LoRa and Serial port hardware conflict on Feather M0
Dear forum,
I am trying to build a module that collects GPS data (among other things) and sends that data to a receiver via LoRa radio transmission. Unfortunately, when I try to run code like
char[100] data;
  GPSSerial.begin();
  rf95Init();
  if (GPSSerial.available()) {
    GPSSerial.readBytes(data, 100);
  rf95.send(data);
the GPS module, which is connected to the Feather M0 over Serial, would successfully update the "data" buffer in the first loop, then the radio would successfully transmit that data, but in the second loop and beyond, GPSSerial.available() never again returns true, even though I can confirm from external probes (i.e. another feather, or an oscilloscope) that the GPS continues to send Serial data.
I am using an Adafruit Feather M0 Express processor,
an Ultimate GPS FeatherWing,
and an RFM95W LoRa Radio FeatherWing.
I have thoroughly tested each component separately and I am pretty sure the problem lies in code rather than wiring or other hardware issues.
Where is GPSSerial defined ?
Please post your full sketch
What do you think happens if 1 character is available on GPSSerial, and you attempt to read 100 bytes?
How does the function rf95.send() determine how many bytes to transmit?
sorry, what I wrote above was pseudocode. this is the enitre sketch:
#include <SPI.h>
#include <RH_RF95.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BMP3XX.h"
#include <SPI.h>
#include <SdFat.h>
#include <Adafruit_SPIFlash.h>
// for flashTransport definition
#include "flash_config.h"
Adafruit_SPIFlash flash(&flashTransport);
// custom serial port for GPS
#include <Arduino.h>   // required before wiring_private.h
#include "wiring_private.h" // pinPeripheral() function
Uart GPSSerial (&sercom4, A2, A1, SERCOM_RX_PAD_1, UART_TX_PAD_0);
void SERCOM4_Handler()
  GPSSerial.IrqHandler();
// file system object from SdFat
FatVolume fatfs;
#define RFM95_RST 11  // "A"
#define RFM95_CS 10   // "B"
#define RFM95_INT 6   // "D"
#define RF95_FREQ 915.0
RH_RF95 rf95(RFM95_CS, RFM95_INT);
float SEALEVELPRESSURE_HPA = 1001.01657;
#define DATA_FILE "bmp390.csv"
File32 csvFile;
Adafruit_BMP3XX bmp;
Adafruit_NeoPixel rgb(1, 8);  //for status updates during testing
void rgbGreen() {
  rgb.setPixelColor(0, 0, 255, 255);
  rgb.show();
void rgbError() {
  rgb.setPixelColor(0, 255, 0, 0);
  rgb.show();
  pinMode(RFM95_RST, OUTPUT);
  digitalWrite(RFM95_RST, HIGH);
  while (!Serial) delay(1);
  delay(100);
  for (int i = 0; i < 20; i++) {
    Serial.print("/");
  Serial.print("\n\n");
  Serial.println("Welcome to Remote Sensing Unit Software");
    Serial.print("/");
  Serial.print("Radio Client Initializing...");
  // manual reset
  digitalWrite(RFM95_RST, LOW);
  delay(10);
  delay(10);
  if (!rf95.init()) {
    Serial.println("failed");
    while (1)
  Serial.println("success");
  rf95.setFrequency(RF95_FREQ);
  Serial.print("frequency setting: ");
  Serial.print(RF95_FREQ);
  Serial.println("MHz");
  //Serial.println("enter power setting [5-23]:");
  //while (!Serial.available())
  //int i = 0;
  //char c;
  //char num[5];
  //while (Serial.available() && i < 5) {  //get user defined power input
   // c = Serial.read();
   // num[i] = c;
   // i++;
  //int power;
  //power = atoi(num);
  rf95.setTxPower(10, false);
  Serial.print("power set to ");
  Serial.print(10);
  Serial.println(" dBm");
  Serial.println("Radio configured");
  Serial.println("Initializing Barometer/Altimiter/Thermometer...");
  String input;
  input = "D";
  // Serial.println("use default sea level definition or set at current pressure? d/c");
  // while (!Serial.available()) {
  //   delay(10);
  // input = Serial.readString();
  if (bmp.begin_I2C()) {
    Serial.println("valid BMP3 sensor found");
    if (input.equals("c")) {
      Serial.print("setting to sensor value... ");
      delay(10);
      if (!bmp.performReading()) {
        SEALEVELPRESSURE_HPA = (bmp.pressure);
    Serial.println("Could not find a valid BMP3 sensor, check wiring!");
    rgbError();
    while (1)
  Serial.print("Initializing GPS... ");
  GPSSerial.begin(9600);
  pinPeripheral(A1, PIO_SERCOM_ALT);
  pinPeripheral(A2, PIO_SERCOM_ALT);
  // GPSSerial.println("$PMTK220,2000*"); // config command for gps
  // while(!GPSSerial.available());
  // char ackBuf[16];int i;
  // while(GPSSerial.available()) {
  //   char c = GPSSerial.read();
  //   ackBuf[i] = c;
  //   i++;
  //   if (c == '\n' || i == 16) break;
  // if (strcmp(ackBuf, "$PMTK010,003*2C\n")) { // gps replying successfully set to 0.2hz update
  //   Serial.println("failed");
  //   while(1);
  Serial.print("Configuring flash memory... ");
  if (!flash.begin()) {
    rgbError();
    while (1)
  if (Serial) {
  // First call begin to mount the filesystem.  Check that it returns true
  // to make sure the filesystem was mounted.
  if (!fatfs.begin(&flash)) {
    Serial.println("Error, failed to mount newly formatted filesystem");
    Serial.println("Was the flash chip formatted with the fatfs_format example?");
    rgbError();
    while (1)
  Serial.println("mounted filesystem");
  Serial.print("formatting csv for data recording... ");
  csvFile = fatfs.open("bmp390.csv", FILE_WRITE | O_CREAT | O_TRUNC);
  if (csvFile) {
    csvFile.println("sensor data: ");
    csvFile.println("\"altitude\",\"pressure (hPa)\",\"temperature\"");
    Serial.println("data file first line written");
    Serial.println("failed to start write to data file!");
    rgbError();
    while (1);
  csvFile.close();
  Serial.println("all systems are configured, beginning transmissions...");
//xxxx.xx,yyyy.yy,zz.zz
void encodeSend(float bmpData[3]) {
  // xxyy.zz
  float data1 = bmpData[0]; //float
  float data2 = bmpData[1];
  float data3 = bmpData[2];
  // each float needs to be broken up into integer sections: 1234.56 -> [12], [34], [56]
  // xxyy.zz
  uint8_t num1pt1 = (uint8_t)(floor(data1 / 100)); //xx
  uint8_t num1pt2 = (uint8_t)(floor(data1 - num1pt1*100)); //yy
  uint8_t num1pt3 = (uint8_t)(100*(data1 - num1pt1*100 - num1pt2)); //zz
  //xxyy.zz
  uint8_t num2pt1 = (uint8_t)(floor(data2 / 100)); //xx
  uint8_t num2pt2 = (uint8_t)(floor(data2 - num2pt1*100)); //yy
  uint8_t num2pt3 = (uint8_t)(100*(data2 - num2pt1*100 - num2pt2)); //zz
  uint8_t num3pt1 = (uint8_t)(floor(data3)); //xx
  uint8_t num3pt2 = (uint8_t)((data3 - num3pt1)*100); //yy
  uint8_t data[] = {num1pt1, num1pt2, num1pt3, num2pt1, num2pt2, num2pt3, num3pt1, num3pt2};
  Serial.println("encoded message to send: ");
  for (int i = 0; i < 8; i++) {
    Serial.print(data[i]);
    Serial.print(" ");
  rf95.send(data, sizeof(data));
  rf95.waitPacketSent();
  uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
  uint8_t len = sizeof(buf);
  if (rf95.waitAvailableTimeout(500)) {
    if (rf95.recv(buf, &len)) {
      if (!strcmp((char *)buf, "data recieved!!")) {
        Serial.println("transmit success");
        Serial.print("unexpected reply: ");
        Serial.println((char *)buf);
      Serial.println("data recv failed");
    Serial.println("no response from server during data transfer!");
    return;
//char lineBuffer[20]; //xxxx.xx,yyy.y,zzzz.zz
  if (Serial && Serial.available()) {
    Serial.println("You are typing something");
    String input = Serial.readString();
    if (input.equals("kill")) {
      Serial.println("terminating datalogging...");
      rgb.setPixelColor(0, 0, 0, 255);
      rgb.show();
      while (1)
      Serial.println("input ignored");
  ////////////////// BMP390 //////////////////
    Serial.println("reading error");
    rgbError();
    delay(10);
    return;
  float altitude = bmp.readAltitude(SEALEVELPRESSURE_HPA);
  float pressure = bmp.pressure / 100.0;
  float temperature = bmp.temperature;
  if (!altitude || !pressure || !temperature) {
    Serial.println("data measurement failure");
  float dataPacket[] = {altitude, pressure, temperature};
  csvFile = fatfs.open("bmp390.csv", FILE_WRITE | O_CREAT);
  if (csvFile) {
    rgbGreen();
    csvFile.print(altitude);
    csvFile.print(",");
    csvFile.print(pressure);
    csvFile.print(",");
    csvFile.println(temperature);
    Serial.println("failed to write data to file");
    rgbError();
  csvFile.close();
  Serial.print("Altitude: "); Serial.println(altitude);
  Serial.print("Pressure: "); Serial.println(pressure);
  Serial.print("Temperature: "); Serial.println(temperature);
  //////////////////  GPS   //////////////////
  bool reading = GPSSerial.available();
  Serial.println(reading ? "true" : "false");
  char buff[10];
  // for (int i = 0; i < 10; i++) {
  //   buff[i] = c;
  // Serial.println(buff);
  int i = 0;
  char sentence[128];
  while (reading) {
    if (c == '$') {
      i = 0;
      // clear buffer since restarting to read
      for (i; i < 128; i++) {
        sentence[i] = '\0';
      sentence[0] = '$';
      i = 1;
    } else if (c == '*') {
      //Serial.println("nmea done");
      sentence[i] = c;
      reading = false;
      Serial.print("Newest NMEA: ");
      Serial.println(sentence);
    } else if (i >= 128) {
      //Serial.println("overflow");
        sentence[i] = '\0';
      i = 0;
      sentence[i] = c;
      i++;
  //return;
  //////////// Radio Transmission ////////////
  // handshake message
  uint8_t statusMessage[] = "Data Incoming";
  rf95.send(statusMessage, sizeof(statusMessage));
  Serial.print("sending request... ");
  // wait for response
  if (rf95.waitAvailableTimeout(3000)) {
      // check proper handshake response
      if (!strcmp((char *)buf, "ready for data")) {
          Serial.println("handshake complete");
          encodeSend(dataPacket);
      else {
        Serial.print("error, recieved message: ");
      Serial.println("ready check recv failed");
    Serial.println("no response from server during ready check!");
it appears that the SERCOM4 port on the M0 chip that I was trying to use for GPSSerial was already being used to handle to SPI communication between the core processor and the radio chip. for anyone interested in the multipurpose SERCOM ports of the SAMD chips (M0/M4), see this article: https://learn.sparkfun.com/tutorials/adding-more-sercom-ports-for-samd-boards/all
On the Feather M0, predefined Serial1 works "out of box" with the radio, and to use it, nothing in addition to calling Serial1.begin() is required in the code.
