ov10fac:
I have looked at these. Only question I would have is how to make the connections. Since the holes are all isolated, it would require some form of bridge between components. I've seen something like this done in the past with wires wrapped around posts, real old school.
Sorta, it looks like the wires are not inserted into the holes, but rather lay in solder applied to the hole. I can see how using fine wire you can connect several holes to one. Now, I don't think my solder iron has a fine enough tip to do that kind of work. I also probably need to get some thinner solder. Most of my solder work to date has been to solder wire to switch contacts, not wire up a protoboard.
ov10fac:
Yes the fine wire is soldered into the ball of molten solder covering the hole.
Note, the pads on either side of the PCB are joined with a plated through hole.
You need a reasonably sized soldering tip and smallish diameter solder, 1mm to .5mm.
Buy yourself a head magnifying visor ;).
Practice . . .
Did you read the PDF?
Edit:
I find wire wrap wire is best for point to point wiring.
larryd:
Practice . . .
Edit:
I did read the pdf. I was a little confused about the copper foil and what it was being used for however. When you do wire wrap, what do you use for posts. I have been playing with paper clips which seem to work pretty well.
Now I know how to go about making things permanent, a soldering question. I want to use a voltage regulator to drop my motor power (24V) down to 3.3V for the Arduino. In short I only want one power cord exiting the container housing the electronics.
I have found a regulator that should work on Mouser Electronics, but it uses pad type connectors. Is there any special consideration for this type connector when it comes to soldering it to a protoboard? Thanks.
That would work, but at that price I can almost buy a DC motor controller and use switches to do the things I want. I may just run the Arduino off a battery pack, or plain 9V battery. My guess is it should last a good while before I have to replace the battery.
