);
// Enabling Global interrupts
sei();
//Player 2 will input through Interrupts
attachInterrupt(digitalPinToInterrupt(Player_2_moveDownButton), P2_Move_Down, RISING);
attachInterrupt(digitalPinToInterrupt(Player_2_moveUpButton), P2_Move_Up, RISING);
//---------------------------------------LOOP---------------------------------------------
//Printing Both Paddles
//Updating Ball's Position
b.UpdateBall(p1.PaddlePos, p2.PaddlePos);
//-----INTERRUPT SERVICE ROUTINES----FOR PLAYER 2--------------
void P2_Move_Down()
p2.MovePaddleDown();
void P2_Move_Up()
p2.MovePaddleUp();
//----PIN CHANGE INTERRUPT SERVICE ROUTINES----FOR PLAYER 1-----
// Interrupt Routine for Player 1 "UP" Button
ISR(PCINT2_vect)
// The if statements make sure that interrupts does something
// only on rising edge of the clock
if(x_Up)
p1.MovePaddleUp();
x_Up = false;
x_Up = true;
// Interrupt Routine for Player 1 "DOWN" Button
ISR(PCINT0_vect)
if(x_Down)
p1.MovePaddleDown();
x_Down = false;
x_Down = true;
Here is a tinkercad representation:
Schematic:
My build:
