Library Manager is empty2
Thanks, ptillisch.
I'm not sure why, but I don't have any libraries listed (see attached image). I'm afraid I am new to Arduino so do I need to point it to the correct location? It worked fine on IDE 1.8 before I installed IDE 2.0. I would have thought it must find the libraries as it wouldn't compile otherwise?
I'm going to ask you to post the logs that are printed when you run the IDE from the command line terminal. I think that will provide the information that will help us to identify the problem.
Please do this:
  1. Start Windows "File Explorer".
  2. Open the Arduino IDE installation folder.
    (usually C:\Program Files\Arduino IDE or C:\Users\<user name>\AppData\Local\Programs\Arduino IDE).
  3. In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
  4. From the context menu, click "Open PowerShell window here".
    PowerShell will now open with the current directory set to the Arduino IDE installation folder.
  5. Type the following command:
    & ".\Arduino IDE"
  6. Press the Enter key.
    Debug output should now be printed to the PowerShell window as the Arduino IDE starts (or fails to start).
  7. Wait for the Arduino IDE to finish starting, or failing to start.
  8. Switch back to the PowerShell window if the Arduino IDE window took the focus.
  9. Right click on the title bar of the PowerShell window.
    This will open a context menu.
  10. Select Edit > Select All from the context menu.
    This will select all the text in the PowerShell window.
  11. Press Ctrl+C.
    This will copy the contents of the PowerShell window to the clipboard.
  12. Open a forum reply here by clicking the Reply button.
  13. Click the </> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  14. Press Ctrl+V.
    This will paste the output into the code block.
  15. Move the cursor outside of the code block markup before you add any additional text to your reply.
  16. Click the Reply button to post the output.
Please let me know if you have any questions or problems while following those instructions.
Hi ptillisch,
Here is the debug information. Thanks
PS C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Starting backend process. PID: 3484
Using browser-only version of superagent in non-browser environment
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
root INFO Configuration directory URI: 'file:///c%3A/Users/Terry%20Mann/.theia'
root INFO Backend Object.initialize: 4.4 ms [Finished 1.166 s after backend start]
root INFO Backend Object.configure: 3.4 ms [Finished 1.166 s after backend start]
root INFO Backend MessagingContribution.onStart: 1.6 ms [Finished 1.166 s after backend start]
root INFO Backend OSBackendApplicationContribution.configure: 0.4 ms [Finished 1.212 s after backend start]
root INFO Backend DefaultWorkspaceServer.onStart: 0.3 ms [Finished 1.212 s after backend start]
root INFO Backend LocalizationBackendContribution.configure: 0.2 ms [Finished 1.213 s after backend start]
root INFO Backend LocalizationBackendContribution.initialize: 46.0 ms [Finished 1.213 s after backend start]
root INFO Backend TaskBackendApplicationContribution.onStart: 0.2 ms [Finished 1.213 s after backend start]
root INFO Backend ElectronTokenBackendContribution.configure: 1.3 ms [Finished 1.214 s after backend start]
root INFO Backend PluginDeployerContribution.initialize: 0.4 ms [Finished 1.214 s after backend start]
root INFO Backend ConfigServiceImpl.onStart: 0.8 ms [Finished 1.215 s after backend start]
root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.5 ms [Finished 1.216 s after backend start]
root INFO Backend ArduinoDaemonImpl.onStart: 1.4 ms [Finished 1.217 s after backend start]
root INFO Backend NodeFileUploadService.configure: 2.3 ms [Finished 1.217 s after backend start]
daemon INFO Starting daemon from C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
discovery-log INFO start
discovery-log INFO start new deferred
root INFO Backend BoardDiscovery.onStart: 0.8 ms [Finished 1.219 s after backend start]
root INFO Backend FileDownloadEndpoint.configure: 0.5 ms [Finished 1.219 s after backend start]
root INFO Backend AuthenticationServiceImpl.onStart: 0.4 ms [Finished 1.220 s after backend start]
root INFO Backend PluginApiContribution.configure: 0.5 ms [Finished 1.220 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.4 ms [Finished 1.221 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 1.222 s after backend start]
root INFO Backend PlotterBackendContribution.configure: 0.9 ms [Finished 1.223 s after backend start]
root INFO Theia app listening on http://localhost:59623.
root INFO Finished starting backend application: 4.6 ms [Finished 1.225 s after backend start]
root WARN The local plugin referenced by local-dir:/c%3A/Users/Terry%20Mann/.arduinoIDE/plugins does not exist.
root WARN The local plugin referenced by local-dir:/c%3A/Users/Terry%20Mann/.arduinoIDE/extensions does not exist.
root WARN The local plugin referenced by local-dir:C:\Users\Terry Mann\.arduinoProIDE\plugins does not exist.
Restoring workspace roots: c:\Users\Terry Mann\AppData\Local\Arduino15\RemoteSketchbook\ArduinoCloud\5736244c-0d4e-461e-90b9-5dd4a2165804\my_Servo_Test
isTempSketch: false. Input was c:\Users\Terry Mann\AppData\Local\Arduino15\RemoteSketchbook\ArduinoCloud\5736244c-0d4e-461e-90b9-5dd4a2165804\my_Servo_Test
root INFO PluginTheiaDirectoryHandler: accepting plugin with path
root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@0.3.10" with engines:
root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.5" with engines:
root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.69.0" with engines:
root INFO ---- DURATION: loadCliConfig took 47.881 ms. Args: [] ----
root INFO Resolve plugins list: 86.3 ms [Finished 1.305 s after backend start]
root INFO Deployed backend plugin "cortex-debug@0.3.10" from "C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension": 8.7 ms [Finished 1.315 s after backend start]
root INFO Deployed backend plugin "vscode-arduino-tools@0.0.2-beta.5" from "C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 8.0 ms [Finished 1.323 s after backend start]
root INFO Deployed backend plugin "cpp@1.52.1" from "C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 37.9 ms [Finished 1.361 s after backend start]
root INFO Deployed backend plugin "json@1.46.1" from "C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 8.9 ms [Finished 1.370 s after backend start]
root INFO Deployed backend plugin "json-language-features@1.46.1" from "C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 6.7 ms [Finished 1.377 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-cs@1.69.0" from "C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 243.2 ms [Finished 1.620 s after backend start]
daemon INFO {"level":"info","msg":"Using config file: c:\\Users\\Terry Mann\\.arduinoIDE\\arduino-cli.yaml","time":"2022-10-05T09:40:31+01:00"}
{"level":"info","msg":"arduino-cli.exe version 0.27.1","time":"2022-10-05T09:40:31+01:00"}
{"level":"info","msg":"Executing `arduino-cli daemon`","time":"2022-10-05T09:40:31+01:00"}
{"IP":"127.0.0.1","Port":"59624"}
daemon INFO Daemon is running.
root INFO Deployed backend plugin "vscode-language-pack-de@1.69.0" from "C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 141.9 ms [Finished 1.762 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-es@1.69.0" from "C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 128.2 ms [Finished 1.890 s after backend start]
daemon INFO {"level":"info","msg":"Loading hardware from: C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages","time":"2022-10-05T09:40:31+01:00"}
{"level":"info","msg":"Loading package arduino from: C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware","time":"2022-10-05T09:40:31+01:00"}
{"level":"info","msg":"Adding monitor tool","protocol":"serial","time":"2022-10-05T09:40:31+01:00","tool":"builtin:serial-monitor"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:avr","Installed":"1.8.5","Latest":"1.8.5","Name":"Arduino AVR Boards"},"time":"2022-10-05T09:40:31+01:00"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:sam","Installed":"1.6.12","Latest":"1.6.12","Name":"Arduino ARM (32-bits) Boards"},"time":"2022-10-05T09:40:31+01:00"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:samd","Installed":"1.8.13","Latest":"1.8.13","Name":"Arduino SAMD (32-bits ARM Cortex-M0+) Boards"},"time":"2022-10-05T09:40:31+01:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-10-05T09:40:31+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-10-05T09:40:31+01:00"}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:31+01:00","tool":{"version":"4.5.0","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:31+01:00","tool":{"version":"1.2.0","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:31+01:00","tool":{"version":"1.2.1","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:31+01:00","tool":{"version":"1.3.0","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:31+01:00","tool":{"version":"4.8.3-2014q1","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:31+01:00","tool":{"version":"7-2017q4","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:31+01:00","tool":{"version":"7.3.0-atmel3.6.1-arduino7","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:31+01:00","tool":{"version":"6.3.0-arduino17","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:31+01:00","tool":{"version":"1.6.1-arduino","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:31+01:00","tool":{"version":"1.7.0-arduino3","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:31+01:00","tool":{"version":"0.10.0-arduino7","systems":null}}
{"level":"info","msg":"Loading package builtin from: C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages\\builtin","time":"2022-10-05T09:40:31+01:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-10-05T09:40:31+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-10-05T09:40:31+01:00"}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:31+01:00","tool":{"version":"5.8-arduino11","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:31+01:00","tool":{"version":"1.0.6","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:31+01:00","tool":{"version":"1.3.2","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:31+01:00","tool":{"version":"0.10.0","systems":null}}
{"index":"C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\package_index.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\package_index.json.sig","time":"2022-10-05T09:40:31+01:00","trusted":true}
{"dir":"C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-10-05T09:40:31+01:00"}
{"dir":"C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-10-05T09:40:31+01:00"}
{"dir":"C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-10-05T09:40:31+01:00"}
{"index":"C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\library_index.json","level":"info","msg":"Loading libraries index file","time":"2022-10-05T09:40:31+01:00"}
root INFO Deployed backend plugin "vscode-language-pack-fr@1.69.0" from "C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 103.4 ms [Finished 1.994 s after backend start]
daemon INFO {"dir":"C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2022-10-05T09:40:31+01:00"}
{"dir":"C:\\Users\\Terry Mann\\OneDrive\\Documents\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-10-05T09:40:31+01:00"}
root INFO Deployed backend plugin "vscode-language-pack-it@1.69.0" from "C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 82.8 ms [Finished 2.077 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ja@1.69.0" from "C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 73.9 ms [Finished 2.150 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-nl@1.48.3" from "C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 26.8 ms [Finished 2.177 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-pt-BR@1.69.0" from "C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 111.4 ms [Finished 2.289 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ru@1.69.0" from "C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 101.3 ms [Finished 2.390 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-tr@1.69.0" from "C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 71.2 ms [Finished 2.461 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-zh-hans@1.69.0" from "C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 70.4 ms [Finished 2.532 s after backend start]
root INFO Deploy plugins list: 86.3 ms [Finished 2.542 s after backend start]
discovery-log INFO start request start watch
discovery-log INFO start requested start watch
discovery-log INFO start resolved watching
daemon INFO {"level":"info","msg":"starting discovery builtin:mdns-discovery process","time":"2022-10-05T09:40:32+01:00"}
{"level":"info","msg":"starting discovery builtin:serial-discovery process","time":"2022-10-05T09:40:32+01:00"}
daemon INFO {"level":"info","msg":"started discovery builtin:mdns-discovery process","time":"2022-10-05T09:40:32+01:00"}
daemon INFO {"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:mdns-discovery","time":"2022-10-05T09:40:32+01:00"}
{"level":"info","msg":"started discovery builtin:serial-discovery process","time":"2022-10-05T09:40:32+01:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:serial-discovery","time":"2022-10-05T09:40:32+01:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-10-05T09:40:32+01:00"}
daemon INFO {"level":"info","msg":"sending command START_SYNC to discovery builtin:serial-discovery","time":"2022-10-05T09:40:32+01:00"}
{"level":"info","msg":"from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-10-05T09:40:32+01:00"}
{"level":"info","msg":"sending command START_SYNC to discovery builtin:mdns-discovery","time":"2022-10-05T09:40:32+01:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: start_sync, message: OK","time":"2022-10-05T09:40:32+01:00"}
{"level":"info","msg":"from discovery builtin:mdns-discovery received message type: start_sync, message: OK","time":"2022-10-05T09:40:32+01:00"}
root WARN Frontend s.configure took longer than the expected maximum 100 milliseconds: 212.0 ms [Finished 2.054 s after frontend start]
app-state-change >>> new app state <started_contributions was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <started_contributions> for window <1>
root INFO Start frontend contributions: 549.7 ms [Finished 2.333 s after frontend start]
root INFO Changed application state from 'init' to 'started_contributions'.
app-state-change >>> new app state <attached_shell was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <attached_shell> for window <1>
root INFO Changed application state from 'started_contributions' to 'attached_shell'.
root INFO >>> Restoring the layout state...
root INFO ------- SERIALIZED LAYOUT DATA -------
root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"kind":"navigatable","uri":"file:///c%3A/Users/Terry%20Mann/AppData/Local/Arduino15/RemoteSketchbook/ArduinoCloud/5736244c-0d4e-461e-90b9-5dd4a2165804/my_Servo_Test/my_Servo_Test.ino","counter":0}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":136,\"column\":6},\"position\":{\"lineNumber\":136,\"column\":6}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":129,\"column\":1},\"firstPositionDeltaTop\":-13},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":231,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"},{"constructionOptions":{"factoryId":"serial-monitor"}}],"currentIndex":1}},"pinned":[false,false],"size":367,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":true,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":248},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"arduino-sketchbook-widget"}
root INFO ------- END SERIALIZED LAYOUT DATA -------
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1] Waiting for backend deployment: 136.3 ms [Finished 2.466 s after frontend start]
root ERROR ---- !!!SLOW!!! DURATION: getSketchesNew took 125.615 ms. Args: [{"uri":"file:///c%3A/Users/Terry%20Mann/OneDrive/Documents/Arduino"}] ----
root INFO Refreshing token auth0|5736244c-0d4e-461e-90b9-5dd4a2165804
root INFO [hosted-plugin: 17936] PLUGIN_HOST(17936) starting instance
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1] Sync of 16 plugins: 860.1 ms [Finished 3.326 s after frontend start]
app-state-change >>> new app state <initialized_layout was received from sender <1>. current window ID: 1
root INFO <<< The layout has been successfully restored.
app-state-change <<< new app state is <initialized_layout> for window <1>
root INFO Initialize the workbench layout: 1242.3 ms [Finished 3.620 s after frontend start]
root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][marus25.cortex-debug]: Loaded contributions.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][arduino.vscode-arduino-tools]: Loaded contributions.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][vscode.cpp]: Loaded contributions.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][vscode.json]: Loaded contributions.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][vscode.json-language-features]: Loaded contributions.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1] Load contributions of 16 plugins: 97.8 ms [Finished 3.719 s after frontend start]
root WARN Frontend I.onDidInitializeLayout took longer than the expected maximum 100 milliseconds: 100.9 ms [Finished 3.722 s after frontend start]
root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
root WARN a registered grammar configuration for 'cpp' language is overridden
app-state-change >>> new app state <ready was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <ready> for window <1>
root INFO Frontend application start: 2990.8 ms [Finished 6.325 s after backend start]
root INFO Replace loading indicator with ready workbench UI (animation): 912.5 ms [Finished 4.638 s after frontend start]
root INFO Changed application state from 'initialized_layout' to 'ready'.
root INFO Executing startup tasks: []
root ERROR Request list failed with error: 13 INTERNAL: grpc: error while marshaling: string field contains invalid UTF-8
root ERROR Request installed failed with error: 13 INTERNAL: grpc: error while marshaling: string field contains invalid UTF-8
daemon INFO ERROR: 2022/10/05 09:40:35 [core] grpc: server failed to encode response:  rpc error: code = Internal desc = grpc: error while marshaling: string field contains invalid UTF-8
root INFO ---- DURATION: getSketchesNew took 76.669 ms. Args: [{}] ----
Checking for update
daemon INFO ERROR: 2022/10/05 09:40:36 [core] grpc: server failed to encode response:  rpc error: code = Internal desc = grpc: error while marshaling: string field contains invalid UTF-8
root ERROR Request search failed with error: 13 INTERNAL: grpc: error while marshaling: string field contains invalid UTF-8
root INFO [hosted-plugin: 17936] PLUGIN_HOST(17936): PluginManagerExtImpl/init()
root INFO [hosted-plugin: 17936] PLUGIN_HOST(17936): initializing(cortex-debug@0.3.10 with C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 17936] Debugger contribution has been registered: cortex-debug
root INFO [hosted-plugin: 17936] PLUGIN_HOST(17936): initializing(vscode-arduino-tools@0.0.2-beta.5 with C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 17936] PLUGIN_HOST(17936): initializing(cpp@1.52.1 with C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 17936] PLUGIN_HOST(17936): initializing(json@1.46.1 with C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 17936] PLUGIN_HOST(17936): initializing(json-language-features@1.46.1 with C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(17936): initializing(vscode-language-pack-cs@1.69.0 with C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 17936] PLUGIN_HOST(17936): initializing(vscode-language-pack-de@1.69.0 with C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 17936] PLUGIN_HOST(17936): initializing(vscode-language-pack-es@1.69.0 with C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 17936] PLUGIN_HOST(17936): initializing(vscode-language-pack-fr@1.69.0 with C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 17936] PLUGIN_HOST(17936): initializing(vscode-language-pack-it@1.69.0 with C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 17936] PLUGIN_HOST(17936): initializing(vscode-language-pack-ja@1.69.0 with C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 17936] PLUGIN_HOST(17936): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 17936] PLUGIN_HOST(17936): initializing(vscode-language-pack-pt-BR@1.69.0 with C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 17936] PLUGIN_HOST(17936): initializing(vscode-language-pack-ru@1.69.0 with C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 17936] PLUGIN_HOST(17936): initializing(vscode-language-pack-tr@1.69.0 with C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 17936] PLUGIN_HOST(17936): initializing(vscode-language-pack-zh-hans@1.69.0 with C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 17936] PLUGIN_HOST(17936): PluginManagerExtImpl/loadPlugin(C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
root INFO [hosted-plugin: 17936] PLUGIN_HOST(17936): PluginManagerExtImpl/loadPlugin(C:\Users\Terry Mann\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][marus25.cortex-debug]: Started plugin.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][arduino.vscode-arduino-tools]: Started plugin.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][vscode.cpp]: Started plugin.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][vscode.json]: Started plugin.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][vscode.json-language-features]: Started plugin.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-cs]: Started plugin.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-de]: Started plugin.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-es]: Started plugin.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-fr]: Started plugin.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-it]: Started plugin.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-ja]: Started plugin.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-nl]: Started plugin.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-pt-br]: Started plugin.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-ru]: Started plugin.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-tr]: Started plugin.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1][ms-ceintl.vscode-language-pack-zh-hans]: Started plugin.
root INFO [481c9d7b-5b59-4f7b-a6a8-849aebd144e1] Start of 16 plugins: 2031.8 ms [Finished 5.761 s after frontend start]
root ERROR Child node 'WorkspaceNodeId' does not belong to this 'WorkspaceNodeId' tree.
root INFO Starting language server: arduino:samd:nano_33_iot
Update for version 2.0.0 is not available (latest version: 2.0.0, downgrade is allowed).
daemon INFO {"level":"info","msg":"Searching tools required for board arduino:samd:nano_33_iot","time":"2022-10-05T09:40:36+01:00"}
daemon INFO {"level":"info","msg":"Required tool","time":"2022-10-05T09:40:36+01:00","tool":{"ToolName":"CMSIS","ToolVersion":"4.5.0","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2022-10-05T09:40:36+01:00","tool":{"ToolName":"CMSIS-Atmel","ToolVersion":"1.2.0","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2022-10-05T09:40:36+01:00","tool":{"ToolName":"arduinoOTA","ToolVersion":"1.2.1","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2022-10-05T09:40:36+01:00","tool":{"ToolName":"arm-none-eabi-gcc","ToolVersion":"7-2017q4","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2022-10-05T09:40:36+01:00","tool":{"ToolName":"bossac","ToolVersion":"1.7.0-arduino3","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2022-10-05T09:40:36+01:00","tool":{"ToolName":"openocd","ToolVersion":"0.10.0-arduino7","ToolPackager":"arduino"}}
{"dir":"C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2022-10-05T09:40:36+01:00"}
{"dir":"C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-10-05T09:40:36+01:00"}
{"dir":"C:\\Users\\Terry Mann\\OneDrive\\Documents\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-10-05T09:40:36+01:00"}
daemon INFO {"level":"info","msg":"Resolving include Wire.h for arch samd","time":"2022-10-05T09:40:37+01:00"}
{"level":"info","lib":"Wire","msg":"  found better lib","prio":"64C","time":"2022-10-05T09:40:37+01:00"}
daemon INFO {"level":"info","msg":"Resolving include Adafruit_PWMServoDriver.h for arch samd","time":"2022-10-05T09:40:37+01:00"}
{"level":"info","lib":"Adafruit-PWM-Servo-Driver-Library-master","msg":"  found better lib","prio":"3EB","time":"2022-10-05T09:40:37+01:00"}
daemon INFO {"level":"info","msg":"Searching tools required for board arduino:samd:nano_33_iot","time":"2022-10-05T09:40:38+01:00"}
{"level":"info","msg":"Required tool","time":"2022-10-05T09:40:38+01:00","tool":{"ToolName":"CMSIS","ToolVersion":"4.5.0","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2022-10-05T09:40:38+01:00","tool":{"ToolName":"CMSIS-Atmel","ToolVersion":"1.2.0","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2022-10-05T09:40:38+01:00","tool":{"ToolName":"arduinoOTA","ToolVersion":"1.2.1","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2022-10-05T09:40:38+01:00","tool":{"ToolName":"arm-none-eabi-gcc","ToolVersion":"7-2017q4","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2022-10-05T09:40:38+01:00","tool":{"ToolName":"bossac","ToolVersion":"1.7.0-arduino3","ToolPackager":"arduino"}}
daemon INFO {"level":"info","msg":"Required tool","time":"2022-10-05T09:40:38+01:00","tool":{"ToolName":"openocd","ToolVersion":"0.10.0-arduino7","ToolPackager":"arduino"}}
daemon INFO {"level":"info","msg":"Updating libraries index","time":"2022-10-05T09:40:42+01:00"}
daemon INFO {"level":"info","msg":"URL: https://downloads.arduino.cc/packages/package_index.tar.bz2","time":"2022-10-05T09:40:42+01:00"}
{"level":"info","msg":"Updating index","time":"2022-10-05T09:40:42+01:00","url":{"Scheme":"https","Opaque":"","User":null,"Host":"downloads.arduino.cc","Path":"/packages/package_index.tar.bz2","RawPath":"","ForceQuery":false,"RawQuery":"","Fragment":"","RawFragment":""}}
root INFO core-client-provider [platform-index]
root INFO core-client-provider [library-index]
daemon INFO {"level":"info","msg":"Loading hardware from: C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages","time":"2022-10-05T09:40:43+01:00"}
daemon INFO {"level":"info","msg":"Loading package arduino from: C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware","time":"2022-10-05T09:40:43+01:00"}
daemon INFO {"level":"info","msg":"Adding monitor tool","protocol":"serial","time":"2022-10-05T09:40:43+01:00","tool":"builtin:serial-monitor"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:avr","Installed":"1.8.5","Latest":"1.8.5","Name":"Arduino AVR Boards"},"time":"2022-10-05T09:40:43+01:00"}
daemon INFO {"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:sam","Installed":"1.6.12","Latest":"1.6.12","Name":"Arduino ARM (32-bits) Boards"},"time":"2022-10-05T09:40:43+01:00"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:samd","Installed":"1.8.13","Latest":"1.8.13","Name":"Arduino SAMD (32-bits ARM Cortex-M0+) Boards"},"time":"2022-10-05T09:40:43+01:00"}
daemon INFO {"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-10-05T09:40:43+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-10-05T09:40:43+01:00"}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:43+01:00","tool":{"version":"4.5.0","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:43+01:00","tool":{"version":"1.2.0","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:43+01:00","tool":{"version":"1.2.1","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:43+01:00","tool":{"version":"1.3.0","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:43+01:00","tool":{"version":"4.8.3-2014q1","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:43+01:00","tool":{"version":"7-2017q4","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:43+01:00","tool":{"version":"7.3.0-atmel3.6.1-arduino7","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:43+01:00","tool":{"version":"6.3.0-arduino17","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:43+01:00","tool":{"version":"1.6.1-arduino","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:43+01:00","tool":{"version":"1.7.0-arduino3","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:43+01:00","tool":{"version":"0.10.0-arduino7","systems":null}}
{"level":"info","msg":"Loading package builtin from: C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages\\builtin","time":"2022-10-05T09:40:43+01:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-10-05T09:40:43+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-10-05T09:40:43+01:00"}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:43+01:00","tool":{"version":"5.8-arduino11","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:43+01:00","tool":{"version":"1.0.6","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:43+01:00","tool":{"version":"1.3.2","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-05T09:40:43+01:00","tool":{"version":"0.10.0","systems":null}}
daemon INFO {"index":"C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\package_index.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\package_index.json.sig","time":"2022-10-05T09:40:43+01:00","trusted":true}
daemon INFO {"dir":"C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-10-05T09:40:43+01:00"}
daemon INFO {"dir":"C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-10-05T09:40:43+01:00"}
daemon INFO {"dir":"C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-10-05T09:40:43+01:00"}
{"index":"C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\library_index.json","level":"info","msg":"Loading libraries index file","time":"2022-10-05T09:40:43+01:00"}
daemon INFO {"dir":"C:\\Users\\Terry Mann\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2022-10-05T09:40:43+01:00"}
daemon INFO {"dir":"C:\\Users\\Terry Mann\\OneDrive\\Documents\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-10-05T09:40:43+01:00"}
discovery-log INFO restarting before stop
discovery-log INFO stop
discovery-log INFO >>> Stopping boards watcher...
discovery-log INFO Canceling boards watcher...
discovery-log INFO disposing requesting cancel
discovery-log INFO disposing canceled
discovery-log INFO error received
discovery-log INFO cancel error received!
discovery-log INFO stop received event: either end or cancel
discovery-log INFO stop stopped
discovery-log INFO received end
discovery-log INFO restarting after stop
daemon INFO {"level":"info","msg":"boards watcher stream closed","time":"2022-10-05T09:40:43+01:00"}
daemon INFO {"level":"info","msg":"starting discovery builtin:mdns-discovery process","time":"2022-10-05T09:40:43+01:00"}
{"level":"info","msg":"starting discovery builtin:serial-discovery process","time":"2022-10-05T09:40:43+01:00"}
daemon INFO {"level":"info","msg":"started discovery builtin:mdns-discovery process","time":"2022-10-05T09:40:44+01:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:mdns-discovery","time":"2022-10-05T09:40:44+01:00"}
{"level":"info","msg":"started discovery builtin:serial-discovery process","time":"2022-10-05T09:40:44+01:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:serial-discovery","time":"2022-10-05T09:40:44+01:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-10-05T09:40:44+01:00"}
{"level":"info","msg":"from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-10-05T09:40:44+01:00"}
daemon INFO {"level":"info","msg":"sending command START_SYNC to discovery builtin:serial-discovery","time":"2022-10-05T09:40:44+01:00"}
{"level":"info","msg":"sending command START_SYNC to discovery builtin:mdns-discovery","time":"2022-10-05T09:40:44+01:00"}
{"level":"info","msg":"from discovery builtin:mdns-discovery received message type: start_sync, message: OK","time":"2022-10-05T09:40:44+01:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: start_sync, message: OK","time":"2022-10-05T09:40:44+01:00"}
Thanks. I can see the problem here:
Unlike Arduino IDE 1.x, Arduino IDE 2.x currently is not compatible with library metadata files that have non-UTF-8 character encoding. This bug causes the Library Manager to be empty when you have a library installed with a metadata file using a different encoding:
The fix is to do one of the following:
  • If the library is needed, change the encoding of its library.properties metadata file.
  • If the library is not needed, delete it.
In order to accomplish either, we first need to find the problematic library(s). What is very unfortunate is that the IDE doesn't tell us which library is causing the error. So we must consider all the libraries you have installed under this folder:
C:\Users\Terry Mann\OneDrive\Documents\Arduino\libraries
You could do that by moving all the folders out of the libraries subfolder of your sketchbook folder and then move them back in one by one, restarting the Arduino IDE after each library, until you find the problematic one.
If you have a lot of libraries, you could employ the more efficient (but more complicated) "bisection" technique, where you remove half the libraries and restart the Arduino IDE, the result of which will tell you whether that half contains a problematic library or not. You can then continue through the libraries in the half that contained a problematic library, splitting the collection in half each at each step until you finally reduce it to only the "bad" ones.
Once you find the problematic library(s), file encoding can be changed to UTF-8 using most any text editor which is designed for use by programmers (e.g., VS Code, Notepad++). I'm happy to help you out with that process if needed.
