I try to make as lot of people a scale with cheap load cell (40-50Kg) from AE and an ADS1232 (gain 128, 3.3v) for reading. The construction is like that. Its a “half scale” (there is only half Kg on the load cells part), the other side is at the height of that part :
First, i discovered that there is a way for Load Cell (no sign on mine), so one gave value going up, and the second going down, which make useless result.
I connect the 2 load cell in parallel as described in different solution.
So, i get value increasing when i put more load on it, which make me feel like it is basically working but the problem is the value is not accurate. Each time, i make average of value given by the ADS1232 :
0Kg : -140200
8.8Kg : -23400 (13.27)
18.8Kg : 104200 (13)
28.8Kg : 233700 (12.98)
38.8Kg : 382100 (13.46)
48.8Kg : 518900 (13.50)
38.8Kg : 381100 (13.43)
28.8Kg : 242000 (13.27)
18.8Kg : 103800 (12.97)
8.8Kg : -24100 (13.19)
0Kg : -140300
58.8Kg : 585200 (12.33)
68.8Kg : 692400 (12.10)
So, at beginning, the ratio is more less 13.20 but if i put too much weight, it going down to 12, thats first problem. The second is the value is decreasing other time.
At 68.8Kg, it start at 692400, but few minutes after, it is 686000 and continu going down. So, it makes difference around 1-2Kg if a apply a ratio as 12.5, but if value allways change, there is no accuracy.
So, my questions are :
I know it is cheap load cell (< 5€) and industrial one cost hundred euros. I don’t need really good precision in fact but is there a way to get more precise result ? I can scale it to the maximum load and make some conversion after for example, applying a scale of 13 for result beetween 0Kg and 60Kg then a scale of 12 for result beetween 60Kg and more, but would like to know if there is other way. Until for a load > 60Kg, the value decrease other time, it’s hard to make something.
Is my construction not as good as it could be, for example using a unique 50Kg cell (load is maximum 110Kg) or using 4 cells ?
I don’t really get why the value is decreasing so much other time at > 60Kg, i can understand that the load is undercontraint and need to stabilize, but it’s should not take so much time.
Thanks in advance,
