Hello everybody. I have a project running with an arduino uno, cnc shield, grbl, and I want to be able to control the Z-axis homing with LDR MODULE, but I run into a problem that I don't know how to wire it to the cnc shield as they are not mechanical switches. Anyone to help me?
Do you have specifications on that module?
The relay output is a mechanical switch, and with the three terminals, they are probably "common", "normally-closed" and "normally-open", just like a regular limit switch.
I would worry that the LDR+relay is slow as compared to a mechanical limit switch or an optical limit switch, which may cause accuracy/repeatability issues at higher travel speeds.
Description:
5V Light Photoswitch Sensor Switch LDR Photoresistor Relay Module Light Detection Photosensitive Sensor Board
Stable version of the module is 5V supply, without delay function, pull relay matt, bright disconnect
Uses:
Light detection and brightness detection,
detection can be adjusted via potentiometer brightness valve point comes relays,
and do all kinds of brightness detection switch,you can control all kinds of street lights automatically turn on at night,during the day and automatically turns off and car supplies control and automation equipment.
Module Features:
using the photoresistor induction light intensity comes with the relay,direct control load, Distribution bit sensitivity adjustment, start relay threshold set by adjusting potentiometer,when the dark this threshold, the module relay is energized,bright this threshold, the relay release;
5 V power input is designed for relay board regulator transistor to provide sensor Used to makethe product more stable and reliable;
onboard optocoupler isolation drive relay, the effective protection of the chip to make the product more reliable work;
has four fixed bolt hole for easy installation
small board PCB size: 5cm x 2.6cm
Module using the instructions:
1, photoresistors module is most sensitive to ambient light,generally used to detect the brightness of the ambient light.
2, the module when the ambient light is darker than the threshold value is set,the relay is energized, the common terminal and the normally start is turned on,when external ambient light is brighter than the set threshold value, the relay isswitched off, the common terminal and the normally closed end connected;
3, the public side, normally open, normally closed three ports, the equivalent of a dual-control switch, relay coil power, public end and often the beginning of
conduction, radio, public end normally closed terminal conduction;
Electrical parameters:
- Supply voltage: VDC
- Current:> 100mA
- Load: 250V 10A AC or 30V 10A DC (the current is less than this range can be used)
this is every thing about the module.
`type or paste code here`
I can't tell which terminal is which from either this text or the pic, but if they are unlabeled you can measure them with a meter to figure out which two terminals to connect to the shield.
and i am using the ky-008 laser sensor in front of the ldr.
actually i made a circuit like this one and replaced the led with the wires form cnc shield homing pins and it worked.
With those terminals, the "COM" and "NC" or "NO" would hook up exactly like a regular limit switch.
thank you i will try it.
So your CNC machine is dust-free?
Why not use a Z-axis homing puck.
Leo..
thanks for the suggestion, but I, am making an automated stage for microscope it can't work with it.
