Dear Sirs,
Greetings!
First time I have tried SPI TFT LCD ILI9341... Plenty example codes tried none of them work on it apart from LCDWIKI Examples...Mostly all are working.But Touch Button example is not working,Just white screen observed.
Infact I need Touch Button functionality,unfortunately couldnt succeed.Moreover its Software SPI doesnt work ,had to connect all wires for hardware SPI, purpose of Pin saving failed too.
Uno is being used,Pin Numbers are changed accordingly.
Please Help me.
Thanks,
Regards,
Dino_T
#include <LCDWIKI_GUI.h> //Core graphics library
#include <LCDWIKI_KBV.h> //Hardware-specific library
#include <LCDWIKI_TOUCH.h> //touch screen library
#include "switch_font.c"
LCDWIKI_KBV my_lcd(ILI9488,40,38,39,43,41); //model,cs,cd,wr,rd,reset
LCDWIKI_TOUCH my_touch(53,52,50,51,44); //tcs,tclk,tdout,tdin,tirq
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#define BUTTON_X 40
#define BUTTON_Y 100
#define BUTTON_W 60
#define BUTTON_H 30
#define BUTTON_SPACING_X 20
#define BUTTON_SPACING_Y 20
#define BUTTON_TEXTSIZE 2
// We have a status line for like, is FONA working
#define STATUS_X 10
#define STATUS_Y 65
boolean switch_flag_1 = true,switch_flag_2 = true,switch_flag_3 = true,switch_flag_4 = true,switch_flag_5 = true,switch_flag_6 = true;
int16_t menu_flag = 1,old_menu_flag;
uint16_t px,py;
void show_string(uint8_t *str,int16_t x,int16_t y,uint8_t csize,uint16_t fc, uint16_t bc,boolean mode)
my_lcd.Set_Text_Mode(mode);
my_lcd.Set_Text_Size(csize);
my_lcd.Set_Text_colour(fc);
my_lcd.Set_Text_Back_colour(bc);
my_lcd.Print_String(str,x,y);
void show_picture(const uint8_t *color_buf,int16_t buf_size,int16_t x1,int16_t y1,int16_t x2,int16_t y2)
my_lcd.Set_Addr_Window(x1, y1, x2, y2);
my_lcd.Push_Any_Color(color_buf, buf_size, 1, 1);
boolean is_pressed(int16_t x1,int16_t y1,int16_t x2,int16_t y2,int16_t px,int16_t py)
if((px > x1 && px < x2) && (py > y1 && py < y2))
return true;
return false;
void show_system_menu(void)
show_string("time setting",10,150,2,BLACK, BLACK,1);
show_string("date setting",10,170,2,BLACK, BLACK,1);
show_string("alarm setting",10,190,2,BLACK, BLACK,1);
show_string("talk setting",10,210,2,BLACK, BLACK,1);
show_string("sound setting",10,230,2,BLACK, BLACK,1);
switch(menu_flag)
case 1:
my_lcd.Set_Draw_color(BLUE);
my_lcd.Fill_Rectangle(0, 147, my_lcd.Get_Display_Width()-1, 166);
show_string("time setting",10,150,2,WHITE, BLACK,1);
case 2:
my_lcd.Fill_Rectangle(0, 167, my_lcd.Get_Display_Width()-1, 186);
show_string("date setting",10,170,2,WHITE, BLACK,1);
case 3:
my_lcd.Fill_Rectangle(0, 187, my_lcd.Get_Display_Width()-1, 206);
show_string("alarm setting",10,190,2,WHITE, BLACK,1);
case 4:
my_lcd.Fill_Rectangle(0, 207, my_lcd.Get_Display_Width()-1, 226);
show_string("talk setting",10,210,2,WHITE, BLACK,1);
case 5:
my_lcd.Fill_Rectangle(0, 227, my_lcd.Get_Display_Width()-1, 246);
show_string("sound setting",10,230,2,WHITE, BLACK,1);
default:
void setup(void)
my_lcd.Init_LCD();
my_lcd.Set_Rotation(0);
my_touch.TP_Init(my_lcd.Get_Rotation(),my_lcd.Get_Display_Width(),my_lcd.Get_Display_Height());
my_lcd.Fill_Screen(WHITE);
my_lcd.Set_Draw_color(192, 192, 192);
my_lcd.Draw_Fast_HLine(0, 3, my_lcd.Get_Display_Width());
show_picture(switch_on_2,sizeof(switch_on_2)/2,5,5,34,34);
show_string("switch is on ",60,11,2,GREEN, BLACK,1);
my_lcd.Draw_Fast_HLine(0, 37, my_lcd.Get_Display_Width());
show_string("wifi setting",5,40,2,BLACK, BLACK,1);
show_picture(switch_on_3,sizeof(switch_on_3)/2,195,40,234,54);
my_lcd.Draw_Fast_HLine(0, 57, my_lcd.Get_Display_Width());
show_string("bt setting",5,60,2,BLACK, BLACK,1);
show_picture(switch_on_3,sizeof(switch_on_3)/2,195,60,234,74);
my_lcd.Draw_Fast_HLine(0, 77, my_lcd.Get_Display_Width());
show_string("auto time",5,80,2,BLACK, BLACK,1);
show_picture(switch_on_1,sizeof(switch_on_1)/2,204,80,218,94);
my_lcd.Draw_Fast_HLine(0, 97, my_lcd.Get_Display_Width());
show_string("enable lock",5,100,2,BLACK, BLACK,1);
show_picture(switch_on_1,sizeof(switch_on_1)/2,204,100,218,114);
my_lcd.Draw_Fast_HLine(0, 116, my_lcd.Get_Display_Width());
show_string("system setting >",5,119,2,BLUE, BLACK,1);
my_lcd.Draw_Fast_HLine(0, 138, my_lcd.Get_Display_Width());
void loop(void)
px = 0;
py = 0;
my_touch.TP_Scan(0);
if (my_touch.TP_Get_State()&TP_PRES_DOWN)
px = my_touch.x;
py = my_touch.y;
if(is_pressed(5,5,34,34,px,py))
if(switch_flag_1)
show_picture(switch_off_2,sizeof(switch_off_2)/2,5,5,34,34);
my_lcd.Set_Draw_color(WHITE);
my_lcd.Fill_Rectangle(60, 11, 216, 27);
show_string("switch is off ",60,11,2,RED, BLACK,1);
switch_flag_1 = false;
switch_flag_1 = true;
delay(100);
if(is_pressed(195,40,234,54,px,py))
if(switch_flag_2)
show_picture(switch_off_3,sizeof(switch_off_3)/2,195,40,234,54);
switch_flag_2 = false;
switch_flag_2 = true;
delay(100);
if(is_pressed(195,60,234,74,px,py))
if(switch_flag_3)
show_picture(switch_off_3,sizeof(switch_off_3)/2,195,60,234,74);
switch_flag_3 = false;
switch_flag_3 = true;
delay(100);
if(is_pressed(205,81,217,93,px,py))
if(switch_flag_4)
show_picture(switch_off_1,sizeof(switch_off_1)/2,204,80,218,94);
switch_flag_4 = false;
switch_flag_4 = true;
delay(100);
if(is_pressed(205,101,217,113,px,py))
if(switch_flag_5)
show_picture(switch_off_1,sizeof(switch_off_1)/2,204,100,218,114);
switch_flag_5 = false;
switch_flag_5 = true;
delay(100);
if(is_pressed(5,119,my_lcd.Get_Display_Width()-1,137,px,py))
my_lcd.Set_Draw_color(MAGENTA);
my_lcd.Fill_Rectangle(0, 117, my_lcd.Get_Display_Width()-1, 137);
delay(100);
if(switch_flag_6)
show_string("system setting <",5,119,2,BLUE, BLACK,1);
show_system_menu();
switch_flag_6 = false;
my_lcd.Fill_Rectangle(0, 147, my_lcd.Get_Display_Width()-1, 250);
if(is_pressed(0,147,my_lcd.Get_Display_Width()-1,247,px,py)&&(!switch_flag_6))
old_menu_flag = menu_flag;
if(is_pressed(0,147,my_lcd.Get_Display_Width()-1,166,px,py))
menu_flag = 1;
if(is_pressed(0,167,my_lcd.Get_Display_Width()-1,186,px,py))
menu_flag = 2;
if(is_pressed(0,187,my_lcd.Get_Display_Width()-1,206,px,py))
menu_flag = 3;
if(is_pressed(0,207,my_lcd.Get_Display_Width()-1,226,px,py))
menu_flag = 4;
if(is_pressed(0,227,my_lcd.Get_Display_Width()-1,246,px,py))
menu_flag = 5;
if(old_menu_flag != menu_flag)
switch(old_menu_flag)
case 1:
case 2:
case 3:
case 4:
case 5:
default:
delay(100);
