liquidCrystal_i2c does not name a type, need help
Hi all, i need help. (I am still a novice)
While i have been writing a sketch for my Arduino Uno based Weather Station, i decide to chage my LCD
i2c 16 x 2 for a LCD i2c 20 x 4, so i can have readouts for multiple sensor. Since i removed the 16 x 2 and wired up the 20 x 4 to the Arduino, i altered lcd.begin(20,4); in my sketch, i have not been able to run the sketch without getting errors, the current one is "liquidCrystal_i2c does not name a type" i have tried different libraries from different sources nothing seems to change, can anyone help me?
I cannot upload both the sketch and error messages, it exceeds the word count, so i will start with the sketch.
Regards
Ray
#include <SparkFunBME280.h>
#include <SoftWire.h>
#include <SoftI2CMaster.h>
#include <Wire.h>
liquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Addr, En, Rw, Rs, d4, d5, d6, d7, backlighpin, polarity
#define BME280_ADDRESS 0x76
unsigned long int hum_raw,temp_raw,pres_raw;
signed long int t_fine;
uint16_t dig_T1;
int16_t dig_T2;
int16_t dig_T3;
uint16_t dig_P1;
int16_t dig_P2;
int16_t dig_P3;
int16_t dig_P4;
int16_t dig_P5;
int16_t dig_P6;
int16_t dig_P7;
int16_t dig_P8;
int16_t dig_P9;
int8_t  dig_H1;
int16_t dig_H2;
int8_t  dig_H3;
int16_t dig_H4;
int16_t dig_H5;
int8_t  dig_H6;
uint8_t osrs_t = 1;             //Temperature oversampling x 1
uint8_t osrs_p = 1;             //Pressure oversampling x 1
uint8_t osrs_h = 1;             //Humidity oversampling x 1
uint8_t mode = 3;               //Normal mode
uint8_t t_sb = 5;               //Tstandby 1000ms
uint8_t filter = 0;             //Filter off
uint8_t spi3w_en = 0;           //3-wire SPI Disable
uint8_t ctrl_meas_reg = (osrs_t << 5) | (osrs_p << 2) | mode;
uint8_t config_reg    = (t_sb << 5) | (filter << 2) | spi3w_en;
uint8_t ctrl_hum_reg  = osrs_h;
Wire.begin();
writeReg(0xF2,ctrl_hum_reg);
writeReg(0xF4,ctrl_meas_reg);
writeReg(0xF5,config_reg);
readTrim();
double temp_act = 0.0, press_act = 0.0,hum_act=0.0;
signed long int temp_cal;
unsigned long int press_cal,hum_cal;
readData();
temp_cal = calibration_T(temp_raw);
press_cal = calibration_P(pres_raw);
hum_cal = calibration_H(hum_raw);
temp_act = (double)temp_cal / 100.0;
press_act = (double)press_cal / 100.0;
hum_act = (double)hum_cal / 1024.0;
  lcd.begin(20,4);
  lcd.clear();
  lcd.clear();
  lcd.setCursor(0,2);
  lcd.print("TEMP : ");
  lcd.print(temp_act);
  lcd.print(" Deg,C");
  lcd.setCursor(0,1);
  lcd.print("HUMIDITY : ");
  lcd.print(hum_act);
  lcd.print("%");
  lcd.setCursor(0,0);
  lcd.print("PRESS :");
  lcd.print(press_act);
  lcd.print(" mBar");
delay(10000);
void readTrim()
uint8_t data[32],i=0;
Wire.beginTransmission(BME280_ADDRESS);
Wire.write(0x88);
Wire.endTransmission();
Wire.requestFrom(BME280_ADDRESS,24);
while(Wire.available()){
data[i] = Wire.read();
i++;
Wire.write(0xA1);
Wire.requestFrom(BME280_ADDRESS,1);
i++;
Wire.write(0xE1);
Wire.requestFrom(BME280_ADDRESS,7);
i++;
dig_T1 = (data[1] << 8) | data[0];
dig_T2 = (data[3] << 8) | data[2];
dig_T3 = (data[5] << 8) | data[4];
dig_P1 = (data[7] << 8) | data[6];
dig_P2 = (data[9] << 8) | data[8];
dig_P3 = (data[11]<< 8) | data[10];
dig_P4 = (data[13]<< 8) | data[12];
dig_P5 = (data[15]<< 8) | data[14];
dig_P6 = (data[17]<< 8) | data[16];
dig_P7 = (data[19]<< 8) | data[18];
dig_P8 = (data[21]<< 8) | data[20];
dig_P9 = (data[23]<< 8) | data[22];
dig_H1 = data[24];
dig_H2 = (data[26]<< 8) | data[25];
dig_H3 = data[27];
dig_H4 = (data[28]<< 4) | (0x0F & data[29]);
dig_H5 = (data[30] << 4) | ((data[29] >> 4) & 0x0F);
dig_H6 = data[31];
void writeReg(uint8_t reg_address, uint8_t data)
Wire.write(reg_address);
Wire.write(data);
void readData()
int i = 0;
uint32_t data[8];
Wire.write(0xF7);
Wire.requestFrom(BME280_ADDRESS,8);
i++;
pres_raw = (data[0] << 12) | (data[1] << 4) | (data[2] >> 4);
temp_raw = (data[3] << 12) | (data[4] << 4) | (data[5] >> 4);
hum_raw  = (data[6] << 8) | data[7];
signed long int calibration_T(signed long int adc_T)
signed long int var1, var2, T;
var1 = ((((adc_T >> 3) - ((signed long int)dig_T1<<1))) * ((signed long int)dig_T2)) >> 11;
var2 = (((((adc_T >> 4) - ((signed long int)dig_T1)) * ((adc_T>>4) - ((signed long int)dig_T1))) >> 12) * ((signed long int)dig_T3)) >> 14;
t_fine = var1 + var2;
T = (t_fine * 5 + 128) >> 8;
return T;
unsigned long int calibration_P(signed long int adc_P)
signed long int var1, var2;
unsigned long int P;
var1 = (((signed long int)t_fine)>>1) - (signed long int)64000;
var2 = (((var1>>2) * (var1>>2)) >> 11) * ((signed long int)dig_P6);
var2 = var2 + ((var1*((signed long int)dig_P5))<<1);
var2 = (var2>>2)+(((signed long int)dig_P4)<<16);
var1 = (((dig_P3 * (((var1>>2)*(var1>>2)) >> 13)) >>3) + ((((signed long int)dig_P2) * var1)>>1))>>18;
var1 = ((((32768+var1))*((signed long int)dig_P1))>>15);
if (var1 == 0)
return 0;
P = (((unsigned long int)(((signed long int)1048576)-adc_P)-(var2>>12)))*3125;
if(P<0x80000000)
P = (P << 1) / ((unsigned long int) var1);
P = (P / (unsigned long int)var1) * 2;
var1 = (((signed long int)dig_P9) * ((signed long int)(((P>>3) * (P>>3))>>13)))>>12;
var2 = (((signed long int)(P>>2)) * ((signed long int)dig_P8))>>13;
P = (unsigned long int)((signed long int)P + ((var1 + var2 + dig_P7) >> 4));
return P;
unsigned long int calibration_H(signed long int adc_H)
signed long int v_x1;
v_x1 = (t_fine - ((signed long int)76800));
v_x1 = (((((adc_H << 14) -(((signed long int)dig_H4) << 20) - (((signed long int)dig_H5) * v_x1)) +
((signed long int)16384)) >> 15) * (((((((v_x1 * ((signed long int)dig_H6)) >> 10) *
(((v_x1 * ((signed long int)dig_H3)) >> 11) + ((signed long int) 32768))) >> 10) + (( signed long int)2097152)) *
((signed long int) dig_H2) + 8192) >> 14));
v_x1 = (v_x1 - (((((v_x1 >> 15) * (v_x1 >> 15)) >> 7) * ((signed long int)dig_H1)) >> 4));
v_x1 = (v_x1 < 0 ? 0 : v_x1);
v_x1 = (v_x1 > 419430400 ? 419430400 : v_x1);
return (unsigned long int)(v_x1 >> 12);
The character Matrices LCD do not natively support I2C, as 99.9% of them are natively driven by an old M6800 bus. As a result, there are a few implementations of on board I2C conversions. Can you take some photos of your matrix, the back, or where the connections are, or link datasheets or source information for your matrix?
This line looks wrong. Should it start with an uppercase L ?
Should you also #include the LiquidCrystal_I2C library ?
Hi UKHeliBob.
I carried out your suggestions, now the error is "Positive was not declared in this scope"
Hi Perehama.
There's nothing on the LCD screen as i cannot upload the sketch, or do you mean something else?
Ray
JHer's the latest sketch
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Addr, En, Rw, Rs, d4, d5, d6, d7, backlighpin, polarity
uint16_t dig_T1;
int16_t dig_T2;
int16_t dig_T3;
uint16_t dig_P1;
int16_t dig_P2;
int16_t dig_P3;
int16_t dig_P4;
int16_t dig_P5;
int16_t dig_P6;
int16_t dig_P7;
int16_t dig_P8;
int16_t dig_P9;
int8_t  dig_H1;
int16_t dig_H2;
int8_t  dig_H3;
int16_t dig_H4;
int16_t dig_H5;
int8_t  dig_H6;
Wire.begin();
readTrim();
readData();
  lcd.begin(20,4);
  lcd.clear();
  lcd.clear();
  lcd.setCursor(0,2);
  lcd.setCursor(0,1);
  lcd.print(hum_act);
  lcd.print("%");
  lcd.setCursor(0,0);
  lcd.print(" mBar");
delay(10000);
void readTrim()
Wire.write(0x88);
i++;
Wire.write(0xA1);
i++;
Wire.write(0xE1);
i++;
dig_H1 = data[24];
dig_H3 = data[27];
dig_H6 = data[31];
Wire.write(data);
void readData()
int i = 0;
uint32_t data[8];
Wire.write(0xF7);
i++;
return T;
if (var1 == 0)
return 0;
if(P<0x80000000)
return P;
gresleyman:
Hi Perehama.
I mean a picture of the LCD screen you are using so we can see the pinout of the LCD. You talk of and I2C LCD, but you have the following in your code:
That looks more like the constructor for LiquidCrystal than it does the constructor for LiquidCrystal_I2C
LiquidCrystal_I2C(uint8_t lcd_Addr,uint8_t lcd_cols,uint8_t lcd_rows);
Perehama:
Which would probably also explain why ‘POSITIVE’ is not defined.
OP, by the way, your indenting is atrocious. Try “ctrl-t” in the IDE.
Hi all.
Many thanks for your help and contributions.
After much Googling, i came across a conversation about folders, missing one's that is. I had a quick check of my Arduino folder, and found the Hardware folder missing, a quick check of the hard drive it was still in the original Arduino software, i took a copy and pasted it into the Arduino document file and hey presto my sketch ran first time.
Regards
Ray
