Library Manager is empty
Im having almost the same problem.
Im running the latest nightly update on a MacBook Pro with Big Sur.
The library manager is empty most of the time, if I reduce the number of files
in the Sketchbook folder and the the libraries folder, then the Manager list is populated with the automated file list. The same applies to the Examples list.
Thanks for your report @Robgx.
I have a suspicion about the cause of this problem, but will need you to provide some additional information to confirm it.
Please do this:
  1. Select File > Quit from the Arduino IDE menus if it is running.
  2. Add all the files back to your Sketchbook folder and libraries folder.
  3. Open your Applications folder.
  4. Open Utilities.
  5. Double-click on "Terminal".
  6. Type the following command:
    "/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
  7. Press Enter
  8. Wait for the Arduino IDE to finish starting, or failing to start.
    If it starts, attempt to open a sketch, or whatever action it is that causes the failure.
  9. Switch back to the terminal window if the Arduino IDE window took the focus.
  10. Press +A.
    This will select all the text in the terminal window.
  11. Press +C.
    This will copy the selected text to the clipboard.
  12. Open a forum reply here by clicking the Reply button.
  13. Click the </> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the output is correctly formatted.
    Code block
  14. Press +V.
    This will paste the output into the code block.
  15. Move the cursor outside of the code block markup before you add any additional text to your reply.
  16. Click the Reply button to post the output.
Please let me know if you have any questions or problems while following those instructions.
Last login: Thu Jun  9 11:38:35 on ttys000
robertgilbert@Roberts-MBP ~ % /Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE
zsh: no such file or directory: /Applications/Arduino
robertgilbert@Roberts-MBP ~ % "/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
Starting backend process. PID: 23809
Using browser-only version of superagent in non-browser environment
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
root INFO Configuration directory URI: 'file:///Users/robertgilbert/.theia'
root INFO Backend Object.initialize: 7.1 ms [Finished 4.066 s after backend start]
root INFO Backend Object.configure: 5.6 ms [Finished 4.066 s after backend start]
root INFO Backend MessagingContribution.onStart: 2.8 ms [Finished 4.066 s after backend start]
root INFO Backend OSBackendApplicationContribution.configure: 0.5 ms [Finished 4.191 s after backend start]
root INFO Backend DefaultWorkspaceServer.onStart: 0.4 ms [Finished 4.192 s after backend start]
root WARN Backend LocalizationBackendContribution.initialize took longer than the expected maximum 50 milliseconds: 125.7 ms [Finished 4.192 s after backend start]
root INFO Backend LocalizationBackendContribution.configure: 0.7 ms [Finished 4.192 s after backend start]
root INFO Backend TaskBackendApplicationContribution.onStart: 0.4 ms [Finished 4.192 s after backend start]
root INFO Backend PluginDeployerContribution.initialize: 1.8 ms [Finished 4.194 s after backend start]
root INFO Backend ElectronTokenBackendContribution.configure: 1.7 ms [Finished 4.194 s after backend start]
root INFO Backend ConfigServiceImpl.onStart: 2.3 ms [Finished 4.195 s after backend start]
root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.7 ms [Finished 4.197 s after backend start]
root INFO Backend ArduinoDaemonImpl.onStart: 0.6 ms [Finished 4.197 s after backend start]
daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/arduino-ide-extension/build/arduino-cli...
root INFO Backend NodeFileUploadService.configure: 3.2 ms [Finished 4.199 s after backend start]
root INFO Backend PlotterBackendContribution.initialize: 0.4 ms [Finished 4.200 s after backend start]
root INFO Backend AuthenticationServiceImpl.onStart: 0.4 ms [Finished 4.200 s after backend start]
root INFO Backend FileDownloadEndpoint.configure: 4.5 ms [Finished 4.205 s after backend start]
root INFO Backend PluginApiContribution.configure: 0.7 ms [Finished 4.206 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.3 ms [Finished 4.207 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 4.207 s after backend start]
root INFO Backend PlotterBackendContribution.configure: 0.2 ms [Finished 4.207 s after backend start]
root INFO Theia app listening on http://localhost:60662.
root INFO Finished starting backend application: 6.0 ms [Finished 4.211 s after backend start]
root WARN The local plugin referenced by local-dir:/Users/robertgilbert/.arduinoIDE/plugins does not exist.
root WARN The local plugin referenced by local-dir:/Users/robertgilbert/.arduinoProIDE/plugins does not exist.
root WARN The local plugin referenced by local-dir:/Users/robertgilbert/.arduinoIDE/extensions does not exist.
root INFO PluginTheiaDirectoryHandler: accepting plugin with path
root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@0.3.10" with engines:
root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.2" with engines:
root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
root INFO Resolve plugins list: 43.2 ms [Finished 4.247 s after backend start]
root INFO Deployed backend plugin "cortex-debug@0.3.10" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/cortex-debug/extension/dist/extension": 7.7 ms [Finished 4.255 s after backend start]
root INFO Deployed backend plugin "vscode-arduino-tools@0.0.2-beta.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-arduino-tools/extension/dist/bundle": 4.0 ms [Finished 4.259 s after backend start]
root INFO Deployed backend plugin "cpp@1.52.1" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-cpp/extension": 15.1 ms [Finished 4.274 s after backend start]
root INFO ---- DURATION: loadCliConfig took 88.950 ms. Args: [] ----
root INFO Deployed backend plugin "json@1.46.1" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-json/extension": 11.0 ms [Finished 4.285 s after backend start]
root INFO Deployed backend plugin "json-language-features@1.46.1" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-json-language-features/extension/client/dist/jsonMain": 3.1 ms [Finished 4.289 s after backend start]
Restoring workspace roots: /private/var/folders/7m/d4qksq395qs4dscf8qhfr9tc0000gn/T/.arduinoIDE-unsaved2022511-10433-3umvcj.vv44s/sketch_jun11a
root INFO Deployed backend plugin "vscode-language-pack-de@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-de/extension": 677.2 ms [Finished 4.966 s after backend start]
daemon INFO {"level":"info","msg":"Using config file: /Users/robertgilbert/.arduinoIDE/arduino-cli.yaml","time":"2022-06-12T15:17:35+01:00"}
{"level":"info","msg":"arduino-cli version 0.23.0","time":"2022-06-12T15:17:35+01:00"}
{"level":"info","msg":"Executing `arduino-cli daemon`","time":"2022-06-12T15:17:35+01:00"}
{"IP":"127.0.0.1","Port":"60663"}
daemon INFO Daemon is running.
root INFO Deployed backend plugin "vscode-language-pack-fr@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-fr/extension": 382.8 ms [Finished 5.349 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ja@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-ja/extension": 638.2 ms [Finished 5.987 s after backend start]
daemon INFO {"index":"/Users/robertgilbert/Library/Arduino15/package_index.json","level":"info","msg":"Checking signature","signatureFile":"/Users/robertgilbert/Library/Arduino15/package_index.json.sig","time":"2022-06-12T15:17:36+01:00","trusted":true}
{"error":"opening signature file: open /Users/robertgilbert/Library/Arduino15/package_esp32_index.json.sig: no such file or directory","index":"/Users/robertgilbert/Library/Arduino15/package_esp32_index.json","level":"info","msg":"Checking signature","signatureFile":"/Users/robertgilbert/Library/Arduino15/package_esp32_index.json.sig","time":"2022-06-12T15:17:36+01:00"}
{"level":"info","msg":"Loading hardware from: /Users/robertgilbert/Library/Arduino15/packages","time":"2022-06-12T15:17:36+01:00"}
{"level":"info","msg":"Loading package arduino from: /Users/robertgilbert/Library/Arduino15/packages/arduino/hardware","time":"2022-06-12T15:17:36+01:00"}
{"error":"opening signature file: open /Users/robertgilbert/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/installed.json.sig: no such file or directory","index":"/Users/robertgilbert/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/installed.json","level":"info","msg":"Checking signature","signatureFile":"/Users/robertgilbert/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/installed.json.sig","time":"2022-06-12T15:17:36+01:00"}
{"level":"info","msg":"Adding monitor tool","protocol":"serial","time":"2022-06-12T15:17:36+01:00","tool":"builtin:serial-monitor"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:avr","Installed":"1.8.5","Latest":"1.8.5","Name":"Arduino AVR Boards"},"time":"2022-06-12T15:17:36+01:00"}
{"level":"info","msg":"Checking existence of 'tools' path: /Users/robertgilbert/Library/Arduino15/packages/arduino/tools","time":"2022-06-12T15:17:36+01:00"}
{"level":"info","msg":"Loading tools from dir: /Users/robertgilbert/Library/Arduino15/packages/arduino/tools","time":"2022-06-12T15:17:36+01:00"}
{"level":"info","msg":"Loaded tool","time":"2022-06-12T15:17:36+01:00","tool":{"version":"1.3.0","systems":[{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_386.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_386.tar.bz2","Checksum":"SHA-256:3e7f59d6fbc7a724598303f0d3289d0c4fd137a8973437980658379a024887b2","Size":2633516,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_amd64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_amd64.tar.bz2","Checksum":"SHA-256:aa45ee2441ffc3a122daec5802941d1fa2ac47adf5c5c481b5e0daa4dc259ffa","Size":2716248,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_arm.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_arm.tar.bz2","Checksum":"SHA-256:1888587409b56aef4ba0ab0e6703b3dccba7cc3a022756ba9b908247e5d5a656","Size":2567435,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_arm64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_arm64.tar.bz2","Checksum":"SHA-256:835ed8f37cffac37e979d1b0f6041559592d3d98be52f0e8611b76c4858e4113","Size":2472427,"CachePath":"packages"}},{"os":"i386-apple-darwin11","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-darwin_amd64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-darwin_amd64.tar.bz2","Checksum":"SHA-256:d5d0f82ff829c0e434d12a2ee640a6fbd78f893ab37782edbb8b5bf2359d119e","Size":2766116,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-windows_386.zip","ArchiveFileName":"arduinoOTA-1.3.0-windows_386.zip","Checksum":"SHA-256:051943844eee442460d2c709edefadca184287fffd2b6c100dd53aa742aa05f6","Size":2768948,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-06-12T15:17:36+01:00","tool":{"version":"7.3.0-atmel3.6.1-arduino7","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-arm-linux-gnueabihf.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-arm-linux-gnueabihf.tar.bz2","Checksum":"SHA-256:3903553d035da59e33cff9941b857c3cb379cb0638105dfdf69c97f0acc8e7b5","Size":34683056,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:03d322b9df6da17289e9e7c6233c34a8535d9c645c19efc772ba19e56914f339","Size":38045723,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-apple-darwin14.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-apple-darwin14.tar.bz2","Checksum":"SHA-256:f6ed2346953fcf88df223469088633eb86de997fa27ece117fd1ef170d69c1f8","Size":36684546,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-w64-mingw32.zip","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-w64-mingw32.zip","Checksum":"SHA-256:a54f64755fff4cb792a1495e5defdd789902a2a3503982e81b898299cf39800e","Size":52519412,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:954bbffb33545bcdcd473af993da2980bf32e8461ff55a18e0eebc7b2ef69a4c","Size":37176991,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:bd8c37f6952a2130ac9ee32c53f6a660feb79bee8353c8e289eb60fdcefed91e","Size":37630618,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-06-12T15:17:36+01:00","tool":{"version":"6.3.0-arduino17","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-armhf-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-armhf-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:2a8e68c5d803aa6f902ef219f177ec3a4c28275d85cbe272962ad2cd374f50d1","Size":219631,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:6cf948f751acfe7b96684537f2291c766ec8b54b4f7dc95539864821456fa9fc","Size":229852,"CachePath":"packages"}},{"os":"x86_64-apple-darwin12","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-x86_64-apple-darwin12.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-x86_64-apple-darwin12.tar.bz2","Checksum":"SHA-256:120cc9edaae699e7e9ac50b1b8eb0e7d51fdfa555bac54233c2511e6ee5418c9","Size":279045,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:accdfb920af2aabf4f7461d2ac73c0751760f525216dc4e7657427a78c60d13d","Size":254271,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:5c8cc6c17db9300e1451fe41cd7178b0442b4490ee6fdbc0aed9811aef96c05f","Size":244550,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-i686-w64-mingw32.zip","ArchiveFileName":"avrdude-6.3.0-arduino17-i686-w64-mingw32.zip","Checksum":"SHA-256:e99188873c7c5ad8f8f906f068c33600e758b2e36cce3adbd518a21bd266749d","Size":328460,"CachePath":"packages"}}]}}
daemon INFO {"level":"info","msg":"Loading package builtin from: /Users/robertgilbert/Library/Arduino15/packages/builtin","time":"2022-06-12T15:17:36+01:00"}
root INFO Deployed backend plugin "vscode-language-pack-nl@1.48.3" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-nl/extension": 93.6 ms [Finished 6.080 s after backend start]
daemon INFO {"level":"info","msg":"Checking existence of 'tools' path: /Users/robertgilbert/Library/Arduino15/packages/builtin/tools","time":"2022-06-12T15:17:36+01:00"}
{"level":"info","msg":"Loading tools from dir: /Users/robertgilbert/Library/Arduino15/packages/builtin/tools","time":"2022-06-12T15:17:36+01:00"}
{"level":"info","msg":"Loaded tool","time":"2022-06-12T15:17:36+01:00","tool":{"version":"5.8-arduino11","systems":[{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://downloads.arduino.cc/tools/ctags-5.8-arduino11-pm-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"ctags-5.8-arduino11-pm-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:3e219116f54d9035f6c49c600d0bb358710dcce139798ad237de0eef7998d0e2","Size":106930,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://downloads.arduino.cc/tools/ctags-5.8-arduino11-pm-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"ctags-5.8-arduino11-pm-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:62b514f3aaf37b5429ef703853bb46365fb91b4754c1916d085bf134004886e3","Size":111604,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://downloads.arduino.cc/tools/ctags-5.8-arduino11-pm-i686-mingw32.zip","ArchiveFileName":"ctags-5.8-arduino11-pm-i686-mingw32.zip","Checksum":"SHA-256:106c9f074a3e2ec55bd8a461c1522bb4c90488275f061c3d51942862c99b8ba7","Size":116455,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://downloads.arduino.cc/tools/ctags-5.8-arduino11-pm-x86_64-apple-darwin.zip","ArchiveFileName":"ctags-5.8-arduino11-pm-x86_64-apple-darwin.zip","Checksum":"SHA-256:bf74807260ddf0e1fc94d67e9cd8a41b7c0a2f0bee03e254e6975139b37ef250","Size":118296,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://downloads.arduino.cc/tools/ctags-5.8-arduino11-pm-armv6-linux-gnueabihf.tar.bz2","ArchiveFileName":"ctags-5.8-arduino11-pm-armv6-linux-gnueabihf.tar.bz2","Checksum":"SHA-256:098e8dc6a7dc0ddf09ef28e6e2e81d2ae181d12f41fb182dd78ff1387d4eb285","Size":95271,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://downloads.arduino.cc/tools/ctags-5.8-arduino11-pm-aarch64-linux-gnu.tar.bz2","ArchiveFileName":"ctags-5.8-arduino11-pm-aarch64-linux-gnu.tar.bz2","Checksum":"SHA-256:89b6f8adb7b7124ebe2eb30970ea77c754cd2239e0d8a6b0102ae2a36416c6ef","Size":100819,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-06-12T15:17:36+01:00","tool":{"version":"1.0.5","systems":[{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.5_Linux_32bit.tar.gz","ArchiveFileName":"mdns-discovery_v1.0.5_Linux_32bit.tar.gz","Checksum":"SHA-256:98cf9f9314ce8512baa4778d617bad5682f4dae74d00ee50c023863969a2a21a","Size":2392091,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.5_Linux_64bit.tar.gz","ArchiveFileName":"mdns-discovery_v1.0.5_Linux_64bit.tar.gz","Checksum":"SHA-256:99ceb2ec11c40761e9cf996f8b1b5a65ae8d5db0ba6978a0518f36bb2d8628cd","Size":2466817,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.5_Windows_32bit.zip","ArchiveFileName":"mdns-discovery_v1.0.5_Windows_32bit.zip","Checksum":"SHA-256:149d33749e617f5f58344416f045f0e0f5ae8124eba5771e17d33768d4ce3221","Size":2584774,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.5_Windows_64bit.zip","ArchiveFileName":"mdns-discovery_v1.0.5_Windows_64bit.zip","Checksum":"SHA-256:aec72b399693b2e109df865e272a4bc834b0930162a52cdb18ded294b5cb7e12","Size":2631982,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.5_macOS_64bit.tar.gz","ArchiveFileName":"mdns-discovery_v1.0.5_macOS_64bit.tar.gz","Checksum":"SHA-256:7da2a90ddd2a047b9ef05076b60e415f924d74901bc89c99e956568f34928a14","Size":2416088,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.5_Linux_ARMv6.tar.gz","ArchiveFileName":"mdns-discovery_v1.0.5_Linux_ARMv6.tar.gz","Checksum":"SHA-256:055ca34355ed84923f052178497313dfc2c4e1973a4f0ba8289793e06fd194cd","Size":2296508,"CachePath":"packages"}},{"os":"arm64-linux-gnueabihf","Resource":{"URL":"https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.5_Linux_ARM64.tar.gz","ArchiveFileName":"mdns-discovery_v1.0.5_Linux_ARM64.tar.gz","Checksum":"SHA-256:1a77a4284194ae13abcc9d945cf1afb55d5e9a9381e3e8c071fdb4aec202b477","Size":2297337,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-06-12T15:17:36+01:00","tool":{"version":"1.3.2","systems":[{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.3.2_Linux_32bit.tar.gz","ArchiveFileName":"serial-discovery_v1.3.2_Linux_32bit.tar.gz","Checksum":"SHA-256:86890adaedf38bcb62ceba904f94fb383ee7e9524d8d767bf3bb8032f0f4ca3f","Size":1588777,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.3.2_Linux_64bit.tar.gz","ArchiveFileName":"serial-discovery_v1.3.2_Linux_64bit.tar.gz","Checksum":"SHA-256:a18efd5eb4c085131ea2df63c10cb0df0e1b6d0de38761a71e94cb0fa40a08c3","Size":1630523,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.3.2_Windows_32bit.zip","ArchiveFileName":"serial-discovery_v1.3.2_Windows_32bit.zip","Checksum":"SHA-256:03045731c39009d99e1527f4127cc2595e434d923eccef025f5d5fdd82b2803d","Size":1814067,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.3.2_Windows_64bit.zip","ArchiveFileName":"serial-discovery_v1.3.2_Windows_64bit.zip","Checksum":"SHA-256:94ef68fb35d9ffed75f1c46607932d614d3d5b4722faf69487c6d433f7374868","Size":1843894,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.3.2_macOS_64bit.tar.gz","ArchiveFileName":"serial-discovery_v1.3.2_macOS_64bit.tar.gz","Checksum":"SHA-256:369e84d34cdee39277e840e7bdaf8393f3c10eefbd9934c9535cf57c4aaa3b20","Size":1699050,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.3.2_Linux_ARMv6.tar.gz","ArchiveFileName":"serial-discovery_v1.3.2_Linux_ARMv6.tar.gz","Checksum":"SHA-256:89ccc9bd3d22cfc1eec242fe00a34da2cba29c0008eb34d36509aea2c5a2819f","Size":1531250,"CachePath":"packages"}},{"os":"arm64-linux-gnueabihf","Resource":{"URL":"https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.3.2_Linux_ARM64.tar.gz","ArchiveFileName":"serial-discovery_v1.3.2_Linux_ARM64.tar.gz","Checksum":"SHA-256:3209edd3dd783d6d9b8c7957a83fb0315648b9c45b916c6a8297d2e247816206","Size":1531863,"CachePath":"packages"}}]}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-06-12T15:17:36+01:00","tool":{"version":"0.9.1","systems":[{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.9.1_Linux_32bit.tar.gz","ArchiveFileName":"serial-monitor_v0.9.1_Linux_32bit.tar.bz2","Checksum":"SHA-256:3939282c9c74dd259a0ebd66d959133efafc8b50fd800860d8c1f634615b665c","Size":1899387,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.9.1_Linux_64bit.tar.gz","ArchiveFileName":"serial-monitor_v0.9.1_Linux_64bit.tar.bz2","Checksum":"SHA-256:f121374fc33a66350381591816b2f2a0b0a108d70cf0ca01c59cc05186e6a5ce","Size":1954589,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.9.1_Windows_32bit.zip","ArchiveFileName":"serial-monitor_v0.9.1_Windows_32bit.zip","Checksum":"SHA-256:15157e93618365cd959df57a9a25ccaa5a79d46a34f589e8711f571fe2e318e7","Size":1956735,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.9.1_Windows_64bit.zip","ArchiveFileName":"serial-monitor_v0.9.1_Windows_64bit.zip","Checksum":"SHA-256:e45561908526e855a7b9284ee438d2503cb21f9a5421fd840c1f10cd46b10b25","Size":1990791,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.9.1_macOS_64bit.tar.gz","ArchiveFileName":"serial-monitor_v0.9.1_macOS_64bit.tar.bz2","Checksum":"SHA-256:ebb4750e079ec893d89e9e256cd80b0e810a6cc17cd66189978f46246f52e14a","Size":1871195,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.9.1_Linux_ARMv6.tar.gz","ArchiveFileName":"serial-monitor_v0.9.1_Linux_ARMv6.tar.bz2","Checksum":"SHA-256:bd2cf410f7fbcb43dbe6ea9bdf265585de96bf7247cb425d050537ee59d16355","Size":1829212,"CachePath":"packages"}},{"os":"arm64-linux-gnueabihf","Resource":{"URL":"https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.9.1_Linux_ARM64.tar.gz","ArchiveFileName":"serial-monitor_v0.9.1_Linux_ARM64.tar.bz2","Checksum":"SHA-256:be774d68c72fe7d79f9f6ec53f23e63e71793a15a60ed1210d51ec78c6fc0dc1","Size":1837454,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loading package esp32 from: /Users/robertgilbert/Library/Arduino15/packages/esp32/hardware","time":"2022-06-12T15:17:36+01:00"}
root INFO Deployed backend plugin "vscode-language-pack-tr@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-tr/extension": 167.3 ms [Finished 6.248 s after backend start]
daemon INFO {"error":"opening signature file: open /Users/robertgilbert/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/installed.json.sig: no such file or directory","index":"/Users/robertgilbert/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/installed.json","level":"info","msg":"Checking signature","signatureFile":"/Users/robertgilbert/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/installed.json.sig","time":"2022-06-12T15:17:36+01:00"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"esp32:esp32","Installed":"1.0.6","Latest":"1.0.6","Name":"esp32"},"time":"2022-06-12T15:17:36+01:00"}
{"level":"info","msg":"Checking existence of 'tools' path: /Users/robertgilbert/Library/Arduino15/packages/esp32/tools","time":"2022-06-12T15:17:36+01:00"}
{"level":"info","msg":"Loading tools from dir: /Users/robertgilbert/Library/Arduino15/packages/esp32/tools","time":"2022-06-12T15:17:36+01:00"}
{"level":"info","msg":"Loaded tool","time":"2022-06-12T15:17:36+01:00","tool":{"version":"3.0.0","systems":[{"os":"i686-mingw32","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/1.0.5-rc5/esptool-3.0.0.2-windows.zip","ArchiveFileName":"esptool-3.0.0.2-windows.zip","Checksum":"SHA-256:b192bfc1545a3c92658ce586b4edcc2aca3f0ad4b3fa8417d658bc8a48f1387e","Size":3434736,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/1.0.5-rc5/esptool-3.0.0.2-macos.tar.gz","ArchiveFileName":"esptool-3.0.0.2-macos.tar.gz","Checksum":"SHA-256:2cafab7f1ebce89475b84c115548eaace40b6366d7b3f9862cdb2fc64f806643","Size":3859642,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/1.0.5-rc5/esptool-3.0.0.2-linux.tar.gz","ArchiveFileName":"esptool-3.0.0.2-linux.tar.gz","Checksum":"SHA-256:d5cb51da1c74ff69f81b820470d2ecccb5c7c3a2dec7776483d4c89588b00020","Size":57526,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/1.0.5-rc5/esptool-3.0.0.2-linux.tar.gz","ArchiveFileName":"esptool-3.0.0.2-linux.tar.gz","Checksum":"SHA-256:d5cb51da1c74ff69f81b820470d2ecccb5c7c3a2dec7776483d4c89588b00020","Size":57526,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/1.0.5-rc5/esptool-3.0.0.2-linux.tar.gz","ArchiveFileName":"esptool-3.0.0.2-linux.tar.gz","Checksum":"SHA-256:d5cb51da1c74ff69f81b820470d2ecccb5c7c3a2dec7776483d4c89588b00020","Size":57526,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/1.0.5-rc5/esptool-3.0.0.2-linux.tar.gz","ArchiveFileName":"esptool-3.0.0.2-linux.tar.gz","Checksum":"SHA-256:d5cb51da1c74ff69f81b820470d2ecccb5c7c3a2dec7776483d4c89588b00020","Size":57526,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-06-12T15:17:36+01:00","tool":{"version":"0.2.3","systems":[{"os":"i686-mingw32","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-win32.zip","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-win32.zip","Checksum":"SHA-256:b647f2c2efe6949819c85ea9404271b55c7c9c25bcb98d3b98a1d0ba771adf56","Size":249809,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-osx.tar.gz","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-osx.tar.gz","Checksum":"SHA-256:9f43fc74a858cf564966b5035322c3e5e61c31a647c5a1d71b388ed6efc48423","Size":130270,"CachePath":"packages"}},{"os":"i386-apple-darwin","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-osx.tar.gz","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-osx.tar.gz","Checksum":"SHA-256:9f43fc74a858cf564966b5035322c3e5e61c31a647c5a1d71b388ed6efc48423","Size":130270,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-linux64.tar.gz","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-linux64.tar.gz","Checksum":"SHA-256:5e1a4ff41385e842f389f6b5254102a547e566a06b49babeffa93ef37115cb5d","Size":50646,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-linux32.tar.gz","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-linux32.tar.gz","Checksum":"SHA-256:464463a93e8833209cdc29ba65e1a12fec31718dc10075c195a2445b2c3f6cb0","Size":48751,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-linux-armhf.tar.gz","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-linux-armhf.tar.gz","Checksum":"SHA-256:ade3dc00117912ac08a1bdbfbfe76b12d21a34bc5fa1de0cfc45fe7a8d0a0185","Size":40665,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-linux-armhf.tar.gz","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-linux-armhf.tar.gz","Checksum":"SHA-256:ade3dc00117912ac08a1bdbfbfe76b12d21a34bc5fa1de0cfc45fe7a8d0a0185","Size":40665,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-06-12T15:17:36+01:00","tool":{"version":"1.22.0-97-gc752ad5-5.2.0","systems":[{"os":"i686-mingw32","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/1.0.5-rc5/xtensa-esp32-elf-win32-1.22.0-97-gc752ad5-5.2.0.zip","ArchiveFileName":"xtensa-esp32-elf-win32-1.22.0-97-gc752ad5-5.2.0.zip","Checksum":"SHA-256:80571e5d5a63494f4fa758bb9d8fb882ba4059853a8c412a84d232dc1c1400e6","Size":125747216,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/1.0.5-rc5/xtensa-esp32-elf-macos-1.22.0-97-gc752ad5-5.2.0.tar.gz","ArchiveFileName":"xtensa-esp32-elf-macos-1.22.0-97-gc752ad5-5.2.0.tar.gz","Checksum":"SHA-256:b1ce39a563ae359cf363fb7d8ee80cb1e5226fda83188203cff60f16f55e33ef","Size":50525386,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/1.0.5-rc5/xtensa-esp32-elf-linux64-1.22.0-97-gc752ad5-5.2.0.tar.gz","ArchiveFileName":"xtensa-esp32-elf-linux64-1.22.0-97-gc752ad5-5.2.0.tar.gz","Checksum":"SHA-256:96f5f6e7611a0ed1dc47048c54c3113fc5cebffbf0ba90d8bfcd497afc7ef9f3","Size":44225380,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/1.0.5-rc5/xtensa-esp32-elf-linux32-1.22.0-97-gc752ad5-5.2.0.tar.gz","ArchiveFileName":"xtensa-esp32-elf-linux32-1.22.0-97-gc752ad5-5.2.0.tar.gz","Checksum":"SHA-256:8094a2c30b474e99ce64dd0ba8f310c4614eb3b3cac884a3aea0fd5f565af119","Size":45575521,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/1.0.5-rc5/xtensa-esp32-elf-linux-armel-1.22.0-97-gc752ad5-5.2.0.tar.gz","ArchiveFileName":"xtensa-esp32-elf-linux-armel-1.22.0-97-gc752ad5-5.2.0.tar.gz","Checksum":"SHA-256:d70d550f88448fa476b29fa50ef5502ab497a16ac7fa9ca24c6d0a39bb1e681e","Size":50657803,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/1.0.5-rc5/xtensa-esp32-elf-linux-armel-1.22.0-97-gc752ad5-5.2.0.tar.gz","ArchiveFileName":"xtensa-esp32-elf-linux-armel-1.22.0-97-gc752ad5-5.2.0.tar.gz","Checksum":"SHA-256:d70d550f88448fa476b29fa50ef5502ab497a16ac7fa9ca24c6d0a39bb1e681e","Size":50657803,"CachePath":"packages"}}]}}
{"dir":"/Users/robertgilbert/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-06-12T15:17:36+01:00"}
daemon INFO {"dir":"/Users/robertgilbert/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-06-12T15:17:36+01:00"}
root INFO Deployed backend plugin "vscode-language-pack-zh-hans@1.53.2" from "/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-language-pack-zh-hans/extension": 381.2 ms [Finished 6.629 s after backend start]
root INFO Deploy plugins list: 43.2 ms [Finished 6.632 s after backend start]
daemon INFO {"dir":"/Users/robertgilbert/Documents/Arduino/libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-06-12T15:17:37+01:00"}
daemon INFO {"level":"info","msg":"starting discovery builtin:mdns-discovery process","time":"2022-06-12T15:17:37+01:00"}
{"level":"info","msg":"starting discovery builtin:serial-discovery process","time":"2022-06-12T15:17:37+01:00"}
daemon INFO {"level":"info","msg":"started discovery builtin:serial-discovery process","time":"2022-06-12T15:17:37+01:00"}
daemon INFO {"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.23.0\" to discovery builtin:serial-discovery","time":"2022-06-12T15:17:37+01:00"}
{"level":"info","msg":"started discovery builtin:mdns-discovery process","time":"2022-06-12T15:17:37+01:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.23.0\" to discovery builtin:mdns-discovery","time":"2022-06-12T15:17:37+01:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-06-12T15:17:37+01:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-06-12T15:17:37+01:00"}
{"level":"info","msg":"sending command START_SYNC to discovery builtin:mdns-discovery","time":"2022-06-12T15:17:37+01:00"}
{"level":"info","msg":"sending command START_SYNC to discovery builtin:serial-discovery","time":"2022-06-12T15:17:37+01:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: start_sync, message: OK","time":"2022-06-12T15:17:37+01:00"}
{"level":"info","msg":"from discovery builtin:mdns-discovery received message type: start_sync, message: OK","time":"2022-06-12T15:17:37+01:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: add, port: /dev/cu.Bluetooth-Incoming-Port","time":"2022-06-12T15:17:37+01:00"}
root WARN Frontend s.configure took longer than the expected maximum 100 milliseconds: 317.0 ms [Finished 2.661 s after frontend start]
root WARN Frontend commands.onStart took longer than the expected maximum 100 milliseconds: 158.7 ms [Finished 2.821 s after frontend start]
root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 243.6 ms [Finished 3.064 s after frontend start]
root WARN Frontend C.onStart took longer than the expected maximum 100 milliseconds: 104.4 ms [Finished 3.191 s after frontend start]
root WARN Frontend A.onStart took longer than the expected maximum 100 milliseconds: 116.9 ms [Finished 3.333 s after frontend start]
root WARN Frontend l.onStart took longer than the expected maximum 100 milliseconds: 178.8 ms [Finished 3.514 s after frontend start]
root INFO Board config changed:
app-state-change >>> new app state <started_contributions was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <started_contributions> for window <1>
root INFO Start frontend contributions: 1518.2 ms [Finished 3.675 s after frontend start]
root INFO Changed application state from 'init' to 'started_contributions'.
app-state-change >>> new app state <attached_shell was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <attached_shell> for window <1>
root INFO Changed application state from 'started_contributions' to 'attached_shell'.
root INFO >>> Restoring the layout state...
root INFO ------- SERIALIZED LAYOUT DATA -------
root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"kind":"navigatable","uri":"file:///private/var/folders/7m/d4qksq395qs4dscf8qhfr9tc0000gn/T/.arduinoIDE-unsaved2022511-10433-3umvcj.vv44s/sketch_jun11a/sketch_jun11a.ino","counter":0}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":11,\"column\":1},\"position\":{\"lineNumber\":11,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":11,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"},{"constructionOptions":{"factoryId":"serial-monitor"}}],"currentIndex":1}},"pinned":[false,false],"size":232,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":true,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":0.2,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":0.2,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":0.2,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":0.2,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":0.2,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":248},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"serial-monitor"}
root INFO ------- END SERIALIZED LAYOUT DATA -------
Checking for update
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353] Waiting for backend deployment: 359.1 ms [Finished 3.876 s after frontend start]
root INFO [hosted-plugin: 23823] PLUGIN_HOST(23823) starting instance
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353] Sync of 11 plugins: 829.6 ms [Finished 4.706 s after frontend start]
Found version 2.0.0-rc7 (url: arduino-ide_2.0.0-rc7_macOS_64bit.zip, arduino-ide_2.0.0-rc7_macOS_64bit.dmg)
2022-06-12 15:17:39.924 Arduino IDE Helper (Renderer)[23817:770392] CoreText note: Client requested name ".NewYork-Regular", it will get Times-Roman rather than the intended font. All system UI font access should be through proper APIs such as CTFontCreateUIFontForLanguage() or +[NSFont systemFontOfSize:].
2022-06-12 15:17:39.924 Arduino IDE Helper (Renderer)[23817:770392] CoreText note: Set a breakpoint on CTFontLogSystemFontNameRequest to debug.
2022-06-12 15:17:39.938 Arduino IDE Helper (Renderer)[23817:770392] CoreText note: Client requested name ".NewYork-Regular", it will get Times-Roman rather than the intended font. All system UI font access should be through proper APIs such as CTFontCreateUIFontForLanguage() or +[NSFont systemFontOfSize:].
root INFO isTemp?
2022-06-12 15:17:40.033 Arduino IDE Helper (Renderer)[23817:770392] CoreText note: Client requested name ".NewYork-Regular", it will get Times-Roman rather than the intended font. All system UI font access should be through proper APIs such as CTFontCreateUIFontForLanguage() or +[NSFont systemFontOfSize:].
2022-06-12 15:17:40.034 Arduino IDE Helper (Renderer)[23817:770392] CoreText note: Client requested name ".NewYork-Regular", it will get Times-Roman rather than the intended font. All system UI font access should be through proper APIs such as CTFontCreateUIFontForLanguage() or +[NSFont systemFontOfSize:].
root INFO starting monitor
app-state-change >>> new app state <initialized_layout was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <initialized_layout> for window <1>
root INFO <<< The layout has been successfully restored.
root INFO Initialize the workbench layout: 1413.0 ms [Finished 5.176 s after frontend start]
root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][marus25.cortex-debug]: Loaded contributions.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][arduino.vscode-arduino-tools]: Loaded contributions.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][vscode.cpp]: Loaded contributions.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][vscode.json]: Loaded contributions.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][vscode.json-language-features]: Loaded contributions.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353] Load contributions of 11 plugins: 154.4 ms [Finished 5.332 s after frontend start]
root WARN Frontend u.onDidInitializeLayout took longer than the expected maximum 100 milliseconds: 155.8 ms [Finished 5.332 s after frontend start]
root INFO isTemp?
root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
root WARN a registered grammar configuration for 'cpp' language is overridden
root INFO [hosted-plugin: 23823] PLUGIN_HOST(23823): PluginManagerExtImpl/init()
root INFO [hosted-plugin: 23823] PLUGIN_HOST(23823): initializing(cortex-debug@0.3.10 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
root INFO [hosted-plugin: 23823] Debugger contribution has been registered: cortex-debug
root INFO [hosted-plugin: 23823] PLUGIN_HOST(23823): initializing(vscode-arduino-tools@0.0.2-beta.2 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
root INFO [hosted-plugin: 23823] PLUGIN_HOST(23823): initializing(cpp@1.52.1 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
root INFO [hosted-plugin: 23823] PLUGIN_HOST(23823): initializing(json@1.46.1 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
root INFO [hosted-plugin: 23823] PLUGIN_HOST(23823): initializing(json-language-features@1.46.1 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
root INFO [hosted-plugin: 23823] PLUGIN_HOST(23823): initializing(vscode-language-pack-de@1.53.2 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
root INFO [hosted-plugin: 23823] PLUGIN_HOST(23823): initializing(vscode-language-pack-fr@1.53.2 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
root INFO [hosted-plugin: 23823] PLUGIN_HOST(23823): initializing(vscode-language-pack-ja@1.53.2 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
root INFO [hosted-plugin: 23823] PLUGIN_HOST(23823): initializing(vscode-language-pack-nl@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
root INFO [hosted-plugin: 23823] PLUGIN_HOST(23823): initializing(vscode-language-pack-tr@1.53.2 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
root INFO [hosted-plugin: 23823] PLUGIN_HOST(23823): initializing(vscode-language-pack-zh-hans@1.53.2 with /Applications/Arduino IDE.app/Contents/Resources/app/node_modules/@theia/plugin-ext-vscode/lib/node/plugin-vscode-init)
root INFO [hosted-plugin: 23823] PLUGIN_HOST(23823): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-json-language-features/extension/client/dist/jsonMain)
root INFO [hosted-plugin: 23823] PLUGIN_HOST(23823): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-arduino-tools/extension/dist/bundle)
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][marus25.cortex-debug]: Started plugin.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][arduino.vscode-arduino-tools]: Started plugin.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][vscode.cpp]: Started plugin.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][vscode.json]: Started plugin.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][vscode.json-language-features]: Started plugin.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][ms-ceintl.vscode-language-pack-de]: Started plugin.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][ms-ceintl.vscode-language-pack-fr]: Started plugin.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][ms-ceintl.vscode-language-pack-ja]: Started plugin.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][ms-ceintl.vscode-language-pack-nl]: Started plugin.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][ms-ceintl.vscode-language-pack-tr]: Started plugin.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353][ms-ceintl.vscode-language-pack-zh-hans]: Started plugin.
root INFO [a73fe8e4-75e1-4a7a-889d-23dd06726353] Start of 11 plugins: 694.8 ms [Finished 6.037 s after frontend start]
app-state-change >>> new app state <ready was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <ready> for window <1>
root INFO Frontend application start: 3690.3 ms [Finished 10.736 s after backend start]
root INFO Replace loading indicator with ready workbench UI (animation): 891.7 ms [Finished 6.228 s after frontend start]
root INFO isTemp?
root INFO Changed application state from 'initialized_layout' to 'ready'.
root WARN Mismatching sketch file <tmp.ino> and sketch folder name <Homewatch.v1.0>. Skipping
root WARN Mismatching sketch file <tmp.ino> and sketch folder name <Homewatch.v2.0>. Skipping
root WARN Mismatching sketch file <tmp.ino> and sketch folder name <Homewatch.v3.0>. Skipping
root WARN Mismatching sketch file <tmp.ino> and sketch folder name <Homewatch.v4.0>. Skipping
root WARN Mismatching sketch file <tmp.ino> and sketch folder name <Homewatch.v5.0>. Skipping
root ERROR ---- !!!SLOW!!! DURATION: getSketchesNew took 9382.398 ms. Args: [{"uri":"file:///Users/robertgilbert/Documents/Arduino"}] ----
root ERROR ---- !!!SLOW!!! DURATION: getSketchesNew took 6989.857 ms. Args: [{}] ----
daemon INFO {"level":"info","msg":"URL: https://downloads.arduino.cc/packages/package_index.tar.bz2","time":"2022-06-12T15:17:49+01:00"}
{"level":"info","msg":"Updating index","time":"2022-06-12T15:17:49+01:00","url":{"Scheme":"https","Opaque":"","User":null,"Host":"downloads.arduino.cc","Path":"/packages/package_index.tar.bz2","RawPath":"","ForceQuery":false,"RawQuery":"","Fragment":"","RawFragment":""}}
daemon INFO {"level":"info","monitor":"serial-monitor","msg":"Starting monitor process","time":"2022-06-12T15:17:49+01:00"}
daemon INFO {"level":"info","monitor":"serial-monitor","msg":"Monitor process started successfully!","time":"2022-06-12T15:17:50+01:00"}
{"command":"HELLO 1 \"arduino-cli 0.23.0\"","level":"info","monitor":"serial-monitor","msg":"sending command","time":"2022-06-12T15:17:50+01:00"}
daemon INFO {"error":false,"event_type":"hello","level":"info","message":"OK","monitor":"serial-monitor","msg":"received message","time":"2022-06-12T15:17:50+01:00"}
{"command":"DESCRIBE","level":"info","monitor":"serial-monitor","msg":"sending command","time":"2022-06-12T15:17:50+01:00"}
daemon INFO {"error":false,"event_type":"describe","level":"info","message":"OK","monitor":"serial-monitor","msg":"received message","time":"2022-06-12T15:17:50+01:00"}
{"command":"QUIT","level":"info","monitor":"serial-monitor","msg":"sending command","time":"2022-06-12T15:17:50+01:00"}
{"level":"error","monitor":"serial-monitor","msg":"stopped decode loop: EOF","time":"2022-06-12T15:17:50+01:00"}
{"level":"info","monitor":"serial-monitor","msg":"Killing monitor process","time":"2022-06-12T15:17:50+01:00"}
{"level":"info","monitor":"serial-monitor","msg":"Monitor process killed","time":"2022-06-12T15:17:50+01:00"}
daemon INFO {"level":"info","monitor":"serial-monitor","msg":"Starting monitor process","time":"2022-06-12T15:17:50+01:00"}
{"command":"OPEN 127.0.0.1:60687 /dev/cu.Bluetooth-Incoming-Port","level":"info","monitor":"serial-monitor","msg":"sending command","time":"2022-06-12T15:17:50+01:00"}
daemon INFO ERROR: 2022/06/12 15:17:50 [core] grpc: server failed to encode response:  rpc error: code = Internal desc = grpc: error while marshaling: string field contains invalid UTF-8
root ERROR Request list failed with error: 13 INTERNAL: grpc: error while marshaling: string field contains invalid UTF-8
root ERROR Request installed failed with error: 13 INTERNAL: grpc: error while marshaling: string field contains invalid UTF-8
root ERROR Request search failed with error: 13 INTERNAL: grpc: error while marshaling: string field contains invalid UTF-8
root INFO started monitor to /dev/cu.Bluetooth-Incoming-Port using serial
daemon INFO {"error":false,"event_type":"open","level":"info","message":"OK","monitor":"serial-monitor","msg":"received message","time":"2022-06-12T15:17:50+01:00"}
{"command":"CONFIGURE baudrate 9600","level":"info","monitor":"serial-monitor","msg":"sending command","time":"2022-06-12T15:17:50+01:00"}
{"error":false,"event_type":"configure","level":"info","message":"OK","monitor":"serial-monitor","msg":"received message","time":"2022-06-12T15:17:50+01:00"}
{"command":"CONFIGURE bits 8","level":"info","monitor":"serial-monitor","msg":"sending command","time":"2022-06-12T15:17:50+01:00"}
{"command":"CONFIGURE parity None","level":"info","monitor":"serial-monitor","msg":"sending command","time":"2022-06-12T15:17:50+01:00"}
{"command":"CONFIGURE stop_bits 1","level":"info","monitor":"serial-monitor","msg":"sending command","time":"2022-06-12T15:17:50+01:00"}
{"level":"info","msg":"Port /dev/cu.Bluetooth-Incoming-Port successfully opened","time":"2022-06-12T15:17:50+01:00"}
root INFO Starting language server: esp32:esp32:esp32doit-devkit-v1
root INFO Downloading index: package_index.tar.bz2 completed.
daemon INFO {"level":"info","msg":"URL: https://dl.espressif.com/dl/package_esp32_index.json","time":"2022-06-12T15:17:50+01:00"}
{"level":"info","msg":"Updating index","time":"2022-06-12T15:17:50+01:00","url":{"Scheme":"https","Opaque":"","User":null,"Host":"dl.espressif.com","Path":"/dl/package_esp32_index.json","RawPath":"","ForceQuery":false,"RawQuery":"","Fragment":"","RawFragment":""}}
root INFO Downloading index: package_esp32_index.json completed.
daemon INFO {"level":"info","msg":"Searching tools required for board esp32:esp32:esp32doit-devkit-v1","time":"2022-06-12T15:17:50+01:00"}
{"level":"info","msg":"Required tool","time":"2022-06-12T15:17:50+01:00","tool":{"ToolName":"esptool_py","ToolVersion":"3.0.0","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2022-06-12T15:17:50+01:00","tool":{"ToolName":"mkspiffs","ToolVersion":"0.2.3","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2022-06-12T15:17:50+01:00","tool":{"ToolName":"xtensa-esp32-elf-gcc","ToolVersion":"1.22.0-97-gc752ad5-5.2.0","ToolPackager":"esp32"}}
Hi ptillisch, hope this is what you wanted. Thanks for your help.
Thanks, yes that is exactly what I needed to confirm my suspicion. The important part is here:
There is a known issue with the Arduino IDE 2.x where if a library is installed that uses non-UTF-8 character encoding in its metadata file, it breaks the Library Manager:
Since Arduino IDE 1.x handles other encodings just fine, some library authors have used them instead of UTF-8 without any idea it might cause problems for the users.
When you removed some files from the libraries folder, you must have happened to remove the problematic library.
So the way to proceed is to identify the specific library (possibly multiple libraries) and then either remove it (if you have no need for it), or else change the encoding of its library.properties metadata file to be compatible with Arduino IDE 2.x.
Unfortunately, the IDE doesn't give us any idea of where the file is so you'll have to find it by trial and error.
You could do that by moving all the folders out of the libraries subfolder of your sketchbook folder and then move them back in one by one, restarting the Arduino IDE after each library, until you find the problematic one.
If you have a lot of libraries, you could employ the more efficient (but more complicated) "bisection" technique, where you remove half the libraries and restart the Arduino IDE, the result of which will tell you whether that half contains a problematic library or not. You can then continue through the libraries in the half that contained a problematic library, splitting the collectin in half each at each step until you finally reduce it to only the bad ones.
File encoding can be changed to UTF-8 using most any text editor which is designed for use by programmers (e.g., VS Code, Notepad++). I'm happy to help you out with that process if needed.
Thanks for that ptillisch. Bisection here I come.
I’ll keep you posted on the result!
Problem now solved, all seems to be functioning well.
One library folder from 200 plus! It was downloaded from GitHub,
do you want the name?
Great work! I'm glad you found it. 200; Thank goodness for bisection!
Sure. This information might come in handy while supporting others with the same problem.
Yes, its "TimerFour". I wouldn't want to embarrass the author and I should say that I've got TimerThree, TimerTwo and TimerOne on my machine, they all appear to be behaving. Certainly even the bad file didn't appear to cause any problems in V1.
Anyway, thanks again buddy!
I have this problem on windows 10. Sketch folder is set correctly but nothing is in the library manager. Why? How can I fix this?
Hi @fluxanode1. Thanks for your report.
I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
  1. Start Windows "File Explorer".
  2. Open the Arduino IDE installation folder.
    (usually C:\Program Files\Arduino IDE or C:\Users\<user name>\AppData\Local\Programs\Arduino IDE).
  3. In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
  4. From the context menu, click "Open PowerShell window here".
    PowerShell will now open with the current directory set to the Arduino IDE installation folder.
  5. Type the following command:
    & ".\Arduino IDE"
  6. Press the Enter key.
    Debug output should now be printed to the PowerShell window as the Arduino IDE starts (or fails to start).
  7. Wait for the Arduino IDE to finish starting, or failing to start.
  8. Switch back to the PowerShell window if the Arduino IDE window took the focus.
  9. Right click on the title bar of the PowerShell window.
    This will open a context menu.
  10. Select Edit > Select All from the context menu.
    This will select all the text in the PowerShell window.
  11. Press Ctrl+C.
    This will copy the contents of the PowerShell window to the clipboard.
  12. Open a forum reply here by clicking the Reply button.
  13. Click the </> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  14. Press Ctrl+V.
    This will paste the output into the code block.
  15. Move the cursor outside of the code block markup before you add any additional text to your reply.
  16. Click the Reply button to post the output.
Please let me know if you have any questions or problems while following those instructions.
Ok interestingly it finally populated. Don't know why but it's there now.
Thanks.
The Arduino IDE 2.x user interface has an "asynchronous" design, where it is populated on the fly rather than blocking. This means that if you open Library Manager while it it still downloading the index file from the Internet or processing that large file, it will be empty, then eventually the listings will appear. It can definitely be confusing at times.
So I updated to the 2.0.0-rc9.1 and am having the same problem but now it is not populating again. I did what you suggested in power shell and the results are below.
PS D:\Program Files\Arduino IDE> 6.    & ".\Arduino IDE"
At line:1 char:7
+ 6.    & ".\Arduino IDE"
Unexpected token '&' in expression or statement.
    + CategoryInfo          : ParserError: (:) [], ParentContainsErrorRecordException
    + FullyQualifiedErrorId : UnexpectedToken
PS D:\Program Files\Arduino IDE> & ".\Arduino IDE"
PS D:\Program Files\Arduino IDE> & ".\arduino IDE"
Starting backend process. PID: 9140
Using browser-only version of superagent in non-browser environment
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
root INFO Configuration directory URI: 'file:///c%3A/Users/ChuckW/.theia'
root INFO Backend Object.initialize: 4.0 ms [Finished 1.718 s after backend start]
root INFO Backend Object.configure: 3.1 ms [Finished 1.718 s after backend start]
root INFO Backend MessagingContribution.onStart: 1.4 ms [Finished 1.718 s after backend start]
root INFO Backend OSBackendApplicationContribution.configure: 0.4 ms [Finished 1.770 s after backend start]
root INFO Backend DefaultWorkspaceServer.onStart: 0.3 ms [Finished 1.770 s after backend start]
root INFO Backend LocalizationBackendContribution.configure: 0.4 ms [Finished 1.770 s after backend start]
root INFO Backend TaskBackendApplicationContribution.onStart: 0.2 ms [Finished 1.770 s after backend start]
root WARN Backend LocalizationBackendContribution.initialize took longer than the expected maximum 50 milliseconds: 52.1 ms [Finished 1.770 s after backend start]
root INFO Backend ElectronTokenBackendContribution.configure: 2.1 ms [Finished 1.773 s after backend start]
root INFO Backend ConfigServiceImpl.onStart: 2.6 ms [Finished 1.773 s after backend start]
root INFO Backend PluginDeployerContribution.initialize: 0.8 ms [Finished 1.773 s after backend start]
root INFO Backend ArduinoDaemonImpl.onStart: 0.5 ms [Finished 1.774 s after backend start]
root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.2 ms [Finished 1.775 s after backend start]
daemon INFO Starting daemon from D:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
root INFO Backend NodeFileUploadService.configure: 2.2 ms [Finished 1.776 s after backend start]
discovery-log INFO start
discovery-log INFO start new deferred
root INFO Backend BoardDiscovery.onStart: 0.4 ms [Finished 1.776 s after backend start]
root INFO Backend FileDownloadEndpoint.configure: 0.6 ms [Finished 1.777 s after backend start]
root INFO Backend AuthenticationServiceImpl.onStart: 0.6 ms [Finished 1.778 s after backend start]
root INFO Backend PluginApiContribution.configure: 0.7 ms [Finished 1.779 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.3 ms [Finished 1.780 s after backend start]
root INFO Backend PlotterBackendContribution.configure: 1.3 ms [Finished 1.782 s after backend start]
root INFO Theia app listening on http://localhost:52567.
root INFO Finished starting backend application: 6.1 ms [Finished 1.785 s after backend start]
root WARN The local plugin referenced by local-dir:/c%3A/Users/ChuckW/.arduinoIDE/plugins does not exist.
root WARN The local plugin referenced by local-dir:/c%3A/Users/ChuckW/.arduinoIDE/extensions does not exist.
root WARN The local plugin referenced by local-dir:C:\Users\ChuckW\.arduinoProIDE\plugins does not exist.
Restoring workspace roots: d:\ChuckW\Arduino\EchoBoth
root INFO PluginTheiaDirectoryHandler: accepting plugin with path
root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@0.3.10" with engines:
root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.5" with engines:
root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.69.0" with engines:
root INFO ---- DURATION: loadCliConfig took 61.823 ms. Args: [] ----
root INFO Resolve plugins list: 1235.9 ms [Finished 3.013 s after backend start]
root INFO Deployed backend plugin "cortex-debug@0.3.10" from "D:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension": 3.1 ms [Finished 3.017 s after backend start]
root INFO Deployed backend plugin "vscode-arduino-tools@0.0.2-beta.5" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 2.3 ms [Finished 3.019 s after backend start]
root INFO Deployed backend plugin "cpp@1.52.1" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 11.9 ms [Finished 3.031 s after backend start]
root INFO Deployed backend plugin "json@1.46.1" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 2.1 ms [Finished 3.033 s after backend start]
root INFO Deployed backend plugin "json-language-features@1.46.1" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 0.8 ms [Finished 3.034 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-cs@1.69.0" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 117.1 ms [Finished 3.151 s after backend start]
daemon INFO {"level":"info","msg":"Using config file: c:\\Users\\ChuckW\\.arduinoIDE\\arduino-cli.yaml","time":"2022-08-03T15:04:15-05:00"}
{"level":"info","msg":"arduino-cli.exe version 0.25.1","time":"2022-08-03T15:04:15-05:00"}
{"level":"info","msg":"Executing `arduino-cli daemon`","time":"2022-08-03T15:04:15-05:00"}
{"IP":"127.0.0.1","Port":"54443"}
daemon INFO Daemon is running.
root INFO Deployed backend plugin "vscode-language-pack-de@1.69.0" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 121.6 ms [Finished 3.273 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-es@1.69.0" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 119.8 ms [Finished 3.392 s after backend start]
daemon INFO {"level":"info","msg":"Loading hardware from: c:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\packages","time":"2022-08-03T15:04:15-05:00"}
{"level":"info","msg":"Loading package arduino from: C:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware","time":"2022-08-03T15:04:15-05:00"}
{"level":"info","msg":"Adding monitor tool","protocol":"serial","time":"2022-08-03T15:04:15-05:00","tool":"builtin:serial-monitor"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:avr","Installed":"1.8.5","Latest":"1.8.5","Name":"Arduino AVR Boards"},"time":"2022-08-03T15:04:15-05:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-08-03T15:04:15-05:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-08-03T15:04:15-05:00"}
{"level":"info","msg":"Loaded tool","time":"2022-08-03T15:04:15-05:00","tool":{"version":"1.3.0","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-03T15:04:15-05:00","tool":{"version":"7.3.0-atmel3.6.1-arduino7","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-03T15:04:15-05:00","tool":{"version":"6.3.0-arduino17","systems":null}}
{"level":"info","msg":"Loading package builtin from: C:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\packages\\builtin","time":"2022-08-03T15:04:15-05:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-08-03T15:04:15-05:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-08-03T15:04:15-05:00"}
{"level":"info","msg":"Loaded tool","time":"2022-08-03T15:04:15-05:00","tool":{"version":"5.8-arduino11","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-03T15:04:15-05:00","tool":{"version":"1.0.5","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-03T15:04:15-05:00","tool":{"version":"1.3.2","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-03T15:04:15-05:00","tool":{"version":"0.9.1","systems":null}}
{"level":"info","msg":"Loading package esp8266 from: C:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware","time":"2022-08-03T15:04:15-05:00"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"esp8266:esp8266","Installed":"3.0.2","Latest":"3.0.2","Name":"ESP8266 Boards (3.0.2)"},"time":"2022-08-03T15:04:15-05:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools","time":"2022-08-03T15:04:15-05:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools","time":"2022-08-03T15:04:15-05:00"}
{"level":"info","msg":"Loaded tool","time":"2022-08-03T15:04:15-05:00","tool":{"version":"3.0.4-gcc10.3-1757bed","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-03T15:04:15-05:00","tool":{"version":"3.7.2-post1","systems":null}}
{"level":"info","msg":"Loading package teensy from: C:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware","time":"2022-08-03T15:04:15-05:00"}
{"error":"opening signature file: open C:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.56.53\\installed.json.sig: The system cannot find the file specified.","index":"C:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.56.53\\installed.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.56.53\\installed.json.sig","time":"2022-08-03T15:04:15-05:00"}
{"level":"info","msg":"Adding monitor tool","protocol":"teensy","time":"2022-08-03T15:04:15-05:00","tool":"teensy:teensy-monitor"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"teensy:avr","Installed":"1.56.53","Latest":"1.56.53","Name":"Teensy"},"time":"2022-08-03T15:04:15-05:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\packages\\teensy\\tools","time":"2022-08-03T15:04:15-05:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\packages\\teensy\\tools","time":"2022-08-03T15:04:15-05:00"}
{"level":"info","msg":"Loaded tool","time":"2022-08-03T15:04:15-05:00","tool":{"version":"1.56.1","systems":[{"os":"i686-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-compile-linux32.tar.bz2","ArchiveFileName":"teensy-compile-linux32.tar.bz2","Checksum":"SHA-256:f28a8bbaa28600404ed997dea48862b9e97a243fc1d74090d0365cbdb1290e52","Size":71528248,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-compile-linux64.tar.bz2","ArchiveFileName":"teensy-compile-linux64.tar.bz2","Checksum":"SHA-256:f61ee7358909e4aebc3c0de5ada2c61208d0ea0f01384d7f73b4a8ad396bf383","Size":72871529,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-compile-linuxaarch64.tar.bz2","ArchiveFileName":"teensy-compile-linuxaarch64.tar.bz2","Checksum":"SHA-256:257fd45f8ef802bd5c18991934eaad8819115749c7f3604a31c7a2445a1cc9b2","Size":73079610,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-compile-linuxarm.tar.bz2","ArchiveFileName":"teensy-compile-linuxarm.tar.bz2","Checksum":"SHA-256:e63680d1acea958a4082ee70a1bf4501c62dd2e594e525db921154c90cd8b234","Size":67881541,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-compile-macos.tar.bz2","ArchiveFileName":"teensy-compile-macos.tar.bz2","Checksum":"SHA-256:cfab7921641ce18db7abb6a4dad8e18beedc389a506ccb6ead5f95c3e6cb4f22","Size":80269350,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://www.pjrc.com/teensy/td_156/teensy-compile-windows.tar.bz2","ArchiveFileName":"teensy-compile-windows.tar.bz2","Checksum":"SHA-256:c078866371fd7202639810c50aeb1ee469838e399617d93d38c823be4c3368e3","Size":84734981,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-08-03T15:04:15-05:00","tool":{"version":"1.56.53","systems":[{"os":"i686-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_157-beta3/teensy-discovery-linux32.tar.bz2","ArchiveFileName":"teensy-discovery-linux32.tar.bz2","Checksum":"SHA-256:266a6a5d7568a71d304bddce596a319bd46384cace2d70e40bc363a87cfbfcb0","Size":9265,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_157-beta3/teensy-discovery-linux64.tar.bz2","ArchiveFileName":"teensy-discovery-linux64.tar.bz2","Checksum":"SHA-256:c1f5c3394a7a819c6f962e034ca744d685db0e707bb3fef79183ade869a74aa2","Size":9490,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_157-beta3/teensy-discovery-linuxaarch64.tar.bz2","ArchiveFileName":"teensy-discovery-linuxaarch64.tar.bz2","Checksum":"SHA-256:7970996123211dcf8f7623eb9a9910f7501db90c1898abb1aad5f299758ee1bb","Size":8943,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://www.pjrc.com/teensy/td_157-beta3/teensy-discovery-linuxarm.tar.bz2","ArchiveFileName":"teensy-discovery-linuxarm.tar.bz2","Checksum":"SHA-256:4ab4f7e625ae0e4926bda085b1a99e5a409a0887acd5bcdeef8d49cfa4a4e5e7","Size":8801,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"https://www.pjrc.com/teensy/td_157-beta3/teensy-discovery-macos.tar.bz2","ArchiveFileName":"teensy-discovery-macos.tar.bz2","Checksum":"SHA-256:546974a5738eba58d987d7604337e442fa1a5a54af1bcccba8c7dcee38cd50b4","Size":10272,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://www.pjrc.com/teensy/td_157-beta3/teensy-discovery-windows.tar.bz2","ArchiveFileName":"teensy-discovery-windows.tar.bz2","Checksum":"SHA-256:1988f3ed7b5a83a805b6e0fa14bf13208c70ad04c030feaa43bfa1ff1284af16","Size":18872,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-08-03T15:04:15-05:00","tool":{"version":"1.56.53","systems":[{"os":"i686-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_157-beta3/teensy-monitor-linux32.tar.bz2","ArchiveFileName":"teensy-monitor-linux32.tar.bz2","Checksum":"SHA-256:9a1c5c557cdc5de622fdad597a6f5fdba99a0e8b449842d05456154fd786e15f","Size":10343,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_157-beta3/teensy-monitor-linux64.tar.bz2","ArchiveFileName":"teensy-monitor-linux64.tar.bz2","Checksum":"SHA-256:a8fb5d682bd104b97a8087d88a5cc3f823c9f742f940d744fcdfd9ee3880d5e5","Size":10561,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_157-beta3/teensy-monitor-linuxaarch64.tar.bz2","ArchiveFileName":"teensy-monitor-linuxaarch64.tar.bz2","Checksum":"SHA-256:9937fdf7924eb9bde7941b7801c3ca5d7f2592ad4482a6400e13f0f567806488","Size":10070,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://www.pjrc.com/teensy/td_157-beta3/teensy-monitor-linuxarm.tar.bz2","ArchiveFileName":"teensy-monitor-linuxarm.tar.bz2","Checksum":"SHA-256:20c7a31db449618f5a516a0eced2e2a43b0a8b74a285ecbc225f5d7e6a605c22","Size":9877,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"https://www.pjrc.com/teensy/td_157-beta3/teensy-monitor-macos.tar.bz2","ArchiveFileName":"teensy-monitor-macos.tar.bz2","Checksum":"SHA-256:1541c1c151a7ba93f3b333a21483e2e176e7ff60f51fb1f9edb4df5e343b3b36","Size":12312,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://www.pjrc.com/teensy/td_157-beta3/teensy-monitor-windows.tar.bz2","ArchiveFileName":"teensy-monitor-windows.tar.bz2","Checksum":"SHA-256:e8e271887bd01fe97a75eab6d82f72ec36ee351e0694b1ab669f6c7a450c244b","Size":20300,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-08-03T15:04:15-05:00","tool":{"version":"1.56.53","systems":[{"os":"i686-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_157-beta3/teensy-tools-linux32.tar.bz2","ArchiveFileName":"teensy-tools-linux32.tar.bz2","Checksum":"SHA-256:7abd16609ff71a47ca1a4fb12d55815c0744c67189a99173c843b18ce4a14969","Size":5379510,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_157-beta3/teensy-tools-linux64.tar.bz2","ArchiveFileName":"teensy-tools-linux64.tar.bz2","Checksum":"SHA-256:6267acc7f673014b9d5f81e8569e5770afd53ec40db5efe5311bab7e15e6788a","Size":5364860,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://www.pjrc.com/teensy/td_157-beta3/teensy-tools-linuxaarch64.tar.bz2","ArchiveFileName":"teensy-tools-linuxaarch64.tar.bz2","Checksum":"SHA-256:a0201b0c985c18b7f8edfd8411b4551065bbf59808773b2a50d9bf20d8ba58c4","Size":5542879,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://www.pjrc.com/teensy/td_157-beta3/teensy-tools-linuxarm.tar.bz2","ArchiveFileName":"teensy-tools-linuxarm.tar.bz2","Checksum":"SHA-256:e9f887b4371b98aa6afc44c30735c5f6dd1d88d48859ed2e47b8031d6b0b9dee","Size":5432668,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"https://www.pjrc.com/teensy/td_157-beta3/teensy-tools-macos.tar.bz2","ArchiveFileName":"teensy-tools-macos.tar.bz2","Checksum":"SHA-256:b8c45a884a4cfd3618101c522ea5c0003bbf3d60b4cde884f77befa47af39f88","Size":6184980,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://www.pjrc.com/teensy/td_157-beta3/teensy-tools-windows.tar.bz2","ArchiveFileName":"teensy-tools-windows.tar.bz2","Checksum":"SHA-256:ad443c077a3523c1b2043d8c85d02ab88982f7ada4af2368284c46cd186f92c1","Size":5560884,"CachePath":"packages"}}]}}
{"index":"c:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\package_index.json","level":"info","msg":"Checking signature","signatureFile":"c:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\package_index.json.sig","time":"2022-08-03T15:04:15-05:00","trusted":true}
{"error":"opening signature file: open c:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\package_teensy_index.json.sig: The system cannot find the file specified.","index":"c:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\package_teensy_index.json","level":"info","msg":"Checking signature","signatureFile":"c:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\package_teensy_index.json.sig","time":"2022-08-03T15:04:15-05:00"}
{"dir":"C:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-08-03T15:04:15-05:00"}
{"dir":"C:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.56.53\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-08-03T15:04:15-05:00"}
{"dir":"C:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-08-03T15:04:15-05:00"}
{"dir":"d:\\ChuckW\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-08-03T15:04:15-05:00"}
root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open c:\Users\ChuckW\AppData\Local\Arduino15\library_index.json: Access is denied.
root INFO Deployed backend plugin "vscode-language-pack-fr@1.69.0" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 105.1 ms [Finished 3.497 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-it@1.69.0" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 80.4 ms [Finished 3.578 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ja@1.69.0" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 138.8 ms [Finished 3.717 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-nl@1.48.3" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 57.7 ms [Finished 3.774 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-pt-BR@1.69.0" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 119.2 ms [Finished 3.894 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ru@1.69.0" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 115.8 ms [Finished 4.009 s after backend start]
root WARN Frontend s.configure took longer than the expected maximum 100 milliseconds: 386.0 ms [Finished 2.080 s after frontend start]
root INFO Deployed backend plugin "vscode-language-pack-tr@1.69.0" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 88.3 ms [Finished 4.098 s after backend start]
root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 106.4 ms [Finished 2.206 s after frontend start]
root INFO Deployed backend plugin "vscode-language-pack-zh-hans@1.69.0" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 83.9 ms [Finished 4.182 s after backend start]
root INFO Deploy plugins list: 1235.9 ms [Finished 4.188 s after backend start]
root INFO Start frontend contributions: 765.3 ms [Finished 2.386 s after frontend start]
root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"kind":"navigatable","uri":"file:///d%3A/ChuckW/Arduino/EchoBoth/EchoBoth.ino","counter":0}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":35,\"column\":1},\"position\":{\"lineNumber\":35,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":35,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":null},"pinned":[],"expanded":false},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":true,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":323},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"library-list-widget"}
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f] Waiting for backend deployment: 92.1 ms [Finished 2.475 s after frontend start]
root INFO [hosted-plugin: 10792] PLUGIN_HOST(10792) starting instance
root WARN Mismatching sketch file <BS.ino> and sketch folder name <BB_datataker>. Skipping
root WARN Mismatching sketch file <SD.ino> and sketch folder name <BB_DataTaker>. Skipping
root WARN Mismatching sketch file <Serial.ino> and sketch folder name <BB_DataTaker>. Skipping
root WARN Mismatching sketch file <My_Time.ino> and sketch folder name <BB_DataTaker>. Skipping
root WARN Mismatching sketch file <Time_Fncts.ino> and sketch folder name <BB_DataTaker>. Skipping
root WARN Mismatching sketch file <Time_funcs.ino> and sketch folder name <BB_Data_Taker_1.0-022321>. Skipping
root WARN Mismatching sketch file <time_functs.ino> and sketch folder name <dst_testing02_10_2021VS>. Skipping
root WARN Mismatching sketch file <String_functs.ino> and sketch folder name <BB_DataTaker>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <BB_Data_Taker_1.0-022321>. Skipping
root WARN Mismatching sketch file <SetTimeFunction.ino> and sketch folder name <BB_DataTaker>. Skipping
root WARN Mismatching sketch file <Initialize_HW.ino> and sketch folder name <BB_Data_Taker_1.0-022321>. Skipping
root WARN Mismatching sketch file <time_testing.ino> and sketch folder name <TimeTeensy3-mod1>. Skipping
root WARN Mismatching sketch file <Time_funcs_done.ino> and sketch folder name <bbtaker_1.0>. Skipping
root WARN Mismatching sketch file <Initialize.ino> and sketch folder name <bbtaker_10-29-20>. Skipping
root WARN Mismatching sketch file <Initialize.ino> and sketch folder name <bbtaker_11-01-20>. Skipping
root WARN Mismatching sketch file <Initialize.ino> and sketch folder name <bbtaker_11-02-20>. Skipping
root WARN Mismatching sketch file <Initialize.ino> and sketch folder name <bbtaker_11-03-20>. Skipping
root WARN Mismatching sketch file <Serial_data_functs.ino> and sketch folder name <BB_DataTaker>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <bbtaker_10-29-20>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <bbtaker_11-01-20>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <bbtaker_11-02-20>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <bbtaker_11-03-20>. Skipping
root WARN Mismatching sketch file <Time_funcs_done.ino> and sketch folder name <sketch_sep18b>. Skipping
root WARN Mismatching sketch file <MTP_Loop.ino> and sketch folder name <BB_DT_071421_MTP_test>. Skipping
root WARN Mismatching sketch file <Menu_test.ino> and sketch folder name <BB_Data_Taker_1-030521>. Skipping
root WARN Mismatching sketch file <Time_funcs.ino> and sketch folder name <BB_DT_071421_MTP_test>. Skipping
root WARN Mismatching sketch file <Time_funcs_done.ino> and sketch folder name <bbtaker_10-13-20>. Skipping
root WARN Mismatching sketch file <Time_funcs_done.ino> and sketch folder name <bbtaker_10-14-20>. Skipping
root WARN Mismatching sketch file <Time_funcs_done.ino> and sketch folder name <bbtaker_10-15-20>. Skipping
root WARN Mismatching sketch file <Time_funcs_done.ino> and sketch folder name <bbtaker_10-29-20>. Skipping
root WARN Mismatching sketch file <Time_funcs_done.ino> and sketch folder name <bbtaker_11-01-20>. Skipping
root WARN Mismatching sketch file <Time_funcs_done.ino> and sketch folder name <bbtaker_11-02-20>. Skipping
root WARN Mismatching sketch file <Time_funcs_done.ino> and sketch folder name <bbtaker_11-03-20>. Skipping
root WARN Mismatching sketch file <DST.ino> and sketch folder name <BB_Data_Taker_02-08-21 - Copy>. Skipping
root WARN Mismatching sketch file <Time_funcs.ino> and sketch folder name <BB_Data_Taker_02-08-21>. Skipping
root WARN Mismatching sketch file <Time_funcs.ino> and sketch folder name <BB_Data_Taker_02-10-21>. Skipping
root WARN Mismatching sketch file <Time_funcs.ino> and sketch folder name <BB_Data_Taker_02-22-21>. Skipping
root WARN Mismatching sketch file <Time_funcs.ino> and sketch folder name <BB_Data_Taker_1-022321>. Skipping
root WARN Mismatching sketch file <Time_funcs.ino> and sketch folder name <BB_Data_Taker_1-030521>. Skipping
root WARN Mismatching sketch file <Time_funcs.ino> and sketch folder name <BB_Data_Taker_1-031321>. Skipping
root WARN Mismatching sketch file <Time_funcs.ino> and sketch folder name <BB_Data_Taker_1-052421>. Skipping
root WARN Mismatching sketch file <Time_funcs.ino> and sketch folder name <BB_Data_Taker_1-052521>. Skipping
root WARN Mismatching sketch file <Time_funcs.ino> and sketch folder name <BB_Data_Taker_1-060921>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <BB_DT_071421_MTP_test>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <BB_Data_Taker_02-08-21>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <BB_Data_Taker_02-10-21>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <BB_Data_Taker_02-22-21>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <BB_Data_Taker_1-022321>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <BB_Data_Taker_1-030521>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <BB_Data_Taker_1-031321>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <BB_Data_Taker_1-052421>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <BB_Data_Taker_1-052521>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <BB_Data_Taker_1-060921>. Skipping
root WARN Mismatching sketch file <Process_data.ino> and sketch folder name <BB_DT_071421_MTP_test>. Skipping
root WARN Mismatching sketch file <Process_data.ino> and sketch folder name <BB_Data_Taker_1-022321>. Skipping
root WARN Mismatching sketch file <Process_data.ino> and sketch folder name <BB_Data_Taker_1-030521>. Skipping
root WARN Mismatching sketch file <Process_data.ino> and sketch folder name <BB_Data_Taker_1-052421>. Skipping
root WARN Mismatching sketch file <Process data.ino> and sketch folder name <BB_Data_Taker_1-052521>. Skipping
root WARN Mismatching sketch file <Process data.ino> and sketch folder name <BB_Data_Taker_1-060921>. Skipping
root WARN Mismatching sketch file <MTP_func.ino> and sketch folder name <BB_Data_Taker_1-070121_MTP>. Skipping
root WARN Mismatching sketch file <Initialize_HW.ino> and sketch folder name <BB_DT_071421_MTP_test>. Skipping
root WARN Mismatching sketch file <Initialize_HW.ino> and sketch folder name <BB_Data_Taker_02-08-21>. Skipping
root WARN Mismatching sketch file <Initialize_HW.ino> and sketch folder name <BB_Data_Taker_02-10-21>. Skipping
root WARN Mismatching sketch file <Initialize_HW.ino> and sketch folder name <BB_Data_Taker_02-22-21>. Skipping
root WARN Mismatching sketch file <Initialize_HW.ino> and sketch folder name <BB_Data_Taker_1-022321>. Skipping
root WARN Mismatching sketch file <Initialize_HW.ino> and sketch folder name <BB_Data_Taker_1-030521>. Skipping
root WARN Mismatching sketch file <Initialize_HW.ino> and sketch folder name <BB_Data_Taker_1-031321>. Skipping
root WARN Mismatching sketch file <Initialize_HW.ino> and sketch folder name <BB_Data_Taker_1-052421>. Skipping
root WARN Mismatching sketch file <Initialize_HW.ino> and sketch folder name <BB_Data_Taker_1-052521>. Skipping
root WARN Mismatching sketch file <Initialize_HW.ino> and sketch folder name <BB_Data_Taker_1-060921>. Skipping
root WARN Mismatching sketch file <Time_funcs_done.ino> and sketch folder name <bbtaker_10-12-20.txt>. Skipping
root WARN Mismatching sketch file <Time_funcs.ino> and sketch folder name <BB_Data_Taker_1-062521_MTP>. Skipping
root WARN Mismatching sketch file <Time_funcs.ino> and sketch folder name <BB_Data_Taker_1-070121_MTP>. Skipping
root WARN Mismatching sketch file <DST.ino> and sketch folder name <BB_Data_Taker_12-02-20_adding_MTP>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <BB_Data_Taker_1-062521_MTP>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <BB_Data_Taker_1-070121_MTP>. Skipping
root WARN Mismatching sketch file <Time_funcs.ino> and sketch folder name <BB_Data_Taker_1-022321_test2>. Skipping
root WARN Mismatching sketch file <Menu_test.ino> and sketch folder name <BB_Data_Taker_1-052421-failed>. Skipping
root WARN Mismatching sketch file <Process_data.ino> and sketch folder name <BB_Data_Taker_1-062521_MTP>. Skipping
root WARN Mismatching sketch file <Process_data.ino> and sketch folder name <BB_Data_Taker_1-070121_MTP>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <BB_Data_Taker_1-022321_test2>. Skipping
root WARN Mismatching sketch file <Time_funcs.ino> and sketch folder name <BB_Data_Taker_1-052421-failed>. Skipping
root WARN Mismatching sketch file <Initialize_HW.ino> and sketch folder name <BB_Data_Taker_1-062521_MTP>. Skipping
root WARN Mismatching sketch file <Initialize_HW.ino> and sketch folder name <BB_Data_Taker_1-070121_MTP>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <BB_Data_Taker_02-08-21 - Copy>. Skipping
root WARN Mismatching sketch file <Process_data.ino> and sketch folder name <BB_Data_Taker_1-022321_test2>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <BB_Data_Taker_1-052421-failed>. Skipping
root WARN Mismatching sketch file <Initialize_HW.ino> and sketch folder name <BB_Data_Taker_1-022321_test2>. Skipping
root WARN Mismatching sketch file <Process data.ino> and sketch folder name <BB_Data_Taker_1-052421-failed>. Skipping
root WARN Mismatching sketch file <Serial Receive with an end-marker.ino> and sketch folder name <BB_DataTaker>. Skipping
root WARN Mismatching sketch file <Initialize_HW.ino> and sketch folder name <BB_Data_Taker_02-08-21 - Copy>. Skipping
root WARN Mismatching sketch file <Initialize_HW.ino> and sketch folder name <BB_Data_Taker_1-052421-failed>. Skipping
root WARN Mismatching sketch file <Initialize.ino> and sketch folder name <BB_Data_Taker_12-02-20_adding_MTP>. Skipping
root WARN Mismatching sketch file <Processing.ino> and sketch folder name <BB_Data_Taker_12-02-20_adding_MTP>. Skipping
root WARN Mismatching sketch file <Time_funcs_done.ino> and sketch folder name <BB_Data_Taker_02-08-21 - Copy>. Skipping
root WARN Mismatching sketch file <DST.ino> and sketch folder name <BB_Data_Taker_11-03-20_serial_port_change>. Skipping
root WARN Mismatching sketch file <DST.ino> and sketch folder name <BB_Data_Taker_11-28-20_serial_port_change>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <BB_Data_Taker_12-02-20_adding_MTP>. Skipping
root WARN Mismatching sketch file <DST.ino> and sketch folder name <BB_Data_Taker_12-16-20_serial_port_change>. Skipping
root WARN Mismatching sketch file <Time_funcs_done.ino> and sketch folder name <BB_Data_Taker_12-02-20_adding_MTP>. Skipping
root WARN Mismatching sketch file <BB_Data_Taker_02-08-21.ino> and sketch folder name <BB_Data_Taker_02-08-21 - Copy>. Skipping
root WARN Mismatching sketch file <Initialize.ino> and sketch folder name <BB_Data_Taker_11-03-20_serial_port_change>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <BB_Data_Taker_11-03-20_serial_port_change>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <BB_Data_Taker_11-28-20_serial_port_change>. Skipping
root WARN Mismatching sketch file <menu_functs.ino> and sketch folder name <BB_Data_Taker_12-16-20_serial_port_change>. Skipping
root WARN Mismatching sketch file <Initialize_HW.ino> and sketch folder name <BB_Data_Taker_11-28-20_serial_port_change>. Skipping
root WARN Mismatching sketch file <Initialize_HW.ino> and sketch folder name <BB_Data_Taker_12-16-20_serial_port_change>. Skipping
root WARN Mismatching sketch file <Time_funcs_done.ino> and sketch folder name <BB_Data_Taker_11-03-20_serial_port_change>. Skipping
root WARN Mismatching sketch file <Time_funcs_done.ino> and sketch folder name <BB_Data_Taker_11-28-20_serial_port_change>. Skipping
root WARN Mismatching sketch file <Time_funcs_done.ino> and sketch folder name <BB_Data_Taker_12-16-20_serial_port_change>. Skipping
root WARN Mismatching sketch file <LowLatencyLogger.ino> and sketch folder name <LowLatencyLoggerADXL345>. Skipping
root WARN Mismatching sketch file <LowLatencyLogger.ino> and sketch folder name <LowLatencyLoggerMPU6050>. Skipping
root ERROR ---- !!!SLOW!!! DURATION: getSketchesNew took 582.104 ms. Args: [{"uri":"file:///d%3A/ChuckW/Arduino"}] ----
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f] Sync of 16 plugins: 776.2 ms [Finished 3.251 s after frontend start]
discovery-log INFO start request start watch
discovery-log INFO start requested start watch
discovery-log INFO start resolved watching
daemon INFO {"level":"info","msg":"starting discovery teensy:teensy-discovery process","time":"2022-08-03T15:04:18-05:00"}
daemon INFO {"level":"info","msg":"starting discovery builtin:mdns-discovery process","time":"2022-08-03T15:04:18-05:00"}
{"level":"info","msg":"starting discovery builtin:serial-discovery process","time":"2022-08-03T15:04:18-05:00"}
daemon INFO {"level":"info","msg":"started discovery builtin:mdns-discovery process","time":"2022-08-03T15:04:18-05:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.25.1\" to discovery builtin:mdns-discovery","time":"2022-08-03T15:04:18-05:00"}
{"level":"info","msg":"started discovery teensy:teensy-discovery process","time":"2022-08-03T15:04:18-05:00"}
daemon INFO {"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.25.1\" to discovery teensy:teensy-discovery","time":"2022-08-03T15:04:18-05:00"}
{"level":"info","msg":"started discovery builtin:serial-discovery process","time":"2022-08-03T15:04:18-05:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.25.1\" to discovery builtin:serial-discovery","time":"2022-08-03T15:04:18-05:00"}
root INFO isTemp?
daemon INFO {"level":"info","msg":"from discovery teensy:teensy-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-08-03T15:04:18-05:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-08-03T15:04:18-05:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-08-03T15:04:18-05:00"}
{"level":"info","msg":"sending command START_SYNC to discovery builtin:serial-discovery","time":"2022-08-03T15:04:18-05:00"}
daemon INFO {"level":"info","msg":"sending command START_SYNC to discovery teensy:teensy-discovery","time":"2022-08-03T15:04:18-05:00"}
{"level":"info","msg":"sending command START_SYNC to discovery builtin:mdns-discovery","time":"2022-08-03T15:04:18-05:00"}
{"level":"info","msg":"from discovery teensy:teensy-discovery received message type: start_sync, message: OK","time":"2022-08-03T15:04:18-05:00"}
{"level":"info","msg":"from discovery builtin:mdns-discovery received message type: start_sync, message: OK","time":"2022-08-03T15:04:18-05:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: start_sync, message: OK","time":"2022-08-03T15:04:18-05:00"}
daemon INFO {"level":"info","msg":"from discovery teensy:teensy-discovery received message type: add, port: usb:0/140000/0/3","time":"2022-08-03T15:04:18-05:00"}
discovery-log INFO onData
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: add, port: COM2","time":"2022-08-03T15:04:18-05:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: add, port: COM12","time":"2022-08-03T15:04:18-05:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: add, port: COM1","time":"2022-08-03T15:04:18-05:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: add, port: COM17","time":"2022-08-03T15:04:18-05:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: add, port: COM3","time":"2022-08-03T15:04:18-05:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: add, port: COM4","time":"2022-08-03T15:04:18-05:00"}
root INFO Attached boards and available ports changed:
root INFO  - Attached board: Teensy 3.2 / 3.1 [teensy:avr:teensy31] on COM12 Serial Teensy Ports
root INFO ------------------------------------------
root INFO <<< The layout has been successfully restored.
app-state-change >>> new app state <initialized_layout was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <initialized_layout> for window <1>
root INFO Initialize the workbench layout: 2041.4 ms [Finished 4.468 s after frontend start]
root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][marus25.cortex-debug]: Loaded contributions.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][arduino.vscode-arduino-tools]: Loaded contributions.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][vscode.cpp]: Loaded contributions.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][vscode.json]: Loaded contributions.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][vscode.json-language-features]: Loaded contributions.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f] Load contributions of 16 plugins: 83.1 ms [Finished 4.552 s after frontend start]
root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
root WARN a registered grammar configuration for 'cpp' language is overridden
root INFO  - New port is available on COM2 Serial Port
root INFO isTemp?
root INFO [hosted-plugin: 10792] PLUGIN_HOST(10792): PluginManagerExtImpl/init()
root INFO [hosted-plugin: 10792] PLUGIN_HOST(10792): initializing(cortex-debug@0.3.10 with D:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 10792] Debugger contribution has been registered: cortex-debug
root INFO [hosted-plugin: 10792] PLUGIN_HOST(10792): initializing(vscode-arduino-tools@0.0.2-beta.5 with D:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 10792] PLUGIN_HOST(10792): initializing(cpp@1.52.1 with D:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 10792] PLUGIN_HOST(10792): initializing(json@1.46.1 with D:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 10792] PLUGIN_HOST(10792): initializing(json-language-features@1.46.1 with D:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 10792] PLUGIN_HOST(10792): initializing(vscode-language-pack-cs@1.69.0 with D:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 10792] PLUGIN_HOST(10792): initializing(vscode-language-pack-de@1.69.0 with D:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 10792] PLUGIN_HOST(10792): initializing(vscode-language-pack-es@1.69.0 with D:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 10792] PLUGIN_HOST(10792): initializing(vscode-language-pack-fr@1.69.0 with D:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 10792] PLUGIN_HOST(10792): initializing(vscode-language-pack-it@1.69.0 with D:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 10792] PLUGIN_HOST(10792): initializing(vscode-language-pack-ja@1.69.0 with D:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 10792] PLUGIN_HOST(10792): initializing(vscode-language-pack-nl@1.48.3 with D:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 10792] PLUGIN_HOST(10792): initializing(vscode-language-pack-pt-BR@1.69.0 with D:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 10792] PLUGIN_HOST(10792): initializing(vscode-language-pack-ru@1.69.0 with D:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 10792] PLUGIN_HOST(10792): initializing(vscode-language-pack-tr@1.69.0 with D:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 10792] PLUGIN_HOST(10792): initializing(vscode-language-pack-zh-hans@1.69.0 with D:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 10792] PLUGIN_HOST(10792): PluginManagerExtImpl/loadPlugin(D:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
root INFO  - New port is available on COM12 Serial Port (USB)
root INFO  - New port is available on COM1 Serial Port
root INFO  - New port is available on COM17 Serial Port
root INFO  - New port is available on COM3 Serial Port
root INFO  - New port is available on COM4 Serial Port
app-state-change >>> new app state <ready was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <ready> for window <1>
root INFO Frontend application start: 3665.1 ms [Finished 7.569 s after backend start]
root INFO Replace loading indicator with ready workbench UI (animation): 861.9 ms [Finished 5.418 s after frontend start]
root INFO Changed application state from 'initialized_layout' to 'ready'.
root INFO isTemp?
root INFO Executing startup tasks: []
root INFO ---- DURATION: installed took 34.325 ms. Args: [{}] ----
Checking for update
root ERROR ---- !!!SLOW!!! DURATION: getSketchesNew took 208.592 ms. Args: [{}] ----
root INFO ---- DURATION: installed took 50.843 ms. Args: [{"fqbn":"teensy:avr:teensy31"}] ----
Update for version 2.0.0-rc9.1 is not available (latest version: 2.0.0-rc9.1, downgrade is allowed).
root INFO [hosted-plugin: 10792] PLUGIN_HOST(10792): PluginManagerExtImpl/loadPlugin(D:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][marus25.cortex-debug]: Started plugin.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][arduino.vscode-arduino-tools]: Started plugin.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][vscode.cpp]: Started plugin.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][vscode.json]: Started plugin.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][vscode.json-language-features]: Started plugin.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-cs]: Started plugin.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-de]: Started plugin.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-es]: Started plugin.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-fr]: Started plugin.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-it]: Started plugin.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-ja]: Started plugin.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-nl]: Started plugin.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-pt-br]: Started plugin.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-ru]: Started plugin.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-tr]: Started plugin.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f][ms-ceintl.vscode-language-pack-zh-hans]: Started plugin.
root INFO [e2b6f0d4-b678-467f-9206-08482fd38d2f] Start of 16 plugins: 2202.2 ms [Finished 6.762 s after frontend start]
root INFO Starting language server: teensy:avr:teensy31
daemon INFO {"level":"info","msg":"Searching tools required for board teensy:avr:teensy31","time":"2022-08-03T15:04:21-05:00"}
daemon INFO {"level":"info","msg":"Required tool","time":"2022-08-03T15:04:21-05:00","tool":{"ToolName":"teensy-compile","ToolVersion":"1.56.1","ToolPackager":"teensy"}}
{"level":"info","msg":"Required tool","time":"2022-08-03T15:04:21-05:00","tool":{"ToolName":"teensy-tools","ToolVersion":"1.56.53","ToolPackager":"teensy"}}
{"dir":"C:\\Program Files (x86)\\Arduino\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2022-08-03T15:04:21-05:00"}
{"dir":"C:\\Users\\ChuckW\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.56.53\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-08-03T15:04:21-05:00"}
daemon INFO {"dir":"d:\\ChuckW\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-08-03T15:04:21-05:00"}
daemon INFO {"level":"info","msg":"Searching tools required for board teensy:avr:teensy31","time":"2022-08-03T15:04:24-05:00"}
daemon INFO {"level":"info","msg":"Required tool","time":"2022-08-03T15:04:24-05:00","tool":{"ToolName":"teensy-compile","ToolVersion":"1.56.1","ToolPackager":"teensy"}}
{"level":"info","msg":"Required tool","time":"2022-08-03T15:04:24-05:00","tool":{"ToolName":"teensy-tools","ToolVersion":"1.56.53","ToolPackager":"teensy"}}
daemon INFO {"level":"info","msg":"Updating libraries index","time":"2022-08-03T15:04:28-05:00"}
daemon INFO {"level":"info","msg":"URL: https://downloads.arduino.cc/packages/package_index.tar.bz2","time":"2022-08-03T15:04:28-05:00"}
{"level":"info","msg":"Updating index","time":"2022-08-03T15:04:28-05:00","url":{"Scheme":"https","Opaque":"","User":null,"Host":"downloads.arduino.cc","Path":"/packages/package_index.tar.bz2","RawPath":"","ForceQuery":false,"RawQuery":"","Fragment":"","RawFragment":""}}
root INFO core-client-provider [library-index]
root INFO core-client-provider [platform-index]
daemon INFO {"level":"info","msg":"URL: https://www.pjrc.com/teensy/td_156/package_teensy_index.json","time":"2022-08-03T15:04:28-05:00"}
{"level":"info","msg":"Updating index","time":"2022-08-03T15:04:28-05:00","url":{"Scheme":"https","Opaque":"","User":null,"Host":"www.pjrc.com","Path":"/teensy/td_156/package_teensy_index.json","RawPath":"","ForceQuery":false,"RawQuery":"","Fragment":"","RawFragment":""}}
daemon INFO {"level":"info","msg":"Updating libraries index","time":"2022-08-03T15:04:30-05:00"}
daemon INFO {"level":"info","msg":"Updating libraries index","time":"2022-08-03T15:04:32-05:00"}
root ERROR Failed to update indexes
seeing this message after normal start up, see attached
This is definitely the cause of the empty Library Manager.
Do you have any idea about why Arduino IDE is not able to save a file to this path?:
Yes it's because Arduino is installed on the "D" drive and the folder doesn't exist. I there a way to change the path?
Now it will not start up completely, it is stuck on the splash screen.
I checked and the folder does exist. No reason why it can't be accessed.
When it last ran it did finally populate after several restarts. i received a message about it downloading. But now it will not start completely.
That shouldn't make any difference. I often install Arduino IDE on my E:\ drive.
I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
  1. Start Windows "File Explorer".
  2. Open the Arduino IDE installation folder.
    (usually C:\Program Files\Arduino IDE or C:\Users\<user name>\AppData\Local\Programs\Arduino IDE).
  3. In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
  4. From the context menu, click "Open PowerShell window here".
    PowerShell will now open with the current directory set to the Arduino IDE installation folder.
  5. Type the following command:
    & ".\Arduino IDE"
  6. Press the Enter key.
    Debug output should now be printed to the PowerShell window as the Arduino IDE starts (or fails to start).
  7. Wait for the Arduino IDE to finish starting, or failing to start.
  8. Switch back to the PowerShell window if the Arduino IDE window took the focus.
  9. Right click on the title bar of the PowerShell window.
    This will open a context menu.
  10. Select Edit > Select All from the context menu.
    This will select all the text in the PowerShell window.
  11. Press Ctrl+C.
    This will copy the contents of the PowerShell window to the clipboard.
  12. Open a forum reply here by clicking the Reply button.
  13. Click the </> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  14. Press Ctrl+V.
    This will paste the output into the code block.
  15. Move the cursor outside of the code block markup before you add any additional text to your reply.
  16. Click the Reply button to post the output.
Please let me know if you have any questions or problems while following those instructions.
Already uninstalled and reinstalled on the c: drive using the msi installer. No problem with it starting or updating the library manager
