I have a LOT of questions, but I'd appreciate ANY AND ALL help. I'm so lost.
First, some context. I've been using Arduino Uno R3 boards (non-solderable) for all my animatronic projects since 2020. But after many issues with durability, sustainability, and design, I've finally accepted that I need something permanent. The most current example of this issue lies in my wearable cosplay head of Foxy The Pirate from Five Nights At Freddy's 1. I have many pictures and videos of the progress of him on my YouTube channel (see my profile) if you need more of a reference. Anyways, I was able to get 5 of the servos working in December of 2023 and then fast forward to me returning home this summer and they barely function now. Not only was the electrical tape making bonds delicate, but also, none of the servos had any kind of screws holding the servo arms in place, not to mention that the setup was sloppy and random. The best way I can put it is that I kept trying to use miscellaneous scraps of materials until the servos remained in place and functioned decently. So, when I found out that everything was completely malfunctioning this summer, I undid everything (the setup was one breadboard panel, two Arduino Uno R3 boards, and three 9V batteries (one connected to each component). So I've come here to ask for help on choosing a new, proper, and solderable board and accessories, but the problem is, I'm really confused, frustrated, and just want to have one animatronic cosplay whose servos don't disconnect or malfunction every 5 minutes because I'm clearly not using or doing things right. So, I really, really, really would appreciate ALL THE HELP I CAN GET! Here are all my main questions, I really hope someone can provide some clarification!
1.) Which solderable Arduino board do I buy if I want to solder a minimum of 5 (maximum of 7) servo motors to the board? How would you solder two LEDs to this board?
2.) Is that even possible on any one Arduino board? Like, is it possible to solder all 7 servos directly onto the Arduino board? Or, at what (if any) number limit of servos is some external board needed like how the (pin header only, no soldering) Arduino Uno R3 board needs a breadboard for projects containing more than 1 micro servo?
3.) Would a stripped USB cable attached to a power bank (with its stripped end soldered to the Arduino board) supply enough power for 5-7 micro servos and 2 LEDs? Or if a second board (like a breadboard?) is needed, will I need two USB power banks?
4.) (I don't expect this one to be answered, but I'd be really grateful if somebody did) What would the setup/layout and code be for this board and/or its accessories? (Would it be different from an Arduino Uno R3 and a breadboard?) Like, could someone provide an image showing the pin locations, boards, batteries, etc.?
