Losing Programming at startup
Hey everyone,
I just started messing around in the arduino world and so far it's a blast. The problem I am having is that I am losing my programming everytime I unplug the USB connection on my UNO board. As long as the board has power, it preforms as expected. When I unplug the USB and plug it back in I get the default pin 13 flashing and nothing else. I have to re-upload my scketch in order to get the board to run again. Is the board supposed to reset to a default program every time there is a power cycle? Any help would be great.
Also, how do you pronounce Arduino?
-Andrew
This was an issue with some of the first Uno boards.
There is a problem with the bootloader code. There is a new bootloader available but that involves re-programming the bootloader which requires an ISP programmer or another arduino to act as an ISP programmer.
If you cannot re-program the new bootloader yourself then I suggest you simply get in contact with whoever you bought it from and they should be able to offer a replacement.
Thanks for the quick reply. Looks like I will be looking into how to fix the bootloader.
